How to install armbian in h618?
when I use emac0 same dts as orange pi zero2 (RTL8211f,axp305) the log like [ 1.875818] dwmac-sun8i 5020000.ethernet: IRQ eth_wake_irq not found [ 1.875832] dwmac-sun8i 5020000.ethernet: IRQ eth_lpi not found [ 1.876038] dwmac-sun8i 5020000.ethernet: supply phy-io not found, using dummy regulator [ 1.876212] dwmac-sun8i 5020000.ethernet: PTP uses main clock [ 1.876242] dwmac-sun8i 5020000.ethernet: Current syscon value is not the default 51fe6 (expect 0) [ 1.879401] dwmac-sun8i 5020000.ethernet: No HW DMA feature register supported [ 1.879426] dwmac-sun8i 5020000.ethernet: RX Checksum Offload Engine supported [ 1.879434] dwmac-sun8i 5020000.ethernet: COE Type 2 [ 1.879443] dwmac-sun8i 5020000.ethernet: TX Checksum insertion supported [ 1.879451] dwmac-sun8i 5020000.ethernet: Normal descriptors [ 1.879459] dwmac-sun8i 5020000.ethernet: Chain mode enabled [ 1.880698] mdio_bus stmmac-0: MDIO device at address 0 is missing. [ 1.899782] mmc2: new DDR MMC card at address 0001 [ 1.902560] mmcblk2: mmc2:0001 UY7CS0 117 GiB [ 1.915805] mmcblk2: p1 p2 p3 p4 p5 [ 1.917149] mmcblk2boot0: mmc2:0001 UY7CS0 4.00 MiB [ 1.919393] mmcblk2boot1: mmc2:0001 UY7CS0 4.00 MiB [ 1.921901] sun4i-drm display-engine: bound 1100000.mixer (ops 0xffff800080ede728) [ 1.922172] sun4i-drm display-engine: bound 6510000.tcon-top (ops 0xffff800080ee34c0) [ 1.922427] sun4i-drm display-engine: bound 6515000.lcd-controller (ops 0xffff800080edb550) [ 1.981778] dwmac-sun8i 5020000.ethernet: EMAC reset timeout [ 1.981808] dwmac-sun8i 5020000.ethernet eth0: stmmac_dvr_remove: removing driver [ 2.000392] dwmac-sun8i: probe of 5020000.ethernet failed with error -110 ---------------------------- when I use default vantar eth, with emac1, there is no erro, but when line plun in it does not response. [ 5.784131] dwmac-sun8i 5030000.ethernet: IRQ eth_wake_irq not found [ 5.784157] dwmac-sun8i 5030000.ethernet: IRQ eth_lpi not found [ 5.784165] dwmac-sun8i 5030000.ethernet: IRQ sfty not found [ 5.821569] dwmac-sun8i 5030000.ethernet: supply phy-io not found, using dummy regulator [ 5.852038] dwmac-sun8i 5030000.ethernet: PTP uses main clock [ 5.852092] dwmac-sun8i 5030000.ethernet: Current syscon value is not the default 53fe1 (expect 0) [ 5.862416] dwmac-sun8i 5030000.ethernet: No HW DMA feature register supported [ 5.862438] dwmac-sun8i 5030000.ethernet: RX Checksum Offload Engine supported [ 5.862443] dwmac-sun8i 5030000.ethernet: COE Type 2 [ 5.862450] dwmac-sun8i 5030000.ethernet: TX Checksum insertion supported [ 5.862455] dwmac-sun8i 5030000.ethernet: Normal descriptors [ 5.862461] dwmac-sun8i 5030000.ethernet: Chain mode enabled [ 5.964131] sunxi-snd-mach soc:ahub_dam_mach: ASoC: can't create pcm ahub_dam-snd-soc-dummy-dai :-22 [ 5.978763] sunxi-snd-mach soc:ahub_dam_mach: probe with driver sunxi-snd-mach failed with error -22 [ 6.161460] dwmac-sun8i 5030000.ethernet end0: renamed from eth0 [ 6.229051] dwmac-sun8i 5030000.ethernet end0: Register MEM_TYPE_PAGE_POOL RxQ-0 [ 6.233434] dwmac-sun8i 5030000.ethernet end0: PHY [stmmac-0:00] driver [Generic PHY] (irq=POLL) [ 6.241542] dwmac-sun8i 5030000.ethernet end0: No Safety Features support found [ 6.241565] dwmac-sun8i 5030000.ethernet end0: No MAC Management Counters available [ 6.241574] dwmac-sun8i 5030000.ethernet end0: PTP not supported by HW [ 6.246544] dwmac-sun8i 5030000.ethernet end0: configuring for phy/rmii link mode ---------------- and I try orange pi zero 2w dts, with gmac driver ,the behavior like vontar, no error, no response. the atatchment is same as zero 2 hv16.dts
514: boot0: Allwinner boot0 size: 61440 bytes eGON checksum matches: 0xe69a1706 DRAM parameters: A64 H616 DRAM clock : 0x288 0x288 - DRAM type : 0x3 0x3 - ZQ value : 0x3030303 - - ODT enabled : 0xe0e0e0e 0x1 - DX ODT : - 0x3030303 - DX DRI : - 0xe0e0e0e - CA DRI : - 0x1f12 - PARA1 : 0x1f12 0x30fb - PARA2 : 0x1 0 - MR0 : 0x30fb 0x840 - MR1 : 0 0x4 - MR2 : 0x840 0x8 - MR3 : 0x4 0 - TPR0 : 0x8 0xc0001002 - TPR6 : 0 0x33808080 - TRP10 : 0 0x2f1107 - TRP11 : 0 0xddddcccc - TRP12 : 0xc0001002 0xeddc7665 - TRP13 : 0 0x40 the ethernet chip is rtl8211f, power is axp313a the attachment is origin adroid dts. android_sunxi.dts
Thank you very much. I have built up with the same patch vontar h618 of minarch. I have 2 boxes, those are white brand. And I have tried gmac driver in orange pi zero2. There are the same issue. when the net plugin or pullout, the ethernet has no response. I have no idea about this.
@Nick A I have clone your build, but there is a error when building https://paste.armbian.com/osojimuwem AR sound/soc/built-in.a [🐳|🔨] LD [M] net/netfilter/ipvs/ip_vs.o [🐳|🔨] AR sound/built-in.a [🐳|🔨] AR net/built-in.a [🐳|🔨] CC [M] kernel/kheaders.o [🐳|🔨] make[2]: *** [Makefile:1923: .] Error 2 [🐳|🔨] make[1]: *** [/armbian/cache/sources/linux-kernel-worktree/6.6__sunxi64__arm64/Makefile:359: __build_one_by_one] Error 2 [🐳|🔨] make: *** [Makefile:234: __sub-make] Error 2 [🐳|💥] Error 2 occurred in main shell [ at /armbian/lib/functions/logging/runners.sh:211 run_host_command_logged_raw() --> lib/functions/logging/runners.sh:211 run_host_command_logged() --> lib/functions/logging/runners.sh:193 run_kernel_make_internal() --> lib/functions/compilation/kernel-make.sh:61 run_kernel_make_long_running() --> lib/functions/compilation/kernel-make.sh:74 do_with_ccache_statistics() --> lib/functions/compilation/ccache.sh:39 kernel_build() --> lib/functions/compilation/kernel.sh:218 do_with_hooks() --> lib/functions/general/extensions.sh:557 do_with_logging() --> lib/functions/logging/section-logging.sh:81 kernel_prepare_build_and_package() --> lib/functions/compilation/kernel.sh:157 compile_kernel() --> lib/functions/compilation/kernel.sh:91 artifact_kernel_build_from_sources() --> lib/functions/artifacts/artifact-kernel.sh:238 artifact_build_from_sources() --> lib/functions/artifacts/artifacts-obtain.sh:34 obtain_complete_artifact() --> lib/functions/artifacts/artifacts-obtain.sh:280 build_artifact_for_image() --> lib/functions/artifacts/artifacts-obtain.sh:392 main_default_build_packages() --> lib/functions/main/build-packages.sh:108 full_build_packages_rootfs_and_image() --> lib/functions/main/default-build.sh:31 do_with_default_build() --> lib/functions/main/default-build.sh:42 cli_standard_build_run() --> lib/functions/cli/cli-build.sh:25 armbian_cli_run_command() --> lib/functions/cli/utils-cli.sh:136 cli_entrypoint() --> lib/functions/cli/entrypoint.sh:176 main() --> compile.sh:50
@Nick A how to use Armbian-20240716-unofficial_24.5.0-trunk_Transpeed-8k618-t_bookworm_edge_6.7.12_server.img.tar.xz I have decompresss and flash to sd card, it cant boot. livesuit cant recognize it. Thank you very much.
thank you very much, the box has no name, I have already tried these image before, it does not boot to login. only vontar reache the login screen. Maybe the ethernet doesnot work because the power problem, the ethernet does not receive the elec signal when line plug.
I have learned a lot from the thread. thanks for Nick A. I have installed MiniArch-20240715-6.10.0-board-h618.vontar_h618-SD-Image.img.xz on my box. My board hw is 4G+128G, rtl8211f, axp313a. But the ethernet does not work. The emac1 eth is up, but cant get Ip. the attach is the android dts, and dmesg. I want to try emac0, but it was failed when it init phy link. another question, can I burn an commandline image by phoenix suite? I have a xfce ubuntu phoenix image, but I cant swith it to cmd mode. is there an armbian same as vontar? I am more farmiliar with debian/Ubuntu. I batted it for 2weeks, Thanks a lot. dmsg.tgz
help, who know how to calculate the live image crc? I modify rootfs part , and use write back by dd, then the phoenix image suite log prompt me that pr_crc != nand_crc, and failed. I know the Vxx tis the crc of the xx, but I try crc32 to calc, that is not same.
