- Will not start booting when HDMI is attached to certain powered-off TVs
Okay, found another klew to this issue... Apparently the pi is outputting video at a default 4K spec, and most of the TVs I'm using aren't accepting it, but one is.... Multiple lines of: Then: I would have played with the shell, but the machine is way up on a wall, and I had to transcribe the above from a photo of the screen. ^^; Edit: And yes, I triple-checked the issue only pops up when the attached TV is turned off.
Armbian 24.5.1. I don't have a serial console setup so I can't tell if it's actually starting to boot or not, but it never gets to the point where a video signal is sent to HDMI. It *does* send a CEC on signal to the TV, which does turn on, and power-cycling the Pi then begins a normal boot process. Pi also boots normally headless. Problem noted on one Insignia model and on a Vizio TV, works as expected on another Insignia model, on a Hisense and on an LG. Issue began after updating the kernel from legacy.
TheSHAD0W
