base-files missing for 24.5.1 armhf
Repo is fixed. Thanks !
Hello Check the other topic and tried your mirror but it does not work. apt-get update : Réception de :7 https://imola.armbian.com/apt bookworm InRelease [68,7 kB] Réception de :8 https://imola.armbian.com/apt bookworm/main armhf Packages [181 kB] Réception de :9 https://imola.armbian.com/apt bookworm/main all Packages [9 415 B] Réception de :10 https://imola.armbian.com/apt bookworm/main armhf Contents (deb) [4 182 kB] Réception de :11 https://imola.armbian.com/apt bookworm/main all Contents (deb) [32,5 kB] Réception de :12 https://imola.armbian.com/apt bookworm/bookworm-utils all Packages [2 624 B] Réception de :13 https://imola.armbian.com/apt bookworm/bookworm-utils armhf Packages [26,0 kB] Réception de :14 https://imola.armbian.com/apt bookworm/bookworm-utils all Contents (deb) [6 653 B] Réception de :15 https://imola.armbian.com/apt bookworm/bookworm-utils armhf Contents (deb) [12,9 kB] base-files: Installé : 24.5.1-12.4+deb12u5-bookworm Candidat : 24.5.1-12.4+deb12u5-bookworm Table de version : *** 24.5.1-12.4+deb12u5-bookworm 750 750 http://admtools.bdx.int/debian bookworm/main armhf Packages => this is my local mirror to fix the current issue on my side. 100 /var/lib/dpkg/status 12.4+deb12u6 500 500 http://ftp.debian.org/debian bookworm/main armhf Packages As you can see, your mirror does not appear in apt-cache policy. Index are still broken Regards
Hello Both mirrors have the deb package but it's not referenced anymore (looking my grep in /var/lib/apt/lists). I just tested with jevincanders mirror: apt-cache policy base-files base-files: Installé : 24.5.1-12.4+deb12u5-bookworm Candidat : 24.5.1-12.4+deb12u5-bookworm Table de version : *** 24.5.1-12.4+deb12u5-bookworm 100 100 /var/lib/dpkg/status 12.4+deb12u6 500 500 http://ftp.debian.org/debian bookworm/main armhf Packages No base-files available. apt-cache policy linux-image-current-sunxi linux-image-current-sunxi: Installé : 24.5.1 Candidat : 24.5.1 Table de version : *** 24.5.1 500 500 http://mirrors.jevincanders.net/armbian/apt bookworm/main armhf Packages 100 /var/lib/dpkg/status 24.2.1 500 500 http://mirrors.jevincanders.net/armbian/apt bookworm/main armhf Packages Something is broken with armhf with armbian repository. Regards
Seems base-files is not referenced: grep linux-image-current-sunxi /var/lib/apt/lists/armbian.site-meganet.com_apt_dists_bookworm_* armbian.site-meganet.com_apt_dists_bookworm_main_binary-armhf_Packages:Package: linux-image-current-sunxi armbian.site-meganet.com_apt_dists_bookworm_main_binary-armhf_Packages:Filename: pool/main/l/linux-6.6.31/linux-image-current-sunxi_24.5.1_armhf__6.6.31-Se3d3-D440d-P83e6-C5047H5c21-HK01ba-V014b-Bf15a-R448a.deb armbian.site-meganet.com_apt_dists_bookworm_main_binary-armhf_Packages:Package: linux-image-current-sunxi armbian.site-meganet.com_apt_dists_bookworm_main_binary-armhf_Packages:Filename: pool/main/l/linux-6.6.16/linux-image-current-sunxi_24.2.1_armhf__6.6.16-Seb3e-D6b4a-P2359-Ce96bHfe66-HK01ba-V014b-B067e-R448a.deb grep 'Package: base-files' /var/lib/apt/lists/armbian.site-meganet.com_apt_dists_bookworm_* => return nothing
Hello Since few days, base-files is missing from armbian repository for armhf arch apt-cache policy base-files base-files: Installé : 24.5.1-12.4+deb12u5-bookworm Candidat : 24.5.1-12.4+deb12u5-bookworm Table de version : *** 24.5.1-12.4+deb12u5-bookworm 100 100 /var/lib/dpkg/status 12.4+deb12u6 500 500 http://ftp.debian.org/debian bookworm/main armhf Packages On the armbian repository http://armbian.hosthatch.com/apt/pool/bookworm/b/base-files/ only arm64 is available. Is it normal ?
totoxxx
