PeterRies
  1. Thanks Igor for the explanation and dziekon for the 2 bytes change that did the job!! Excellent description. 😀
  2. Hi there, I revived my BananaPi M1 (ARM7 32bit) last week. I installed a fresh armbian and just docker like this: sudo apt-get update sudo apt-get install ca-certificates curl sudo install -m 0755 -d /etc/apt/keyrings sudo curl -fsSL https://download.docker.com/linux/debian/gpg -o /etc/apt/keyrings/docker.asc sudo chmod a+r /etc/apt/keyrings/docker.asc echo "deb [arch=$(dpkg --print-architecture) signed-by=/etc/apt/keyrings/docker.asc] https://download.docker.com/linux/debian \ $(. /etc/os-release && echo "$VERSION_CODENAME") stable" | sudo tee /etc/apt/sources.list.d/docker.list > /dev/null sudo apt-get update sudo apt-get install docker-ce docker-ce-cli containerd.io docker-buildx-plugin docker-compose-plugin sudo gpasswd -a $USER docker newgrp docker docker run hello-world The "Hello world" worked. But when I tried to run anything useful things failed. Seafile installed okay, but calling the UI timed out. Paperless-ngx complained that paperless-webserver cannot find route to redis. Stuff like this. I just want to use the machine in my internal Network at home. To investigate further I installed a simple httpd docker to see if I can reach that one. No luck. Neither from another machine in my LAN, nor via lynx on BananaPi calling localhost. The request goes out as the port seems to be open, but it never reaches the daemon inside the container or cannot respond. Same commands on my "production box" (a HP t630 with debian bookworm) work fine. So my conclusion is that it must be something in the OS. I compared iptables on BananaPi and t630 and checked the output of 'sudo /usr/sbin/sysctl -a | grep forwarding | grep ipv4' - they are the same. I'm a little bit clueless where to check, what commands to use as I'm quite new to docker. Do you have any suggestions? Thanks, Peter.
