Eloy Bote Falcon
  1. Thank you very much @c0rnelius the patch works perfectly. And thank you @Igor too for the link to setup the wifi!
  2. Hey c0rnelius, Can you please tell me where to put the patch? Searching the repository I see 3 similar file names: build/patch/kernel/archive/sunxi-6.6/patches.armbian/arch-arm64-dts-allwinner-sun50i-h618-bananapi-m4-zero.patch build/patch/kernel/archive/sunxi-6.7/patches.armbian/arm64-dts-allwinner-sun50i-h618-bananapi-m4-zero.patch build/patch/kernel/archive/sunxi-6.9/patches.armbian/arch-arm64-dts-allwinner-sun50i-h618-bananapi-m4-zero.patch It's a noob question sorry but I'm new to the project, sorry.
  3. Hi, I'm trying to build armbian with the tutorial https://docs.armbian.com/Developer-Guide_Build-Preparation/#what-do-i-need but I get this error: ~/git/others/armbian/build$ ./compile.sh [🚸] Docker is installed, but not usable [ can't use Docker; check your Docker config / groups / etc ] [💥] Problem detected [ Docker installed but not usable ] [💥] Exiting in 10 seconds [ Press <Ctrl-C> to abort, <Enter> to ignore and continue ] Counting down: 9... 8... 7... 6... 5... 4... 3... 2... 1... 0... [💥] error! [ Exiting due to 'Docker installed but not usable' ] [💥] Exiting with error 43 [ at /home/eloy/git/others/armbian/build/lib/functions/logging/traps.sh:1 exit_with_error() --> lib/functions/logging/traps.sh:1 exit_if_countdown_not_aborted() --> lib/functions/general/countdown.sh:41 cli_standard_relaunch_docker_or_sudo() --> lib/functions/cli/utils-cli.sh:261 cli_standard_build_pre_run() --> lib/functions/cli/cli-build.sh:14 armbian_cli_pre_run_command() --> lib/functions/cli/utils-cli.sh:122 cli_entrypoint() --> lib/functions/cli/entrypoint.sh:79 main() --> ./compile.sh:50 ] I have virtualbox installed, and my OS is: cat /etc/os-release PRETTY_NAME="Ubuntu 22.04.4 LTS" NAME="Ubuntu" VERSION_ID="22.04" VERSION="22.04.4 LTS (Jammy Jellyfish)" VERSION_CODENAME=jammy ID=ubuntu ID_LIKE=debian HOME_URL="https://www.ubuntu.com/" SUPPORT_URL="https://help.ubuntu.com/" BUG_REPORT_URL="https://bugs.launchpad.net/ubuntu/" PRIVACY_POLICY_URL="https://www.ubuntu.com/legal/terms-and-policies/privacy-policy" UBUNTU_CODENAME=jammy lscpu Architecture: x86_64 CPU op-mode(s): 32-bit, 64-bit Address sizes: 43 bits physical, 48 bits virtual Byte Order: Little Endian CPU(s): 8 On-line CPU(s) list: 0-7 Vendor ID: AuthenticAMD Model name: AMD Ryzen 5 3500U with Radeon Vega Mobile Gfx What am I doing wrong? Thanks in advance.
  4. Thanks for the path c0rnelius! Honestly I have never build armbian but I think that I can do it applying your patch with this 2 guides: https://docs.armbian.com/Developer-Guide_User-Configurations/#user-provided-patches https://docs.armbian.com/Developer-Guide_Build-Preparation/#what-do-i-need If you dont' have any users with this new revision of M4 zero and need any help just ask me please!
  5. Definitely is the new revision. I can check the other armbian image 20240819-Bananapi-Armbian_24.8.0-trunk_Bpi-m4zero_Debian12 to see how can I enable the wifi device, but I don't know where to start, maybe the device tree?
  6. Hey kris, there is no nmcli command c0rnelius: I purchased the board a few weeks ago, is the new version with 4GB ram and 32Gb emmc.
  7. Hi, I'm trying to setup the wifi with the image: Armbian 24.8.1 Bookworm Minimal / IOT But there is no wlan0 on the ip a command. Can you please give me a hint on how to setup the wifi with the bananapi M4 zero? I have also tried the server image debian12 but found the same issue. FYI I tried an image from the BPI M4 zero website: 20240819-Bananapi-Armbian_24.8.0-trunk_Bpi-m4zero_Debian12 And there is wlan0 so I successfully configured the wifi ( but there is no bananapi-config to copy the image to the emmc but that's another story... ) Thanks in advance!
