Making Allwinner H616 run armbian OS
Hey All - just a FYI - your transpeed (non-secure-boot) image working on the T95Max (H618/4GB/32GB) - no wifi - but not on my list of needs. Much faster than the Q1 - worth the extra $3 lol Sorry, specifically, @Nick A - your image from github
How to install armbian on TX3-mini (Allwinner h313 processor)
try this image that @rafman made let him know if it work in the thread
x96q h313
@rafman I have only been working with the sdcard, not the emmc. I do know the current idea I proposed is definitely not in my abilities will probably just leave it as is - it does the job just fine.
Since the H616 is supposed to be very similar to H313 - try this image that @rafman made. Would be great to know if it works. Just load to SD and see if it boots.
x96q h313
@rafman would it be possible to re-patch the x96q image after running a script on it that seemingly breaks it? so basically: load the sd boot on x96q / q1 run script (that seems to break booting) re-patch x96q (then reboot) possible?
x96q h313
@rafman thanks! boots up like a champ. getting further on my other issue (dietpi) but will try and sort that out in their forum. If I wanted to try and get an alternative image to boot on this Q1/H313 - what are the core boot files I need to copy from the image? Or is that just a non-starter approach? Cheers!
x96q h313
@rafman the image you compiled for me for the Q1 is ubuntu based - are you able to share the debian based one from your previous posts?
x96q h313
@rafman oh excellent. thanks for the tip. Still getting acquainted with this. I was just going for consistency since I had another old box running it. considering I can get the Q1 for $40 CDN on amazon - its a really good deal to put together a quick pihole for a friends and family. I feel like the tv-box producers are missing an opportunity in not building their own armbian version will full support. They would sell more boxes!
x96q h313
@rafman I have been trying to convert this image to a DietPi install (they have a script) and I have managed to get over a few hurdles and challenges along the way (no_pubkey issues - I bypassed with "deb [trusted=yes] ") but I've hit a wall. Can you shed some light on this? I am not having any luck sorting out the diversion issue. Can the image you compiled be done without usr-merge? Or is this more-so an issue of them having to upgrade their script? Just waiting for dietpi forum approval so I can bounce it off them over there. Cheers Preparing to unpack .../base-files_13.5_arm64.deb ... dpkg-divert: error: 'diversion of /lib32 to /.lib32.usr-is-merged by base-files' clashes with 'diversion of /lib32 to /lib32.usr-is-merged by base-files' dpkg: error processing archive /tmp/apt/archives/base-files_13.5_arm64.deb (--unpack): new base-files package pre-installation script subprocess returned error exit status 2 motd-news.timer is a disabled or a static unit not running, not starting it. motd-news.service is a disabled or a static unit not running, not starting it. Errors were encountered while processing: /tmp/apt/archives/base-files_13.5_arm64.deb E: Sub-process /usr/bin/dpkg returned an error code (1)
x96q h313
@rafman Success! took a few tries to write the image - decompressing it first seemed to make etcher happier about it. (inside the archive the .img extension was missing) lack of bt or wifi is no big deal as mainly looking to repurpose some of these into pi-holes. Will let you know how I make out with the other box I have. I have a mix of some boxes because was using some for remote android signage players for a customer, and the signage app did not perform well on some boxes. Plus just other past tinkering. edit: so just tested what was supposed to be an H313 (best I can tell from my buying history) - no dice. opened it up, it's an S905W. It was from primecables (branded) and board is a TX3MINI-P If there is any other hardware that you spot or want tested, let me know. I don't mind buying & testing pre-built images. That much I have some time for. Zero programming chops here. Batch files at best.
x96q h313
@rafman loading on sdcard and booting. currently boots android just fine by default. identical pcb and chips to your Q1. I also have another H313 box willing to experiment with for the cause. Currently have another older box booting off sd just fine. (V88 Piano - using DietPi Rock64)
x96q h313
@rafman I have the identical Q1 box however every image I flash will not boot on it. Anything I am missing?
eibrog
