Armbian for H313 X96-Q LPDDR3 TV-Box
Hi. In October 2024, I wrote that I had a problem installing Armbian on eMMC of the tv box. I managed to solve this problem. Here's what you need to do: 1. Download the image from the link - https://github.com/NickAlilovic/build/releases/download/20250306/Armbian-unofficial_25.05.0-trunk_X96q-lpddr3-v1-3_bookworm_edge_6.12.11_xfce_desktop.img.xz 2. Burn the image to microSD using Rufus or BalenaEtcher 3. Insert the microSD and turn on the tv box 4. Install Armbian 5. Next, launch the terminal and enter sequentially: armbian-install -> Boot from eMMC - system on eMMC -> ext4 (waiting ~5-10 minutes) 6. Turn off the tv box and extract the microSD 7. Turn on the tv box (Wi-Fi is not working) 8. Next, launch the terminal and enter sequentially: armbian-config -> System -> Kernel -> SY210 - Manage device tree overlays 9. Turn off the tv box (waiting ~5-10 minutes) 10. Turn on the tv box (Wi-Fi is working) Special thanks to @Nick A Good luck to all!!!
I have followed all the points of your instructions, but the tv box does not load. Do I need to flash u-boot?
Hello. I followed your instructions and failed to complete point 3 (screenshots attached). 1> Write the downloaded image on SD Card using Balena Etcher. ...OK! 2> Boot from SD Card. ...OK! 3> Install it via armbian-install to eMMc (don't reboot). ...FAIL! Screenshot 1 - The step "Counting files..." lasted 5 minutes. Screenshot 2 - The step "Transferring rootfs to..." lasted 1 minute. The progress always stayed at 0 %. Screenshot 3 - The step "Cleaning up..." lasted 2 minutes. Screenshot 4 - This message appeared at the step "Cleaning up..." Screenshot 5 - The final message "All done" I also tried to clone the sd card using this command $ sudo dd if=/dev/mmcblk0 of=/dev/mmcblk2 bs=1M status=progress The result is the same - the tv box does not load from emmc
Hello. I used this image https://github.com/sicXnull/armbian-build/releases/download/v24.8.0-trunk.425/Armbian-unofficial_24.11.0-trunk_X96q_bookworm_current_6.6.44_mate_desktop.img.xz My tv box boots from an SD card with this image, but does not install on emmc. My tv box is X96Q H313 PC040BB 9031 SanDisk SDADFAAP-i66. I am attaching a photo.
I am trying to install Armbian on emmc of the tv box X96Q using armbian-install. The installation is aborted at the file copying stage (message "Cleaning up ... Almost done", but the tv box does not start with emmc). @rafman please share the image (or the path) with a secure boot for the tv box X96Q or Z1
Hello. I created the image according to the instructions of @sicxnull - Armbian boots from microsd very well. How do I install this image in emmc? Please write the instructions
vok4us
