dezldog
  1. I was able to find and install rock-5-itx_debian_bullseye_kde_b6.img.xz Here are the outputs: radxa@rock-5-itx:~$ uname -a Linux rock-5-itx 5.10.110-37-rockchip #27a257394 SMP Thu May 23 02:38:59 UTC 2024 aarch64 GNU/Linux radxa@rock-5-itx:~$ cat /proc/asound/cards 0 [rockchiphdmi1 ]: rockchip-hdmi1 - rockchip-hdmi1 rockchip-hdmi1 1 [rockchiphdmi0 ]: rockchip-hdmi0 - rockchip-hdmi0 rockchip-hdmi0 2 [rockchiphdmi2 ]: rockchip-hdmi2 - rockchip-hdmi2 rockchip-hdmi2 3 [rockchipspdiftx]: rockchip_spdif- - rockchip,spdif-tx1 rockchip,spdif-tx1 4 [rockchiphdmiin ]: rockchip_hdmiin - rockchip,hdmiin rockchip,hdmiin 5 [rockchipes8316 ]: rockchip-es8316 - rockchip-es8316 rockchip-es8316 radxa@rock-5-itx:~$ amixer -c5 Simple mixer control 'Headphone',0 Capabilities: pvolume pswitch pswitch-joined Playback channels: Front Left - Front Right Limits: Playback 0 - 3 Mono: Front Left: Playback 3 [100%] [0.00dB] [on] Front Right: Playback 3 [100%] [0.00dB] [on] Simple mixer control 'Headphone Mixer',0 Capabilities: volume Playback channels: Front Left - Front Right Capture channels: Front Left - Front Right Limits: 0 - 11 Front Left: 0 [0%] [-12.00dB] Front Right: 0 [0%] [-12.00dB] Simple mixer control 'Speaker',0 Capabilities: pswitch pswitch-joined Playback channels: Mono Mono: Playback [on] Simple mixer control 'Mic Boost',0 Capabilities: pswitch pswitch-joined Playback channels: Mono Mono: Playback [on] Simple mixer control 'I2STDM Digital Loopback Mode',0 Capabilities: enum Items: 'Disabled' 'Mode1' 'Mode2' 'Mode2 Swap' Item0: 'Disabled' Simple mixer control 'Playback Polarity',0 Capabilities: enum Items: 'Normal' 'R Invert' 'L Invert' 'L + R Invert' Item0: 'Normal' Simple mixer control 'Capture Polarity',0 Capabilities: enum Items: 'Normal' 'Invert' Item0: 'Normal' Simple mixer control 'ADC',0 Capabilities: cvolume cvolume-joined Capture channels: Mono Limits: Capture 0 - 192 Mono: Capture 0 [0%] [-99999.99dB] Simple mixer control 'ADC Double Fs',0 Capabilities: pswitch pswitch-joined Playback channels: Mono Mono: Playback [off] Simple mixer control 'ADC PGA Gain',0 Capabilities: volume volume-joined Playback channels: Mono Capture channels: Mono Limits: 0 - 10 Mono: 0 [0%] [-3.50dB] Simple mixer control 'ADC Soft Ramp',0 Capabilities: pswitch pswitch-joined Playback channels: Mono Mono: Playback [on] Simple mixer control 'ALC',0 Capabilities: cswitch cswitch-joined Capture channels: Mono Mono: Capture [off] Simple mixer control 'ALC Capture Attack Time',0 Capabilities: volume volume-joined Playback channels: Mono Capture channels: Mono Limits: 0 - 10 Mono: 2 [20%] Simple mixer control 'ALC Capture Decay Time',0 Capabilities: volume volume-joined Playback channels: Mono Capture channels: Mono Limits: 0 - 10 Mono: 3 [30%] Simple mixer control 'ALC Capture Hold Time',0 Capabilities: volume volume-joined Playback channels: Mono Capture channels: Mono Limits: 0 - 10 Mono: 0 [0%] Simple mixer control 'ALC Capture Max',0 Capabilities: volume volume-joined Playback channels: Mono Capture channels: Mono Limits: 0 - 28 Mono: 28 [100%] [35.50dB] Simple mixer control 'ALC Capture Min',0 Capabilities: volume volume-joined Playback channels: Mono Capture channels: Mono Limits: 0 - 28 Mono: 0 [0%] [-12.00dB] Simple mixer control 'ALC Capture Noise Gate',0 Capabilities: pswitch pswitch-joined Playback channels: Mono Mono: Playback [off] Simple mixer control 'ALC Capture Noise Gate Threshold',0 Capabilities: volume volume-joined Playback channels: Mono Capture channels: Mono Limits: 0 - 31 Mono: 0 [0%] Simple mixer control 'ALC Capture Noise Gate Type',0 Capabilities: enum Items: 'Constant PGA Gain' 'Mute ADC Output' Item0: 'Constant PGA Gain' Simple mixer control 'ALC Capture Target',0 Capabilities: volume volume-joined Playback channels: Mono Capture channels: Mono Limits: 0 - 10 Mono: 11 [110%] [0.00dB] Simple mixer control 'DAC',0 Capabilities: pvolume Playback channels: Front Left - Front Right Limits: Playback 0 - 192 Mono: Front Left: Playback 192 [100%] [0.00dB] Front Right: Playback 192 [100%] [0.00dB] Simple mixer control 'DAC Double Fs',0 Capabilities: pswitch pswitch-joined Playback channels: Mono Mono: Playback [off] Simple mixer control 'DAC Mono Mix',0 Capabilities: pswitch pswitch-joined Playback channels: Mono Mono: Playback [off] Simple mixer control 'DAC Notch Filter',0 Capabilities: pswitch pswitch-joined Playback channels: Mono Mono: Playback [off] Simple mixer control 'DAC Soft Ramp',0 Capabilities: pswitch pswitch-joined Playback channels: Mono Mono: Playback [off] Simple mixer control 'DAC Soft Ramp Rate',0 Capabilities: volume volume-joined Playback channels: Mono Capture channels: Mono Limits: 0 - 4 Mono: 4 [100%] Simple mixer control 'DAC Source Mux',0 Capabilities: enum Items: 'LDATA TO LDAC, RDATA TO RDAC' 'LDATA TO LDAC, LDATA TO RDAC' 'RDATA TO LDAC, RDATA TO RDAC' 'RDATA TO LDAC, LDATA TO RDAC' Item0: 'LDATA TO LDAC, RDATA TO RDAC' Simple mixer control 'DAC Stereo Enhancement',0 Capabilities: volume volume-joined Playback channels: Mono Capture channels: Mono Limits: 0 - 7 Mono: 0 [0%] Simple mixer control 'Differential Mux',0 Capabilities: enum Items: 'lin1-rin1' 'lin2-rin2' 'lin1-rin1 with 20db Boost' 'lin2-rin2 with 20db Boost' Item0: 'lin1-rin1' Simple mixer control 'Digital Mic Mux',0 Capabilities: enum Items: 'dmic disable' 'dmic data at high level' 'dmic data at low level' Item0: 'dmic disable' Simple mixer control 'Headset Mic',0 Capabilities: pswitch pswitch-joined Playback channels: Mono Mono: Playback [off] Simple mixer control 'Left Headphone Mixer LLIN',0 Capabilities: pswitch pswitch-joined Playback channels: Mono Mono: Playback [off] Simple mixer control 'Left Headphone Mixer Left DAC',0 Capabilities: pswitch pswitch-joined Playback channels: Mono Mono: Playback [on] Simple mixer control 'Left Headphone Mux',0 Capabilities: enum Items: 'lin1-rin1' 'lin2-rin2' 'lin-rin with Boost' 'lin-rin with Boost and PGA' Item0: 'lin1-rin1' Simple mixer control 'Main Mic',0 Capabilities: pswitch pswitch-joined Playback channels: Mono Mono: Playback [on] Simple mixer control 'Right Headphone Mixer RLIN',0 Capabilities: pswitch pswitch-joined Playback channels: Mono Mono: Playback [off] Simple mixer control 'Right Headphone Mixer Right DAC',0 Capabilities: pswitch pswitch-joined Playback channels: Mono Mono: Playback [on] Simple mixer control 'Right Headphone Mux',0 Capabilities: enum Items: 'lin1-rin1' 'lin2-rin2' 'lin-rin with Boost' 'lin-rin with Boost and PGA' Item0: 'lin1-rin1' radxa@rock-5-itx:~$ pulseaudio --dump-conf ### Read from configuration file: /etc/pulse/daemon.conf ### daemonize = no fail = yes high-priority = yes nice-level = -11 realtime-scheduling = yes realtime-priority = 5 allow-module-loading = yes allow-exit = yes use-pid-file = yes system-instance = no local-server-type = user cpu-limit = no enable-shm = yes flat-volumes = no rescue-streams = yes lock-memory = no exit-idle-time = 20 scache-idle-time = 20 dl-search-path = /usr/lib/pulse-14.2/modules default-script-file = /etc/pulse/default.pa load-default-script-file = yes log-target = log-level = notice resample-method = auto avoid-resampling = no enable-remixing = yes remixing-use-all-sink-channels = yes remixing-produce-lfe = no remixing-consume-lfe = no lfe-crossover-freq = 0 default-sample-format = s16le default-sample-rate = 44100 alternate-sample-rate = 48000 default-sample-channels = 2 default-channel-map = front-left,front-right default-fragments = 4 default-fragment-size-msec = 25 enable-deferred-volume = yes deferred-volume-safety-margin-usec = 8000 deferred-volume-extra-delay-usec = 0 shm-size-bytes = 0 log-meta = no log-time = no log-backtrace = 0 rlimit-fsize = -1 rlimit-data = -1 rlimit-stack = -1 rlimit-core = -1 rlimit-rss = -1 rlimit-as = -1 rlimit-nproc = -1 rlimit-nofile = 256 rlimit-memlock = -1 rlimit-locks = -1 rlimit-sigpending = -1 rlimit-msgqueue = -1 rlimit-nice = 31 rlimit-rtprio = 9 rlimit-rttime = 200000 I do get audio out of the back panel now, but It is worth noting that the ui is reporting that it is using the front panel headphone out and not the back panel. It is also not stereo. It is also worth noting that this image is _way_ less stable and much slower than the OS: Armbian bookworm 25.2.0-trunk.252/Linux 6.1.84-vendor-rk35xx kernel version on my other m.2 card! Thanks! What should I try next?
  2. Here is current (I'll try the image you suggest on a different nvme then post that too): rock5:~:# fastfetch .. root@rock5 `:]x**j-,' ---------- .,+t***********z\<" OS: Armbian bookworm 25.2.0-trunk.252 aarch64 ?******************; Host: Radxa ROCK 5 ITX '*n` .'`^,;;,^`'. ,cc. Kernel: Linux 6.1.84-vendor-rk35xx -<. .[l Uptime: 21 hours, 53 mins // ^^ ^^ \\ Packages: 1659 (dpkg) !^ ^^ ": Shell: zsh 5.9 'tt}` !~]rj_ ")t/. Display (ASUS VP228): 1920x1080 @ 60 Hz in 22" [External] Itttt?' ~~]rr] `{tttt, DE: Cinnamon 5.6.8 \tttttt!""I_]r("""~tttttt1 WM: Muffin (X11) '_tttttttttttt)ftttttttttttti. WM Theme: cinnamon (Numix) \*ztttttttttttttttttttttttttf**[ Theme: Numix [GTK2/3/4] l**c)tttttttttttttttttttttttt(z**, Icons: Numix [GTK2/3/4] .z*x.`tttttttttttttttttttttttt.`u*n Font: Sans (9pt) [GTK2/3/4] >` (tttttttttttttttttttttt] "I Cursor: whiteglass (24px) ,tttttttttttttttttttttt` Terminal: GNOME Terminal 3.46.8 ./tttttfttttttttfttttt( Terminal Font: Monospace (11pt) 'I)))(\()(tt))|\()({;' CPU: rk3588 (8) @ 2.35 GHz .~~~~~~~|)~~~~~~~< GPU: Mali-G610 (Panfrost) '[)))))1|()))))))? Memory: 2.46 GiB / 23.17 GiB (11%) ",,," ",,,^ Swap: 0 B / 11.59 GiB (0%) Disk (/): 16.89 GiB / 916.81 GiB (2%) - ext4 Disk (/home/clarkh/mounts/sda): 8.37 GiB / 1.79 TiB (0%) - ext4 Disk (/var/log): 4.28 MiB / 46.84 MiB (9%) - ext4 Local IP (enP3p49s0): 192.168.50.146/24 Locale: en_US.UTF-8 rock5:~:# cat /proc/asound/cards 0 [rockchiphdmi1 ]: rockchip-hdmi1 - rockchip-hdmi1 rockchip-hdmi1 1 [rockchiphdmi0 ]: rockchip-hdmi0 - rockchip-hdmi0 rockchip-hdmi0 2 [rockchiphdmi2 ]: rockchip-hdmi2 - rockchip-hdmi2 rockchip-hdmi2 3 [rockchiphdmiin ]: rockchip-hdmiin - rockchip-hdmiin rockchip-hdmiin 4 [rockchipes8316 ]: rockchip-es8316 - rockchip-es8316 rockchip-es8316 5 [rockchipspdiftx]: simple-card - rockchip,spdif-tx1 rockchip,spdif-tx1 rock5:~:# amixer -c4 Simple mixer control 'Headphone',0 Capabilities: pvolume pswitch pswitch-joined Playback channels: Front Left - Front Right Limits: Playback 0 - 3 Mono: Front Left: Playback 2 [67%] [-12.00dB] [on] Front Right: Playback 2 [67%] [-12.00dB] [on] Simple mixer control 'Headphone Mixer',0 Capabilities: volume Playback channels: Front Left - Front Right Capture channels: Front Left - Front Right Limits: 0 - 11 Front Left: 0 [0%] [-12.00dB] Front Right: 0 [0%] [-12.00dB] Simple mixer control 'Speaker',0 Capabilities: pswitch pswitch-joined Playback channels: Mono Mono: Playback [off] Simple mixer control 'Mic Boost',0 Capabilities: pswitch pswitch-joined Playback channels: Mono Mono: Playback [on] Simple mixer control 'I2STDM Digital Loopback Mode',0 Capabilities: enum Items: 'Disabled' 'Mode1' 'Mode2' 'Mode2 Swap' Item0: 'Disabled' Simple mixer control 'Playback Polarity',0 Capabilities: enum Items: 'Normal' 'R Invert' 'L Invert' 'L + R Invert' Item0: 'Normal' Simple mixer control 'Capture Polarity',0 Capabilities: enum Items: 'Normal' 'Invert' Item0: 'Normal' Simple mixer control 'ADC',0 Capabilities: cvolume cvolume-joined Capture channels: Mono Limits: Capture 0 - 192 Mono: Capture 0 [0%] [-99999.99dB] Simple mixer control 'ADC Double Fs',0 Capabilities: pswitch pswitch-joined Playback channels: Mono Mono: Playback [off] Simple mixer control 'ADC PGA Gain',0 Capabilities: volume volume-joined Playback channels: Mono Capture channels: Mono Limits: 0 - 10 Mono: 0 [0%] [-3.50dB] Simple mixer control 'ADC Soft Ramp',0 Capabilities: pswitch pswitch-joined Playback channels: Mono Mono: Playback [on] Simple mixer control 'ALC',0 Capabilities: cswitch cswitch-joined Capture channels: Mono Mono: Capture [off] Simple mixer control 'ALC Capture Attack Time',0 Capabilities: volume volume-joined Playback channels: Mono Capture channels: Mono Limits: 0 - 10 Mono: 2 [20%] Simple mixer control 'ALC Capture Decay Time',0 Capabilities: volume volume-joined Playback channels: Mono Capture channels: Mono Limits: 0 - 10 Mono: 3 [30%] Simple mixer control 'ALC Capture Hold Time',0 Capabilities: volume volume-joined Playback channels: Mono Capture channels: Mono Limits: 0 - 10 Mono: 0 [0%] Simple mixer control 'ALC Capture Max',0 Capabilities: volume volume-joined Playback channels: Mono Capture channels: Mono Limits: 0 - 28 Mono: 28 [100%] [35.50dB] Simple mixer control 'ALC Capture Min',0 Capabilities: volume volume-joined Playback channels: Mono Capture channels: Mono Limits: 0 - 28 Mono: 0 [0%] [-12.00dB] Simple mixer control 'ALC Capture Noise Gate',0 Capabilities: pswitch pswitch-joined Playback channels: Mono Mono: Playback [off] Simple mixer control 'ALC Capture Noise Gate Threshold',0 Capabilities: volume volume-joined Playback channels: Mono Capture channels: Mono Limits: 0 - 31 Mono: 0 [0%] Simple mixer control 'ALC Capture Noise Gate Type',0 Capabilities: enum Items: 'Constant PGA Gain' 'Mute ADC Output' Item0: 'Constant PGA Gain' Simple mixer control 'ALC Capture Target',0 Capabilities: volume volume-joined Playback channels: Mono Capture channels: Mono Limits: 0 - 11 Mono: 11 [100%] [-1.50dB] Simple mixer control 'DAC',0 Capabilities: pvolume Playback channels: Front Left - Front Right Limits: Playback 0 - 192 Mono: Front Left: Playback 152 [79%] [-20.00dB] Front Right: Playback 152 [79%] [-20.00dB] Simple mixer control 'DAC Double Fs',0 Capabilities: pswitch pswitch-joined Playback channels: Mono Mono: Playback [off] Simple mixer control 'DAC Mono Mix',0 Capabilities: pswitch pswitch-joined Playback channels: Mono Mono: Playback [off] Simple mixer control 'DAC Notch Filter',0 Capabilities: pswitch pswitch-joined Playback channels: Mono Mono: Playback [off] Simple mixer control 'DAC Soft Ramp',0 Capabilities: pswitch pswitch-joined Playback channels: Mono Mono: Playback [off] Simple mixer control 'DAC Soft Ramp Rate',0 Capabilities: volume volume-joined Playback channels: Mono Capture channels: Mono Limits: 0 - 4 Mono: 4 [100%] Simple mixer control 'DAC Source Mux',0 Capabilities: enum Items: 'LDATA TO LDAC, RDATA TO RDAC' 'LDATA TO LDAC, LDATA TO RDAC' 'RDATA TO LDAC, RDATA TO RDAC' 'RDATA TO LDAC, LDATA TO RDAC' Item0: 'LDATA TO LDAC, RDATA TO RDAC' Simple mixer control 'DAC Stereo Enhancement',0 Capabilities: volume volume-joined Playback channels: Mono Capture channels: Mono Limits: 0 - 7 Mono: 0 [0%] Simple mixer control 'Differential Mux',0 Capabilities: enum Items: 'lin1-rin1' 'lin2-rin2' 'lin1-rin1 with 20db Boost' 'lin2-rin2 with 20db Boost' Item0: 'lin1-rin1' Simple mixer control 'Digital Mic Mux',0 Capabilities: enum Items: 'dmic disable' 'dmic data at high level' 'dmic data at low level' Item0: 'dmic disable' Simple mixer control 'Headset Mic',0 Capabilities: pswitch pswitch-joined Playback channels: Mono Mono: Playback [off] Simple mixer control 'Left Headphone Mixer LLIN',0 Capabilities: pswitch pswitch-joined Playback channels: Mono Mono: Playback [off] Simple mixer control 'Left Headphone Mixer Left DAC',0 Capabilities: pswitch pswitch-joined Playback channels: Mono Mono: Playback [on] Simple mixer control 'Left Headphone Mux',0 Capabilities: enum Items: 'lin1-rin1' 'lin2-rin2' 'lin-rin with Boost' 'lin-rin with Boost and PGA' Item0: 'lin1-rin1' Simple mixer control 'Main Mic',0 Capabilities: pswitch pswitch-joined Playback channels: Mono Mono: Playback [on] Simple mixer control 'Receive PATH0 Source Select',0 Capabilities: enum Items: 'From SDI0' 'From SDI1' 'From SDI2' 'From SDI3' Item0: 'From SDI0' Simple mixer control 'Receive PATH1 Source Select',0 Capabilities: enum Items: 'From SDI0' 'From SDI1' 'From SDI2' 'From SDI3' Item0: 'From SDI1' Simple mixer control 'Receive PATH2 Source Select',0 Capabilities: enum Items: 'From SDI0' 'From SDI1' 'From SDI2' 'From SDI3' Item0: 'From SDI2' Simple mixer control 'Receive PATH3 Source Select',0 Capabilities: enum Items: 'From SDI0' 'From SDI1' 'From SDI2' 'From SDI3' Item0: 'From SDI3' Simple mixer control 'Right Headphone Mixer RLIN',0 Capabilities: pswitch pswitch-joined Playback channels: Mono Mono: Playback [off] Simple mixer control 'Right Headphone Mixer Right DAC',0 Capabilities: pswitch pswitch-joined Playback channels: Mono Mono: Playback [on] Simple mixer control 'Right Headphone Mux',0 Capabilities: enum Items: 'lin1-rin1' 'lin2-rin2' 'lin-rin with Boost' 'lin-rin with Boost and PGA' Item0: 'lin1-rin1' Simple mixer control 'Transmit SDO0 Source Select',0 Capabilities: enum Items: 'From PATH0' 'From PATH1' 'From PATH2' 'From PATH3' Item0: 'From PATH0' Simple mixer control 'Transmit SDO1 Source Select',0 Capabilities: enum Items: 'From PATH0' 'From PATH1' 'From PATH2' 'From PATH3' Item0: 'From PATH1' Simple mixer control 'Transmit SDO2 Source Select',0 Capabilities: enum Items: 'From PATH0' 'From PATH1' 'From PATH2' 'From PATH3' Item0: 'From PATH2' Simple mixer control 'Transmit SDO3 Source Select',0 Capabilities: enum Items: 'From PATH0' 'From PATH1' 'From PATH2' 'From PATH3' Item0: 'From PATH3' Simple mixer control 'hp switch',0 Capabilities: pswitch pswitch-joined Playback channels: Mono Mono: Playback [off] Simple mixer control 'spk switch',0 Capabilities: pswitch pswitch-joined Playback channels: Mono Mono: Playback [off] Running PulseAudio has no effect. Here's its config: rock5:~:# pulseaudio --dump-conf ### Read from configuration file: /etc/pulse/daemon.conf ### daemonize = no fail = yes high-priority = yes nice-level = -11 realtime-scheduling = yes realtime-priority = 5 allow-module-loading = yes allow-exit = yes use-pid-file = yes system-instance = no local-server-type = user cpu-limit = no enable-shm = yes flat-volumes = no rescue-streams = yes lock-memory = no exit-idle-time = 20 scache-idle-time = 20 dl-search-path = /usr/lib/pulse-16.1+dfsg1/modules default-script-file = /etc/pulse/default.pa load-default-script-file = yes log-target = log-level = notice resample-method = auto avoid-resampling = no enable-remixing = yes remixing-use-all-sink-channels = yes remixing-produce-lfe = no remixing-consume-lfe = no lfe-crossover-freq = 0 default-sample-format = s16le default-sample-rate = 44100 alternate-sample-rate = 48000 default-sample-channels = 2 default-channel-map = front-left,front-right default-fragments = 4 default-fragment-size-msec = 25 enable-deferred-volume = yes deferred-volume-safety-margin-usec = 8000 deferred-volume-extra-delay-usec = 0 shm-size-bytes = 0 log-meta = no log-time = no log-backtrace = 0 rlimit-fsize = -1 rlimit-data = -1 rlimit-stack = -1 rlimit-core = -1 rlimit-rss = -1 rlimit-as = -1 rlimit-nproc = -1 rlimit-nofile = 256 rlimit-memlock = -1 rlimit-locks = -1 rlimit-sigpending = -1 rlimit-msgqueue = -1 rlimit-nice = 31 rlimit-rtprio = 9 rlimit-rttime = 200000 Thanks!
  3. Hi again - I have tried Armbian_25.2.0-trunk.128_Rock-5-itx_bookworm_vendor_6.1.84_gnome-backported-mesa_desktop.img.xz, the latest ROOBI, and ubuntu-24.04-preinstalled-desktop-arm64-rock-5-itx.img.xz. I have had no better results than with Armbian_24.11.1_Rock-5-itx_bookworm_vendor_6.1.75_cinnamon-backported-mesa_desktop.img.xz. Should I go looking for kernel modules, or DE issues (and I am probably over my head here, but willing to try/help out)
  4. This is the image I used for the install: Armbian_24.11.1_Rock-5-itx_bookworm_vendor_6.1.75_cinnamon-backported-mesa_desktop.img.xz It is unclear which I should use from this list 🙂 (I am very familiar with Cinnamon): Armbian_25.2.0-trunk.128_Rock-5-itx_bookworm_vendor_6.1.84_gnome-backported-mesa_desktop.img.txt 19.3 KB 2024-12-06T09:40:44Z Armbian_25.2.0-trunk.128_Rock-5-itx_bookworm_vendor_6.1.84_gnome-backported-mesa_desktop.img.xz 1.34 GB 2024-12-06T09:40:17Z Armbian_25.2.0-trunk.128_Rock-5-itx_bookworm_vendor_6.1.84_gnome-backported-mesa_desktop.img.xz.asc 833 Bytes 2024-12-06T09:40:17Z Armbian_25.2.0-trunk.128_Rock-5-itx_bookworm_vendor_6.1.84_gnome-backported-mesa_desktop.img.xz.sha 219 Bytes 2024-12-06T09:40:16Z Armbian_25.2.0-trunk.128_Rock-5-itx_bookworm_vendor_6.1.84_gnome-backported-mesa_desktop.img.xz.torrent 111 KB 2024-12-06T09:40:16Z Armbian_25.2.0-trunk.128_Rock-5-itx_oracular_vendor_6.1.84_minimal.img.txt 19.2 KB 2024-12-06T09:51:54Z Armbian_25.2.0-trunk.128_Rock-5-itx_oracular_vendor_6.1.84_minimal.img.xz 226 MB 2024-12-06T09:51:25Z Armbian_25.2.0-trunk.128_Rock-5-itx_oracular_vendor_6.1.84_minimal.img.xz.asc 833 Bytes 2024-12-06T09:51:25Z Armbian_25.2.0-trunk.128_Rock-5-itx_oracular_vendor_6.1.84_minimal.img.xz.sha 187 Bytes 2024-12-06T09:51:25Z Armbian_25.2.0-trunk.128_Rock-5-itx_oracular_vendor_6.1.84_minimal.img.xz.torrent 21.6 KB 2024-12-06T09:51:24Z Armbian_25.2.0-trunk.128_Rock-5-itx_trixie_vendor_6.1.84_minimal.img.txt 19.2 KB 2024-12-06T09:31:00Z Armbian_25.2.0-trunk.128_Rock-5-itx_trixie_vendor_6.1.84_minimal.img.xz 245 MB 2024-12-06T09:30:51Z Armbian_25.2.0-trunk.128_Rock-5-itx_trixie_vendor_6.1.84_minimal.img.xz.asc 833 Bytes 2024-12-06T09:30:50Z Armbian_25.2.0-trunk.128_Rock-5-itx_trixie_vendor_6.1.84_minimal.img.xz.sha 183 Bytes 2024-12-06T09:30:50Z Armbian_25.2.0-trunk.128_Rock-5-itx_trixie_vendor_6.1.84_minimal.img.xz.torrent 23.1 KB 2024-12-06T09:30:49Z Perhaps I should just chill, keep upgrading, and carry on? I don't want to consume too much time when Armbian is such a HUGE undertaking...
  5. ok - so I am daft.. This is the output when I select the back panel and the audio is plugged in: https://paste.next.armbian.com/bikesavono
  6. thank you, idk about this... https://paste.next.armbian.com/enazuhetan it is worth noting that atm I had disconnected the external audio. here is the output with the back panel audio plugged in: https://paste.next.armbian.com/origizihuw Thanks!
  7. Hi, I can not get the back panel audio working, the HDMI analog audio to my display works, but changing the output to Analog out is not working. Any suggestions as to where I can start to troubleshoot? Thanks!
