Skidd
  1. I know this isn't the CORRECT fix. But, I managed to hack a working image by modifying the file kernel-deb.sh At line 52, I changed declare kernel_version_family="${kernel_version}-${BRANCH}-${LINUXFAMILY}" to declare kernel_version_family="${kernel_version}-rt47-${BRANCH}-${LINUXFAMILY}" The board booted, and uname shows the kernel I expected $ uname -a Linux orangepizero2w 6.6.65-rt47-current-sunxi64 #7 SMP PREEMPT_RT Wed Dec 11 15:13:43 UTC 2024 aarch 64 GNU/Linux
  2. In short, I'm trying to build a FULLY-PREEMPT-REALTIME system to run on my Orange Pi Zero 2W. I used this post as a reference, and got quite far. But, I'm stuck on something that I believe I undestand, but don't know how to resolve. I don't believe this is a probleme specific to my board though. What I've done so far with success is both install and run a pre-built Armbian Image on this board, as well as build my own image and run it. Both work perfectly. Now, I'm attempting to apply the RT patch and build a fresh image (or even just a Kernel) to get the FULL REALTIME kernel support working. However, the build system fails after the kernel is built sucesfully, as it is unable to find the resulting kernel image generated. I belive the issue is simply that when the RT .patch is applied and configured to the kernel, it builds a kernel file with an alterered filename. Instead of 6.6.65-current-sunxi64 It creates 6.6.65-rt47-current-sunxi64 As a result, the build process for the kernel stage fails as it's unable to find the file it is expecting to find. Here is what I have done, and what outputs I am finding. As stated, It was a success with A locally built clean Armbian ./compile.sh BOARD=orangepizero2w BRANCH=current RELEASE=bookworm BUILD_MINIMAL=yes BUILD_DESKTOP=no KERNEL_CONFIGURE=no AUFS=no KERNELBRANCH='tag:v6.6.65' System booted up and ran as normal. $ uname -a inux orangepizero2w 6.6.65-current-sunxi64 #2 SMP Wed Dec 11 15:13:43 UTC 2024 aarch64 GNU/Linux I then attempted to apply the PREEMPT_RT kernel patch. download and gunzip https://cdn.kernel.org/pub/linux/kernel/projects/rt/6.6/patch-6.6.65-rt47.patch.gz into the directory userpatches/kernel/archive/sunxi-6.6 Then a kernel-configure step Worth noting that I do see this patch file applied in the output of the following command. ./compile.sh BOARD=orangepizero2w BRANCH=current RELEASE=bookworm KERNELBRANCH='tag:v6.6.65' kernel-config Where I proceeded to enable the full REALTIME kernel (4th option). General setup -> Preemption Mode -> Fully Preemptible Kernel (Real-Time) Finally followed with a compile command. ./compile.sh BOARD=orangepizero2w BRANCH=current RELEASE=bookworm BUILD_MINIMAL=yes BUILD_DESKTOP=no KERNEL_CONFIGURE=no AUFS=no KERNELBRANCH='tag:v6.6.65' The part of the build output that I beleive is relevant is this. It shows the failure, and what I believe is an indication of why it fails. It appears that the build script it is not aware of needing to find the file name that has the rt47 portion. 🐳|🔨] INSTALL /armbian/.tmp/work-3b1e65cb-74c9-47f6-aa6c-d7787497b9b0/kernel_dest_install_dir-44x4J/dtbs/allwinner/overlay/sun50i-h616-i2c1-pi.dtbo [🐳|🔨] INSTALL /armbian/.tmp/work-3b1e65cb-74c9-47f6-aa6c-d7787497b9b0/kernel_dest_install_dir-44x4J/dtbs/allwinner/overlay/sun50i-h616-i2c2-pi.dtbo [🐳|🔨] INSTALL /armbian/.tmp/work-3b1e65cb-74c9-47f6-aa6c-d7787497b9b0/kernel_dest_install_dir-44x4J/dtbs/allwinner/overlay/sun50i-h616-gpu.dtbo [🐳|🔨] INSTALL /armbian/.tmp/work-3b1e65cb-74c9-47f6-aa6c-d7787497b9b0/kernel_dest_install_dir-44x4J/dtbs/allwinner/overlay/sun50i-a64-fixup.scr [🐳|🔨] INSTALL /armbian/.tmp/work-3b1e65cb-74c9-47f6-aa6c-d7787497b9b0/kernel_dest_install_dir-44x4J/dtbs/allwinner/overlay/sun50i-h5-fixup.scr [🐳|🔨] INSTALL /armbian/.tmp/work-3b1e65cb-74c9-47f6-aa6c-d7787497b9b0/kernel_dest_install_dir-44x4J/dtbs/allwinner/overlay/sun50i-h6-fixup.scr [🐳|🔨] INSTALL /armbian/.tmp/work-3b1e65cb-74c9-47f6-aa6c-d7787497b9b0/kernel_dest_install_dir-44x4J/dtbs/allwinner/overlay/sun50i-h616-fixup.scr [🐳|🔨] INSTALL /armbian/.tmp/work-3b1e65cb-74c9-47f6-aa6c-d7787497b9b0/kernel_dest_install_dir-44x4J/dtbs/allwinner/overlay/README.sun50i-a64-overlays [🐳|🔨] INSTALL /armbian/.tmp/work-3b1e65cb-74c9-47f6-aa6c-d7787497b9b0/kernel_dest_install_dir-44x4J/dtbs/allwinner/overlay/README.sun50i-h5-overlays [🐳|🔨] make[1]: Nothing to be done for 'install'. [🐳|🔨] make: Nothing to be done for 'install'. [🐳|🌱] Kernel built in [ 95 seconds - 6.6.65-sunxi64 ] [🐳|🌱] Packaging kernel [ sunxi64 linux-sunxi64-current ] [🐳|🌱] Kernel .deb package version [ 6.6.65-S943e-Dfa7d-P3e46-Caa1fH5c21-HK01ba-Vc222-B59f0-R448a ] [🐳|🌱] Packaging linux-image [ sunxi64 linux-sunxi64-current ] [🐳|🔨] [ 26M] /armbian/.tmp/work-3b1e65cb-74c9-47f6-aa6c-d7787497b9b0/kernel_dest_install_dir-44x4J/image/boot [🐳|🔨] ├── [215K] config-6.6.65-rt47-current-sunxi64 [🐳|🔨] ├── [3.4M] System.map-6.6.65-rt47-current-sunxi64 [🐳|🔨] └── [ 22M] vmlinuz-6.6.65-rt47-current-sunxi64 [🐳|🔨] [🐳|🔨] 26M used in 0 directories, 3 files [🐳|🌱] Kernel-built image filetype [ vmlinuz-6.6.65-current-sunxi64: cannot open `/armbian/.tmp/work-3b1e65cb-74c9-47f6-aa6c-d7787497b9b0/kernel_dest_install_dir-44x4J/image/boot/vmlinuz-6.6.65-current-sunxi64' (No such file or directory) ] [🐳|🔨] ls: cannot access '/armbian/.tmp/work-3b1e65cb-74c9-47f6-aa6c-d7787497b9b0/kernel_dest_install_dir-44x4J/image/boot/vmlinuz-6.6.65-current-sunxi64': No such file or directory [🐳|🔨] /armbian/.tmp/work-3b1e65cb-74c9-47f6-aa6c-d7787497b9b0/kernel_dest_install_dir-44x4J/image/boot: [🐳|🔨] total 26220 [🐳|🔨] drwxrwxr-x 2 root root 100 Dec 30 17:08 . [🐳|🔨] drwxrwxr-x 3 root root 60 Dec 30 17:07 .. [🐳|🔨] -rw-rw-r-- 1 root root 220621 Dec 30 17:08 config-6.6.65-rt47-current-sunxi64 [🐳|🔨] -rw-rw-r-- 1 root root 3564498 Dec 30 17:08 System.map-6.6.65-rt47-current-sunxi64 [🐳|🔨] -rw-rw-r-- 1 root root 23056392 Dec 30 17:08 vmlinuz-6.6.65-rt47-current-sunxi64 [🐳|💥] Error 2 occurred in main shell [ at /armbian/lib/functions/logging/runners.sh:211 run_host_command_logged_raw() --> lib/functions/logging/runners.sh:211 run_host_command_logged() --> lib/functions/logging/runners.sh:193 kernel_package_callback_linux_image() --> lib/functions/compilation/kernel-debs.sh:221 create_kernel_deb() --> lib/functions/compilation/kernel-debs.sh:131 prepare_kernel_packaging_debs() --> lib/functions/compilation/kernel-debs.sh:72 kernel_package() --> lib/functions/compilation/kernel.sh:248 do_with_hooks() --> lib/functions/general/extensions.sh:567 do_with_logging() --> lib/functions/logging/section-logging.sh:81 kernel_prepare_build_and_package() --> lib/functions/compilation/kernel.sh:171 compile_kernel() --> lib/functions/compilation/kernel.sh:100 artifact_kernel_build_from_sources() --> lib/functions/artifacts/artifact-kernel.sh:240 artifact_build_from_sources() --> lib/functions/artifacts/artifacts-obtain.sh:34 obtain_complete_artifact() --> lib/functions/artifacts/artifacts-obtain.sh:280 build_artifact_for_image() --> lib/functions/artifacts/artifacts-obtain.sh:392 main_default_build_packages() --> lib/functions/main/build-packages.sh:106 full_build_packages_rootfs_and_image() --> lib/functions/main/default-build.sh:31 do_with_default_build() --> lib/functions/main/default-build.sh:42 cli_standard_build_run() --> lib/functions/cli/cli-build.sh:25 armbian_cli_run_command() --> lib/functions/cli/utils-cli.sh:136 cli_entrypoint() --> lib/functions/cli/entrypoint.sh:176 main() --> compile.sh:50 ] [🐳|💥] Cleaning up [ please wait for cleanups to finish ] [🐳|🌿] ANSI log file built; inspect it by running: [ less -RS output/logs/log-build-3b1e65cb-74c9-47f6-aa6c-d7787497b9b0.log.ans ] [🐳|🌿] Share log manually (or SHARE_LOG=yes): [ curl --data-binary @output/logs/log-build-3b1e65cb-74c9-47f6-aa6c-d7787497b9b0.log.ans https://paste.armbian.com/log ] [💥] -------------Docker run failed after 152s-------------------------- [ 🐳 failed ] [🌱] Cleaning up [ please wait for cleanups to finish ] ~/devel/personal/Armbian/build │ main !1 Thanks for any help with this. I hope I've provided enough information to make sense of what I'm attempting to do.
