Kashyap Gada
  1. Hi I want to work with g_audio drivers on the usb type c otg port. When I build the image with current kernel, by applying the following overlay (I only change dr_mode to peripheral) i am able to convert the usb port in peripheral mode and successfully load the g_audio drivers and audio interfaces also come up. /dts-v1/; /plugin/; / { compatible = "rockchip,rk3588s"; fragment@0 { target = <&usb_host0_xhci>; // This matches the label in the device tree __overlay__ { dr_mode = "peripheral"; }; }; }; But when i want to do similar with the vendor kernel, which has different device tree, changing dr_mode doesn't work. /dts-v1/; /plugin/; / { compatible = "rockchip,rk3588s"; fragment@0 { target = <&usbdrd3_0>; // Target the usbdrd3_0 node __overlay__ { usb@fc000000 { dr_mode = "peripheral"; // Change dr_mode to peripheral }; }; }; }; The device trees for usb type c port for both kernels are as below - //***This node is of current kernel*** usb@fc000000 { power-domains = <0x21 0x1f>; snps,dis-u1-entry-quirk; snps,dis_enblslpm_quirk; phy-names = "usb2-phy\0usb3-phy"; clock-names = "ref_clk\0suspend_clk\0bus_clk"; snps,dis-u2-freeclk-exists-quirk; usb-role-switch; phy_type = "utmi_wide"; resets = <0x1f 0x152>; interrupts = <0x00 0xdc 0x04 0x00>; clocks = <0x1f 0x194 0x1f 0x193 0x1f 0x192>; snps,dis-u2-entry-quirk; compatible = "rockchip,rk3588-dwc3\0snps,dwc3"; snps,dis-del-phy-power-chg-quirk; status = "okay"; phys = <0x23 0x24 0x04>; reg = <0x00 0xfc000000 0x00 0x400000>; phandle = <0x116>; dr_mode = "peripheral"; snps,dis-tx-ipgap-linecheck-quirk; port { endpoint { remote-endpoint = <0x25>; phandle = <0xeb>; }; }; }; ------------ dmesg output [ 15.417624] i2c 6-0022: deferred probe pending: typec_fusb302: cannot register tcpm port [ 600.475296] g_audio gadget.0: Linux USB Audio Gadget, version: Feb 2, 2012 [ 600.475317] g_audio gadget.0: g_audio ready Vendor Kernel //***This node is of vendor kernel usbdrd3_0 { #address-cells = <0x02>; clock-names = "ref\0suspend\0bus"; clocks = <0x02 0x1a3 0x02 0x1a2 0x02 0x1a1>; #size-cells = <0x02>; compatible = "rockchip,rk3588-dwc3\0rockchip,rk3399-dwc3"; ranges; status = "okay"; phandle = <0x22b>; usb@fc000000 { power-domains = <0x06 0x1f>; snps,dis-u1-entry-quirk; snps,dis_enblslpm_quirk; phy-names = "usb2-phy\0usb3-phy"; snps,dis-u2-freeclk-exists-quirk; usb-role-switch; phy_type = "utmi_wide"; quirk-skip-phy-init; resets = <0x02 0x2a4>; interrupts = <0x00 0xdc 0x04>; snps,dis-u2-entry-quirk; compatible = "snps,dwc3"; snps,parkmode-disable-hs-quirk; snps,dis-del-phy-power-chg-quirk; status = "okay"; snps,parkmode-disable-ss-quirk; phys = <0x74 0x75>; reg = <0x00 0xfc000000 0x00 0x400000>; phandle = <0x22c>; dr_mode = "otg"; reset-names = "usb3-otg"; snps,dis-tx-ipgap-linecheck-quirk; port { #address-cells = <0x01>; #size-cells = <0x00>; endpoint@0 { remote-endpoint = <0x76>; reg = <0x00>; phandle = <0x183>; }; }; }; }; //dmesg output [ 41.238153] [GTP-ERR][__do_register_ext_module:79] Module [goodix-fwu] timeout [ 243.574594] g_audio gadget.0: Hardware params: access 3, format 2, channels 2, rate 48000 [ 243.574756] g_audio gadget.0: Linux USB Audio Gadget, version: Feb 2, 2012 [ 243.574773] g_audio gadget.0: g_audio ready [ 243.578558] typec_fusb302 6-0022: Looking up vbus-supply from device tree [ 243.581576] dwc3 fcd00000.usb: device reset Can some one help me what kind of overlay should i make to convert the port to peripheral mode.
  2. I run a audio loop code on a Raspberry pi 4/5 and Orange Pi 5. The latency of audio loop is 0.2 seconds on Raspberry pi but on orange pi it takes 1.2 seconds. For orange pi, i am facing this problem with different Operating systems as well apart from armbian. I've used Ubuntu, Orange Pi OS, Armbian. All have got this problem. The code I have attached. Since the issue is faced in multiple Operating System I strongly feel this has to do with the driver level softwares or directly related optimization from Rockchip. Can anyone guide what I could do audio-loop.cpp
