UnhealthyTweak
  1. Please share your AI skills to translate vendor android DTS into armbian compatible DTS. The work seems menial and lacks any sort of documentation. An automated workflow would do wonders, if created by someone who understands it fully.
  2. Hi, For Tanix TX68 to get all USB ports working it was enough to toggle status = "disabled" to "okay" in transpeed-8k618 DTS. (unfortunatelly i cannot spin up an external HDD by it while having soldered 2x18650 UPS, to little amps available) Getting WiFi / BT to work on the other hand is not solved. BT: - modules loaded out of the box, no errors in dmesg after changing something in DTS but hcitool dev/scan show nothing WiFi: - modprobe: ERROR: could not insert 'aic8800_fdrv': No such device - I tried modifying parts of Transpeed DTS to align with vendor Android DTS with no result Probably same issue as on T95Z Plus: I tried its image: https://github.com/LYU4662/t95zplus-h618-build same error. I diffed android DTS between T95Z & TX68 - almost identical tp95_android.dts tx68_android.dts
  3. Hi again, The question was already asked a couple of times by some people in this thread But I don't see anyone reporting back after getting a hint from Nick. I don't even know where to start looking for information, the problem is I do have android and armbian DTS (attached) Armbian is for a different board - transpeed instead of tanix tx68. How do I know which parts to change and how? I tried some changes with WIFI parts of the config, to more or less match parts from android into armbian, but there are undefined variables, it won't compile. I don't know - some symbols, addresses etc. I tried https://github.com/goecho/aic8800_linux_drvier today, the driver compiles and loads just fine, but there is no new device in `ip link` command. Starting to think that maybe using AOSP + docker on it could be easier than fixing DTB for Armbian? Thank you android.txt armbian.txt
  4. Thanks, although the aic8800_fdrv module fails modprobe due to no device found error, Bluetooth module loads, but it was same when I compiled the module myself a month ago. It is fine for what it is though, maybe it will work without accessories in the future
  5. Let me introduce my device: - tanix tx68 - wifi/bluetooth not working - tried building modules for aw869a, failed to load, tried pre-built ones in form of .deb packages, didn't work either - internal storage not working - failed mounting it from within armbian - 1x USB2 port not working (works on default Android, doesn't work on slimboxTV Android) - IR not working - using an image from https://github.com/NickAlilovic/build/releases as is, great! - using it for Home Assistant - using external WiFi adapter - headless, tried at first with an external display but it kept stalling/crashing the GPU every few seconds and kept getting lower resolution. To be honest, an Intel N100 for 4x the price would have been a better choice, though tx68 is usable.
