x96q h313
Hello @Nick A U-Boot SPL 2025DRAM:testing 32-bit widtDRAM:Store cfg DRAM:1st writing pattern DRAM:detecting column address bits detected 10 columns DRAM:restore cfg DRAM:reconfigure for all active rows DRAM:store cfg DRAM:2nd writing pattern DRAM:detecting row address bits detected 15 rows DRAM:restoring cfg DRAM:end of auto detect dram size MBUS port 0 cfg0 0100000d cfg1 00640080 MBUS port 1 cfg0 06000009 cfg1 01000578 MBUS port 2 cfg0 0200000d cfg1 00600100 MBUS port 3 cfg0 01000009 cfg1 00500064 MBUS port 4 cfg0 20000209 cfg1 1388157c MBUS port 5 cfg0 00640209 cfg1 00200040 MBUS port 6 cfg0 00640209 cfg1 00200040 MBUS port 8 cfg0 01000009 cfg1 00400080 MBUS port 11 cfg0 01000009 cfg1 00640080 MBUS port 14 cfg0 04000009 cfg1 00400100 MBUS port 16 cfg0 2000060d cfg1 09600af0 MBUS port 21 cfg0 0800060d cfg1 02000300 MBUS port 22 cfg0 01000009 cfg1 00640080 MBUS port 25 cfg0 0064000f cfg1 00200040 MBUS port 26 cfg0 20000209 cfg1 1388157c MBUS port 37 cfg0 01000009 cfg1 00400080 MBUS port 38 cfg0 00640209 cfg1 00200040 MBUS port 39 cfg0 20000209 cfg1 1388157c MBUS port 40 cfg0 00640209 cfg1 00200040 2048 MiB Trying to boot from MMC1 NOTICE: BL31: v2.10.2(debug):armbian OTICE: BL31: Built : 17:39:39, Mar 4 2025 NOTICE: BL31: Detected Allwinner H616 SoC (1823) NOTICE: BL31: Found U-Boot DTB at 0x4a092eb0, model: Q1 H616 INFO: ARM GICv2 driver initialized INFO: Configuring SPC Controller INFO: PMIC: Probing AXP305 on RSB ERROR: RSB: set run-time address: 0x10003 INFO: Could not init RSB: -65539 INFO: BL31: Platform setup done INFO: BL31: Initializing runtime services INFO: BL31: cortex_a53: CPU workaround for erratum 855873 was applied INFO: BL31: cortex_a53: CPU workaround for erratum 1530924 was applied INFO: PSCI: Suspend is unavailable INFO: BL31: Preparing for EL3 exit to normal world INFO: Entry point address = 0x4a000000 INFO: SPSR = 0x3c9 INFO: Changed devicetree. ns16550_serial serial@5000000: pinctrl_select_state_full: uclass_get_device_by_phandle_id: err=-19
x96q h313
@Nick A U-Boot SPL 2024.01-armbian-2024.01-S866c-Pf4aa-H8869-V3382-Bb703-R448a (Mar 03 2025 - 00:27:16 +0000) DRAM base address is defined as 0x40000000 DRAM has 15 b/raw, 10 b/col, 4 B/width, 2 #rank and 8 #bank DRAM top address must be less than 0x80000000 DRAM top address must be less than 0x60000000 DRAM: 1536 MiB Trying to boot from MMC1 NOTICE: BL31: v2.10.2(debug):armbian NOTICE: BL31: Built : 00:14:31, Mar 3 2025 NOTICE: BL31: Detected Allwinner H616 SoC (1823) NOTICE: BL31: Found U-Boot DTB at 0x4a094198, model: Transpeed 8K618-T INFO: ARM GICv2 driver initialized INFO: Configuring SPC Controller INFO: PMIC: Probing AXP305 on RSB ERROR: RSB: set run-time address: 0x10003 INFO: Could not init RSB: -65539 INFO: BL31: Platform setup done INFO: BL31: Initializing runtime services INFO: BL31: cortex_a53: CPU workaround for erratum 855873 was applied INFO: BL31: cortex_a53: CPU workaround for erratum 1530924 was applied INFO: PSCI: Suspend is unavailable INFO: BL31: Preparing for EL3 exit to normal world INFO: Entry point address = 0x4a000000 INFO: SPSR = 0x3c9 INFO: Changed devicetree. ns16550_serial serial@5000000: pinctrl_select_state_full: uclass_get_device_by_phandle_id: err=-19 U-Boot 2024.01-armbian-2024.01-S866c-Pf4aa-H8869-V3382-Bb703-R448a (Mar 03 2025 - 00:27:16 +0000) Allwinner Technology CPU: Allwinner H616 (SUN50I) Model: Transpeed 8K618-T DRAM: 2 GiB (effective 0 Bytes)
x96q h313
@Nick A U-Boot SPL 2024.01-armbian-2024.01-S866c-Pd8a4-Ha9af-V80bb-Bda0a-R448a (Jul 27 2024 - 16:54:35 -0400) DRAM:This DRAM setup is currently not supported. resetting ...
x96q h313
@Nick A When boot Android without SD [286]HELLO! SBOOT is starting! [289]sboot commit : 749c1f9a [292]set pll start [295]periph0 has been enabled [298]set pll end [300]unknow PMU [301]unknow PMU [304]tPMU: 0x9c [305]PMU: AXP1530 [307]dram return write ok [310]board init ok [312]try to probe rtc region [314]DRAM BOOT DRIVE INFO: V0.651 [318]the chip id is 0x5c00 [320]chip id check OK [324]DRAM_VCC set to 1200 mv [327]DRAM CLK =648 MHZ [329]DRAM Type =7 (3:DDR3,4:DDR4,7:LPDDR3,8:LPDDR4) [337]Actual DRAM SIZE =1536 M [340]DRAM SIZE =1536 MBytes, para1 = 30fa, para2 = 6001000, dram_tpr13 = 26061 [349]DRAM simple test OK. [351]rtc standby flag is 0x0, super standby flag is 0x0 [357][mmc]: mmc driver ver 2021-10-12 [361][mmc]: b mmc 2 bias 4 [369][mmc]: Wrong media type 0x0, but host sdc2, try mmc first [375][mmc]: ***Try MMC card 2*** [400][mmc]: RMCA OK! [402][mmc]: wrong freq 2 at spd md 2 [406][mmc]: MMC 5.0 [408][mmc]: HSSDR52/SDR25 8 bit [411][mmc]: 50000000 Hz [414][mmc]: 7456 MB [416][mmc]: ***SD/MMC 2 init OK!!!*** [506]read toc1 from emmc 32800 sector [510]OLD version: 0.0 [512]NEW version: 0.0 [588]load rotpk hash [651]load monitor-key hash [654]load monitor hash [859]load boot-key hash [862]load boot hash [928]load vbmeta-key hash [930]load vbmeta hash [998]load recovery-key hash [1001]load recovery hash [1004]monitor entry=0x48000000 [1007]uboot entry=0x4a000000 [1010]optee entry=0x48600000 [1013]tunning data addr:0x4a0003e8 [1019]run out of boot0 NOTICE: BL3-1: v1.0(debug):05d6c57 NOTICE: BL3-1: Built : 13:35:35, 2021-10-28 NOTICE: BL3-1 commit: 8 NOTICE: cpuidle init version V1.0 NOTICE: secure os exist MESSAGE: [0x0] TEE-CORE: OP-TEE version: 81ab7a47 #1 2020年 05月 06日 星期三 02:40:04 UTC arm NOTICE: BL3-1: Preparing for EL3 exit to normal world NOTICE: BL3-1: Next image address = 0x4a000000 NOTICE: BL3-1: Next image spsr = 0x1d3 U-Boot 2018.05-g23fdfbb-dirty (Oct 08 2024 - 14:18:27 +0800) Allwinner Technology [01.115]CPU: Allwinner Family [01.118]Model: sun50iw9 I2C: ready [01.122]DRAM: 1.5 GiB [01.125]Relocation Offset is: 55ebf000 [01.167]secure enable bit: 1 [01.170]pmu_axp152_probe pmic_bus_read fail [01.174]PMU: AXP1530 [01.179]CPU=1008 MHz,PLL6=600 Mhz,AHB=200 Mhz, APB1=100Mhz MBus=400Mhz [01.187]drv_disp_init [01.217]__clk_enable: clk is null. [01.223]drv_disp_init finish [01.226]gic: sec monitor mode [01.256]flash init start [01.258]workmode = 0,storage type = 2 [01.261]MMC: 2 [01.263][mmc]: mmc driver ver uboot2018:2021-07-19 14:09:00 [01.269][mmc]: get sdc_type fail and use default host:tm4. [01.280][mmc]: get sdc2 sdc_dis_host_caps 0x1c0. [01.284][mmc]: SUNXI SDMMC Controller Version:0x40502 [01.309][mmc]: Best spd md: 1-HSSDR52/SDR25, freq: 2-50000000, Bus width: 8 [01.315]sunxi flash init ok [01.319]Loading Environment from SUNXI_FLASH... OK secure storage read hdcpkey fail [01.333]secure storage read hdcpkey fail with:-1 01.340]secure storage read widevine fail with:-1 [01.345]usb burn from boot delay time 0 weak:otg_phy_config [01.358]usb prepare ok [02.162]overtime [02.166]do_burn_from_boot usb : no usb exist FAT: Misaligned buffer address (9be7b6d8) 32 bytes read in 4 ms (7.8 KiB/s) tcon_de_attach:de=0,tcon=2[02.304]boot_gui_init:finish [02.307]bmp_name=bootlogo.bmp 2764856 bytes read in 60 ms (43.9 MiB/s) [02.388][mmc]: delete mmc-hs400-1_8v from dtb [02.392][mmc]: delete mmc-hs200-1_8v from dtb [02.396][mmc]: delete mmc-ddr-1_8v from dtb [02.400][mmc]: get max-frequency ok 50000000 Hz [02.408]update dts ** Unrecognized filesystem type ** [02.418]load file(ULI/factory/rootwait init.txt) error. ** Unrecognized filesystem type ** [02.432]load file(ULI/factory/snum.txt) error. [02.436]name in map mac ** Unrecognized filesystem type ** [02.448]load file(ULI/factory/wifi_mac.txt) error. ** Unrecognized filesystem type ** [02.461]load file(ULI/factory/bt_mac.txt) error. ** Unrecognized filesystem type ** [02.475]load file(ULI/factory/selinux.txt) error. ** Unrecognized filesystem type ** [02.489]load file(ULI/factory/specialstr.txt) error. [02.501]update part info [02.523]update bootcmd [02.525]No ethernet found. Hit any key to stop autoboot: 0 [03.043]not supported key [03.045]actual n size:1000, e:10001 valid CACHE: Misaligned operation at range [44ffffe0, 462a5800] [03.221]Starting kernel ... [03.223][mmc]: mmc exit start [03.242][mmc]: mmc 2 exit ok [ 0.000000] Booting Linux on physical CPU 0x0 [ 0.000000] Linux version 4.9.170 (cmj@a-X11DPi-N-T) (gcc version 5.3.1 20160412 (Linaro GCC 5.3-2016.05) ) #1 SMP PREEMPT Tue Oct 8 14:19:52 CST 2024 [ 0.000000] Boot CPU: AArch64 Processor [410fd034] [ 0.000000] bootconsole [earlycon0] enabled [ 0.027910] BOOTEVENT: 27.893457: ON [ 0.262939] sunxi_i2c_probe()2209 - [i2c3] warning: failed to get regulator id [ 0.264028] sunxi_i2c_probe()2209 - [i2c5] warning: failed to get regulator id [ 0.265360] axp2101-regulator axp2101-regulator.0: Setting DCDC frequency for unsupported AXP variant [ 0.265445] axp2101-regulator axp2101-regulator.0: Error setting dcdc frequency: -22 [ 0.300863] [ac200] get ave_regulator_name failed! [ 0.301454] [ac200] pwm enable [ 0.395525] failed to get standby led pin assign [ 0.395577] f�[ 0.402603] uart uart1: get regulator failed [ 0.435522] [NAND][NE] Not found valid nand node on dts [ 0.444120] sunxi-wlan soc@03000000:wlan: get gpio chip_en failed [ 0.451100] sunxi-wlan soc@03000000:wlan: get gpio power_en failed [ 0.585049] hci: request ohci1-controller gpio:232 [ 0.777501] axp2101_pek: axp2101-pek can not register without irq [ 0.788132] sunxi_ir_startup: get ir protocol failed [ 0.796693] VE: get debugfs_mpp_root is NULL, please check mpp [ 0.796693] [ 0.804950] VE: sunxi ve debug register driver failed! [ 0.804950] [ 0.822760] mmc:failed to get gpios [ 0.904232] mmc:failed to get gpios [ 0.943193] FD655: Fd655 Driver init. [ 0.947785] FD655: fd655_driver_probe [ 0.952035] FD655: fd655_driver_probe [ 0.956716] FD655: register_fd655_driver: Successed to add fd655 module [ 0.957064] sunxi-mmc sdc1: smc 2 p1 err, cmd 52, RTO !! [ 0.970680] FD655: ====================Command opne in probe============= [ 0.979843] FD655: ====================Display boot in probe============= [ 0.987695] gpio user platform_driver_register sucess [ 0.996873] sunxi-mmc sdc1: smc 2 p1 err, cmd 52, RTO !! [ 1.007359] sunxi-mmc sdc1: smc 2 p1 err, cmd 8, RTO !! [ 1.013525] failed get gpio-spdif gpio from dts,spdif_gpio:-2 [ 1.023466] [audio-codec]dachpf_cfg configurations missing or invalid. [ 1.030901] lineout_vol:26, linein_gain:3, fmin_gain:3, digital_vol:0, adcdrc_cfg:0, adchpf_cfg:0, dacdrc_cfg:0, dachpf_cfg:0, ramp_func_used:1, pa_msleep_time:160, pa_ctl_level:0, gpio-spk:0 [ 1.055105] sndhdmi sndhdmi: ASoC: CPU DAI (null) not registered [ 1.061916] sndhdmi sndhdmi: snd_soc_register_card() failed: -517 [ 1.075611] sunxi-ahub-cpudai 5097000.cpudai3-controller: ahub cpudai id invalid [ 1.110982] ERROR: pinctrl_get for HDMI2.0 DDC fail [ 1.122002] tv_probe()1435 - of_property_read_string tv_power failed! [ 1.204673] cpu cpu1: opp_list_debug_create_link: Failed to create link [ 1.212222] cpu cpu1: _add_opp_dev: Failed to register opp debugfs (-12) [ 1.219828] cpu cpu2: opp_list_debug_create_link: Failed to create link [ 1.227283] cpu cpu2: _add_opp_dev: Failed to register opp debugfs (-12) [ 1.234875] cpu cpu3: opp_list_debug_create_link: Failed to create link [ 1.242339] cpu cpu3: _add_opp_dev: Failed to register opp debugfs (-12) [ 1.835468] selinux: avc: denied { set } for scontext=u:r:vendor_init:s0 tcontext=u:object_r:default_prop:s0 tclass=property_service permissive=1 [ 1.835468] [ 1.853641] selinux: avc: denied { set } for scontext=u:r:vendor_init:s0 tcontext=u:object_r:dalvik_prop:s0 tclass=property_service permissive=1 [ 1.853641] [ 2.712388] FAT-fs (mmcblk0p15): bogus number of reserved sectors console:/ $ [ 4.782896] apexd: Failed to walk /product/apex : Can't open /product/apex for reading : No such file or directory Gatekeeper_TA_CreateEntryPoint [ 6.847852] selinux: avc: denied { set } for property=sys.s[ 26.016698] SSV6XXX_SDIO mmc2:0001:1: vendor = 0x3030 device = 0x3030 [ 26.039197] SSV6XXX_SDIO mmc2:0001:1: dataIOPort 0x10000 regIOPort 0x10020 [ 26.052393] sunxi-mmc sdc1: smc 2 p1 err, cmd 52, RE RCE !! [ 26.094556] SSV6XXX_SDIO mmc2:0001:1: dataIOPort 0x10000 regIOPort 0x10020 [ 26.133735] SSV6XXX HCI TX Task started. [ 26.214299] Enable HCI TX aggregation [ 27.657092] SSV WLAN driver SSV6006C: Set new macaddr [ 27.665106] SSV WLAN driver SSV6006C: VIF 34:17:36:33:73:fc of type 2 is added. [ 29.193481] audit: rate limit exceeded
x96q h313
@Nick A U-Boot SPL 2024.01-armbian-2024.01-S866c-P7ea0-Ha9af-V6d37-Bda0a-R448a (Mar 02 2025 - 00:01:40 +0100) DRAM base address is defined as 0x40000000 DRAM has 15 b/raw, 10 b/col, 4 B/width, 2 #rank and 8 #bank DRAM top address must be less than 0x80000000 DRAM top address must be less than 0x60000000 DRAM: 1536 MiB Trying to boot from MMC1 NOTICE: BL31: v2.10.2(debug):armbian NOTICE: BL31: Built : 23:44:48, Mar 1 2025 NOTICE: BL31: Detected Allwinner H616 SoC (1823) NOTICE: BL31: Found U-Boot DTB at 0x4a0ae700, model: hechuang,x96-q LPDDR3 v1.3 INFO: ARM GICv2 driver initialized INFO: Configuring SPC Controller INFO: PMIC: Probing AXP305 on RSB ERROR: RSB: set run-time address: 0x10003 INFO: Could not init RSB: -65539 INFO: BL31: Platform setup done INFO: BL31: Initializing runtime services INFO: BL31: cortex_a53: CPU workaround for erratum 855873 was applied INFO: BL31: cortex_a53: CPU workaround for erratum 1530924 was applied INFO: PSCI: Suspend is unavailable INFO: BL31: Preparing for EL3 exit to normal world INFO: Entry point address = 0x4a000000 INFO: SPSR = 0x3c9 INFO: Changed devicetree. ns16550_serial serial@5000000: pinctrl_select_state_full: uclass_get_device_by_phandle_id: err=-19 U-Boot 2024.01-armbian-2024.01-S866c-P7ea0-Ha9af-V6d37-Bda0a-R448a (Mar 02 2025 - 00:01:40 +0100) Allwinner Technology CPU: Allwinner H616 (SUN50I) Model: hechuang,x96-q LPDDR3 v1.3 DRAM: 2 GiB (effective 0 Bytes)
x96q h313
Hello @Nick A thanks, i compiled with the patch. But I have to apply the modification "https://github.com/armbian/build/issues/7048" #chroot_sdcard debsums --silent Otherwise I get the errors: [💥] Error context msg [ Check MD5 sum of installed packages failed ] [💥] Cleaning up [ please wait for cleanups to finish ] The SD card does not boot, the blue LED does not light up, after 7-8 seconds i have a consumption of 0.021A less than 1 second and 0. Without the SD card BOOT well on Android TV. I tried 2 different SD cards, with BelenaEtcher and Rufus. Can @rafman or @eibrog share their img please.
x96q h313
Hello everyone, I have an ATV Q1 V3.0 box running Android TV 10. Some people have put img with secure boot, but all the links are expired. Can someone provide a link for an img with secure boot please ? Thanks.
Cesar93600
