- Orange Pi Zero 3 ili9486 TFT LCD (WaveShare 35a)
hello, agesome! The same thing happened to me, test 20mhz (20000000), I suggest increasing above 32mhz and test. I'm using mine at 46mhz and it's normal, but it used to give an error, it wouldn't update the screen, it would freeze, now it's normal because I disabled “dma-names=””;” Try it and let me know.
I was missing because I was testing the ili9486. So, I used the conversion from ili9341 to ili9486, for a while and it worked well, however, it was slow because it did not support more than 21mhz, so I tried to make the ili9486 work, after a few days I managed to make it work, but I had to disable the “dma-names” because it was making the screen not update, I am now using the ili9486 at 48mhz, working well. I'm using the LCD directly on the board.
I also felt that xinput_calibration didn't change anything. I was configuring it here, because the touch didn't reach the corner of the LCD and it was stable, but now it's shaking too, but now the touch reaches the corner of the screen. So it's probably just the settings, I'll see if I can sort it out.
Hi, I'm back, now I'm trying once again to connect the screen to the orange pi zero 3. I was looking at this link, panel-mipi-dbi-spi, it doesn't work on the ili9486, but it works on the ili9341, so I would have to modify the ili9486 to the ili9341. I'll try that now . I now have the dupont wires.
- ST7796 display w/ opiz3
WDR_s
