Rockpi4B reboot loop - seems homeassistant and Zigbee2mqtt and USB related
Well I tried everything to make it work, including switching from PoE to a proven USB power supply, nothing worked. The only thing that worked is flashing back the latest Radxa bullseye image with 5.10.110 kernel, and upgrading to bookworm. I have a lot of errors at boot, so I might consider updating the kernel at some point, but I have absolutely no idea how to do that without flashing a new image. Considering 5.10.110 is the last kernel available from Radxa, I think I'm stuck... I suppressed the radxa apt in the sources.list as there is no bookworm apt, only bullseye. Could I still use the bullseye radxa apt with a bookworm debian? [ 59.024477] ramoops ramoops: failed to locate DT /reserved-memory resource [ 59.084556] fiq_debugger fiq_debugger.0: IRQ fiq not found [ 59.084581] fiq_debugger fiq_debugger.0: IRQ wakeup not found [ 59.084597] fiq_debugger_probe: could not install nmi irq handler [ 60.711536] rockchip-usb2phy ff770000.syscon:usb2-phy@e450: IRQ index 0 not found [ 60.714528] rockchip-usb2phy ff770000.syscon:usb2-phy@e460: IRQ index 0 not found [ 60.723981] rkvdec_init:1230: failed on clk_get clk_hevc_cabac [ 60.724074] mpp_rkvdec ff660000.rkvdec: shared_video_hevc_cabac is not found! [ 60.724090] rkvdec_init:1261: No hevc cabac reset resource define [ 60.746975] rockchip-vop ff8f0000.vop: missing rockchip,grf property [ 60.747264] rockchip-vop ff900000.vop: missing rockchip,grf property [ 60.750685] no ATF memory for init [ 60.763340] no ATF memory for init [ 60.767736] rk_gmac-dwmac fe300000.ethernet: cannot get clock clk_mac_speed [ 61.067311] vcc_cam: failed to get the current voltage: -EPROBE_DEFER [ 61.067671] vcc_mipi: failed to get the current voltage: -EPROBE_DEFER [ 61.090893] vcc_sdio: unsupportable voltage range: 3300000-3000000uV [ 61.094146] rockchip-dmc dmc: Failed to get ddr_leakage [ 61.094884] rockchip-dmc dmc: could not find power_model node [ 61.099683] rksfc_base v1.1 2016-01-08 [ 61.695258] rockchip-pcie f8000000.pcie: PCIe link training gen1 timeout! [ 61.695324] rockchip-pcie f8000000.pcie: deferred probe failed [ 69.217783] rk-multicodecs es8316-sound: ASoC: Property 'rockchip,audio-routing' does not exist or its length is not even [ 69.309154] rk-multicodecs es8316-sound: ASoC: Property 'rockchip,audio-routing' does not exist or its length is not even [ 69.456788] debugfs: File 'Left Hp mixer' in directory 'dapm' already present! [ 69.456983] debugfs: File 'Right Hp mixer' in directory 'dapm' already present! [ 69.457046] debugfs: File 'HPCP L' in directory 'dapm' already present! [ 69.457078] debugfs: File 'HPCP R' in directory 'dapm' already present! [ 69.457127] debugfs: File 'HPVOL L' in directory 'dapm' already present! [ 69.457157] debugfs: File 'HPVOL R' in directory 'dapm' already present! [ 70.938277] udc fe800000.usb: failed to start radxa-otgutils: -19 [ 81.008640] ieee80211 phy0: brcmf_escan_timeout: timer expired [ 89.540144] hdmi-audio-codec hdmi-audio-codec.5.auto: hdmi_codec_startup doesn't support capture [ 89.540187] hdmi-audio-codec hdmi-audio-codec.5.auto: ASoC: error at snd_soc_dai_startup on i2s-hifi: -22 [ 89.540706] hdmi-audio-codec hdmi-audio-codec.5.auto: hdmi_codec_startup doesn't support capture [ 89.540728] hdmi-audio-codec hdmi-audio-codec.5.auto: ASoC: error at snd_soc_dai_startup on i2s-hifi: -22 [ 89.541174] hdmi-audio-codec hdmi-audio-codec.5.auto: hdmi_codec_startup doesn't support capture [ 89.541195] hdmi-audio-codec hdmi-audio-codec.5.auto: ASoC: error at snd_soc_dai_startup on i2s-hifi: -22 [ 6419.589939] hdmi-audio-codec hdmi-audio-codec.5.auto: hdmi_codec_startup doesn't support capture [ 6419.589981] hdmi-audio-codec hdmi-audio-codec.5.auto: ASoC: error at snd_soc_dai_startup on i2s-hifi: -22 [ 6419.590499] hdmi-audio-codec hdmi-audio-codec.5.auto: hdmi_codec_startup doesn't support capture [ 6419.590521] hdmi-audio-codec hdmi-audio-codec.5.auto: ASoC: error at snd_soc_dai_startup on i2s-hifi: -22 [ 6419.590978] hdmi-audio-codec hdmi-audio-codec.5.auto: hdmi_codec_startup doesn't support capture [ 6419.591003] hdmi-audio-codec hdmi-audio-codec.5.auto: ASoC: error at snd_soc_dai_startup on i2s-hifi: -22
Yes I'm aware that I can only rely on the community for any help or tip. I'm now considering to revert back to a bullseye setup with a 5.10 Radxa kernel, but I was kind of reluctant to keep an old version of Debian as my Rockpi is accessible from ouside my network... The Rockpi is powered by a PoE hat, it never had any issue so far but maybe the PoE management is the culprit. I'll try an use the Rockpi with a traditional power supply, but in any case if this is the issue it won't be a sustainable solution for my target setup.
- Rockpi4B reboot loop - seems homeassistant and Zigbee2mqtt and USB related
Hi, I used to run a full docker environment using the Radxa Debian buster image upgraded to bullseye. Lately as the backport repo has been archived I decided to move onto Armbian as upgrading bullseye to bookworm did not boot (or seemed so...). After flashing the latest Rockpi4 image to the Rockpi4, I copied the docker configuration and files backups. I now have a akward behavior: - starting all the stacks (or containers) works fine, all seems ok - rebooting via sudo reboot provokes an endless reboot cycle which is only ended if I unplug the USB Zigbee coordinator key. Once the loop is stopped, the RockPi does not have any IPv4 address (only IPv6) and is unreacheable by SSH. - power cycling with the USB key unplugged fixes the boot loop and everything is back to "normal", except the following dmseg errors: rock@rockpi4b:~$ sudo dmesg -l 0,1,2,3 [ 3.099273] rockchip-pcie f8000000.pcie: PCIe link training gen1 timeout! [ 3.099333] rockchip-pcie f8000000.pcie: probe with driver rockchip-pcie failed with error -110 [ 11.200510] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43456-sdio for chip BCM4345/9 [ 11.731680] brcmfmac: brcmf_c_process_txcap_blob: no txcap_blob available (err=-2) [ 11.732234] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM4345/9 wl0: Jun 16 2017 12:38:26 version 7.45.96.2 (66c4e21@sh-git) (r) FWID 01-1813af84 [ 99.980012] cpu cpu4: _set_opp_voltage: failed to set voltage (825000 825000 1250000 mV): -6 [ 99.980072] cpu cpu4: Failed to set regulator voltages: -6 [ 99.980097] cpufreq: __target_index: Failed to change cpu frequency: -6 [ 246.811985] cpu cpu4: _set_opp_voltage: failed to set voltage (825000 825000 1250000 mV): -6 [ 246.812046] cpu cpu4: Failed to set regulator voltages: -6 [ 246.812070] cpufreq: __target_index: Failed to change cpu frequency: -6 [ 400.087329] cpu cpu4: _set_opp_voltage: failed to set voltage (825000 825000 1250000 mV): -6 [ 400.087387] cpu cpu4: Failed to set regulator voltages: -6 [ 400.087410] cpufreq: __target_index: Failed to change cpu frequency: -6 Now this is where it gets strange: if I prevent zigbee2mqtt container to automatically start at boot (which cannot be a permanent solution obviously) it doesn't matter if the USB key is plugged in or not (whichever usb port), Armbian boots ok and all other containers start ok. I already checked the /dev/ttyusb0 access rights, tried to change the docker container user, activate the rockchipdw3 overlay, changing the USB port for the Zigbee key, switching from rolling to stable and vice versa, to no avail. No need to say that the same config worked under bullseye. Does someone have any lead or clue about what's happening ? Where can I look as logs don't show anything special... Any help would be greatly appreciated, thanks in advance! My config: Rockpi4B, Armbian_community_25.11.0-trunk.70_Rockpi-4b_bookworm_current_6.12.43_minimal.img, usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus
Mossieur Oeuf
