naz
  1. Here's my updated version of the original recipie: 1) boot system from fresh downloaded SD (Armbian Jammy Desktop) 2) NVME setup (sudo gparted) - if empty create a partition table (GPT) if not delete all partitions - create EXT4 partition (nvme0n1p1) - optionally create more partitions (system recovery, backups, home ...) - format partitions nvme0n1p1 -> EXT4 - check partitions (if old NVME) 3) run sudo armbian-install - option 7 to flash mtdblock0 (bootloader install) - option 4 (to install system and boot from mtdblock0) choose nvme0n1p1 partition to install system don't POWEROFF, just EXIT 4) this step is now performed by option 4 above 5) - sudo mount /dev/nvme0n1p1 /mnt - check files/directories are already copied (ls -l /mnt) - if you have any other partitions (e.g., /home), you need to extend /mnt/etc/fstab: - use blkid to discover UUID of partitions of interest 6) - sudo poweroff - remove SD - press power button to restart By The Way, if you're coming in with ssh -Y (or PuTTY), you'll have difficulty running gparted. Here's an excellent explanation of how to fix that problem: https://www.simplified.guide/ssh/x11-forwarding-as-root
