Eatocee
  1. Hello, I was experiencing the same problem, and both of these workarounds did not work for me. However! Even though I am quite inexperienced when it comes to these kinds of problems, I managed to get it working reliably again with the help of my favourite LLM-slop-machine. Made the file: /etc/wpa_supplicant/wpa_supplicant-wlan0.conf ctrl_interface=/run/wpa_supplicant update_config=1 network={ ssid="YourSSID" psk="YourPassword" key_mgmt=WPA-PSK } ran these commands: sudo systemctl enable wpa_supplicant@wlan0.service sudo systemctl restart wpa_supplicant@wlan0.service sudo systemctl restart systemd-networkd then this one: sudo wpa_supplicant -i wlan0 -c /etc/wpa_supplicant/wpa_supplicant-wlan0.conf -D nl80211 -d got this error from that: nl80211: Register frame command failed (type=208): ret=-114 (Operation already in progress) then these commands: sudo systemctl stop wpa_supplicant@wlan0.service sudo systemctl stop wpa_supplicant.service sudo pkill -9 wpa_supplicant || true sudo rm -f /run/wpa_supplicant/* then started the service again and watching logs: sudo systemctl start wpa_supplicant@wlan0.service sudo journalctl -u wpa_supplicant@wlan0 -f From there i saw "wlan0: Associated with" and "wlan0: WPA: Key negotiation completed" however when running ip addr show wlan0 It only showed me 2 lines and no IP. Checked that I was connected to the correct access point with: iw dev wlan0 link I installed dhcpcd5 to assign an IP. sudo apt install dhcpcd5 assigning IP and checking if it was assigned: sudo dhcpcd wlan0 ip addr show wlan0 Then also after restarting everything worked well for me. From the wpa error, it looks like there were 2 instances? I am not sure. I would love to hear someone elses opinion on this, since I am not 100% sure what exactly I did, but it worked. I hope this helps someone!
