x96q h313
@rafman I'm sorry, I thought we only needed FEL to confirm that it was Alwinner. I can go to FEL, but what can I do there? I thought that it was possible to understand from the UART logs why the boot from the SD card was not happening, but I could not see anything
x96q h313
x96q h313
@rafman This is the output from the UART, apparently this is an allwiner processor and I can enter FEL if I press the button before turning it on. Maybe you can somehow see the reason here, I couldn’t find anything yet
x96q h313
@bladyle @sicxnull Maybe there is a problem with the card? What volume and class is the minimum required?
x96q h313
@bladyle dont work for me , i dont know why, tv box starded on adroid
x96q h313
@rafman I try install miniarch or armbian to my device X96q based on h313 and memory chip samsung KMR82001M-B609. I recorded the image on an SD card, inserted it into the device, pressed the button in the AV input and turned on the power. The X96q splash screen appeared, quickly disappeared and nothing else happens. If i dont press the button, box start with android. How can i start from sd card?
Armbian for H313 X96-Q LPDDR3 TV-Box
My device start with adnroid if i dont press the button
How can I install this image on device? I recorded the image on an SD card, inserted it into the device, pressed the button in the AV input and turned on the power. The X96q splash screen appeared, quickly disappeared and nothing else happens.
