Banana Pi M1 can not run in Armbian Linux v6.6 (problem the device turns off)
The SD card problem is ruled out since I tested another system on the same card and there is no problem it works perfectly example image, 2022-04-17-ubuntu-16.04-mate-desktop-mpv-1080p-bpi-m1-m1p-r1-sd-emmc.img . Other systems like lakkaTv also work, I tried with several USB power adapters and it only generates problems with modern versions of Armbian
I have a big problem with the latest Armbian images, the problem not only persists with the latest versions, with the previous one the same thing happened to me with the old Ubuntu images, it works without problems with the old kernel, I have a video published with the problem since it works but at certain times the device turns off and does not turn on a single LED light until I reconnect it, I thought it was a problem with the power supply but not with the old Ubuntu images it works and even with the game emulators of the lakka-tv image, so I came to the conclusion that the hardware is in good condition, therefore check what the fault could be because the computer usually turns off. I leave the link of the video it is in Spanish, sorry . HARDWARE: Banana Pi M1
- Ubuntu 24.04 (Noble) and Orange Pi Zero 3 soundcard output problem!
Hello, I have problems with the armbian distributions on my orange pi zero 3 because I can't even use chatgpt to activate the sound card on the expansion board that comes as an accessory for the orange pi zero 3. I'm referring to the board that has two USB outputs and an audio jack port that I think is also a video port, but I can't get sound out of that port, only sound comes out of the HDMI port. It's a real mystery since there's no problem with the other distributions, but with armbian I can't get that audio output port to work. If you can help me please, I've tried a number of things and I can't get it to work.
