Renoria
  1. in the meantime I tried moving OS to SSD and kept bootloader in the SD using armbian install option 1 and it works fine…
  2. Hi @Efe Çetin, how do I write SPI image manually? as for the content inside SSD, this is what it shows: cat /mnt/boot/armbianEnv.txt verbosity=1 bootlogo=false console=both extraargs=cma=256M overlay_prefix=rockchip-rk3588 fdtfile=rockchip/rk3588s-orangepi-5.dtb rootdev=UUID=98220746-d581-4d83-9e96-0f31702ef529 rootfstype=ext4 usbstoragequirks=0x2537:0x1066:u,0x2537:0x1068:u Thanks in advance!
  3. @Igor could you help how to figure out if both SSD, SPI flash are ok? happy to provide logs as well, which to share?
  4. Hi @Igor, that’s what I selected (not the sata loader) and then ext4 but no luck.
  5. Hi guys, First post here, I successfully managed to flash and boot Armbian 25.8.2 (Bookworm Minimal) from an SD card. Everything was working great, HDMI output and network included. I then ran “sudo armbian-install” and selected Option 4 to move the system to my NVMe SSD and make it boot from there. The process itself completed without errors. However, after shutting down and removing the SD card and powering on again the system doesn’t boot. I have the red LED turned on however the green LED that was previously flickering doesn’t turn on. There’s also no HDMI output and the board doesn’t connect to the network. I tried inserting the SD card and the system does boot from that just fine. Where did I screw up? Appreciate the help!
