DontMindMe
  1. So summary for now: The system works fine and the hard drives are being detected and mount fine. I would want to upgrade the Kernels at some point to use be update but for now this works OK. Originally i was planning to run Yunohost but sticking with https://syncthing.net/ for now. One additional question (I realize I might need to open a new thread for this.) How can I use the ATX Pins on the board, i.e. the power button, reset button etc. Thank y'all for your help! much appreciated.
  2. That was it. Build finished. I'll try it and report back.
  3. I tried it but I got this error: E: Packages were downgraded and -y was used without --allow-downgrades. [🐳|💥] Error context msg [ Installation of /root/base-files_24.5.1-12ubuntu4.6-jammy_arm64__1-jammy-1armbian1-Bbba0-U12ubuntu4.6-R55fa.deb failed rock-5-itx jammy no rk35xx ] Here the complete log: Do you have any tips or suggestions that I could try? Thank you! Cheers!
  4. Hey everyone, Thank you all for picking up on this issue. @NicoDI tried changing the Kernel to 5.10 in the ``armbian-config``` but that did not boot so I burned the image again. I will try to compile it using the doker and report back. @Igor How would I use the doker to build an image with those patches? Do I need to include those changes explicit after puling the Armbian repository? Cheers, David
  5. I installed Debian 12 (Bookworm)XFCE from the official Armbian website onto the NVME SSD of the board. Everything works fine except the 4 hard drives that are connected to boards SATA connectors. They do appear and work when i boot into the Debian provided by Radxa, so I know hardware isn't an issue. I think that they also worked during the very first boot of the system but after ``` apt update && apt upgrade ``` and reboot, they stop working. Any advice would be much appreciated. ``` rock-5-itx:~$ lsblk NAME MAJ:MIN RM SIZE RO TYPE MOUNTPOINTS mtdblock0 31:0 0 16M 0 disk mmcblk0 179:0 0 7.3G 0 disk mmcblk0boot0 179:32 0 4M 1 disk mmcblk0boot1 179:64 0 4M 1 disk zram0 252:0 0 11.6G 0 disk [SWAP] zram1 252:1 0 50M 0 disk /var/log zram2 252:2 0 0B 0 disk nvme0n1 259:0 0 476.9G 0 disk └─nvme0n1p1 259:1 0 472.1G 0 part /var/log.hdd / ``` https://paste.armbian.com/qiwimusofo
