Errol
  1. Ahh, the rock-5b page says this: But I suppose it now means 6.10 is experimental. And I twice accidentally downloaded 6.10 instead of 6.1 because the names are so similar. I installed the image for 6.1, kernel 6.1.75-vendor-rk35xx, but now armbian-config has even less options under System/Hardware. Previously all the PWMs where there, some SATA ports and a few I2C ports. Now there is just "opp-oc-24ghz" and "panthor-gpu". I was able to add the overlays manually to armbianEnv.txt. So all my devices are now enabled. Thanks!
  2. Hi Werner, I don't know how this will help, as the issue is configuration/setup related, not system related, but attached anyway. https://paste.armbian.com/ufogojovit Thank you, Errol
  3. Hi, How do enable I2C on pins 3,5 of the GPIO header? I need to enable I2C7_M3. How to enable spidev.0 on SPI0_M2? All these overlays are missing... Thank you, Errol
