enable i2s on Orange pi zero 2w
Hell Hello, No, sorry, I don't have any news from my side. I'm taking a break from this project but I plan to get back to it soon. If you get any progress, let me know, I'm interested! o, No, sorry, I don't have any news on my side. I'm making a break on this project but will go back to find a solution soon. If you get some interesting steps let me know!
Ok, thank you for your help. I will edit my first post to complete with my final goal. I am still a beginner in devie tree. Here is where I am from now : According to the h616 user manual : https://linux-sunxi.org/images/2/24/H616_User_Manual_V1.0_cleaned.pdf The Soc have an audio hub that manage various audio modules (I2s, PCM, DAM, etc). This AHUB is defined with base adress 0x05097000 In the current armbian dts of the Orange pi zero 2w, I see that ahub1_mach, ahub1_plat and ahub_dam_plat are defined and disable. I2s isn't defined. So I first add I2s and attribute pinout : fragment@3 { target = <&pio>; __overlay__ { i2s_pins: pinctrl-i2s { pins = "PI0", "PI1", "PI2", "PI3", "PI4"; function = "i2s"; drive-strength = <8>; }; }; }; Then I add reference to this i2s in the audio hub node : fragment@5 { target-path = "/soc/ahub1_plat"; __overlay__ { status = "okay"; reg = <0x05097200 0x100>; pinctrl-0 = <&i2s_pins>; pinctrl-names = "default"; soundcard-mach,format = "i2s"; soundcard-mach,name = "i2s_soundcard"; }; }; => According to the user manual i2s adress register is 0x05097000 + 0x0200 = 0x05097200 After reboot with my overlay, If I list pin muxing : sudo cat /sys/kernel/debug/pinctrl/300b000.pinctrl/pinmux-pins I get : pin 256 (PI0): UNCLAIMED pin 257 (PI1): UNCLAIMED pin 258 (PI2): UNCLAIMED pin 259 (PI3): UNCLAIMED pin 260 (PI4): UNCLAIMED I am stuck with this unclaimed pins so if one of you have advice or idea on this, it will be cool ! Thank you
Oh, sorry, it's a big mistake, I meant armbian! Many thanks to you, it seems to pull the right kernel. But effectively, I not sure this the right method for my final goal. My goal is to add a device tree overlay to enable i2s on my Orange pi zero 2w board. And then a wm8960 codec For now I stuck with an unclaimed pins. I found a guy that successively make it working but with an old kernel so I would try with same old kernel, but it seems too much complicated. Working overlay : https://github.com/mamin27/H616-mangopi/issues/8
Thank you for your help. My board is an orange pi zero 2w, so my SoC is an sun50i. But if I list the .conf of sun50i, I have: sun50iw1.conf, sun50iw2.conf, sun50iw6.conf, sun50iw9-bpi.conf, sun50iw9.conf but this .conf doesn't have KERNELSOURCE or similar to specify kernel source and version.
- enable i2s on Orange pi zero 2w
GuillaumeB
