aschaenz
  1. I have solved the problem with the following instructions (thx to AI): sudo nano /etc/polkit-1/rules.d/49-desktop-bypass.rules Paste this exact configuration rule into the text editor: polkit.addRule(function(action, subject) { if (subject.user == "<userId>") { return polkit.Result.YES; } }); By explicitly declaring that your primary user account <userId> is trusted by the underlying polkitd architecture, the system settings and the Discover store will instantly clear the action without demanding the bugged KDE graphical authentication prompt to draw on screen. Try opening your System Settings now to see if they open cleanly. If it's still locked up, run this command and paste the errors it gives you: • journalctl -b | grep polkit That will pull the exact system log showing whether it is a session ownership issue or a library failure.
  2. @Werner: https://paste.armbian.com/tategezeze @Igor: I describe an example workflow in detail: 1. Open "System Settings" 2. Search for "Login Screen (SDDM) 3. I select another wallpaper and click "Apply" 4. A popup "Authenticating Required", "Save Settings in SDDM", "Authenticating as <my name> (username)" to enter the password appears for about one second and disappears immediately. So it is not possible for me to enter the password and so it's not possible to save the settings. This happens with all settings where a authenticating is necessary. Kindest regards Albrecht
  3. Hello, i've installed the latest vendor version for Radxa ROCK 5 ITX. When I want to change settings, the password entry pop-up appears briefly and immediately disappears again, preventing the settings from being saved. I performed a completely fresh installation of the computer, and the problem still occurs. What is causing this? Any help would be appreciated. Best regards Albrecht
  4. Dear CryBaby, thank you very much for your answer. I tried a new installation with the image "Armbian_community_24.11.0-trunk.202_Cubietruck_noble_current_6.6.44_xfce_desktop.img.xz" and bluetooth is still not working. I stopped to investigate more time to solve the problem. My question can be closed or marked as solved. Best regards Albrecht
  5. Hello everybody, I'm new in armbian and Cubietruck. It looks to me that bluetooth is installed but if I scan for devices no devices will be found. I have the impression that something is wrong with the driver installation. I used the file image "Armbian_community_24.11.0-trunk.130_Cubietruck_noble_current_6.6.44_xfce_desktop.img.xz" for installation. Any help would be appreciated. Best regards Albrecht
