Картман
  1. Hello everyone, I am creating a custom Armbian build for OPI5 && OPI5b. The task is as follows: install several packages in the system and fully configure it. While there are no issues with installing packages and configuring the network, there is a peculiarity with the login and password. Specifically, sometimes after writing the image to the emmc opi5b or SD card, the system allows me to log in with my pre-configured credentials, but other times, when flashing the same image, the system simply rejects my pre-set data and displays the message “Login Incorrect.” How I set the initial settings for the system: In /root there is a file called .not_logged_in_yet, from which data is pulled when you first log in to the system, thanks to which it is automatically configured (this method was tested on nanopi m6 and RPI 3b+) and everything worked fine, but for some reason, it is with orangepi 5 && orangepi 5b that I get such artifacts. My .not_logged_in_yet looks like this: # Network settings PRESET_NET_CHANGE_DEFAULTS="1" PRESET_NET_WIFI_ENABLED="1" PRESET_NET_WIFI_SSID="MyWiFi" PRESET_NET_WIFI_KEY="MyWiFiPassword" PRESET_NET_WIFI_COUNTRYCODE=“RU” PRESET_CONNECT_WIRELESS="n" PRESET_NET_USE_STATIC="1" PRESET_NET_STATIC_IP="192.168.1.100" PRESET_NET_STATIC_MASK=“255.255.255.0” PRESET_NET_STATIC_GATEWAY="192.168.1.1" PRESET_NET_STATIC_DNS="8.8.8.8 8.8.4.4" # System settings SET_LANG_BASED_ON_LOCATION="n" PRESET_LOCALE="ru_RU.UTF-8" PRESET_TIMEZONE="Europe/Moscow" # Root settings PRESET_ROOT_PASSWORD="mysecretrootpass" # User creation PRESET_USER_NAME="user1" PRESET_USER_PASSWORD="mypassword" PRESET_DEFAULT_REALNAME="User One" PRESET_USER_SHELL="bash" For my Armbian image, I use the VENDOR 6.1 kernel - ubunu 22.04 jammy. What could be the problem?
  2. That's exactly what I did. I wrote a replacement for the .not_logged_in_yet file in my customize-image.sh with pre-set parameters, just like I create /root/provisioning.sh. I was just wondering if there were any other ways to do this.
  3. Hi everyone, I'm new to creating my own images and I'm learning this just because I'm interested in it. I am trying to build ubuntu 24.04 for my rpi3b using the build configuration for rpi4b. Now I'm trying to automate the process of the first launch (skip the selection of bash, zsh, creating a password for root, creating a regular user, etc.). In one of the topics, I found out that I can delete "rm -rf/root/.not_logged_in_yet" And the system will not ask for the initial setup, but to make all the necessary changes for me, I wrote a small function in customize-image.sh: SettingSystemFirtsRun() { #disable defaut script sudo rm -rf /root/.not_logged_in_yet #setting regul user echo "add user $_userName" sudo useradd -m -c -s /bin/bash "$_userName" "$_userName" -p "$_userPass" #change root pass echo 'change root passssss' echo "root:$_rootPass" | sudo chpasswd # Set hostname permanently echo "Setting hostname to $_Hostname" echo "$_Hostname" > /etc/hostname hostname -b "$_Hostname" # Update hosts file sed -i "s/127.0.1.1.*/127.0.1.1\t$_Hostname/g" /etc/hosts } But when the system starts, I still do not see the directory of the user I am creating in /home, while the user himself is being created. The most important thing is that I really want to implement user creation at the assembly stage, although I am less and less convinced that this is even possible... I do not rule out that there are more concise ways to solve this problem, so I will be glad of any advice, good luck to all. P.S. I read the documentation, but I couldn't find a solution there.
