root fs not mountable after upgrade
thanks for helping sorry @Igor my post should not sound like frustration or any other bad thing!! I really appreciate the work and for sure many many hours everybody puts into this project!! I just wondered why things stop working after an upgrade which looks "easy" for a noob like me and try to find out if this is something I made wrong or if others also run into the same thing Here some more details about my setup, sorry to miss this initially Banana-Pi M1 (yes, the old one with native SATA ) Here the actual version which is running fine for me. root@gluster03:~# uname -a Linux gluster03 6.6.75-current-sunxi #1 SMP Sat Feb 1 17:37:57 UTC 2025 armv7l GNU/Linux Then I have started an update as there are two packages which are outdated root@gluster03:~# apt update Hit:1 http://deb.debian.org/debian bullseye InRelease Hit:2 http://deb.debian.org/debian bullseye-updates InRelease Hit:3 http://deb.debian.org/debian bullseye-backports InRelease Hit:5 https://github.armbian.com/configng stable InRelease Hit:4 http://netcup.armbian.com/apt bullseye InRelease Reading package lists... Done Building dependency tree... Done Reading state information... Done 2 packages can be upgraded. Run 'apt list --upgradable' to see them. root@gluster03:~# root@gluster03:~# apt upgrade Reading package lists... Done Building dependency tree... Done Reading state information... Done Calculating upgrade... Done The following packages will be upgraded: armbian-config linux-image-current-sunxi 2 upgraded, 0 newly installed, 0 to remove and 0 not upgraded. Need to get 0 B/40,6 MB of archives. After this operation, 139 kB of additional disk space will be used. Do you want to continue? [Y/n] (Reading database ... 41042 files and directories currently installed.) Preparing to unpack .../armbian-config_25.5.0-trunk.330.0402.205255_all.deb ... Unpacking armbian-config (25.5.0-trunk.330.0402.205255) over (25.5.0-trunk.298.0327.034426) ... Preparing to unpack .../linux-image-current-sunxi_25.2.3_armhf.deb ... Armbian 'linux-image-current-sunxi' for '6.6.75-current-sunxi': 'prerm' starting. Armbian 'linux-image-current-sunxi' for '6.6.75-current-sunxi': 'prerm' finishing. Armbian 'linux-image-current-sunxi' for '6.6.75-current-sunxi': 'preinst' starting. Armbian 'linux-image-current-sunxi' for '6.6.75-current-sunxi': 'preinst' finishing. Unpacking linux-image-current-sunxi (25.2.3) over (25.2.3) ... Armbian 'linux-image-current-sunxi' for '6.6.75-current-sunxi': 'postrm' starting. Armbian 'linux-image-current-sunxi' for '6.6.75-current-sunxi': 'postrm' finishing. Setting up linux-image-current-sunxi (25.2.3) ... Armbian 'linux-image-current-sunxi' for '6.6.75-current-sunxi': 'postinst' starting. dkms: running auto installation service for kernel 6.6.75-current-sunxi:. update-initramfs: Generating /boot/initrd.img-6.6.75-current-sunxi Armbian: update last-installed kernel symlink to 'zImage'... '/boot/zImage' -> 'vmlinuz-6.6.75-current-sunxi' Armbian: Debian compat: linux-update-symlinks install 6.6.75-current-sunxi boot/vmlinuz-6.6.75-current-sunxi Armbian 'linux-image-current-sunxi' for '6.6.75-current-sunxi': 'postinst' finishing. Setting up armbian-config (25.5.0-trunk.330.0402.205255) ... root@gluster03:~# so far so good .. looks fine for me and I am just wondering about the linux image which tells the same version before and after upgrade .. same for Kernel 6.6.75 Now after reboot I get the output attached as Image as I have no serial adapter for the console messages. When I check the SD Card everything is fine and there are no errors .. all files seems fine ... but this is where boot ends from now on. What I am wondering is that the fsck works for exactly the device (mmcblk0p1) which was reported as not available in the next step. If there are other things needed please give me a little hint .. I am not a developer so those things are new to me as it just worked like a charm for at least 10 years until yesterday
Hi Igor; thanks for your fast answer and sorry for the wrong section!! Not sure if I got this right ... do you mean that my banana-pi isnt supported or the trunk I use is not supported? ... I checked this and dont see any repo like untested or nightly build. Its configured to just use main and stable as I see.
Hi there, after upgrade Armbian today the Device (banana-pi) doesnt come up again telling that the root fs couldnt be mount because mmcblk0p1 is not available. After checking SD Card everything seems ok, filesystem is there and doesnt have any error. But still no boot. Then after applying a backup things are fine again. Started the upgrade again and same error like before. When applying those two updates there is repeatedly a dead system afterwards. Tested on different devices now. root@gluster01:~# apt list --upgradable Listing... Done armbian-config/unknown 25.5.0-trunk.330.0402.205255 all [upgradable from: 25.5.0-trunk.286.0324.065110] linux-image-current-sunxi/bullseye 25.2.3 armhf [upgradable from: 25.2.3] root@gluster01:~# Could someone other also confirm this or is there any idea about what is going wrong? Thanks!! best regards, Heiko
transferring files >4GB not working anymore after upgrading to Kernel 6.6.31
Since I upgraded to Armbian 23.8.1 (Kernel 6.6.31) I cant copy larger files from a CIFS share to a local attached sata disk on my banana-pi. Copy starts and gets stuck at around 4GB of transferred data ... its independant if I use rsync, cp or mv to transfer files. What I can see in the logs directly after the transfer gets stuck: root@nas03:~# dmesg [ 1280.477240] ------------[ cut here ]------------ [ 1280.477276] WARNING: CPU: 1 PID: 4182 at lib/iov_iter.c:316 _copy_to_iter+0x3bd/0x3c4 [ 1280.477372] Modules linked in: cmac nls_utf8 cifs cifs_arc4 nls_ucs2_utils cifs_md4 fscache netfs zram evdev axp20x_adc lima gpu_sched drm_shmem_helper sun4i_gpadc_iio sun4i_ts sunxi_cir sunxi_cedrus(C) v4l2_mem2mem videobuf2_dma_contig videobuf2_memops videobuf2_v4l2 videodev videobuf2_common mc display_connector uio_pdrv_genirq cpufreq_dt uio sunrpc ip_tables x_tables autofs4 axp20x_usb_power industrialio pinctrl_axp209 sun4i_gpadc sunxi phy_generic realtek [ 1280.477746] CPU: 1 PID: 4182 Comm: cifsd Tainted: G C 6.6.31-current-sunxi #1 [ 1280.477767] Hardware name: Allwinner sun7i (A20) Family [ 1280.477789] unwind_backtrace from show_stack+0x11/0x14 [ 1280.477824] show_stack from dump_stack_lvl+0x2b/0x34 [ 1280.477851] dump_stack_lvl from __warn+0xb5/0xe0 [ 1280.477877] __warn from warn_slowpath_fmt+0xfb/0x104 [ 1280.477903] warn_slowpath_fmt from _copy_to_iter+0x3bd/0x3c4 [ 1280.477932] _copy_to_iter from __skb_datagram_iter+0x41/0x1cc [ 1280.477962] __skb_datagram_iter from skb_copy_datagram_iter+0x39/0x68 [ 1280.477988] skb_copy_datagram_iter from tcp_recvmsg_locked+0x455/0x6a4 [ 1280.478016] tcp_recvmsg_locked from tcp_recvmsg+0x55/0x14c [ 1280.478035] tcp_recvmsg from inet_recvmsg+0x31/0x9c [ 1280.478059] inet_recvmsg from sock_recvmsg+0x2d/0x44 [ 1280.478084] sock_recvmsg from cifs_readv_from_socket+0xc5/0x278 [cifs] [ 1280.478507] cifs_readv_from_socket [cifs] from cifs_read_iter_from_socket+0x49/0x70 [cifs] [ 1280.478880] cifs_read_iter_from_socket [cifs] from cifs_readv_receive+0x153/0x450 [cifs] [ 1280.479241] cifs_readv_receive [cifs] from cifs_demultiplex_thread+0x2e1/0x6ec [cifs] [ 1280.479655] cifs_demultiplex_thread [cifs] from kthread+0xbf/0xd4 [ 1280.479924] kthread from ret_from_fork+0x11/0x1c [ 1280.479951] Exception stack(0xf129dfb0 to 0xf129dff8) [ 1280.479968] dfa0: 00000000 00000000 00000000 00000000 [ 1280.479985] dfc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 1280.479999] dfe0: 00000000 00000000 00000000 00000000 00000013 00000000 [ 1280.480710] ---[ end trace 0000000000000000 ]--- [ 1280.485954] ------------[ cut here ]------------ [ 1280.485995] WARNING: CPU: 1 PID: 6177 at lib/iov_iter.c:560 iov_iter_zero+0x3c9/0x3d0 [ 1280.486335] Modules linked in: cmac nls_utf8 cifs cifs_arc4 nls_ucs2_utils cifs_md4 fscache netfs zram evdev axp20x_adc lima gpu_sched drm_shmem_helper sun4i_gpadc_iio sun4i_ts sunxi_cir sunxi_cedrus(C) v4l2_mem2mem videobuf2_dma_contig videobuf2_memops videobuf2_v4l2 videodev videobuf2_common mc display_connector uio_pdrv_genirq cpufreq_dt uio sunrpc ip_tables x_tables autofs4 axp20x_usb_power industrialio pinctrl_axp209 sun4i_gpadc sunxi phy_generic realtek [ 1280.487924] CPU: 1 PID: 6177 Comm: kworker/1:1 Tainted: G WC 6.6.31-current-sunxi #1 [ 1280.487946] Hardware name: Allwinner sun7i (A20) Family [ 1280.487961] Workqueue: cifsiod cifs_readahead_complete [cifs] [ 1280.488367] unwind_backtrace from show_stack+0x11/0x14 [ 1280.488405] show_stack from dump_stack_lvl+0x2b/0x34 [ 1280.488432] dump_stack_lvl from __warn+0xb5/0xe0 [ 1280.488459] __warn from warn_slowpath_fmt+0xfb/0x104 [ 1280.488485] warn_slowpath_fmt from iov_iter_zero+0x3c9/0x3d0 [ 1280.488515] iov_iter_zero from cifs_readahead_complete+0x19d/0x1d0 [cifs] [ 1280.488735] cifs_readahead_complete [cifs] from process_one_work+0x113/0x2ac [ 1280.488940] process_one_work from worker_thread+0x21f/0x358 [ 1280.488972] worker_thread from kthread+0xbf/0xd4 [ 1280.489004] kthread from ret_from_fork+0x11/0x1c [ 1280.489027] Exception stack(0xf0985fb0 to 0xf0985ff8) [ 1280.489042] 5fa0: 00000000 00000000 00000000 00000000 [ 1280.489059] 5fc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 1280.489073] 5fe0: 00000000 00000000 00000000 00000000 00000013 00000000 [ 1280.489749] ---[ end trace 0000000000000000 ]--- [ 1280.494188] ------------[ cut here ]------------ [ 1280.494220] WARNING: CPU: 1 PID: 6177 at lib/iov_iter.c:560 iov_iter_zero+0x3c9/0x3d0 [ 1280.494267] Modules linked in: cmac nls_utf8 cifs cifs_arc4 nls_ucs2_utils cifs_md4 fscache netfs zram evdev axp20x_adc lima gpu_sched drm_shmem_helper sun4i_gpadc_iio sun4i_ts sunxi_cir sunxi_cedrus(C) v4l2_mem2mem videobuf2_dma_contig videobuf2_memops videobuf2_v4l2 videodev videobuf2_common mc display_connector uio_pdrv_genirq cpufreq_dt uio sunrpc ip_tables x_tables autofs4 axp20x_usb_power industrialio pinctrl_axp209 sun4i_gpadc sunxi phy_generic realtek [ 1280.495285] CPU: 1 PID: 6177 Comm: kworker/1:1 Tainted: G WC 6.6.31-current-sunxi #1 [ 1280.495310] Hardware name: Allwinner sun7i (A20) Family [ 1280.495323] Workqueue: cifsiod cifs_readahead_complete [cifs] [ 1280.495744] unwind_backtrace from show_stack+0x11/0x14 [ 1280.495788] show_stack from dump_stack_lvl+0x2b/0x34 [ 1280.495817] dump_stack_lvl from __warn+0xb5/0xe0 [ 1280.495846] __warn from warn_slowpath_fmt+0xfb/0x104 [ 1280.495872] warn_slowpath_fmt from iov_iter_zero+0x3c9/0x3d0 [ 1280.495903] iov_iter_zero from cifs_readahead_complete+0x19d/0x1d0 [cifs] [ 1280.496183] cifs_readahead_complete [cifs] from process_one_work+0x113/0x2ac [ 1280.496418] process_one_work from worker_thread+0x21f/0x358 [ 1280.496450] worker_thread from kthread+0xbf/0xd4 [ 1280.496481] kthread from ret_from_fork+0x11/0x1c [ 1280.496505] Exception stack(0xf0985fb0 to 0xf0985ff8) [ 1280.496520] 5fa0: 00000000 00000000 00000000 00000000 [ 1280.496536] 5fc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 1280.496550] 5fe0: 00000000 00000000 00000000 00000000 00000013 00000000 [ 1280.496705] ---[ end trace 0000000000000000 ]--- [ 1280.497845] ------------[ cut here ]------------ [ 1280.497864] WARNING: CPU: 1 PID: 6177 at lib/iov_iter.c:560 iov_iter_zero+0x3c9/0x3d0 [ 1280.497903] Modules linked in: cmac nls_utf8 cifs cifs_arc4 nls_ucs2_utils cifs_md4 fscache netfs zram evdev axp20x_adc lima gpu_sched drm_shmem_helper sun4i_gpadc_iio sun4i_ts sunxi_cir sunxi_cedrus(C) v4l2_mem2mem videobuf2_dma_contig videobuf2_memops videobuf2_v4l2 videodev videobuf2_common mc display_connector uio_pdrv_genirq cpufreq_dt uio sunrpc ip_tables x_tables autofs4 axp20x_usb_power industrialio pinctrl_axp209 sun4i_gpadc sunxi phy_generic realtek [ 1280.498159] CPU: 1 PID: 6177 Comm: kworker/1:1 Tainted: G WC 6.6.31-current-sunxi #1 [ 1280.498179] Hardware name: Allwinner sun7i (A20) Family [ 1280.498192] Workqueue: cifsiod cifs_readahead_complete [cifs] [ 1280.498558] unwind_backtrace from show_stack+0x11/0x14 [ 1280.498594] show_stack from dump_stack_lvl+0x2b/0x34 [ 1280.498622] dump_stack_lvl from __warn+0xb5/0xe0 [ 1280.498651] __warn from warn_slowpath_fmt+0xfb/0x104 [ 1280.498678] warn_slowpath_fmt from iov_iter_zero+0x3c9/0x3d0 [ 1280.498709] iov_iter_zero from cifs_readahead_complete+0x19d/0x1d0 [cifs] [ 1280.498977] cifs_readahead_complete [cifs] from process_one_work+0x113/0x2ac [ 1280.499227] process_one_work from worker_thread+0x21f/0x358 [ 1280.499263] worker_thread from kthread+0xbf/0xd4 [ 1280.499295] kthread from ret_from_fork+0x11/0x1c [ 1280.499320] Exception stack(0xf0985fb0 to 0xf0985ff8) [ 1280.499335] 5fa0: 00000000 00000000 00000000 00000000 [ 1280.499351] 5fc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 1280.499366] 5fe0: 00000000 00000000 00000000 00000000 00000013 00000000 [ 1280.499498] ---[ end trace 0000000000000000 ]--- [ 1280.513191] CIFS: trying to dequeue a deleted mid root@nas03:~# root@nas03:~# root@nas03:~# ps -ef | grep 6177 root 6177 2 3 17:13 ? 00:00:34 [kworker/1:1+events_freezable_power_] root@nas03:~# root@nas03:~# ps -ef | grep 4182 root 4182 2 8 17:10 ? 00:02:26 [cifsd] root@nas03:~# at this point nothing happens anymore on the copy command but system is running and I am able to login. I can see around 45% iowait then without any byte transferred any longer. Going back to Kernel 6.1.63 things are again working and files much larger than 4GB will work as expected. Are there any ideas about how to solve out there or hints I could check? Many thanks in advance for any help!! best regards, Heiko
heikow
