Gugolple
  1. Hello, I updated recently my nanopi neo3 and I am unable to get it to boot. The log from uart is attached below. Is there any idea/log I could report to fix the issue? Thank you and kind regards, Juan. ``` Welcome to minicom 2.8 OPTIONS: I18n Port /dev/ttyUSB0, 00:10:32 Press CTRL-A Z for help on special keys DDR version 1.16 20190528 ID:0x805 N In DDR4 333MHz Bus Width=32 Col=10 Bank=4 Bank Group=2 Row=16 CS=1 Die Bus-Width=16 Size=2048MB ddrconfig:14 OUT Boot1 Release Time: May 13 2019 17:34:36, version: 2.50 ChipType = 0x11, 248 mmc2:cmd1,20 emmc reinit mmc2:cmd1,20 emmc reinit mmc2:cmd1,20 SdmmcInit=2 1 mmc0:cmd5,20 SdmmcInit=0 0 BootCapSize=0 UserCapSize=60906MB FwPartOffset=2000 , 0 StorageInit ok = 32496 Raw SecureMode = 0 SecureInit read PBA: 0x4 SecureInit read PBA: 0x404 SecureInit read PBA: 0x804 SecureInit read PBA: 0xc04 SecureInit read PBA: 0x1004 SecureInit ret = 0, SecureMode = 0 atags_set_bootdev: ret:(0) GPT 0x337a9f0 signature is wrong recovery gpt... GPT 0x337a9f0 signature is wrong recovery gpt fail! LoadTrust Addr:0x4000 No find bl30.bin No find bl32.bin Load uboot, ReadLba = 2000 hdr 000000000337a3b0 + 0x0:0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, Load OK, addr=0x200000, size=0xaea08 RunBL31 0x40000 INFO: Preloader serial: 2 NOTICE: BL31: v1.3(debug):403e0b816 NOTICE: BL31: Built : 14:13:08, Aug 11 2020 NOTICE: BL31:Rockchip release version: v1.3 INFO: ARM GICv2 driver initialized INFO: Using opteed sec cpu_context! INFO: boot cpu mask: 1 INFO: plat_rockchip_pmu_init: pd status 0xe INFO: BL31: Initializing runtime services WARNING: No OPTEE provided by BL2 boot loader, Booting device without OPTEE initialization. SMC`s destined for OPTEE will return SMC_UNK ERROR: Error initializing runtime service opteed_fast INFO: BL31: Preparing for EL3 exit to normal world INFO: Entry point address = 0x200000 INFO: SPSR = 0x3c9 U-Boot 2022.04-armbian (May 27 2023 - 19:32:11 +0000) Model: FriendlyElec NanoPi R2S DRAM: 2 GiB PMIC: RK8050 (on=0x40, off=0x00) Core: 223 devices, 20 uclasses, devicetree: separate MMC: mmc@ff500000: 1 Loading Environment from MMC... MMC Device 0 not found *** Warning - No MMC card found, using default environment In: serial@ff130000 Out: serial@ff130000 Err: serial@ff130000 Model: FriendlyElec NanoPi R2S Net: eth0: ethernet@ff540000 Hit any key to stop autoboot: 0 switch to partitions #0, OK mmc1 is current device Scanning mmc 1:1... Found U-Boot script /boot/boot.scr 3252 bytes read in 5 ms (634.8 KiB/s) ## Executing script at 00500000 Boot script loaded from mmc 1 227 bytes read in 3 ms (73.2 KiB/s) 16255321 bytes read in 709 ms (21.9 MiB/s) 30030336 bytes read in 1305 ms (21.9 MiB/s) 65884 bytes read in 15 ms (4.2 MiB/s) 2825 bytes read in 8 ms (344.7 KiB/s) Applying kernel provided DT fixup script (rockchip-fixup.scr) ## Executing script at 09000000 Unknown command 'kaslrseed' - try 'help' Moving Image from 0x2080000 to 0x2200000, end=3f40000 ## Loading init Ramdisk from Legacy Image at 06000000 ... Image Name: uInitrd Image Type: AArch64 Linux RAMDisk Image (gzip compressed) Data Size: 16255257 Bytes = 15.5 MiB Load Address: 00000000 Entry Point: 00000000 Verifying Checksum ... OK ## Flattened Device Tree blob at 01f00000 Booting using the fdt blob at 0x1f00000 Loading Ramdisk to 7cfa7000, end 7df27919 ... OK Loading Device Tree to 000000007cf2e000, end 000000007cfa6fff ... OK Starting kernel ... Loading, please wait... Starting systemd-udevd version 252.26-1~deb12u2 Timed out for waiting the udev queue being empty. ```
