Mohammad Adel
  1. Is it possible to make a Bodhi Linux version that works on x98h
  2. I need an OpenWrt system on X98H
  3. X98H PRO ------ WIFI AW869A ------ WIFI 6
  4. https://drive.google.com/file/d/1--FlGP4JIjmdrjR9El9vB_rbIbIKM0IM/view?usp=sharing
  5. https://drive.google.com/file/d/1DF7qvYoCEwVHuPMI3v9M9vvotq5hwlca/view?usp=sharing
  6. How do I display information from a Linux server
  7. X98H is booted Armbian-unofficial_25.05.0-trunk_X98h_bookworm_edge_6.12.11_server.img.xz https://github.com/NickAlilovic/build
  8. I need a Linux system that runs on an x98h device Anything that does not work is not booted by the device
  9. The x98h pro device is not the same as the x98h
  10. I need a Linux system that runs on an x98h device Anything that does not work is not booted by the device
  11. i need rom work linux on x98h pro with secure image
  12. X98H Pro FIRMWARE OFICIAL secure image
  13. i need secure image x98h pro
  14. /dts-v1/; /memreserve/ 0x0000000048000000 0x0000000001000000; / { interrupt-parent = <0x1>; #address-cells = <0x2>; #size-cells = <0x2>; model = "sun50iw9"; compatible = "allwinner,h616", "arm,sun50iw9p1"; clocks { compatible = "allwinner,clk-init"; device_type = "clocks"; #address-cells = <0x2>; #size-cells = <0x2>; ranges; reg = <0x0 0x3001000 0x0 0x1000 0x0 0x7010000 0x0 0x400 0x0 0x7000000 0x0 0x4>; losc { #clock-cells = <0x0>; compatible = "allwinner,fixed-clock"; clock-frequency = <0x8000>; clock-output-names = "losc"; linux,phandle = <0x1e>; phandle = <0x1e>; }; iosc { #clock-cells = <0x0>; compatible = "allwinner,fixed-clock"; clock-frequency = <0xf42400>; clock-output-names = "iosc"; linux,phandle = <0x20>; phandle = <0x20>; }; hosc { #clock-cells = <0x0>; compatible = "allwinner,fixed-clock"; clock-frequency = <0x16e3600>; clock-output-names = "hosc"; linux,phandle = <0x9>; phandle = <0x9>; }; osc48m { #clock-cells = <0x0>; compatible = "allwinner,fixed-clock"; clock-frequency = <0x2dc6c00>; clock-output-names = "osc48m"; linux,phandle = <0xa>; phandle = <0xa>; }; hoscdiv32k { #clock-cells = <0x0>; compatible = "allwinner,fixed-clock"; clock-frequency = <0x8000>; clock-output-names = "hoscdiv32k"; linux,phandle = <0xe1>; phandle = <0xe1>; }; pll_periph0div25m { #clock-cells = <0x0>; compatible = "allwinner,fixed-clock"; clock-frequency = <0x17d7840>; clock-output-names = "pll_periph0div25m"; linux,phandle = <0xe2>; phandle = <0xe2>; }; pll_cpu { #clock-cells = <0x0>; compatible = "allwinner,pll-clock"; lock-mode = "new"; clock-output-names = "pll_cpu"; linux,phandle = <0xd5>; phandle = <0xd5>; }; pll_ddr0 { #clock-cells = <0x0>; compatible = "allwinner,pll-clock"; lock-mode = "new"; clock-output-names = "pll_ddr0"; linux,phandle = <0xda>; phandle = <0xda>; }; pll_ddr1 { #clock-cells = <0x0>; compatible = "allwinner,pll-clock"; lock-mode = "new"; clock-output-names = "pll_ddr1"; linux,phandle = <0xe3>; phandle = <0xe3>; }; pll_periph0 { #clock-cells = <0x0>; compatible = "allwinner,pll-clock"; assigned-clocks = <0x2>; assigned-clock-rates = <0x23c34600>; lock-mode = "new"; clock-output-names = "pll_periph0"; linux,phandle = <0x2>; phandle = <0x2>; }; pll_periph1 { #clock-cells = <0x0>; compatible = "allwinner,pll-clock"; assigned-clocks = <0x3>; assigned-clock-rates = <0x23c34600>; lock-mode = "new"; clock-output-names = "pll_periph1"; linux,phandle = <0x3>; phandle = <0x3>; }; pll_gpu { #clock-cells = <0x0>; compatible = "allwinner,pll-clock"; lock-mode = "new"; clock-output-names = "pll_gpu"; linux,phandle = <0xdc>; phandle = <0xdc>; }; pll_video0x4 { #clock-cells = <0x0>; compatible = "allwinner,pll-clock"; lock-mode = "new"; clock-output-names = "pll_video0x4"; linux,phandle = <0x8>; phandle = <0x8>; }; pll_video1 { #clock-cells = <0x0>; compatible = "allwinner,pll-clock"; lock-mode = "new"; assigned-clocks = <0x4>; assigned-clock-rates = <0x19bfcc00>; clock-output-names = "pll_video1"; linux,phandle = <0x4>; phandle = <0x4>; }; pll_video2 { #clock-cells = <0x0>; compatible = "allwinner,pll-clock"; lock-mode = "new"; assigned-clocks = <0x5>; clock-output-names = "pll_video2"; linux,phandle = <0x5>; phandle = <0x5>; }; pll_ve { #clock-cells = <0x0>; compatible = "allwinner,pll-clock"; device_type = "clk_pll_ve"; lock-mode = "new"; clock-output-names = "pll_ve"; linux,phandle = <0x26>; phandle = <0x26>; }; pll_de { #clock-cells = <0x0>; compatible = "allwinner,pll-clock"; assigned-clocks = <0x6>; assigned-clock-rates = <0x297c1e00>; lock-mode = "new"; clock-output-names = "pll_de"; linux,phandle = <0x6>; phandle = <0x6>; }; pll_csi { #clock-cells = <0x0>; compatible = "allwinner,pll-clock"; lock-mode = "new"; clock-output-names = "pll_csi"; linux,phandle = <0xa5>; phandle = <0xa5>; }; pll_audiox4 { #clock-cells = <0x0>; compatible = "allwinner,pll-clock"; assigned-clocks = <0x7>; assigned-clock-rates = <0x5dc0000>; lock-mode = "new"; clock-output-names = "pll_audiox4"; linux,phandle = <0x7>; phandle = <0x7>; }; pll_periph0x2 { #clock-cells = <0x0>; compatible = "allwinner,fixed-factor-clock"; clocks = <0x2>; clock-mult = <0x2>; clock-div = <0x1>; clock-output-names = "pll_periph0x2"; linux,phandle = <0xc>; phandle = <0xc>; }; pll_periph0x4 { #clock-cells = <0x0>; compatible = "allwinner,fixed-factor-clock"; clocks = <0x2>; clock-mult = <0x4>; clock-div = <0x1>; clock-output-names = "pll_periph0x4"; linux,phandle = <0xe4>; phandle = <0xe4>; }; periph32k { #clock-cells = <0x0>; compatible = "allwinner,fixed-factor-clock"; clocks = <0x2>; clock-mult = <0x2>; clock-div = <0x8f0d>; clock-output-names = "periph32k"; linux,phandle = <0xe5>; phandle = <0xe5>; }; pll_periph1x2 { #clock-cells = <0x0>; compatible = "allwinner,fixed-factor-clock"; clocks = <0x3>; clock-mult = <0x2>; clock-div = <0x1>; clock-output-names = "pll_periph1x2"; linux,phandle = <0x86>; phandle = <0x86>; }; pll_audio { #clock-cells = <0x0>; compatible = "allwinner,fixed-factor-clock"; clocks = <0x7>; clock-mult = <0x1>; clock-div = <0x4>; clock-output-names = "pll_audio"; linux,phandle = <0x60>; phandle = <0x60>; }; pll_audiox2 { #clock-cells = <0x0>; compatible = "allwinner,fixed-factor-clock"; clocks = <0x7>; clock-mult = <0x1>; clock-div = <0x2>; clock-output-names = "pll_audiox2"; linux,phandle = <0xe6>; phandle = <0xe6>; }; pll_video0 { #clock-cells = <0x0>; compatible = "allwinner,fixed-factor-clock"; clocks = <0x8>; clock-mult = <0x1>; clock-div = <0x4>; clock-output-names = "pll_video0"; linux,phandle = <0xe7>; phandle = <0xe7>; }; pll_video1x4 { #clock-cells = <0x0>; compatible = "allwinner,fixed-factor-clock"; clocks = <0x4>; clock-mult = <0x4>; clock-div = <0x1>; clock-output-names = "pll_video1x4"; linux,phandle = <0xe8>; phandle = <0xe8>; }; pll_video2x4 { #clock-cells = <0x0>; compatible = "allwinner,fixed-factor-clock"; clocks = <0x5>; clock-mult = <0x4>; clock-div = <0x1>; clock-output-names = "pll_video2x4"; linux,phandle = <0xe9>; phandle = <0xe9>; }; hoscd2 { #clock-cells = <0x0>; compatible = "allwinner,fixed-factor-clock"; clocks = <0x9>; clock-mult = <0x1>; clock-div = <0x2>; clock-output-names = "hoscd2"; linux,phandle = <0xea>; phandle = <0xea>; }; osc48md4 { #clock-cells = <0x0>; compatible = "allwinner,fixed-factor-clock"; clocks = <0xa>; clock-mult = <0x1>; clock-div = <0x4>; clock-output-names = "osc48md4"; linux,phandle = <0x52>; phandle = <0x52>; }; pll_periph0d6 { #clock-cells = <0x0>; compatible = "allwinner,fixed-factor-clock"; clocks = <0x2>; clock-mult = <0x1>; clock-div = <0x6>; clock-output-names = "pll_periph0d6"; linux,phandle = <0xeb>; phandle = <0xeb>; }; cpu { #clock-cells = <0x0>; compatible = "allwinner,cpu-clock"; clock-output-names = "cpu"; linux,phandle = <0xec>; phandle = <0xec>; }; axi { #clock-cells = <0x0>; compatible = "allwinner,periph-clock"; clock-output-names = "axi"; linux,phandle = <0xed>; phandle = <0xed>; }; cpuapb { #clock-cells = <0x0>; compatible = "allwinner,periph-clock"; clock-output-names = "cpuapb"; linux,phandle = <0xee>; phandle = <0xee>; }; psi { #clock-cells = <0x0>; compatible = "allwinner,periph-clock"; clock-output-names = "psi"; linux,phandle = <0xef>; phandle = <0xef>; }; ahb1 { #clock-cells = <0x0>; compatible = "allwinner,periph-clock"; clock-output-names = "ahb1"; linux,phandle = <0xf0>; phandle = <0xf0>; }; ahb2 { #clock-cells = <0x0>; compatible = "allwinner,periph-clock"; clock-output-names = "ahb2"; linux,phandle = <0xf1>; phandle = <0xf1>; }; ahb3 { #clock-cells = <0x0>; compatible = "allwinner,periph-clock"; clock-output-names = "ahb3"; linux,phandle = <0xf2>; phandle = <0xf2>; }; apb1 { #clock-cells = <0x0>; compatible = "allwinner,periph-clock"; clock-output-names = "apb1"; linux,phandle = <0xf3>; phandle = <0xf3>; }; apb2 { #clock-cells = <0x0>; compatible = "allwinner,periph-clock"; clock-output-names = "apb2"; linux,phandle = <0xb7>; phandle = <0xb7>; }; mbus { #clock-cells = <0x0>; compatible = "allwinner,periph-clock"; clock-output-names = "mbus"; linux,phandle = <0xf4>; phandle = <0xf4>; }; de { #clock-cells = <0x0>; compatible = "allwinner,periph-clock"; assigned-clock-parents = <0x6>; assigned-clock-rates = <0x297c1e00>; assigned-clocks = <0xb>; clock-output-names = "de"; linux,phandle = <0xb>; phandle = <0xb>; }; g2d { #clock-cells = <0x0>; compatible = "allwinner,periph-clock"; assigned-clock-parents = <0xc>; assigned-clock-rates = <0x11e1a300>; assigned-clocks = <0xd>; clock-output-names = "g2d"; linux,phandle = <0xd>; phandle = <0xd>; }; di { #clock-cells = <0x0>; compatible = "allwinner,periph-clock"; assigned-clock-parents = <0xc>; assigned-clock-rates = <0x11e1a300>; assigned-clocks = <0xe>; clock-output-names = "di"; linux,phandle = <0xe>; phandle = <0xe>; }; gpu0 { #clock-cells = <0x0>; compatible = "allwinner,periph-clock"; clock-output-names = "gpu0"; linux,phandle = <0xdd>; phandle = <0xdd>; }; gpu1 { #clock-cells = <0x0>; compatible = "allwinner,periph-clock"; clock-output-names = "gpu1"; linux,phandle = <0xde>; phandle = <0xde>; }; ce { #clock-cells = <0x0>; compatible = "allwinner,periph-clock"; clock-output-names = "ce"; linux,phandle = <0xb5>; phandle = <0xb5>; }; ve { #clock-cells = <0x0>; compatible = "allwinner,periph-clock"; clock-output-names = "ve"; linux,phandle = <0x27>; phandle = <0x27>; }; dma { #clock-cells = <0x0>; compatible = "allwinner,periph-clock"; clock-output-names = "dma"; linux,phandle = <0x1f>; phandle = <0x1f>; }; msgbox { #clock-cells = <0x0>; compatible = "allwinner,periph-clock"; clock-output-names = "msgbox"; linux,phandle = <0x21>; phandle = <0x21>; }; hwspinlock_rst { #clock-cells = <0x0>; compatible = "allwinner,periph-clock"; clock-output-names = "hwspinlock_rst"; linux,phandle = <0x22>; phandle = <0x22>; }; hwspinlock_bus { #clock-cells = <0x0>; compatible = "allwinner,periph-clock"; clock-output-names = "hwspinlock_bus"; linux,phandle = <0x23>; phandle = <0x23>; }; hstimer { #clock-cells = <0x0>; compatible = "allwinner,periph-clock"; clock-output-names = "hstimer"; linux,phandle = <0xf5>; phandle = <0xf5>; }; avs { #clock-cells = <0x0>; compatible = "allwinner,periph-clock"; clock-output-names = "avs"; linux,phandle = <0xf6>; phandle = <0xf6>; }; dbgsys { #clock-cells = <0x0>; compatible = "allwinner,periph-clock"; clock-output-names = "dbgsys"; linux,phandle = <0xf7>; phandle = <0xf7>; }; pwm { #clock-cells = <0x0>; compatible = "allwinner,periph-clock"; clock-output-names = "pwm"; linux,phandle = <0x9b>; phandle = <0x9b>; }; iommu { #clock-cells = <0x0>; compatible = "allwinner,periph-clock"; clock-output-names = "iommu"; linux,phandle = <0xdb>; phandle = <0xdb>; }; sdram { #clock-cells = <0x0>; compatible = "allwinner,periph-clock"; clock-output-names = "sdram"; linux,phandle = <0xf8>; phandle = <0xf8>; }; nand0 { #clock-cells = <0x0>; compatible = "allwinner,periph-clock"; clock-output-names = "nand0"; linux,phandle = <0xbb>; phandle = <0xbb>; }; nand1 { #clock-cells = <0x0>; compatible = "allwinner,periph-clock"; clock-output-names = "nand1"; linux,phandle = <0xbc>; phandle = <0xbc>; }; sdmmc0_mod { #clock-cells = <0x0>; compatible = "allwinner,periph-clock"; clock-output-names = "sdmmc0_mod"; linux,phandle = <0x8d>; phandle = <0x8d>; }; sdmmc0_bus { #clock-cells = <0x0>; compatible = "allwinner,periph-clock"; clock-output-names = "sdmmc0_bus"; linux,phandle = <0x8e>; phandle = <0x8e>; }; sdmmc0_rst { #clock-cells = <0x0>; compatible = "allwinner,periph-clock"; clock-output-names = "sdmmc0_rst"; linux,phandle = <0x8f>; phandle = <0x8f>; }; sdmmc1_mod { #clock-cells = <0x0>; compatible = "allwinner,periph-clock"; clock-output-names = "sdmmc1_mod"; linux,phandle = <0x93>; phandle = <0x93>; }; sdmmc1_bus { #clock-cells = <0x0>; compatible = "allwinner,periph-clock"; clock-output-names = "sdmmc1_bus"; linux,phandle = <0x94>; phandle = <0x94>; }; sdmmc1_rst { #clock-cells = <0x0>; compatible = "allwinner,periph-clock"; clock-output-names = "sdmmc1_rst"; linux,phandle = <0x95>; phandle = <0x95>; }; sdmmc2_mod { #clock-cells = <0x0>; compatible = "allwinner,periph-clock"; clock-output-names = "sdmmc2_mod"; linux,phandle = <0x87>; phandle = <0x87>; }; sdmmc2_bus { #clock-cells = <0x0>; compatible = "allwinner,periph-clock"; clock-output-names = "sdmmc2_bus"; linux,phandle = <0x88>; phandle = <0x88>; }; sdmmc2_rst { #clock-cells = <0x0>; compatible = "allwinner,periph-clock"; clock-output-names = "sdmmc2_rst"; linux,phandle = <0x89>; phandle = <0x89>; }; uart0 { #clock-cells = <0x0>; compatible = "allwinner,periph-clock"; clock-output-names = "uart0"; linux,phandle = <0x29>; phandle = <0x29>; }; uart1 { #clock-cells = <0x0>; compatible = "allwinner,periph-clock"; clock-output-names = "uart1"; linux,phandle = <0x2c>; phandle = <0x2c>; }; uart2 { #clock-cells = <0x0>; compatible = "allwinner,periph-clock"; clock-output-names = "uart2"; linux,phandle = <0x2f>; phandle = <0x2f>; }; uart3 { #clock-cells = <0x0>; compatible = "allwinner,periph-clock"; clock-output-names = "uart3"; linux,phandle = <0x32>; phandle = <0x32>; }; uart4 { #clock-cells = <0x0>; compatible = "allwinner,periph-clock"; clock-output-names = "uart4"; linux,phandle = <0x35>; phandle = <0x35>; }; uart5 { #clock-cells = <0x0>; compatible = "allwinner,periph-clock"; clock-output-names = "uart5"; linux,phandle = <0x38>; phandle = <0x38>; }; twi0 { #clock-cells = <0x0>; compatible = "allwinner,periph-clock"; clock-output-names = "twi0"; linux,phandle = <0x3b>; phandle = <0x3b>; }; twi1 { #clock-cells = <0x0>; compatible = "allwinner,periph-clock"; clock-output-names = "twi1"; linux,phandle = <0x3e>; phandle = <0x3e>; }; twi2 { #clock-cells = <0x0>; compatible = "allwinner,periph-clock"; clock-output-names = "twi2"; linux,phandle = <0x41>; phandle = <0x41>; }; twi3 { #clock-cells = <0x0>; compatible = "allwinner,periph-clock"; clock-output-names = "twi3"; linux,phandle = <0x44>; phandle = <0x44>; }; twi4 { #clock-cells = <0x0>; compatible = "allwinner,periph-clock"; clock-output-names = "twi4"; linux,phandle = <0x47>; phandle = <0x47>; }; scr0 { #clock-cells = <0x0>; compatible = "allwinner,periph-clock"; clock-output-names = "scr0"; linux,phandle = <0xb6>; phandle = <0xb6>; }; spi0 { #clock-cells = <0x0>; compatible = "allwinner,periph-clock"; clock-output-names = "spi0"; linux,phandle = <0x7d>; phandle = <0x7d>; }; spi1 { #clock-cells = <0x0>; compatible = "allwinner,periph-clock"; clock-output-names = "spi1"; linux,phandle = <0x81>; phandle = <0x81>; }; ephy_25m { #clock-cells = <0x0>; compatible = "allwinner,periph-clock"; clock-output-names = "ephy_25m"; linux,phandle = <0xcd>; phandle = <0xcd>; }; gmac0 { #clock-cells = <0x0>; compatible = "allwinner,periph-clock"; clock-output-names = "gmac0"; linux,phandle = <0xcc>; phandle = <0xcc>; }; gmac1 { #clock-cells = <0x0>; compatible = "allwinner,periph-clock"; clock-output-names = "gmac1"; linux,phandle = <0xd0>; phandle = <0xd0>; }; gpadc { #clock-cells = <0x0>; compatible = "allwinner,periph-clock"; clock-output-names = "gpadc"; linux,phandle = <0xca>; phandle = <0xca>; }; ts { #clock-cells = <0x0>; compatible = "allwinner,periph-clock"; clock-output-names = "ts"; linux,phandle = <0xc0>; phandle = <0xc0>; }; ths { #clock-cells = <0x0>; compatible = "allwinner,periph-clock"; clock-output-names = "ths"; linux,phandle = <0xc3>; phandle = <0xc3>; }; spdif { #clock-cells = <0x0>; compatible = "allwinner,periph-clock"; clock-output-names = "spdif"; linux,phandle = <0x61>; phandle = <0x61>; }; dmic { #clock-cells = <0x0>; compatible = "allwinner,periph-clock"; clock-output-names = "dmic"; linux,phandle = <0x64>; phandle = <0x64>; }; codec_1x { #clock-cells = <0x0>; compatible = "allwinner,periph-clock"; clock-output-names = "codec_1x"; linux,phandle = <0x67>; phandle = <0x67>; }; codec_4x { #clock-cells = <0x0>; compatible = "allwinner,periph-clock"; clock-output-names = "codec_4x"; linux,phandle = <0xf9>; phandle = <0xf9>; }; ahub { #clock-cells = <0x0>; compatible = "allwinner,periph-clock"; clock-output-names = "ahub"; linux,phandle = <0x6a>; phandle = <0x6a>; }; usbphy0 { #clock-cells = <0x0>; compatible = "allwinner,periph-clock"; clock-output-names = "usbphy0"; linux,phandle = <0x4d>; phandle = <0x4d>; }; usbphy1 { #clock-cells = <0x0>; compatible = "allwinner,periph-clock"; clock-output-names = "usbphy1"; linux,phandle = <0x54>; phandle = <0x54>; }; usbphy2 { #clock-cells = <0x0>; compatible = "allwinner,periph-clock"; clock-output-names = "usbphy2"; linux,phandle = <0x58>; phandle = <0x58>; }; usbphy3 { #clock-cells = <0x0>; compatible = "allwinner,periph-clock"; clock-output-names = "usbphy3"; linux,phandle = <0x5c>; phandle = <0x5c>; }; usbohci0 { #clock-cells = <0x0>; compatible = "allwinner,periph-clock"; clock-output-names = "usbohci0"; linux,phandle = <0x50>; phandle = <0x50>; }; usbohci0_12m { #clock-cells = <0x0>; compatible = "allwinner,periph-clock"; clock-output-names = "usbohci0_12m"; linux,phandle = <0x51>; phandle = <0x51>; }; usbohci1 { #clock-cells = <0x0>; compatible = "allwinner,periph-clock"; clock-output-names = "usbohci1"; linux,phandle = <0x56>; phandle = <0x56>; }; usbohci1_12m { #clock-cells = <0x0>; compatible = "allwinner,periph-clock"; clock-output-names = "usbohci1_12m"; linux,phandle = <0x57>; phandle = <0x57>; }; usbohci2 { #clock-cells = <0x0>; compatible = "allwinner,periph-clock"; clock-output-names = "usbohci2"; linux,phandle = <0x5a>; phandle = <0x5a>; }; usbohci2_12m { #clock-cells = <0x0>; compatible = "allwinner,periph-clock"; clock-output-names = "usbohci2_12m"; linux,phandle = <0x5b>; phandle = <0x5b>; }; usbohci3 { #clock-cells = <0x0>; compatible = "allwinner,periph-clock"; clock-output-names = "usbohci3"; linux,phandle = <0x5e>; phandle = <0x5e>; }; usbohci3_12m { #clock-cells = <0x0>; compatible = "allwinner,periph-clock"; clock-output-names = "usbohci3_12m"; linux,phandle = <0x5f>; phandle = <0x5f>; }; usbehci0 { #clock-cells = <0x0>; compatible = "allwinner,periph-clock"; clock-output-names = "usbehci0"; linux,phandle = <0x4f>; phandle = <0x4f>; }; usbehci1 { #clock-cells = <0x0>; compatible = "allwinner,periph-clock"; clock-output-names = "usbehci1"; linux,phandle = <0x55>; phandle = <0x55>; }; usbehci2 { #clock-cells = <0x0>; compatible = "allwinner,periph-clock"; clock-output-names = "usbehci2"; linux,phandle = <0x59>; phandle = <0x59>; }; usbehci3 { #clock-cells = <0x0>; compatible = "allwinner,periph-clock"; clock-output-names = "usbehci3"; linux,phandle = <0x5d>; phandle = <0x5d>; }; usb3_0_host { #clock-cells = <0x0>; compatible = "allwinner,periph-clock"; clock-output-names = "usb3_0_host"; linux,phandle = <0xfa>; phandle = <0xfa>; }; usbotg { #clock-cells = <0x0>; compatible = "allwinner,periph-clock"; clock-output-names = "usbotg"; linux,phandle = <0x4e>; phandle = <0x4e>; }; lradc { #clock-cells = <0x0>; compatible = "allwinner,periph-clock"; clock-output-names = "lradc"; linux,phandle = <0xcb>; phandle = <0xcb>; }; hdmi { #clock-cells = <0x0>; compatible = "allwinner,periph-clock"; assigned-clock-parents = <0x5>; assigned-clocks = <0xf>; clock-output-names = "hdmi"; linux,phandle = <0xf>; phandle = <0xf>; }; hdmi_slow { #clock-cells = <0x0>; compatible = "allwinner,periph-clock"; assigned-clocks = <0x10>; clock-output-names = "hdmi_slow"; linux,phandle = <0x10>; phandle = <0x10>; }; hdmi_cec { #clock-cells = <0x0>; compatible = "allwinner,periph-clock"; assigned-clocks = <0x11>; clock-output-names = "hdmi_cec"; linux,phandle = <0x11>; phandle = <0x11>; }; display_top { #clock-cells = <0x0>; compatible = "allwinner,periph-clock"; clock-output-names = "display_top"; linux,phandle = <0x98>; phandle = <0x98>; }; tcon_lcd { #clock-cells = <0x0>; compatible = "allwinner,periph-clock"; clock-output-names = "tcon_lcd"; assigned-clock-parents = <0x8>; assigned-clocks = <0x12>; linux,phandle = <0x12>; phandle = <0x12>; }; tcon_lcd1 { #clock-cells = <0x0>; compatible = "allwinner,periph-clock"; clock-output-names = "tcon_lcd1"; assigned-clock-parents = <0x4>; assigned-clocks = <0x13>; linux,phandle = <0x13>; phandle = <0x13>; }; tcon_tv { #clock-cells = <0x0>; compatible = "allwinner,periph-clock"; assigned-clock-parents = <0x5>; assigned-clocks = <0x14>; clock-output-names = "tcon_tv"; linux,phandle = <0x14>; phandle = <0x14>; }; tcon_tv1 { #clock-cells = <0x0>; compatible = "allwinner,periph-clock"; assigned-clock-parents = <0x4>; assigned-clocks = <0x15>; clock-output-names = "tcon_tv1"; linux,phandle = <0x15>; phandle = <0x15>; }; lvds { #clock-cells = <0x0>; compatible = "allwinner,periph-clock"; clock-output-names = "lvds"; assigned-clocks = <0x16>; linux,phandle = <0x16>; phandle = <0x16>; }; tve { #clock-cells = <0x0>; compatible = "allwinner,periph-clock"; clock-output-names = "tve"; assigned-clock-parents = <0x4>; assigned-clocks = <0x17>; linux,phandle = <0x17>; phandle = <0x17>; }; tve_top { #clock-cells = <0x0>; compatible = "allwinner,periph-clock"; clock-output-names = "tve_top"; assigned-clock-parents = <0x4>; assigned-clocks = <0x18>; linux,phandle = <0x18>; phandle = <0x18>; }; csi_top { #clock-cells = <0x0>; compatible = "allwinner,periph-clock"; clock-output-names = "csi_top"; linux,phandle = <0xa4>; phandle = <0xa4>; }; csi_master0 { #clock-cells = <0x0>; compatible = "allwinner,periph-clock"; clock-output-names = "csi_master0"; linux,phandle = <0xa6>; phandle = <0xa6>; }; csi_master1 { #clock-cells = <0x0>; compatible = "allwinner,periph-clock"; clock-output-names = "csi_master1"; linux,phandle = <0xa7>; phandle = <0xa7>; }; hdmi_hdcp { #clock-cells = <0x0>; compatible = "allwinner,periph-clock"; assigned-clock-parents = <0x3>; assigned-clocks = <0x19>; clock-output-names = "hdmi_hdcp"; linux,phandle = <0x19>; phandle = <0x19>; }; pio { #clock-cells = <0x0>; compatible = "allwinner,periph-clock"; clock-output-names = "pio"; linux,phandle = <0x1d>; phandle = <0x1d>; }; cpurcir { #clock-cells = <0x0>; compatible = "allwinner,periph-cpus-clock"; clock-output-names = "cpurcir"; linux,phandle = <0x25>; phandle = <0x25>; }; hosc32k { #clock-cells = <0x0>; compatible = "allwinner,periph-cpus-clock"; clock-output-names = "hosc32k"; linux,phandle = <0x1a>; phandle = <0x1a>; }; losc_out { #clock-cells = <0x0>; compatible = "allwinner,periph-cpus-clock"; assigned-clock-parents = <0x1a>; assigned-clocks = <0x1b>; clock-output-names = "losc_out"; linux,phandle = <0x1b>; phandle = <0x1b>; }; cpurcpus_pll { #clock-cells = <0x0>; compatible = "allwinner,periph-cpus-clock"; clock-output-names = "cpurcpus_pll"; linux,phandle = <0xfb>; phandle = <0xfb>; }; cpurcpus { #clock-cells = <0x0>; compatible = "allwinner,periph-cpus-clock"; clock-output-names = "cpurcpus"; linux,phandle = <0xfc>; phandle = <0xfc>; }; cpurahbs { #clock-cells = <0x0>; compatible = "allwinner,periph-cpus-clock"; clock-output-names = "cpurahbs"; linux,phandle = <0xfd>; phandle = <0xfd>; }; cpurapbs1 { #clock-cells = <0x0>; compatible = "allwinner,periph-cpus-clock"; clock-output-names = "cpurapbs1"; linux,phandle = <0xfe>; phandle = <0xfe>; }; cpurapbs2_pll { #clock-cells = <0x0>; compatible = "allwinner,periph-cpus-clock"; clock-output-names = "cpurapbs2_pll"; linux,phandle = <0xff>; phandle = <0xff>; }; cpurapbs2 { #clock-cells = <0x0>; compatible = "allwinner,periph-cpus-clock"; clock-output-names = "cpurapbs2"; linux,phandle = <0x100>; phandle = <0x100>; }; cpurpio { #clock-cells = <0x0>; compatible = "allwinner,periph-cpus-clock"; clock-output-names = "cpurpio"; linux,phandle = <0x1c>; phandle = <0x1c>; }; dcxo_out { #clock-cells = <0x0>; compatible = "allwinner,periph-cpus-clock"; clock-output-names = "dcxo_out"; linux,phandle = <0x101>; phandle = <0x101>; }; stwi { #clock-cells = <0x0>; compatible = "allwinner,periph-cpus-clock"; clock-output-names = "stwi"; linux,phandle = <0x4a>; phandle = <0x4a>; }; }; soc@03000000 { compatible = "simple-bus"; #address-cells = <0x2>; #size-cells = <0x2>; ranges; device_type = "soc"; linux,phandle = <0x102>; phandle = <0x102>; pinctrl@07022000 { compatible = "allwinner,sun50iw9p1-r-pinctrl"; reg = <0x0 0x7022000 0x0 0x400>; clocks = <0x1c>; device_type = "r_pio"; gpio-controller; interrupt-controller; #interrupt-cells = <0x3>; #size-cells = <0x0>; #gpio-cells = <0x6>; linux,phandle = <0x103>; phandle = <0x103>; s_rsb0@0 { allwinner,pins = "PL0", "PL1"; allwinner,function = "s_rsb0"; allwinner,muxsel = <0x2>; allwinner,drive = <0x2>; allwinner,pull = <0x1>; linux,phandle = <0x104>; phandle = <0x104>; }; s_twi0@0 { allwinner,pins = "PL0", "PL1"; allwinner,pname = "s_twi0_scl", "s_twi0_sda"; allwinner,function = "s_twi0"; allwinner,muxsel = <0x3>; allwinner,drive = <0x1>; allwinner,pull = <0x1>; linux,phandle = <0x4b>; phandle = <0x4b>; }; s_twi0@1 { allwinner,pins = "PL0", "PL1"; allwinner,function = "io_disabled"; allwinner,muxsel = <0x7>; allwinner,drive = <0x1>; allwinner,pull = <0x0>; linux,phandle = <0x4c>; phandle = <0x4c>; }; }; pinctrl@0300b000 { compatible = "allwinner,sun50iw9p1-pinctrl"; reg = <0x0 0x300b000 0x0 0x400>; interrupts = <0x0 0x33 0x4 0x0 0x34 0x4 0x0 0x35 0x4 0x0 0x2b 0x4 0x0 0x36 0x4 0x0 0x37 0x4 0x0 0x38 0x4 0x0 0x39 0x4>; device_type = "pio"; clocks = <0x1d 0x1e 0x9>; gpio-controller; interrupt-controller; #interrupt-cells = <0x3>; #size-cells = <0x0>; #gpio-cells = <0x6>; input-debounce = <0x0 0x0 0x0 0x0 0x0 0x0 0x0>; linux,phandle = <0x53>; phandle = <0x53>; clk_losc@0 { allwinner,pins = "PG10"; allwinner,function = "x32kfout"; allwinner,muxsel = <0x3>; allwinner,drive = <0x2>; allwinner,pull = <0x1>; linux,phandle = <0xd3>; phandle = <0xd3>; }; s_cir0@0 { allwinner,pins = "PH10"; allwinner,function = "ir"; allwinner,muxsel = <0x3>; allwinner,drive = <0x2>; allwinner,pull = <0x1>; linux,phandle = <0x24>; phandle = <0x24>; }; vdevice@0 { allwinner,pins = "PA1", "PA2"; allwinner,function = "Vdevice"; allwinner,muxsel = <0x5>; allwinner,drive = <0x1>; allwinner,pull = <0x1>; linux,phandle = <0xb4>; phandle = <0xb4>; }; uart0@1 { allwinner,pins = "PH0", "PH1"; allwinner,function = "uart0"; allwinner,muxsel = <0x7>; allwinner,drive = <0x1>; allwinner,pull = <0x0>; linux,phandle = <0x2b>; phandle = <0x2b>; }; uart1@0 { allwinner,pins = "PG6", "PG7", "PG8", "PG9"; allwinner,pname = "uart1_tx", "uart1_rx", "uart1_rts", "uart1_cts"; allwinner,function = "uart1"; allwinner,muxsel = <0x2>; allwinner,drive = <0x1>; allwinner,pull = <0x1>; linux,phandle = <0x2d>; phandle = <0x2d>; }; uart1@1 { allwinner,pins = "PG6", "PG7", "PG8", "PG9"; allwinner,function = "io_disabled"; allwinner,muxsel = <0x7>; allwinner,drive = <0x1>; allwinner,pull = <0x0>; linux,phandle = <0x2e>; phandle = <0x2e>; }; uart2@0 { allwinner,pins = "PH5", "PH6", "PH7", "PH8"; allwinner,pname = "uart2_tx", "uart2_rx", "uart2_rts", "uart2_cts"; allwinner,function = "uart2"; allwinner,muxsel = <0x2>; allwinner,drive = <0x1>; allwinner,pull = <0x1>; linux,phandle = <0x30>; phandle = <0x30>; }; uart2@1 { allwinner,pins = "PH5", "PH6", "PH7", "PH8"; allwinner,function = "io_disabled"; allwinner,muxsel = <0x7>; allwinner,drive = <0x1>; allwinner,pull = <0x0>; linux,phandle = <0x31>; phandle = <0x31>; }; uart3@0 { allwinner,pins = "PI9", "PI10", "PI11", "PI12"; allwinner,pname = "uart3_tx", "uart3_rx", "uart3_rts", "uart3_cts"; allwinner,function = "uart3"; allwinner,muxsel = <0x3>; allwinner,drive = <0x1>; allwinner,pull = <0x1>; linux,phandle = <0x33>; phandle = <0x33>; }; uart3@1 { allwinner,pins = "PI9", "PI10", "PI11", "PI12"; allwinner,function = "io_disabled"; allwinner,muxsel = <0x7>; allwinner,drive = <0x1>; allwinner,pull = <0x0>; linux,phandle = <0x34>; phandle = <0x34>; }; uart4@0 { allwinner,pins = "PI13", "PI14", "PI15", "PI16"; allwinner,pname = "uart4_tx", "uart4_rx", "uart4_rts", "uart4_cts"; allwinner,function = "uart4"; allwinner,muxsel = <0x3>; allwinner,drive = <0x1>; allwinner,pull = <0x1>; linux,phandle = <0x36>; phandle = <0x36>; }; uart4@1 { allwinner,pins = "PI13", "PI14", "PI15", "PI16"; allwinner,function = "io_disabled"; allwinner,muxsel = <0x7>; allwinner,drive = <0x1>; allwinner,pull = <0x0>; linux,phandle = <0x37>; phandle = <0x37>; }; uart5@0 { allwinner,pins = "PH2", "PH3"; allwinner,pname = "uart3_tx", "uart3_rx"; allwinner,function = "uart5"; allwinner,muxsel = <0x2>; allwinner,drive = <0x1>; allwinner,pull = <0x1>; linux,phandle = <0x39>; phandle = <0x39>; }; uart5@1 { allwinner,pins = "PH2", "PH3"; allwinner,function = "io_disabled"; allwinner,muxsel = <0x7>; allwinner,drive = <0x1>; allwinner,pull = <0x0>; linux,phandle = <0x3a>; phandle = <0x3a>; }; twi0@0 { allwinner,pins = "PA0", "PA1"; allwinner,pname = "twi0_scl", "twi0_sda"; allwinner,function = "twi0"; allwinner,muxsel = <0x4>; allwinner,drive = <0x1>; allwinner,pull = <0x0>; linux,phandle = <0x3c>; phandle = <0x3c>; }; twi0@1 { allwinner,pins = "PA0", "PA1"; allwinner,function = "io_disabled"; allwinner,muxsel = <0x7>; allwinner,drive = <0x1>; allwinner,pull = <0x0>; linux,phandle = <0x3d>; phandle = <0x3d>; }; twi1@0 { allwinner,pins = "PA2", "PA3"; allwinner,pname = "twi1_scl", "twi1_sda"; allwinner,function = "twi1"; allwinner,muxsel = <0x4>; allwinner,drive = <0x1>; allwinner,pull = <0x0>; linux,phandle = <0x3f>; phandle = <0x3f>; }; twi1@1 { allwinner,pins = "PA2", "PA3"; allwinner,function = "io_disabled"; allwinner,muxsel = <0x7>; allwinner,drive = <0x1>; allwinner,pull = <0x0>; linux,phandle = <0x40>; phandle = <0x40>; }; twi2@0 { allwinner,pins = "PE20", "PE21"; allwinner,pname = "twi2_scl", "twi2_sda"; allwinner,function = "twi2"; allwinner,muxsel = <0x5>; allwinner,drive = <0x1>; allwinner,pull = <0x0>; linux,phandle = <0x42>; phandle = <0x42>; }; twi2@1 { allwinner,pins = "PE20", "PE21"; allwinner,function = "io_disabled"; allwinner,muxsel = <0x7>; allwinner,drive = <0x1>; allwinner,pull = <0x0>; linux,phandle = <0x43>; phandle = <0x43>; }; twi3@0 { allwinner,pins = "PA10", "PA11"; allwinner,pname = "twi3_scl", "twi3_sda"; allwinner,function = "twi3"; allwinner,muxsel = <0x2>; allwinner,drive = <0x1>; allwinner,pull = <0x1>; linux,phandle = <0x45>; phandle = <0x45>; }; twi3@1 { allwinner,pins = "PA10", "PA11"; allwinner,function = "io_disabled"; allwinner,muxsel = <0x7>; allwinner,drive = <0x1>; allwinner,pull = <0x0>; linux,phandle = <0x46>; phandle = <0x46>; }; twi4@0 { allwinner,pins = "PG15", "PG16"; allwinner,pname = "twi4_scl", "twi4_sda"; allwinner,function = "twi4"; allwinner,muxsel = <0x5>; allwinner,drive = <0x1>; allwinner,pull = <0x0>; linux,phandle = <0x48>; phandle = <0x48>; }; twi4@1 { allwinner,pins = "PG15", "PG16"; allwinner,function = "io_disabled"; allwinner,muxsel = <0x7>; allwinner,drive = <0x1>; allwinner,pull = <0x0>; linux,phandle = <0x49>; phandle = <0x49>; }; ts0@0 { allwinner,pins = "PD0", "PD1", "PD2", "PD3", "PD4", "PD5", "PD6", "PD7", "PD8", "PD9", "PD10", "PD11"; allwinner,pname = "ts0_clk", "ts0_err", "ts0_sync", "ts0_dvld", "ts0_d0", "ts0_d1", "ts0_d2", "ts0_d3", "ts0_d4", "ts0_d5", "ts0_d6", "ts0_d7"; allwinner,function = "ts0"; allwinner,muxsel = <0x4>; allwinner,drive = <0x1>; allwinner,pull = <0x0>; linux,phandle = <0xc1>; phandle = <0xc1>; }; ts0_sleep@0 { allwinner,pins = "PD0", "PD1", "PD2", "PD3", "PD4", "PD5", "PD6", "PD7", "PD8", "PD9", "PD10", "PD11"; allwinner,pname = "ts0_clk", "ts0_err", "ts0_sync", "ts0_dvld", "ts0_d0", "ts0_d1", "ts0_d2", "ts0_d3", "ts0_d4", "ts0_d5", "ts0_d6", "ts0_d7"; allwinner,function = "io_disabled"; allwinner,muxsel = <0x7>; allwinner,drive = <0x1>; allwinner,pull = <0x0>; linux,phandle = <0xc2>; phandle = <0xc2>; }; spi0@0 { allwinner,pins = "PC0", "PC2", "PC4", "PC15", "PC16"; allwinner,pname = "spi0_sclk", "spi0_mosi", "spi0_miso", "spi0_wp", "spi0_hold"; allwinner,function = "spi0"; allwinner,muxsel = <0x4>; allwinner,drive = <0x1>; allwinner,pull = <0x0>; linux,phandle = <0x7e>; phandle = <0x7e>; }; spi0@1 { allwinner,pins = "PC3", "PC7"; allwinner,pname = "spi0_cs0", "spi0_cs1"; allwinner,function = "spi0"; allwinner,muxsel = <0x4>; allwinner,drive = <0x1>; allwinner,pull = <0x1>; linux,phandle = <0x7f>; phandle = <0x7f>; }; spi0@2 { allwinner,pins = "PC0", "PC2", "PC3", "PC4", "PC7", "PC15", "PC16"; allwinner,function = "io_disabled"; allwinner,muxsel = <0x7>; allwinner,drive = <0x1>; allwinner,pull = <0x0>; linux,phandle = <0x80>; phandle = <0x80>; }; spi1@0 { allwinner,pins = "PH6", "PH7", "PH8"; allwinner,pname = "spi1_sclk", "spi1_mosi", "spi1_miso"; allwinner,function = "spi1"; allwinner,muxsel = <0x4>; allwinner,drive = <0x1>; allwinner,pull = <0x0>; linux,phandle = <0x82>; phandle = <0x82>; }; spi1@1 { allwinner,pins = "PH5", "PH9"; allwinner,pname = "spi1_cs0", "spi1_cs1"; allwinner,function = "spi1"; allwinner,muxsel = <0x4>; allwinner,drive = <0x1>; allwinner,pull = <0x1>; linux,phandle = <0x83>; phandle = <0x83>; }; spi1@2 { allwinner,pins = "PH5", "PH6", "PH7", "PH8", "PH9"; allwinner,function = "io_disabled"; allwinner,muxsel = <0x7>; allwinner,drive = <0x1>; allwinner,pull = <0x0>; linux,phandle = <0x84>; phandle = <0x84>; }; sdc0@0 { allwinner,pins = "PF0", "PF1", "PF2", "PF3", "PF4", "PF5"; allwinner,function = "sdc0"; allwinner,muxsel = <0x2>; allwinner,drive = <0x3>; allwinner,pull = <0x1>; linux,phandle = <0x90>; phandle = <0x90>; }; sdc0@1 { allwinner,pins = "PF0", "PF1", "PF2", "PF3", "PF4", "PF5"; allwinner,function = "io_disabled"; allwinner,muxsel = <0x7>; allwinner,drive = <0x1>; allwinner,pull = <0x1>; linux,phandle = <0x91>; phandle = <0x91>; }; sdc0@2 { allwinner,pins = "PF0", "PF1", "PF2", "PF3", "PF4", "PF5"; allwinner,function = "uart0_jtag"; allwinner,muxsel = <0x3>; allwinner,drive = <0x1>; allwinner,pull = <0x1>; linux,phandle = <0x92>; phandle = <0x92>; }; sdc1@0 { allwinner,pins = "PG0", "PG1", "PG2", "PG3", "PG4", "PG5"; allwinner,function = "sdc1"; allwinner,muxsel = <0x2>; allwinner,drive = <0x3>; allwinner,pull = <0x1>; linux,phandle = <0x96>; phandle = <0x96>; }; sdc1@1 { allwinner,pins = "PG0", "PG1", "PG2", "PG3", "PG4", "PG5"; allwinner,function = "io_disabled"; allwinner,muxsel = <0x7>; allwinner,drive = <0x1>; allwinner,pull = <0x1>; linux,phandle = <0x97>; phandle = <0x97>; }; sdc2@0 { allwinner,pins = "PC1", "PC5", "PC6", "PC8", "PC9", "PC10", "PC11", "PC13", "PC14", "PC15", "PC16"; allwinner,function = "sdc2"; allwinner,muxsel = <0x3>; allwinner,drive = <0x2>; allwinner,pull = <0x1>; linux,phandle = <0x8a>; phandle = <0x8a>; }; sdc2@1 { allwinner,pins = "PC0", "PC1", "PC5", "PC6", "PC8", "PC9", "PC10", "PC11", "PC13", "PC14", "PC15", "PC16"; allwinner,function = "io_disabled"; allwinner,muxsel = <0x7>; allwinner,drive = <0x1>; allwinner,pull = <0x1>; linux,phandle = <0x8c>; phandle = <0x8c>; }; sdc2@2 { allwinner,pins = "PC0"; allwinner,function = "sdc2"; allwinner,muxsel = <0x3>; allwinner,drive = <0x2>; allwinner,pull = <0x2>; linux,phandle = <0x8b>; phandle = <0x8b>; }; spdif@0 { allwinner,pins = "PH2", "PH3", "PH4"; allwinner,function = "spdif"; allwinner,muxsel = <0x3>; allwinner,drive = <0x1>; allwinner,pull = <0x0>; linux,phandle = <0x62>; phandle = <0x62>; }; spdif_sleep@0 { allwinner,pins = "PH2", "PH3", "PH4"; allwinner,function = "io_disabled"; allwinner,muxsel = <0x7>; allwinner,drive = <0x1>; allwinner,pull = <0x0>; linux,phandle = <0x63>; phandle = <0x63>; }; dmic@0 { allwinner,pins = "PI0", "PI1", "PI2", "PI3", "PI4"; allwinner,function = "dmic"; allwinner,muxsel = <0x3>; allwinner,drive = <0x1>; allwinner,pull = <0x0>; linux,phandle = <0x65>; phandle = <0x65>; }; dmic_sleep@0 { allwinner,pins = "PI0", "PI1", "PI2", "PI3", "PI4"; allwinner,function = "io_disabled"; allwinner,muxsel = <0x7>; allwinner,drive = <0x1>; allwinner,pull = <0x0>; linux,phandle = <0x66>; phandle = <0x66>; }; ahub_daudio0@0 { allwinner,pins = "PA6", "PA7", "PA8", "PA9"; allwinner,function = "h_pcm0"; allwinner,muxsel = <0x3>; allwinner,drive = <0x1>; allwinner,pull = <0x0>; linux,phandle = <0x105>; phandle = <0x105>; }; ahub_daudio0_sleep@0 { allwinner,pins = "PA6", "PA7", "PA8", "PA9"; allwinner,function = "io_disabled"; allwinner,muxsel = <0x7>; allwinner,drive = <0x1>; allwinner,pull = <0x0>; linux,phandle = <0x106>; phandle = <0x106>; }; h_ahub_daudio0@0 { allwinner,pins = "PI0", "PI1", "PI2", "PI3", "PI4"; allwinner,function = "h_pcm0"; allwinner,muxsel = <0x4>; allwinner,drive = <0x1>; allwinner,pull = <0x0>; linux,phandle = <0x6b>; phandle = <0x6b>; }; h_ahub_daudio0_sleep@0 { allwinner,pins = "PI0", "PI1", "PI2", "PI3", "PI4"; allwinner,function = "io_disabled"; allwinner,muxsel = <0x7>; allwinner,drive = <0x1>; allwinner,pull = <0x0>; linux,phandle = <0x6c>; phandle = <0x6c>; }; ahub_daudio2@0 { allwinner,pins = "PG10", "PG11", "PG12", "PG13", "PG14"; allwinner,function = "h_pcm2"; allwinner,muxsel = <0x2>; allwinner,drive = <0x1>; allwinner,pull = <0x0>; linux,phandle = <0x6d>; phandle = <0x6d>; }; ahub_daudio2_sleep@0 { allwinner,pins = "PG10", "PG11", "PG12", "PG13", "PG14"; allwinner,function = "io_disabled"; allwinner,muxsel = <0x7>; allwinner,drive = <0x1>; allwinner,pull = <0x0>; linux,phandle = <0x6e>; phandle = <0x6e>; }; ahub_daudio3@0 { allwinner,pins = "PH5", "PH6", "PH7", "PH8", "PH9"; allwinner,function = "h_pcm3"; allwinner,muxsel = <0x3>; allwinner,drive = <0x1>; allwinner,pull = <0x0>; linux,phandle = <0x6f>; phandle = <0x6f>; }; ahub_daudio3_sleep@0 { allwinner,pins = "PH5", "PH6", "PH7", "PH8", "PH9"; allwinner,function = "io_disabled"; allwinner,muxsel = <0x7>; allwinner,drive = <0x1>; allwinner,pull = <0x0>; linux,phandle = <0x70>; phandle = <0x70>; }; csi1@0 { allwinner,pins = "PE0", "PE2", "PE3", "PE4", "PE5", "PE6", "PE7", "PE8", "PE9", "PE10", "PE11", "PE12", "PE13", "PE14", "PE15", "PE16", "PE17", "PE18", "PE19"; allwinner,pname = "csi1_pck", "csi1_hsync", "csi1_vsync", "csi1_d0", "csi1_d1", "csi1_d2", "csi1_d3", "csi1_d4", "csi1_d5", "csi1_d6", "csi1_d7", "csi1_d8", "csi1_d9", "csi1_d10", "csi1_d11", "csi1_d12", "csi1_d13", "csi1_d14", "csi1_d15"; allwinner,function = "csi1"; allwinner,muxsel = <0x2>; allwinner,drive = <0x1>; allwinner,pull = <0x0>; linux,phandle = <0xb0>; phandle = <0xb0>; }; csi1@1 { allwinner,pins = "PE0", "PE2", "PE3", "PE4", "PE5", "PE6", "PE7", "PE8", "PE9", "PE10", "PE11", "PE12", "PE13", "PE14", "PE15", "PE16", "PE17", "PE18", "PE19"; allwinner,pname = "csi1_pck", "csi1_hsync", "csi1_vsync", "csi1_d0", "csi1_d1", "csi1_d2", "csi1_d3", "csi1_d4", "csi1_d5", "csi1_d6", "csi1_d7", "csi1_d8", "csi1_d9", "csi1_d10", "csi1_d11", "csi1_d12", "csi1_d13", "csi1_d14", "csi1_d15"; allwinner,function = "io_disabled"; allwinner,muxsel = <0x7>; allwinner,drive = <0x1>; allwinner,pull = <0x0>; linux,phandle = <0xb1>; phandle = <0xb1>; }; csi_mclk0@0 { allwinner,pins = "PG19"; allwinner,pname = "csi_mclk0"; allwinner,function = "csi_mclk0"; allwinner,muxsel = <0x3>; allwinner,drive = <0x2>; allwinner,pull = <0x0>; linux,phandle = <0xa8>; phandle = <0xa8>; }; csi_mclk0@1 { allwinner,pins = "PG19"; allwinner,pname = "csi_mclk0"; allwinner,function = "io_disabled"; allwinner,muxsel = <0x7>; allwinner,drive = <0x2>; allwinner,pull = <0x0>; linux,phandle = <0xa9>; phandle = <0xa9>; }; csi_cci0@0 { allwinner,pins = "PG17", "PG18"; allwinner,pname = "csi_cci0_sck", "csi_cci0_sda"; allwinner,function = "csi_cci0"; allwinner,muxsel = <0x3>; allwinner,drive = <0x2>; allwinner,pull = <0x0>; linux,phandle = <0xac>; phandle = <0xac>; }; csi_cci0@1 { allwinner,pins = "PG17", "PG18"; allwinner,pname = "csi_cci0_sck", "csi_cci0_sda"; allwinner,function = "io_disabled"; allwinner,muxsel = <0x7>; allwinner,drive = <0x2>; allwinner,pull = <0x0>; linux,phandle = <0xad>; phandle = <0xad>; }; csi_mclk1@0 { allwinner,pins = "PE1"; allwinner,pname = "csi_mclk1"; allwinner,function = "csi_mclk1"; allwinner,muxsel = <0x2>; allwinner,drive = <0x2>; allwinner,pull = <0x0>; linux,phandle = <0xaa>; phandle = <0xaa>; }; csi_mclk1@1 { allwinner,pins = "PE1"; allwinner,pname = "csi_mclk1"; allwinner,function = "io_disabled"; allwinner,muxsel = <0x7>; allwinner,drive = <0x2>; allwinner,pull = <0x0>; linux,phandle = <0xab>; phandle = <0xab>; }; csi_cci1@0 { allwinner,pins = "PE20", "PE21"; allwinner,pname = "csi_cci1_sck", "csi_cci1_sda"; allwinner,function = "csi_cci1"; allwinner,muxsel = <0x2>; allwinner,drive = <0x2>; allwinner,pull = <0x0>; linux,phandle = <0xae>; phandle = <0xae>; }; csi_cci1@1 { allwinner,pins = "PE20", "PE21"; allwinner,pname = "csi_cci1_sck", "csi_cci1_sda"; allwinner,function = "io_disabled"; allwinner,muxsel = <0x7>; allwinner,drive = <0x2>; allwinner,pull = <0x0>; linux,phandle = <0xaf>; phandle = <0xaf>; }; scr0@0 { allwinner,pins = "PG13", "PG14", "PG10", "PG11", "PG12"; allwinner,pname = "scr0_rst", "scr0_det", "scr0_vccen", "scr0_sck", "scr0_sda"; allwinner,function = "sim0"; allwinner,muxsel = <0x4>; allwinner,drive = <0x0>; allwinner,pull = <0x1>; linux,phandle = <0xb8>; phandle = <0xb8>; }; scr0@1 { allwinner,pins = "PG8", "PG9"; allwinner,pname = "scr0_vppen", "scr0_vppp"; allwinner,function = "sim0"; allwinner,muxsel = <0x4>; allwinner,drive = <0x0>; allwinner,pull = <0x1>; linux,phandle = <0xb9>; phandle = <0xb9>; }; scr0@2 { allwinner,pins = "PG8", "PG9", "PG10", "PG11", "PG12", "PG13", "PG14"; allwinner,function = "io_disabled"; allwinner,muxsel = <0x7>; allwinner,drive = <0x0>; allwinner,pull = <0x0>; linux,phandle = <0xba>; phandle = <0xba>; }; scr1@0 { allwinner,pins = "PH5", "PH6", "PH2", "PH3", "PH4"; allwinner,pname = "scr1_rst", "scr1_det", "scr1_vccen", "scr1_sck", "scr1_sda"; allwinner,function = "sim1"; allwinner,muxsel = <0x5>; allwinner,drive = <0x1>; allwinner,pull = <0x1>; linux,phandle = <0x107>; phandle = <0x107>; }; scr1@1 { allwinner,pins = "PH0", "PH1"; allwinner,pname = "scr1_vppen", "scr1_vppp"; allwinner,function = "sim1"; allwinner,muxsel = <0x5>; allwinner,drive = <0x1>; allwinner,pull = <0x1>; linux,phandle = <0x108>; phandle = <0x108>; }; scr1@2 { allwinner,pins = "PH0", "PH1", "PH2", "PH3", "PH4", "PH5", "PH6"; allwinner,function = "io_disabled"; allwinner,muxsel = <0x7>; allwinner,drive = <0x1>; allwinner,pull = <0x0>; linux,phandle = <0x109>; phandle = <0x109>; }; nand0@2 { allwinner,pins = "PC0", "PC1", "PC2", "PC3", "PC4", "PC5", "PC6", "PC7", "PC8", "PC9", "PC10", "PC11", "PC12", "PC13", "PC14", "PC15", "PC16"; allwinner,function = "io_disabled"; allwinner,muxsel = <0x7>; allwinner,drive = <0x1>; allwinner,pull = <0x0>; linux,phandle = <0xbf>; phandle = <0xbf>; }; ac200@2 { allwinner,pins = "PB0"; allwinner,function = "ac200"; allwinner,muxsel = <0x2>; allwinner,drive = <0x1>; allwinner,pull = <0x0>; linux,phandle = <0x10a>; phandle = <0x10a>; }; ac200@3 { allwinner,pins = "PB0"; allwinner,function = "io_disabled"; allwinner,muxsel = <0x7>; allwinner,drive = <0x1>; allwinner,pull = <0x0>; linux,phandle = <0x10b>; phandle = <0x10b>; }; gmac@0 { allwinner,pins = "PI0", "PI1", "PI2", "PI3", "PI4", "PI5", "PI6", "PI7", "PI8", "PI9", "PI10", "PI11", "PI12", "PI13", "PI14", "PI15", "PI16"; allwinner,function = "gmac0"; allwinner,muxsel = <0x2>; allwinner,drive = <0x3>; allwinner,pull = <0x0>; linux,phandle = <0xce>; phandle = <0xce>; }; gmac@1 { allwinner,pins = "PI0", "PI1", "PI2", "PI3", "PI4", "PI5", "PI6", "PI7", "PI8", "PI9", "PI10", "PI11", "PI12", "PI13", "PI14", "PI15", "PI16"; allwinner,function = "io_disabled"; allwinner,muxsel = <0x7>; allwinner,drive = <0x3>; allwinner,pull = <0x0>; linux,phandle = <0xcf>; phandle = <0xcf>; }; gmac1@0 { allwinner,pins = "PA0", "PA1", "PA2", "PA3", "PA4", "PA5", "PA6", "PA7", "PA8", "PA9"; allwinner,function = "gmac1"; allwinner,muxsel = <0x2>; allwinner,drive = <0x3>; allwinner,pull = <0x0>; linux,phandle = <0xd1>; phandle = <0xd1>; }; gmac1@1 { allwinner,pins = "PA0", "PA1", "PA2", "PA3", "PA4", "PA5", "PA6", "PA7", "PA8", "PA9"; allwinner,function = "io_disabled"; allwinner,muxsel = <0x7>; allwinner,drive = <0x3>; allwinner,pull = <0x0>; linux,phandle = <0xd2>; phandle = <0xd2>; }; lvds0@0 { allwinner,pins = "PD0", "PD1", "PD2", "PD3", "PD4", "PD5", "PD8", "PD9", "PD6", "PD7"; allwinner,pname = "PD0", "PD1", "PD2", "PD3", "PD4", "PD5", "PD8", "PD9", "PD6", "PD7"; allwinner,function = "lvds0"; allwinner,muxsel = <0x3>; allwinner,drive = <0x3>; allwinner,pull = <0x0>; linux,phandle = <0x10c>; phandle = <0x10c>; }; lvds0@1 { allwinner,pins = "PD0", "PD1", "PD2", "PD3", "PD4", "PD5", "PD8", "PD9", "PD6", "PD7"; allwinner,pname = "PD0", "PD1", "PD2", "PD3", "PD4", "PD5", "PD8", "PD9", "PD6", "PD7"; allwinner,function = "lvds0_suspend"; allwinner,muxsel = <0x7>; allwinner,drive = <0x3>; allwinner,pull = <0x0>; linux,phandle = <0x10d>; phandle = <0x10d>; }; lvds1@0 { allwinner,pins = "PD10", "PD11", "PD12", "PD13", "PD14", "PD15", "PD18", "PD19", "PD16", "PD17"; allwinner,pname = "PD10", "PD11", "PD12", "PD13", "PD14", "PD15", "PD18", "PD19", "PD16", "PD17"; allwinner,function = "lvds1"; allwinner,muxsel = <0x3>; allwinner,drive = <0x3>; allwinner,pull = <0x0>; linux,phandle = <0x10e>; phandle = <0x10e>; }; lvds1@1 { allwinner,pins = "PD10", "PD11", "PD12", "PD13", "PD14", "PD15", "PD18", "PD19", "PD16", "PD17"; allwinner,pname = "PD10", "PD11", "PD12", "PD13", "PD14", "PD15", "PD18", "PD19", "PD16", "PD17"; allwinner,function = "lvds1_suspend"; allwinner,muxsel = <0x7>; allwinner,drive = <0x3>; allwinner,pull = <0x0>; linux,phandle = <0x10f>; phandle = <0x10f>; }; lvds2link@0 { allwinner,pins = "PD0", "PD1", "PD2", "PD3", "PD4", "PD5", "PD8", "PD9", "PD6", "PD7", "PD10", "PD11", "PD12", "PD13", "PD14", "PD15", "PD18", "PD19", "PD16", "PD17"; allwinner,pname = "PD0", "PD1", "PD2", "PD3", "PD4", "PD5", "PD8", "PD9", "PD6", "PD7", "PD10", "PD11", "PD12", "PD13", "PD14", "PD15", "PD18", "PD19", "PD16", "PD17"; allwinner,function = "lvds1"; allwinner,muxsel = <0x3>; allwinner,drive = <0x3>; allwinner,pull = <0x0>; linux,phandle = <0x110>; phandle = <0x110>; }; lvds2link@1 { allwinner,pins = "PD0", "PD1", "PD2", "PD3", "PD4", "PD5", "PD8", "PD9", "PD6", "PD7", "PD10", "PD11", "PD12", "PD13", "PD14", "PD15", "PD18", "PD19", "PD16", "PD17"; allwinner,pname = "PD0", "PD1", "PD2", "PD3", "PD4", "PD5", "PD8", "PD9", "PD6", "PD7", "PD10", "PD11", "PD12", "PD13", "PD14", "PD15", "PD18", "PD19", "PD16", "PD17"; allwinner,function = "lvds1_suspend"; allwinner,muxsel = <0x7>; allwinner,drive = <0x3>; allwinner,pull = <0x0>; linux,phandle = <0x111>; phandle = <0x111>; }; rgb24@0 { allwinner,pins = "PD0", "PD1", "PD2", "PD3", "PD4", "PD5", "PD6", "PD7", "PD8", "PD9", "PD10", "PD11", "PD12", "PD13", "PD14", "PD15", "PD16", "PD17", "PD18", "PD19", "PD20", "PD21", "PD22", "PD23", "PD24", "PD25", "PD26", "PD27"; allwinner,pname = "PD0", "PD1", "PD2", "PD3", "PD4", "PD5", "PD6", "PD7", "PD8", "PD9", "PD10", "PD11", "PD12", "PD13", "PD14", "PD15", "PD16", "PD17", "PD18", "PD19", "PD20", "PD21", "PD22", "PD23", "PD24", "PD25", "PD26", "PD27"; allwinner,function = "rgb24"; allwinner,muxsel = <0x2>; allwinner,drive = <0x3>; allwinner,pull = <0x0>; linux,phandle = <0x99>; phandle = <0x99>; }; rgb24@1 { allwinner,pins = "PD0", "PD1", "PD2", "PD3", "PD4", "PD5", "PD6", "PD7", "PD8", "PD9", "PD10", "PD11", "PD12", "PD13", "PD14", "PD15", "PD16", "PD17", "PD18", "PD19", "PD20", "PD21", "PD22", "PD23", "PD24", "PD25", "PD26", "PD27"; allwinner,pname = "PD0", "PD1", "PD2", "PD3", "PD4", "PD5", "PD6", "PD7", "PD8", "PD9", "PD10", "PD11", "PD12", "PD13", "PD14", "PD15", "PD16", "PD17", "PD18", "PD19", "PD20", "PD21", "PD22", "PD23", "PD24", "PD25", "PD26", "PD27"; allwinner,function = "rgb24_suspend"; allwinner,muxsel = <0x7>; allwinner,drive = <0x3>; allwinner,pull = <0x0>; linux,phandle = <0x9a>; phandle = <0x9a>; }; pwm5@0 { allwinner,pins = "PA12"; allwinner,function = "pwm5"; allwinner,muxsel = <0x2>; allwinner,drive = <0xffffffff>; allwinner,pull = <0x0>; allwinner,data = <0xffffffff>; linux,phandle = <0xa2>; phandle = <0xa2>; }; pwm5@1 { allwinner,pins = "PA12"; allwinner,function = "io_disabled"; allwinner,muxsel = <0x7>; allwinner,drive = <0xffffffff>; allwinner,pull = <0x0>; allwinner,data = <0xffffffff>; linux,phandle = <0xa3>; phandle = <0xa3>; }; standby@0 { allwinner,pins = "PH6"; allwinner,function = "gpio_out"; allwinner,muxsel = <0x1>; allwinner,data = <0x0>; allwinner,drive = <0x0>; allwinner,pull = <0x0>; linux,phandle = <0xe0>; phandle = <0xe0>; }; standby@1 { allwinner,pins = "PH7"; allwinner,function = "gpio_out"; allwinner,muxsel = <0x1>; allwinner,data = <0x0>; allwinner,drive = <0x2>; allwinner,pull = <0x2>; linux,phandle = <0xdf>; phandle = <0xdf>; }; standby@2 { allwinner,pins = "PG16"; allwinner,function = "gpio_in"; allwinner,muxsel = <0x0>; allwinner,data = <0x0>; allwinner,drive = <0x0>; allwinner,pull = <0x0>; linux,phandle = <0x112>; phandle = <0x112>; }; card0_boot_para@0 { linux,phandle = <0x184>; phandle = <0x184>; allwinner,pins = "PF0", "PF1", "PF2", "PF3", "PF4", "PF5"; allwinner,function = "card0_boot_para"; allwinner,pname = "sdc_d1", "sdc_d0", "sdc_clk", "sdc_cmd", "sdc_d3", "sdc_d2"; allwinner,muxsel = <0x2>; allwinner,pull = <0x1>; allwinner,drive = <0x3>; allwinner,data = <0xffffffff>; }; card2_boot_para@0 { linux,phandle = <0x185>; phandle = <0x185>; allwinner,pins = "PC5", "PC6", "PC10", "PC13", "PC15", "PC8", "PC9", "PC11", "PC14", "PC16", "PC1"; allwinner,function = "card2_boot_para"; allwinner,pname = "sdc_clk", "sdc_cmd", "sdc_d0", "sdc_d1", "sdc_d2", "sdc_d3", "sdc_d4", "sdc_d5", "sdc_d6", "sdc_d7", "sdc_emmc_rst"; allwinner,muxsel = <0x3>; allwinner,pull = <0x1>; allwinner,drive = <0x3>; allwinner,data = <0xffffffff>; }; card2_boot_para@1 { linux,phandle = <0x186>; phandle = <0x186>; allwinner,pins = "PC0"; allwinner,function = "card2_boot_para"; allwinner,pname = "sdc_ds"; allwinner,muxsel = <0x3>; allwinner,pull = <0x2>; allwinner,drive = <0x3>; allwinner,data = <0xffffffff>; }; twi_para@0 { linux,phandle = <0x187>; phandle = <0x187>; allwinner,pins = "PH14", "PH15"; allwinner,function = "twi_para"; allwinner,pname = "twi_scl", "twi_sda"; allwinner,muxsel = <0x2>; allwinner,pull = <0xffffffff>; allwinner,drive = <0xffffffff>; allwinner,data = <0xffffffff>; }; uart_para@0 { linux,phandle = <0x188>; phandle = <0x188>; allwinner,pins = "PH0", "PH1"; allwinner,function = "uart_para"; allwinner,pname = "uart_debug_tx", "uart_debug_rx"; allwinner,muxsel = <0x2>; allwinner,pull = <0x1>; allwinner,drive = <0xffffffff>; allwinner,data = <0xffffffff>; }; jtag_para@0 { linux,phandle = <0x189>; phandle = <0x189>; allwinner,pins = "PH9", "PH10", "PH11", "PH12"; allwinner,function = "jtag_para"; allwinner,pname = "jtag_ms", "jtag_ck", "jtag_do", "jtag_di"; allwinner,muxsel = <0x3>; allwinner,pull = <0xffffffff>; allwinner,drive = <0xffffffff>; allwinner,data = <0xffffffff>; }; uart0@0 { linux,phandle = <0x18a>; phandle = <0x18a>; allwinner,pins = "PH0", "PH1"; allwinner,function = "uart0"; allwinner,pname = "uart0_tx", "uart0_rx"; allwinner,muxsel = <0x2>; allwinner,pull = <0x1>; allwinner,drive = <0xffffffff>; allwinner,data = <0xffffffff>; }; nand0@0 { linux,phandle = <0x18b>; phandle = <0x18b>; allwinner,pins = "PC0", "PC1", "PC2", "PC4", "PC6", "PC7", "PC8", "PC9", "PC10", "PC11", "PC12", "PC13", "PC14"; allwinner,function = "nand0"; allwinner,pname = "nand0_we", "nand0_ale", "nand0_cle", "nand0_nre", "nand0_d0", "nand0_d1", "nand0_d2", "nand0_d3", "nand0_d4", "nand0_d5", "nand0_d6", "nand0_d7", "nand0_ndqs"; allwinner,muxsel = <0x2>; allwinner,pull = <0x0>; allwinner,drive = <0x1>; allwinner,data = <0xffffffff>; }; nand0@1 { linux,phandle = <0x18c>; phandle = <0x18c>; allwinner,pins = "PC3", "PC5", "PC15", "PC16"; allwinner,function = "nand0"; allwinner,pname = "nand0_ce0", "nand0_rb0", "nand0_ce1", "nand0_rb1"; allwinner,muxsel = <0x2>; allwinner,pull = <0x1>; allwinner,drive = <0x1>; allwinner,data = <0xffffffff>; }; }; auto_print { device_type = "auto_print"; status = "okay"; }; dma-controller@03002000 { compatible = "allwinner,sun50i-dma"; reg = <0x0 0x3002000 0x0 0x1000>; interrupts = <0x0 0x2a 0x4>; clocks = <0x1f>; #dma-cells = <0x1>; linux,phandle = <0x113>; phandle = <0x113>; }; mbus-controller@047fa000 { compatible = "allwinner,sun50i-mbus"; reg = <0x0 0x47fa000 0x0 0x1000>; #mbus-cells = <0x1>; linux,phandle = <0x114>; phandle = <0x114>; }; arisc { compatible = "allwinner,sunxi-arisc"; #address-cells = <0x2>; #size-cells = <0x2>; clocks = <0x1e 0x20 0x9 0x2>; clock-names = "losc", "iosc", "hosc", "pll_periph0"; powchk_used = <0x0>; power_reg = <0x2309621>; system_power = <0x32>; }; arisc_space { compatible = "allwinner,arisc_space"; space1 = <0x48040000 0x0 0x14000>; space2 = <0x48100000 0x18000 0x4000>; space3 = <0x48104000 0x0 0x1000>; space4 = <0x48105000 0x0 0x1000>; }; standby_space { compatible = "allwinner,sun50iw9-usbstandby"; space1 = <0x40020000 0x0 0x800>; }; msgbox@03003000 { compatible = "allwinner,msgbox"; clocks = <0x21>; clock-names = "clk_msgbox"; reg = <0x0 0x3003000 0x0 0x1000>; interrupts = <0x0 0x27 0x1>; status = "okay"; linux,phandle = <0x115>; phandle = <0x115>; }; hwspinlock@3004000 { compatible = "allwinner,sunxi-hwspinlock"; clocks = <0x22 0x23>; clock-names = "clk_hwspinlock_rst", "clk_hwspinlock_bus"; reg = <0x0 0x3004000 0x0 0x1000>; num-locks = <0x8>; status = "okay"; linux,phandle = <0x116>; phandle = <0x116>; }; s_cir@07040000 { compatible = "allwinner,s_cir"; reg = <0x0 0x7040000 0x0 0x400>; interrupts = <0x0 0x6a 0x4>; pinctrl-names = "default"; pinctrl-0 = <0x24>; clocks = <0x9 0x25>; supply = "vcc-pl"; supply_vol = "3300000"; status = "okay"; s_cir0_used = <0x1>; ir_power_key_code0 = <0x40>; ir_addr_code0 = <0xfe01>; ir_power_key_code1 = <0x1a>; ir_addr_code1 = <0xfb04>; ir_power_key_code2 = <0xf2>; ir_addr_code2 = <0x2992>; ir_power_key_code3 = <0x57>; ir_addr_code3 = <0x9f00>; ir_power_key_code4 = <0xdc>; ir_addr_code4 = <0x4cb3>; ir_power_key_code5 = <0x18>; ir_addr_code5 = <0xff00>; ir_power_key_code6 = <0xdc>; ir_addr_code6 = <0xdd22>; ir_power_key_code7 = <0xd>; ir_addr_code7 = <0xbc00>; ir_power_key_code8 = <0x4d>; ir_addr_code8 = <0x4040>; ir_power_key_code9 = <0x51>; ir_addr_code9 = <0x7f80>; wakeup-source; linux,phandle = <0x117>; phandle = <0x117>; }; timer@03009000 { compatible = "allwinner,sun4i-a10-timer"; device_type = "soc_timer"; reg = <0x0 0x3009000 0x0 0x400>; interrupts = <0x0 0x30 0x4>; clocks = <0x9>; linux,phandle = <0x118>; phandle = <0x118>; }; rtc@07000000 { compatible = "allwinner,sunxi-rtc"; device_type = "rtc"; auto_switch; wakeup-source; reg = <0x0 0x7000000 0x0 0x200>; interrupts = <0x0 0x68 0x4>; gpr_offset = <0x100>; gpr_len = <0x8>; gpr_cur_pos = <0x6>; linux,phandle = <0x119>; phandle = <0x119>; }; watchdog@030090a0 { compatible = "allwinner,sun50i-wdt"; reg = <0x0 0x30090a0 0x0 0x20>; interrupts = <0x0 0x32 0x4>; linux,phandle = <0x11a>; phandle = <0x11a>; }; ve@01c0e000 { compatible = "allwinner,sunxi-cedar-ve"; reg = <0x0 0x1c0e000 0x0 0x1000 0x0 0x3000000 0x0 0x10 0x0 0x3001000 0x0 0x1000>; interrupts = <0x0 0x5d 0x4>; clocks = <0x26 0x27>; iommus = <0x28 0x3 0x1>; linux,phandle = <0x11b>; phandle = <0x11b>; }; vp9@01c00000 { compatible = "allwinner,sunxi-google-vp9"; reg = <0x0 0x1c00000 0x0 0x1000 0x0 0x3000000 0x0 0x10 0x0 0x3001000 0x0 0x1000>; interrupts = <0x0 0x5a 0x4>; clocks = <0x26>; iommus = <0x28 0x2 0x1>; #clocks = <0xc>; linux,phandle = <0x11c>; phandle = <0x11c>; }; uart@05000000 { compatible = "allwinner,sun50i-uart"; device_type = "uart0"; reg = <0x0 0x5000000 0x0 0x400>; interrupts = <0x0 0x0 0x4>; clocks = <0x29>; pinctrl-names = "default", "sleep"; pinctrl-1 = <0x2b>; uart0_port = <0x0>; uart0_type = <0x2>; status = "okay"; linux,phandle = <0x11d>; phandle = <0x11d>; pinctrl-0 = <0x18a>; }; uart@05000400 { compatible = "allwinner,sun50i-uart"; device_type = "uart1"; reg = <0x0 0x5000400 0x0 0x400>; interrupts = <0x0 0x1 0x4>; clocks = <0x2c>; pinctrl-names = "default", "sleep"; pinctrl-0 = <0x2d>; pinctrl-1 = <0x2e>; uart1_port = <0x1>; uart1_type = <0x4>; status = "okay"; linux,phandle = <0x11e>; phandle = <0x11e>; }; uart@05000800 { compatible = "allwinner,sun50i-uart"; device_type = "uart2"; reg = <0x0 0x5000800 0x0 0x400>; interrupts = <0x0 0x2 0x4>; clocks = <0x2f>; pinctrl-names = "default", "sleep"; pinctrl-0 = <0x30>; pinctrl-1 = <0x31>; uart2_port = <0x2>; uart2_type = <0x4>; status = "disabled"; linux,phandle = <0x11f>; phandle = <0x11f>; }; uart@05000c00 { compatible = "allwinner,sun50i-uart"; device_type = "uart3"; reg = <0x0 0x5000c00 0x0 0x400>; interrupts = <0x0 0x3 0x4>; clocks = <0x32>; pinctrl-names = "default", "sleep"; pinctrl-0 = <0x33>; pinctrl-1 = <0x34>; uart3_port = <0x3>; uart3_type = <0x4>; status = "disabled"; linux,phandle = <0x120>; phandle = <0x120>; }; uart@05001000 { compatible = "allwinner,sun50i-uart"; device_type = "uart4"; reg = <0x0 0x5001000 0x0 0x400>; interrupts = <0x0 0x4 0x4>; clocks = <0x35>; pinctrl-names = "default", "sleep"; pinctrl-0 = <0x36>; pinctrl-1 = <0x37>; uart4_port = <0x4>; uart4_type = <0x4>; status = "disabled"; linux,phandle = <0x121>; phandle = <0x121>; }; uart@05001400 { compatible = "allwinner,sun50i-uart"; device_type = "uart5"; reg = <0x0 0x5001400 0x0 0x400>; interrupts = <0x0 0x5 0x4>; clocks = <0x38>; pinctrl-names = "default", "sleep"; pinctrl-0 = <0x39>; pinctrl-1 = <0x3a>; uart5_port = <0x5>; uart5_type = <0x2>; status = "disabled"; linux,phandle = <0x122>; phandle = <0x122>; }; twi@0x05002000 { #address-cells = <0x1>; #size-cells = <0x0>; compatible = "allwinner,sun50i-twi"; device_type = "twi0"; reg = <0x0 0x5002000 0x0 0x400>; interrupts = <0x0 0x6 0x4>; clocks = <0x3b>; clock-frequency = <0x61a80>; pinctrl-names = "default", "sleep"; pinctrl-0 = <0x3c>; pinctrl-1 = <0x3d>; status = "disable"; linux,phandle = <0x123>; phandle = <0x123>; }; twi@0x05002400 { #address-cells = <0x1>; #size-cells = <0x0>; compatible = "allwinner,sun50i-twi"; device_type = "twi1"; reg = <0x0 0x5002400 0x0 0x400>; interrupts = <0x0 0x7 0x4>; clocks = <0x3e>; clock-frequency = <0x30d40>; pinctrl-names = "default", "sleep"; pinctrl-0 = <0x3f>; pinctrl-1 = <0x40>; status = "disable"; linux,phandle = <0x124>; phandle = <0x124>; }; twi@0x05002800 { #address-cells = <0x1>; #size-cells = <0x0>; compatible = "allwinner,sun50i-twi"; device_type = "twi2"; reg = <0x0 0x5002800 0x0 0x400>; interrupts = <0x0 0x8 0x4>; clocks = <0x41>; clock-frequency = <0x30d40>; pinctrl-names = "default", "sleep"; pinctrl-0 = <0x42>; pinctrl-1 = <0x43>; status = "disable"; linux,phandle = <0x125>; phandle = <0x125>; }; twi@0x05002c00 { #address-cells = <0x1>; #size-cells = <0x0>; compatible = "allwinner,sun50i-twi"; device_type = "twi3"; reg = <0x0 0x5002c00 0x0 0x400>; interrupts = <0x0 0x9 0x4>; clocks = <0x44>; clock-frequency = <0x30d40>; pinctrl-names = "default", "sleep"; pinctrl-0 = <0x45>; pinctrl-1 = <0x46>; status = "okay"; linux,phandle = <0x126>; phandle = <0x126>; }; twi@0x05003000 { #address-cells = <0x1>; #size-cells = <0x0>; compatible = "allwinner,sun50i-twi"; device_type = "twi4"; reg = <0x0 0x5003000 0x0 0x400>; interrupts = <0x0 0xa 0x4>; clocks = <0x47>; clock-frequency = <0x30d40>; pinctrl-names = "default", "sleep"; pinctrl-0 = <0x48>; pinctrl-1 = <0x49>; status = "disable"; linux,phandle = <0x127>; phandle = <0x127>; }; twi@0x07081400 { #address-cells = <0x1>; #size-cells = <0x0>; compatible = "allwinner,sun50i-twi"; device_type = "twi5"; reg = <0x0 0x7081400 0x0 0x400>; interrupts = <0x0 0x69 0x4>; clocks = <0x4a>; clock-frequency = <0x30d40>; pinctrl-names = "default", "sleep"; pinctrl-0 = <0x4b>; pinctrl-1 = <0x4c>; status = "okay"; no_suspend = <0x1>; linux,phandle = <0x128>; phandle = <0x128>; pmu { compatible = "x-powers,axp1530"; reg = <0x36>; wakeup-source; linux,phandle = <0x129>; phandle = <0x129>; standby_param { vcc-dram = <0x4>; linux,phandle = <0x12a>; phandle = <0x12a>; }; regulators { dcdc1 { regulator-name = "axp1530-dcdc1"; regulator-min-microvolt = <0x7a120>; regulator-max-microvolt = <0x33e140>; regulator-step-delay-us = <0x19>; regulator-final-delay-us = <0x32>; regulator-always-on; linux,phandle = <0x12b>; phandle = <0x12b>; }; dcdc2 { regulator-name = "axp1530-dcdc2"; regulator-min-microvolt = <0x7a120>; regulator-max-microvolt = <0x177fa0>; regulator-step-delay-us = <0x19>; regulator-final-delay-us = <0x32>; regulator-ramp-delay = <0xc8>; regulator-always-on; linux,phandle = <0xd8>; phandle = <0xd8>; }; dcdc3 { regulator-name = "axp1530-dcdc3"; regulator-min-microvolt = <0x7a120>; regulator-max-microvolt = <0x1c1380>; regulator-step-delay-us = <0x19>; regulator-final-delay-us = <0x32>; regulator-always-on; linux,phandle = <0x12c>; phandle = <0x12c>; }; ldo1 { regulator-name = "axp1530-aldo1"; regulator-min-microvolt = <0x7a120>; regulator-max-microvolt = <0x3567e0>; regulator-step-delay-us = <0x19>; regulator-final-delay-us = <0x32>; regulator-always-on; linux,phandle = <0x68>; phandle = <0x68>; }; ldo2 { regulator-name = "axp1530-dldo1"; regulator-min-microvolt = <0x7a120>; regulator-max-microvolt = <0x3567e0>; regulator-step-delay-us = <0x19>; regulator-final-delay-us = <0x32>; regulator-always-on; linux,phandle = <0x69>; phandle = <0x69>; }; }; }; }; usbc0@0 { device_type = "usbc0"; compatible = "allwinner,sunxi-otg-manager"; usb_port_type = <0x1>; usb_detect_type = <0x1>; usb_id_gpio; usb_det_vbus_gpio; usb_drv_vbus_gpio; usb_host_init_state = <0x0>; usb_regulator_io = "nocare"; usb_wakeup_suspend = <0x2>; usb_luns = <0x3>; usb_serial_unique = <0x0>; usb_serial_number = "20080411"; rndis_wceis = <0x1>; wakeup-source; status = "okay"; usb_detect_mode = <0x0>; linux,phandle = <0x12d>; phandle = <0x12d>; }; udc-controller@0x05100000 { compatible = "allwinner,sunxi-udc"; reg = <0x0 0x5100000 0x0 0x1000 0x0 0x0 0x0 0x100>; interrupts = <0x0 0x19 0x4>; clocks = <0x4d 0x4e>; status = "okay"; linux,phandle = <0x12e>; phandle = <0x12e>; }; ehci0-controller@0x05101000 { compatible = "allwinner,sunxi-ehci0"; reg = <0x0 0x5101000 0x0 0xfff 0x0 0x0 0x0 0x100 0x0 0x5100000 0x0 0x1000>; interrupts = <0x0 0x1a 0x4>; clocks = <0x4d 0x4f>; hci_ctrl_no = <0x0>; status = "okay"; linux,phandle = <0x12f>; phandle = <0x12f>; }; ohci0-controller@0x05101400 { compatible = "allwinner,sunxi-ohci0"; reg = <0x0 0x5101000 0x0 0xfff 0x0 0x0 0x0 0x100 0x0 0x5100000 0x0 0x1000>; interrupts = <0x0 0x1b 0x4>; clocks = <0x4d 0x50 0x51 0x52 0x9 0x1e>; hci_ctrl_no = <0x0>; status = "okay"; linux,phandle = <0x130>; phandle = <0x130>; }; usbc1@0 { device_type = "usbc1"; usb_drv_vbus_gpio = <0x53 0x7 0x8 0x0 0x1 0xffffffff 0xffffffff>; usb_host_init_state = <0x1>; usb_regulator_io = "nocare"; usb_wakeup_suspend = <0x2>; wakeup-source; status = "okay"; linux,phandle = <0x131>; phandle = <0x131>; }; ehci1-controller@0x05200000 { compatible = "allwinner,sunxi-ehci1"; reg = <0x0 0x5200000 0x0 0xfff 0x0 0x0 0x0 0x100 0x0 0x5100000 0x0 0x1000>; interrupts = <0x0 0x1c 0x4>; clocks = <0x54 0x55>; hci_ctrl_no = <0x1>; status = "okay"; linux,phandle = <0x132>; phandle = <0x132>; }; ohci1-controller@0x05200400 { compatible = "allwinner,sunxi-ohci1"; reg = <0x0 0x5200000 0x0 0xfff 0x0 0x0 0x0 0x100 0x0 0x5100000 0x0 0x1000>; interrupts = <0x0 0x1d 0x4>; clocks = <0x54 0x56 0x57 0x52 0x9 0x1e>; hci_ctrl_no = <0x1>; status = "okay"; linux,phandle = <0x133>; phandle = <0x133>; }; usbc2@0 { device_type = "usbc2"; usb_drv_vbus_gpio; usb_host_init_state = <0x1>; usb_regulator_io = "nocare"; usb_wakeup_suspend = <0x2>; wakeup-source; status = "okay"; linux,phandle = <0x134>; phandle = <0x134>; }; ehci2-controller@0x05310000 { compatible = "allwinner,sunxi-ehci2"; reg = <0x0 0x5310000 0x0 0xfff 0x0 0x0 0x0 0x100 0x0 0x5100000 0x0 0x1000>; interrupts = <0x0 0x1e 0x4>; clocks = <0x58 0x59>; hci_ctrl_no = <0x2>; status = "okay"; linux,phandle = <0x135>; phandle = <0x135>; }; ohci2-controller@0x05310400 { compatible = "allwinner,sunxi-ohci2"; reg = <0x0 0x5310000 0x0 0xfff 0x0 0x0 0x0 0x100 0x0 0x5100000 0x0 0x1000>; interrupts = <0x0 0x1f 0x4>; clocks = <0x58 0x5a 0x5b 0x52 0x9 0x1e>; hci_ctrl_no = <0x2>; status = "okay"; linux,phandle = <0x136>; phandle = <0x136>; }; usbc3@0 { device_type = "usbc3"; usb_drv_vbus_gpio; usb_host_init_state = <0x1>; usb_regulator_io = "nocare"; usb_wakeup_suspend = <0x2>; wakeup-source; status = "okay"; linux,phandle = <0x137>; phandle = <0x137>; }; ehci3-controller@0x05311000 { compatible = "allwinner,sunxi-ehci3"; reg = <0x0 0x5311000 0x0 0xfff 0x0 0x0 0x0 0x100 0x0 0x5100000 0x0 0x1000>; interrupts = <0x0 0x20 0x4>; clocks = <0x5c 0x5d>; hci_ctrl_no = <0x3>; status = "okay"; linux,phandle = <0x138>; phandle = <0x138>; }; ohci3-controller@0x05311400 { compatible = "allwinner,sunxi-ohci3"; reg = <0x0 0x5311000 0x0 0xfff 0x0 0x0 0x0 0x100 0x0 0x5100000 0x0 0x1000>; interrupts = <0x0 0x21 0x4>; clocks = <0x5c 0x5e 0x5f 0x52 0x9 0x1e>; hci_ctrl_no = <0x3>; status = "okay"; linux,phandle = <0x139>; phandle = <0x139>; }; ac200_codec { compatible = "allwinner,ac200_codec"; status = "disabled"; linux,phandle = <0x13a>; phandle = <0x13a>; }; spdif-controller@0x05093000 { compatible = "allwinner,sunxi-spdif"; reg = <0x0 0x5093000 0x0 0x40>; clocks = <0x60 0x7 0x61>; pinctrl-names = "default", "sleep"; pinctrl-0 = <0x62>; pinctrl-1 = <0x63>; device_type = "spdif"; status = "okay"; linux,phandle = <0x75>; phandle = <0x75>; }; dmic-controller@0x05095000 { compatible = "allwinner,sunxi-dmic"; reg = <0x0 0x5095000 0x0 0x50>; clocks = <0x60 0x7 0x64>; pinctrl-names = "default", "sleep"; pinctrl-0 = <0x65>; pinctrl-1 = <0x66>; device_type = "dmic"; status = "disabled"; linux,phandle = <0x76>; phandle = <0x76>; }; codec@0x05096000 { compatible = "allwinner,sunxi-internal-codec"; reg = <0x0 0x5096000 0x0 0x31c>; clocks = <0x60 0x7 0x67>; device_type = "codec"; status = "okay"; adcdrc_cfg = <0x0>; adchpf_cfg = <0x0>; dacdrc_cfg = <0x0>; dachpf_cfg = <0x0>; fmin_gain = <0x3>; linein_gain = <0x3>; digital_vol = <0x0>; lineout_vol = <0x1a>; ramp_func_used = <0x1>; avcc-supply = <0x68>; vcc33_audio-supply = <0x69>; linux,phandle = <0x78>; phandle = <0x78>; }; cpudai-controller@0x05096000 { compatible = "allwinner,sunxi-internal-cpudai"; reg = <0x0 0x5096000 0x0 0x31c>; device_type = "cpudai"; status = "okay"; linux,phandle = <0x77>; phandle = <0x77>; }; cpudai0-controller@0x05097000 { compatible = "allwinner,sunxi-ahub-cpudai"; reg = <0x0 0x5097000 0x0 0xadf>; id = <0x0>; status = "okay"; linux,phandle = <0x79>; phandle = <0x79>; }; cpudai1-controller@0x05097000 { compatible = "allwinner,sunxi-ahub-cpudai"; reg = <0x0 0x5097000 0x0 0xadf>; id = <0x1>; status = "okay"; linux,phandle = <0x7a>; phandle = <0x7a>; }; cpudai2-controller@0x05097000 { compatible = "allwinner,sunxi-ahub-cpudai"; reg = <0x0 0x5097000 0x0 0xadf>; id = <0x2>; status = "okay"; linux,phandle = <0x7b>; phandle = <0x7b>; }; cpudai3-controller@0x05097000 { compatible = "allwinner,sunxi-ahub-cpudai"; reg = <0x0 0x5097000 0x0 0xadf>; id = <0x3>; status = "okay"; linux,phandle = <0x13b>; phandle = <0x13b>; }; ahub_codec@0x05097000 { compatible = "allwinner,sunxi-ahub"; reg = <0x0 0x5097000 0x0 0xadf>; clocks = <0x60 0x7 0x6a>; status = "okay"; linux,phandle = <0x7c>; phandle = <0x7c>; }; ahub_daudio0@0x05097000 { compatible = "allwinner,sunxi-ahub-daudio"; reg = <0x0 0x5097000 0x0 0xadf>; clocks = <0x60 0x7 0x6a>; pinctrl-names = "default", "sleep"; pinctrl-0 = <0x6b>; pinctrl-1 = <0x6c>; tdm_num = <0x0>; device_type = "ahub_daudio0"; status = "okay"; pinconfig = <0x1>; frametype = <0x0>; pcm_lrck_period = <0x20>; slot_width_select = <0x20>; daudio_master = <0x4>; audio_format = <0x1>; signal_inversion = <0x1>; tdm_config = <0x1>; mclk_div = <0x0>; linux,phandle = <0x71>; phandle = <0x71>; }; ahub_daudio1@0x05097000 { compatible = "allwinner,sunxi-ahub-daudio"; reg = <0x0 0x5097000 0x0 0xadf>; clocks = <0x60 0x7 0x6a>; tdm_num = <0x1>; device_type = "ahub_daudio1"; status = "okay"; pinconfig = <0x0>; frametype = <0x0>; pcm_lrck_period = <0x20>; slot_width_select = <0x20>; daudio_master = <0x4>; audio_format = <0x1>; signal_inversion = <0x1>; tdm_config = <0x1>; mclk_div = <0x1>; linux,phandle = <0x72>; phandle = <0x72>; }; ahub_daudio2@0x05097000 { compatible = "allwinner,sunxi-ahub-daudio"; reg = <0x0 0x5097000 0x0 0xadf>; clocks = <0x60 0x7 0x6a>; pinctrl-names = "default", "sleep"; pinctrl-0 = <0x6d>; pinctrl-1 = <0x6e>; tdm_num = <0x2>; device_type = "ahub_daudio2"; status = "disabled"; pinconfig = <0x1>; frametype = <0x0>; pcm_lrck_period = <0x20>; slot_width_select = <0x20>; daudio_master = <0x4>; audio_format = <0x1>; signal_inversion = <0x1>; tdm_config = <0x1>; mclk_div = <0x4>; linux,phandle = <0x73>; phandle = <0x73>; }; ahub_daudio3@0x05097000 { compatible = "allwinner,sunxi-ahub-daudio"; reg = <0x0 0x5097000 0x0 0xadf>; clocks = <0x60 0x7 0x6a>; pinctrl-names = "default", "sleep"; pinctrl-0 = <0x6f>; pinctrl-1 = <0x70>; tdm_num = <0x3>; device_type = "ahub_daudio3"; status = "disabled"; pinconfig = <0x1>; frametype = <0x0>; pcm_lrck_period = <0x20>; slot_width_select = <0x20>; daudio_master = <0x4>; audio_format = <0x1>; signal_inversion = <0x1>; tdm_config = <0x1>; mclk_div = <0x4>; linux,phandle = <0x74>; phandle = <0x74>; }; sound@0 { compatible = "allwinner,sunxi-daudio0-machine"; sunxi,cpudai-controller = <0x71>; device_type = "snddaudio0"; status = "okay"; linux,phandle = <0x13c>; phandle = <0x13c>; }; sound@1 { compatible = "allwinner,sunxi-hdmi-machine"; sunxi,cpudai-controller = <0x72>; device_type = "sndhdmi"; status = "okay"; linux,phandle = <0x13d>; phandle = <0x13d>; }; sound@2 { compatible = "allwinner,sunxi-daudio2-machine"; sunxi,cpudai-controller = <0x73>; device_type = "snddaudio2"; status = "disabled"; linux,phandle = <0x13e>; phandle = <0x13e>; }; sound@3 { compatible = "allwinner,sunxi-daudio3-machine"; sunxi,cpudai-controller = <0x74>; device_type = "snddaudio3"; status = "disabled"; linux,phandle = <0x13f>; phandle = <0x13f>; }; sound@4 { compatible = "allwinner,sunxi-spdif-machine"; sunxi,spdif-controller = <0x75>; device_type = "sndspdif"; status = "okay"; linux,phandle = <0x140>; phandle = <0x140>; }; sound@5 { compatible = "allwinner,sunxi-dmic-machine"; sunxi,dmic-controller = <0x76>; device_type = "snddmic"; status = "disabled"; linux,phandle = <0x141>; phandle = <0x141>; }; sound@6 { compatible = "allwinner,sunxi-codec-machine"; sunxi,cpudai-controller = <0x77>; sunxi,audio-codec = <0x78>; device_type = "sndcodec"; status = "okay"; linux,phandle = <0x142>; phandle = <0x142>; }; sound@7 { compatible = "allwinner,sunxi-ahub-machine"; sunxi,cpudai-controller0 = <0x79>; sunxi,cpudai-controller1 = <0x7a>; sunxi,cpudai-controller2 = <0x7b>; sunxi,audio-codec = <0x7c>; device_type = "sndahub"; status = "okay"; linux,phandle = <0x143>; phandle = <0x143>; }; spi@05010000 { #address-cells = <0x1>; #size-cells = <0x0>; compatible = "allwinner,sun50i-spi"; device_type = "spi0"; reg = <0x0 0x5010000 0x0 0x1000>; interrupts = <0x0 0xc 0x4>; clocks = <0x2 0x7d>; clock-frequency = <0x5f5e100>; pinctrl-names = "default", "sleep"; pinctrl-0 = <0x7e 0x7f>; pinctrl-1 = <0x80>; spi0_cs_number = <0x1>; spi0_cs_bitmap = <0x1>; status = "disabled"; linux,phandle = <0x144>; phandle = <0x144>; }; spi@05011000 { #address-cells = <0x1>; #size-cells = <0x0>; compatible = "allwinner,sun50i-spi"; device_type = "spi1"; reg = <0x0 0x5011000 0x0 0x1000>; interrupts = <0x0 0xd 0x4>; clocks = <0x2 0x81>; clock-frequency = <0x5f5e100>; pinctrl-names = "default", "sleep"; pinctrl-0 = <0x82 0x83>; pinctrl-1 = <0x84>; spi1_cs_number = <0x1>; spi1_cs_bitmap = <0x1>; status = "disable"; spi_slave_mode = <0x0>; linux,phandle = <0x145>; phandle = <0x145>; spi_board1 { device_type = "spi_board1"; compatible = "rohm,dh2228fv"; spi-max-frequency = <0x5f5e100>; reg = <0x0>; spi-rx-bus-width = <0x1>; spi-tx-bus-width = <0x1>; }; }; pcie@0x05400000 { #address-cells = <0x3>; #size-cells = <0x2>; compatible = "allwinner,sun50i-pcie"; reg = <0x0 0x5400000 0x0 0x2000 0x0 0x5410000 0x0 0x10000>; reg-names = "dbi", "config"; device_type = "pci"; ranges = <0x800 0x0 0x5410000 0x0 0x5410000 0x0 0x10000 0x81000000 0x0 0x0 0x0 0x5e00000 0x0 0x10000 0x82000000 0x0 0x5500000 0x0 0x5500000 0x0 0x800000>; num-lanes = <0x1>; interrupts = <0x0 0x7f 0x4 0x0 0x7e 0x4>; interrupt-names = "msi"; #interrupt-cells = <0x1>; interrupt-map-mask = <0x0 0x0 0x0 0x0>; interrupt-map = <0x0 0x0 0x0 0x1 0x85 0x0 0x7f 0x4>; status = "okay"; linux,phandle = <0x146>; phandle = <0x146>; }; sdmmc@04022000 { compatible = "allwinner,sunxi-mmc-v4p6x"; device_type = "sdc2"; reg = <0x0 0x4022000 0x0 0x1000>; interrupts = <0x0 0x25 0x4>; clocks = <0x9 0x86 0x87 0x88 0x89>; clock-names = "osc24m", "pll_periph", "mmc", "ahb", "rst"; pinctrl-names = "default", "sleep"; pinctrl-0 = <0x8a 0x8b>; pinctrl-1 = <0x8c>; bus-width = <0x8>; cap-mmc-highspeed; cap-cmd23; mmc-cache-ctrl; non-removable; max-frequency = <0x5f5e100>; cap-erase; mmc-high-capacity-erase-size; no-sdio; no-sd; sdc_tm4_sm0_freq0 = <0x0>; sdc_tm4_sm0_freq1 = <0x0>; sdc_tm4_sm1_freq0 = <0x0>; sdc_tm4_sm1_freq1 = <0x0>; sdc_tm4_sm2_freq0 = <0x0>; sdc_tm4_sm2_freq1 = <0x0>; sdc_tm4_sm3_freq0 = <0x5000000>; sdc_tm4_sm3_freq1 = <0x5>; sdc_tm4_sm4_freq0 = <0x50000>; sdc_tm4_sm4_freq1 = <0x4>; status = "disabled"; mmc-ddr-1_8v; mmc-hs200-1_8v; mmc-hs400-1_8v; sunxi-power-save-mode; sunxi-dis-signal-vol-sw; ctl-spec-caps = <0x8>; vmmc-supply = <0x69>; vqmmc-supply = <0x68>; linux,phandle = <0x147>; phandle = <0x147>; }; sdmmc@04020000 { compatible = "allwinner,sunxi-mmc-v4p1x"; device_type = "sdc0"; reg = <0x0 0x4020000 0x0 0x1000>; interrupts = <0x0 0x23 0x4>; clocks = <0x9 0x86 0x8d 0x8e 0x8f>; clock-names = "osc24m", "pll_periph", "mmc", "ahb", "rst"; pinctrl-names = "default", "sleep", "uart_jtag"; pinctrl-0 = <0x90>; pinctrl-1 = <0x91>; pinctrl-2 = <0x92>; max-frequency = <0x8f0d180>; bus-width = <0x4>; cd-gpios = <0x53 0x8 0x10 0x6 0x1 0x3 0xffffffff>; cap-sd-highspeed; cap-wait-while-busy; no-sdio; no-mmc; sunxi-power-save-mode; status = "okay"; cd-used-24M; sd-uhs-sdr50; sd-uhs-ddr50; sd-uhs-sdr104; ctl-spec-caps = <0x8>; vmmc-supply = <0x69>; vqmmc33sw-supply = <0x69>; vdmmc33sw-supply = <0x69>; vqmmc18sw-supply = <0x68>; vdmmc18sw-supply = <0x68>; linux,phandle = <0x148>; phandle = <0x148>; }; sdmmc@04021000 { compatible = "allwinner,sunxi-mmc-v4p1x"; device_type = "sdc1"; reg = <0x0 0x4021000 0x0 0x1000>; interrupts = <0x0 0x24 0x4>; clocks = <0x9 0x86 0x93 0x94 0x95>; clock-names = "osc24m", "pll_periph", "mmc", "ahb", "rst"; pinctrl-names = "default", "sleep"; pinctrl-0 = <0x96>; pinctrl-1 = <0x97>; max-frequency = <0x8f0d180>; bus-width = <0x4>; keep-power-in-suspend; sunxi-dly-52M-ddr4 = <0x1 0x0 0x0 0x0 0x2>; sunxi-dly-104M = <0x1 0x0 0x0 0x0 0x1>; sunxi-dly-208M = <0x1 0x0 0x0 0x0 0x1>; status = "okay"; no-mmc; no-sd; cap-sd-highspeed; sd-uhs-sdr50; sd-uhs-ddr50; sd-uhs-sdr104; sunxi-dis-signal-vol-sw; cap-sdio-irq; ignore-pm-notify; ctl-spec-caps = <0x8>; linux,phandle = <0xd4>; phandle = <0xd4>; }; disp@01000000 { compatible = "allwinner,sunxi-disp"; reg = <0x0 0x1000000 0x0 0x1400000 0x0 0x6510000 0x0 0x200 0x0 0x6511000 0x0 0x1000 0x0 0x6512000 0x0 0x1000 0x0 0x6515000 0x0 0x1000 0x0 0x6516000 0x0 0x1000>; interrupts = <0x0 0x58 0x4 0x0 0x40 0x4 0x0 0x41 0x4 0x0 0x42 0x4 0x0 0x43 0x4>; clocks = <0xb 0x98 0x12 0x13 0x14 0x15 0x16>; boot_disp = <0x0>; fb_base = <0x0>; iommus = <0x28 0x0 0x0>; status = "okay"; disp_init_enable = <0x1>; disp_mode = <0x0>; screen0_output_type = <0x3>; screen0_output_mode = <0xa>; screen0_output_format = <0x0>; screen0_output_bits = <0x0>; screen0_output_eotf = <0x4>; screen0_output_cs = <0x101>; screen0_output_dvi_hdmi = <0x2>; screen0_output_range = <0x2>; screen0_output_scan = <0x0>; screen0_output_aspect_ratio = <0x8>; screen1_output_type = <0x2>; screen1_output_mode = <0xb>; screen1_output_format = <0x1>; screen1_output_bits = <0x0>; screen1_output_eotf = <0x4>; screen1_output_cs = <0x104>; screen1_output_dvi_hdmi = <0x0>; screen1_output_range = <0x2>; screen1_output_scan = <0x0>; screen1_output_aspect_ratio = <0x8>; dev0_output_type = <0x4>; dev0_output_mode = <0xa>; dev0_screen_id = <0x0>; dev0_do_hpd = <0x1>; dev1_output_type = <0x2>; dev1_output_mode = <0xb>; dev1_screen_id = <0x1>; dev1_do_hpd = <0x1>; dev2_output_type = <0x0>; def_output_dev = <0x0>; hdmi_mode_check = <0x1>; fb0_format = <0x0>; fb0_width = <0x500>; fb0_height = <0x2d0>; fb1_format = <0x0>; fb1_width = <0x0>; fb1_height = <0x0>; chn_cfg_mode = <0x1>; disp_para_zone = <0x1>; linux,phandle = <0x149>; phandle = <0x149>; }; tv0@01c94000 { compatible = "allwinner,sunxi-tv"; reg = <0x0 0x6520000 0x0 0x100 0x0 0x6524000 0x0 0x3fc>; clocks = <0x18 0x17>; device_type = "tv0"; pinctrl-names = "active", "sleep"; status = "okay"; dac_src0 = <0x0>; dac_type0 = <0x0>; interface = <0x1>; linux,phandle = <0x14a>; phandle = <0x14a>; }; lcd0@01c0c000 { compatible = "allwinner,sunxi-lcd0"; pinctrl-names = "active", "sleep"; status = "okay"; lcd_used = <0x0>; lcd_driver_name = "default_lcd"; lcd_backlight = <0x32>; lcd_if = <0x0>; lcd_x = <0x500>; lcd_y = <0x320>; lcd_width = <0x96>; lcd_height = <0x5e>; lcd_dclk_freq = <0x46>; lcd_pwm_used = <0x0>; lcd_pwm_ch = <0x0>; lcd_pwm_freq = <0xc350>; lcd_pwm_pol = <0x0>; lcd_pwm_max_limit = <0xff>; lcd_hbp = <0x14>; lcd_ht = <0x58a>; lcd_hspw = <0xa>; lcd_vbp = <0xa>; lcd_vt = <0x32e>; lcd_vspw = <0x5>; lcd_lvds_if = <0x0>; lcd_lvds_colordepth = <0x0>; lcd_lvds_mode = <0x0>; lcd_frm = <0x0>; lcd_hv_clk_phase = <0x0>; lcd_hv_sync_polarity = <0x0>; lcd_gamma_en = <0x0>; lcd_bright_curve_en = <0x0>; lcd_cmap_en = <0x0>; deu_mode = <0x0>; lcdgamma4iep = <0x16>; smart_color = <0x5a>; lcd_pin_power = "bldo1"; lcd_power = "dc1sw"; pinctrl-0 = <0x99>; pinctrl-1 = <0x9a>; linux,phandle = <0x14b>; phandle = <0x14b>; }; lcd1@01c0c001 { compatible = "allwinner,sunxi-lcd1"; pinctrl-names = "active", "sleep"; status = "okay"; linux,phandle = <0x14c>; phandle = <0x14c>; }; boot_disp { compatible = "allwinner,boot_disp"; linux,phandle = <0x14d>; phandle = <0x14d>; }; hdmi@06000000 { compatible = "allwinner,sunxi-hdmi"; reg = <0x0 0x6000000 0x0 0x100000>; interrupts = <0x0 0x3f 0x0>; clocks = <0xf 0x10 0x19 0x11>; status = "okay"; hdmi_used = <0x1>; hdmi_power_cnt = <0x2>; hdmi_power0 = "vcc-hdmi"; hdmi_power1 = "vdd-hdmi"; hdmi_hdcp_enable = <0x1>; hdmi_hdcp22_enable = <0x1>; hdmi_cts_compatibility = <0x0>; hdmi_cec_support = <0x0>; hdmi_cec_super_standby = <0x0>; hdmi_skip_bootedid = <0x1>; ddc_en_io_ctrl = <0x0>; power_io_ctrl = <0x0>; linux,phandle = <0x14e>; phandle = <0x14e>; }; g2d@01480000 { compatible = "allwinner,sunxi-g2d"; reg = <0x0 0x1480000 0x0 0x3ffff>; interrupts = <0x0 0x5a 0x4>; clocks = <0xd>; iommus = <0x28 0x6 0x1>; linux,phandle = <0x14f>; phandle = <0x14f>; }; tr@01000000 { compatible = "allwinner,sun50i-tr"; reg = <0x0 0x1000000 0x0 0x200bc>; interrupts = <0x0 0x60 0x4>; clocks = <0xb>; status = "okay"; linux,phandle = <0x150>; phandle = <0x150>; }; pwm@0300a000 { compatible = "allwinner,sunxi-pwm"; reg = <0x0 0x300a000 0x0 0x3ff>; clocks = <0x9b>; pwm-number = <0x6>; pwm-base = <0x0>; pwms = <0x9c 0x9d 0x9e 0x9f 0xa0 0xa1>; linux,phandle = <0x151>; phandle = <0x151>; }; pwm0@0300a000 { compatible = "allwinner,sunxi-pwm0"; pinctrl-names = "active", "sleep"; reg_base = <0x300a000>; linux,phandle = <0x9c>; phandle = <0x9c>; }; pwm1@0300a000 { compatible = "allwinner,sunxi-pwm1"; pinctrl-names = "active", "sleep"; reg_base = <0x300a000>; linux,phandle = <0x9d>; phandle = <0x9d>; }; pwm2@0300a000 { compatible = "allwinner,sunxi-pwm2"; pinctrl-names = "active", "sleep"; reg_base = <0x300a000>; linux,phandle = <0x9e>; phandle = <0x9e>; }; pwm3@0300a000 { compatible = "allwinner,sunxi-pwm3"; pinctrl-names = "active", "sleep"; reg_base = <0x300a000>; linux,phandle = <0x9f>; phandle = <0x9f>; }; pwm4@0300a000 { compatible = "allwinner,sunxi-pwm4"; pinctrl-names = "active", "sleep"; reg_base = <0x300a000>; linux,phandle = <0xa0>; phandle = <0xa0>; }; pwm5@0300a000 { compatible = "allwinner,sunxi-pwm5"; pinctrl-names = "active", "sleep"; reg_base = <0x300a000>; pinctrl-0 = <0xa2>; pinctrl-1 = <0xa3>; clk_bypass_output = <0x1>; linux,phandle = <0xa1>; phandle = <0xa1>; }; ac200 { compatible = "allwinner,sunxi-ac200"; status = "okay"; tv_used = <0x1>; tv_twi_used = <0x1>; tv_twi_id = <0x3>; tv_twi_addr = <0x10>; tv_pwm_ch = <0x5>; linux,phandle = <0x152>; phandle = <0x152>; }; vind@0 { compatible = "allwinner,sunxi-vin-media", "simple-bus"; #address-cells = <0x2>; #size-cells = <0x2>; ranges; device_id = <0x0>; vind0_clk = <0x16e36000>; reg = <0x0 0x6600800 0x0 0x200 0x0 0x6600000 0x0 0x800>; clocks = <0xa4 0xa5 0xa6 0x9 0xa5 0xa7 0x9 0xa5>; pinctrl-names = "mclk0-default", "mclk0-sleep", "mclk1-default", "mclk1-sleep"; pinctrl-0 = <0xa8>; pinctrl-1 = <0xa9>; pinctrl-2 = <0xaa>; pinctrl-3 = <0xab>; status = "okay"; linux,phandle = <0x153>; phandle = <0x153>; cci@0 { compatible = "allwinner,sunxi-csi_cci"; reg = <0x0 0x6614000 0x0 0x400>; interrupts = <0x0 0x4b 0x4>; pinctrl-names = "default", "sleep"; pinctrl-0 = <0xac>; pinctrl-1 = <0xad>; device_id = <0x0>; status = "okay"; linux,phandle = <0x154>; phandle = <0x154>; }; cci@1 { compatible = "allwinner,sunxi-csi_cci"; reg = <0x0 0x6614400 0x0 0x400>; interrupts = <0x0 0x4c 0x4>; pinctrl-names = "default", "sleep"; pinctrl-0 = <0xae>; pinctrl-1 = <0xaf>; device_id = <0x1>; status = "okay"; linux,phandle = <0x155>; phandle = <0x155>; }; csi@0 { device_type = "csi0"; compatible = "allwinner,sunxi-csi"; reg = <0x0 0x6601000 0x0 0x1000>; interrupts = <0x0 0x49 0x4>; device_id = <0x0>; iommus = <0x28 0x4 0x1>; status = "okay"; linux,phandle = <0x156>; phandle = <0x156>; }; csi@1 { device_type = "csi1"; compatible = "allwinner,sunxi-csi"; reg = <0x0 0x6602000 0x0 0x1000>; interrupts = <0x0 0x4a 0x4>; pinctrl-names = "default", "sleep"; pinctrl-0 = <0xb0>; pinctrl-1 = <0xb1>; device_id = <0x1>; iommus = <0x28 0x4 0x1>; status = "okay"; linux,phandle = <0x157>; phandle = <0x157>; }; mipi@0 { compatible = "allwinner,sunxi-mipi"; reg = <0x0 0x660c000 0x0 0x1000>; interrupts = <0x0 0x4d 0x4>; device_id = <0x0>; status = "okay"; linux,phandle = <0x158>; phandle = <0x158>; }; isp@0 { compatible = "allwinner,sunxi-isp"; device_id = <0x0>; status = "okay"; linux,phandle = <0x159>; phandle = <0x159>; }; isp@1 { compatible = "allwinner,sunxi-isp"; device_id = <0x1>; status = "okay"; linux,phandle = <0x15a>; phandle = <0x15a>; }; scaler@0 { compatible = "allwinner,sunxi-scaler"; device_id = <0x0>; iommus = <0x28 0x4 0x1>; status = "okay"; linux,phandle = <0x15b>; phandle = <0x15b>; }; scaler@1 { compatible = "allwinner,sunxi-scaler"; device_id = <0x1>; iommus = <0x28 0x4 0x1>; status = "okay"; linux,phandle = <0x15c>; phandle = <0x15c>; }; scaler@2 { compatible = "allwinner,sunxi-scaler"; device_id = <0x2>; iommus = <0x28 0x4 0x1>; status = "okay"; linux,phandle = <0x15d>; phandle = <0x15d>; }; scaler@3 { compatible = "allwinner,sunxi-scaler"; device_id = <0x3>; iommus = <0x28 0x4 0x1>; status = "okay"; linux,phandle = <0x15e>; phandle = <0x15e>; }; scaler@4 { compatible = "allwinner,sunxi-scaler"; device_id = <0x4>; iommus = <0x28 0x4 0x1>; status = "okay"; linux,phandle = <0x15f>; phandle = <0x15f>; }; scaler@5 { compatible = "allwinner,sunxi-scaler"; device_id = <0x5>; iommus = <0x28 0x4 0x1>; status = "okay"; linux,phandle = <0x160>; phandle = <0x160>; }; actuator@0 { device_type = "actuator0"; compatible = "allwinner,sunxi-actuator"; actuator0_name = "ad5820_act"; actuator0_slave = <0x18>; actuator0_af_pwdn; actuator0_afvdd = "afvcc-csi"; actuator0_afvdd_vol = <0x2ab980>; status = "disabled"; linux,phandle = <0xb3>; phandle = <0xb3>; }; flash@0 { device_type = "flash0"; compatible = "allwinner,sunxi-flash"; flash0_type = <0x2>; flash0_en; flash0_mode; flash0_flvdd = [00]; flash0_flvdd_vol; device_id = <0x0>; status = "disabled"; linux,phandle = <0xb2>; phandle = <0xb2>; }; sensor@0 { device_type = "sensor0"; compatible = "allwinner,sunxi-sensor"; sensor0_mname = "ov5640"; sensor0_twi_cci_id = <0x0>; sensor0_twi_addr = <0x78>; sensor0_mclk_id = <0x0>; sensor0_pos = "rear"; sensor0_isp_used = <0x0>; sensor0_fmt = <0x0>; sensor0_stby_mode = <0x0>; sensor0_vflip = <0x0>; sensor0_hflip = <0x0>; sensor0_cameravdd-supply; sensor0_cameravdd_vol = <0x2ab980>; sensor0_iovdd-supply; sensor0_iovdd_vol = <0x2ab980>; sensor0_avdd-supply; sensor0_avdd_vol = <0x2ab980>; sensor0_dvdd-supply; sensor0_dvdd_vol = <0x16e360>; sensor0_power_en; sensor0_reset = <0x53 0x4 0xe 0x1 0x0 0x1 0x0>; sensor0_pwdn = <0x53 0x4 0x10 0x1 0x0 0x1 0x0>; sensor0_sm_vs; flash_handle = <0xb2>; act_handle = <0xb3>; device_id = <0x0>; status = "okay"; linux,phandle = <0x161>; phandle = <0x161>; }; sensor@1 { device_type = "sensor1"; compatible = "allwinner,sunxi-sensor"; sensor1_mname = "ov5647"; sensor1_twi_cci_id = <0x1>; sensor1_twi_addr = <0x6c>; sensor1_mclk_id = <0x1>; sensor1_pos = "front"; sensor1_isp_used = <0x0>; sensor1_fmt = <0x0>; sensor1_stby_mode = <0x0>; sensor1_vflip = <0x0>; sensor1_hflip = <0x0>; sensor1_cameravdd-supply; sensor1_cameravdd_vol = <0x2ab980>; sensor1_iovdd-supply; sensor1_iovdd_vol = <0x2ab980>; sensor1_avdd-supply; sensor1_avdd_vol = <0x2ab980>; sensor1_dvdd-supply; sensor1_dvdd_vol = <0x16e360>; sensor1_power_en; sensor1_reset = <0x53 0x4 0xe 0x1 0x0 0x1 0x0>; sensor1_pwdn = <0x53 0x4 0xf 0x1 0x0 0x1 0x0>; sensor1_sm_vs; flash_handle; act_handle; device_id = <0x1>; status = "okay"; linux,phandle = <0x162>; phandle = <0x162>; }; vinc@0 { device_type = "vinc0"; compatible = "allwinner,sunxi-vin-core"; reg = <0x0 0x6609000 0x0 0x200>; interrupts = <0x0 0x45 0x4>; vinc0_csi_sel = <0x0>; vinc0_mipi_sel = <0x0>; vinc0_isp_sel = <0x0>; vinc0_isp_tx_ch = <0x0>; vinc0_rear_sensor_sel = <0x0>; vinc0_front_sensor_sel = <0x0>; vinc0_sensor_list = <0x0>; device_id = <0x0>; iommus = <0x28 0x4 0x1>; status = "okay"; linux,phandle = <0x163>; phandle = <0x163>; }; vinc@1 { device_type = "vinc1"; compatible = "allwinner,sunxi-vin-core"; reg = <0x0 0x6609200 0x0 0x200>; interrupts = <0x0 0x46 0x4>; vinc1_csi_sel = <0x0>; vinc1_mipi_sel = <0x0>; vinc1_isp_sel = <0x0>; vinc1_isp_tx_ch = <0x0>; vinc1_rear_sensor_sel = <0x0>; vinc1_front_sensor_sel = <0x0>; vinc1_sensor_list = <0x0>; device_id = <0x1>; iommus = <0x28 0x4 0x1>; status = "okay"; linux,phandle = <0x164>; phandle = <0x164>; }; vinc@2 { device_type = "vinc2"; compatible = "allwinner,sunxi-vin-core"; reg = <0x0 0x6609400 0x0 0x200>; interrupts = <0x0 0x47 0x4>; vinc2_csi_sel = <0x0>; vinc2_mipi_sel = <0x0>; vinc2_isp_sel = <0x0>; vinc2_isp_tx_ch = <0x0>; vinc2_rear_sensor_sel = <0x0>; vinc2_front_sensor_sel = <0x0>; vinc2_sensor_list = <0x0>; device_id = <0x2>; iommus = <0x28 0x4 0x1>; status = "disabled"; linux,phandle = <0x165>; phandle = <0x165>; }; vinc@3 { device_type = "vinc3"; compatible = "allwinner,sunxi-vin-core"; reg = <0x0 0x6609600 0x0 0x200>; interrupts = <0x0 0x48 0x4>; vinc3_csi_sel = <0x0>; vinc3_mipi_sel = <0x0>; vinc3_isp_sel = <0x0>; vinc3_isp_tx_ch = <0x0>; vinc3_rear_sensor_sel = <0x0>; vinc3_front_sensor_sel = <0x0>; vinc3_sensor_list = <0x0>; device_id = <0x3>; iommus = <0x28 0x4 0x1>; status = "disabled"; linux,phandle = <0x166>; phandle = <0x166>; }; vinc@4 { device_type = "vinc4"; compatible = "allwinner,sunxi-vin-core"; reg = <0x0 0x6609800 0x0 0x200>; interrupts = <0x0 0x4f 0x4>; vinc4_csi_sel = <0x1>; vinc4_mipi_sel = <0xff>; vinc4_isp_sel = <0x1>; vinc4_isp_tx_ch = <0x0>; vinc4_rear_sensor_sel = <0x1>; vinc4_front_sensor_sel = <0x1>; vinc4_sensor_list = <0x0>; device_id = <0x4>; iommus = <0x28 0x5 0x1>; status = "disabled"; linux,phandle = <0x167>; phandle = <0x167>; }; vinc@5 { device_type = "vinc5"; compatible = "allwinner,sunxi-vin-core"; reg = <0x0 0x6609a00 0x0 0x200>; interrupts = <0x0 0x50 0x4>; vinc5_csi_sel = <0x1>; vinc5_mipi_sel = <0xff>; vinc5_isp_sel = <0x1>; vinc5_isp_tx_ch = <0x0>; vinc5_rear_sensor_sel = <0x1>; vinc5_front_sensor_sel = <0x1>; vinc5_sensor_list = <0x0>; device_id = <0x5>; iommus = <0x28 0x5 0x1>; status = "disabled"; linux,phandle = <0x168>; phandle = <0x168>; }; }; vdevice@0 { compatible = "allwinner,sun50i-vdevice"; device_type = "Vdevice"; pinctrl-names = "default"; interrupt-parent = <0x53>; interrupts = <0x0 0x3 0x4>; pinctrl-0 = <0xb4>; test-gpios = <0x53 0x0 0x0 0x1 0x2 0x2 0x1>; status = "okay"; linux,phandle = <0x169>; phandle = <0x169>; }; emce@01905000 { compatible = "allwinner,sunxi-emce"; device_name = "emce"; reg = <0x0 0x1905000 0x0 0x100>; clock-frequency = <0x11e1a300>; linux,phandle = <0x16a>; phandle = <0x16a>; }; ce@1904000 { compatible = "allwinner,sunxi-ce"; device_name = "ce"; reg = <0x0 0x1904000 0x0 0xa0 0x0 0x1904800 0x0 0xa0>; interrupts = <0x0 0x5b 0x1 0x0 0x5c 0x1>; clock-frequency = <0x11e1a300>; clocks = <0xb5 0xc>; linux,phandle = <0x16b>; phandle = <0x16b>; }; deinterlace@0x01420000 { #address-cells = <0x1>; #size-cells = <0x0>; compatible = "allwinner,sunxi-deinterlace"; reg = <0x0 0x1420000 0x0 0x40000>; interrupts = <0x0 0x59 0x4>; clocks = <0xe 0xc>; iommus = <0x28 0x1 0x1>; status = "okay"; linux,phandle = <0x16c>; phandle = <0x16c>; }; smartcard@0x05005000 { #address-cells = <0x1>; #size-cells = <0x0>; compatible = "allwinner,sunxi-scr"; device_type = "scr0"; reg = <0x0 0x5005000 0x0 0x400>; interrupts = <0x0 0x8 0x4>; clocks = <0xb6 0xb7>; clock-frequency = <0x16e3600>; pinctrl-names = "default", "sleep"; pinctrl-0 = <0xb8 0xb9>; pinctrl-1 = <0xba>; status = "disabled"; linux,phandle = <0x16d>; phandle = <0x16d>; }; nand0@04011000 { compatible = "allwinner,sun50iw9-nand"; device_type = "nand0"; reg = <0x0 0x4011000 0x0 0x1000>; interrupts = <0x0 0x22 0x4>; clocks = <0xc 0xbb 0xbc>; pinctrl-names = "default", "sleep"; pinctrl-1 = <0xbf>; nand0_regulator1 = "vcc-nand"; nand0_regulator2 = "none"; nand0_cache_level = <0x55aaaa55>; nand0_flush_cache_num = <0x55aaaa55>; nand0_capacity_level = <0x55aaaa55>; nand0_id_number_ctl = <0x55aaaa55>; nand0_print_level = <0x55aaaa55>; nand0_p0 = <0x55aaaa55>; nand0_p1 = <0x55aaaa55>; nand0_p2 = <0x55aaaa55>; nand0_p3 = <0x55aaaa55>; chip_code = "sun50iw9"; status = "disabled"; linux,phandle = <0x16e>; phandle = <0x16e>; nand0_support_2ch = <0x0>; pinctrl-0 = <0x18b 0x18c>; }; ts0@05060000 { compatible = "allwinner,sun50i-tsc"; device_type = "ts0"; reg = <0x0 0x5060000 0x0 0x1000>; interrupts = <0x0 0x11 0x4>; clocks = <0x2 0xc0>; clock-frequency = <0x7270e00>; pinctrl-names = "ts0-default", "ts0-sleep"; pinctrl-0 = <0xc1>; pinctrl-1 = <0xc2>; ts0config = <0x1>; status = "okay"; linux,phandle = <0x16f>; phandle = <0x16f>; }; thermal_sensor { compatible = "arm,sun50iw9p1"; reg = <0x0 0x5070400 0x0 0x400>; clocks = <0xc3>; clock-names = "bus"; nvmem-cells = <0xc4>; nvmem-cell-names = "calibration"; nvmem-names = "sid"; nvmem = <0xc5>; #thermal-sensor-cells = <0x1>; linux,phandle = <0xc6>; phandle = <0xc6>; }; thermal-zones { cpu_thermal_zone { polling-delay-passive = <0x1f4>; polling-delay = <0x3e8>; thermal-sensors = <0xc6 0x2>; sustainable-power = <0x3e8>; k_po = <0x14>; k_pu = <0x28>; k_i = <0x0>; trips { linux,phandle = <0x170>; phandle = <0x170>; trip-point@0 { temperature = <0xea60>; type = "passive"; hysteresis = <0x0>; linux,phandle = <0x171>; phandle = <0x171>; }; trip-point@1 { temperature = <0x11170>; type = "passive"; hysteresis = <0x0>; linux,phandle = <0xc7>; phandle = <0xc7>; }; cpu_crit@0 { temperature = <0x1c138>; type = "critical"; hysteresis = <0x0>; linux,phandle = <0x172>; phandle = <0x172>; }; }; cooling-maps { map0 { trip = <0xc7>; cooling-device = <0xc8 0xffffffff 0xffffffff>; contribution = <0x400>; }; map1 { trip = <0xc7>; cooling-device = <0xc9 0xffffffff 0xffffffff>; contribution = <0x400>; }; }; }; gpu_thermal_zone { polling-delay-passive = <0x1f4>; polling-delay = <0x3e8>; thermal-sensors = <0xc6 0x0>; sustainable-power = <0x44c>; }; ve_thermal_zone { polling-delay-passive = <0x0>; polling-delay = <0x0>; thermal-sensors = <0xc6 0x1>; }; ddr_thermal_zone { polling-delay-passive = <0x0>; polling-delay = <0x0>; thermal-sensors = <0xc6 0x3>; }; }; gpadc { compatible = "allwinner,sunxi-gpadc"; reg = <0x0 0x5070000 0x0 0x400>; interrupts = <0x0 0x12 0x0>; clocks = <0xca>; status = "okay"; channel_num = <0x1>; channel_select = <0x1>; channel_data_select = <0x0>; channel_compare_select = <0x1>; channel_cld_select = <0x1>; channel_chd_select = <0x0>; channel0_compare_lowdata = <0x19f0a0>; channel0_compare_higdata = <0x124f80>; key_cnt = <0x5>; key0_vol = <0x73>; key0_val = <0x73>; key1_vol = <0xf0>; key1_val = <0x72>; key2_vol = <0x168>; key2_val = <0x8b>; key3_vol = <0x1e0>; key3_val = <0x1c>; key4_vol = <0x258>; key4_val = <0x66>; linux,phandle = <0x173>; phandle = <0x173>; }; keyboard { compatible = "allwinner,keyboard_1350mv"; reg = <0x0 0x5070800 0x0 0x400>; clocks = <0xcb>; interrupts = <0x0 0x14 0x0>; status = "okay"; key_cnt = <0x5>; key0 = <0xd2 0x73>; key1 = <0x19a 0x72>; key2 = <0x24e 0x8b>; key3 = <0x2ee 0x1c>; key4 = <0x370 0xac>; linux,phandle = <0x174>; phandle = <0x174>; }; eth@05020000 { compatible = "allwinner,sunxi-gmac"; reg = <0x0 0x5020000 0x0 0x10000 0x0 0x3000030 0x0 0x4>; interrupts = <0x0 0xe 0x4>; interrupt-names = "gmacirq"; clocks = <0xcc 0xcd>; clock-names = "gmac", "ephy"; device_type = "gmac0"; pinctrl-0 = <0xce>; pinctrl-1 = <0xcf>; pinctrl-names = "default", "sleep"; phy-mode; tx-delay = <0x7>; rx-delay = <0x1f>; phy-rst; gmac-power0; gmac-power1; gmac-power2; status = "disable"; linux,phandle = <0x175>; phandle = <0x175>; }; eth@05030000 { compatible = "allwinner,sunxi-gmac"; reg = <0x0 0x5030000 0x0 0x10000 0x0 0x3000034 0x0 0x4>; interrupts = <0x0 0xf 0x4>; interrupt-names = "gmacirq"; clocks = <0xd0>; clock-names = "gmac"; device_type = "gmac1"; pinctrl-0 = <0xd1>; pinctrl-1 = <0xd2>; pinctrl-names = "default", "sleep"; phy-mode = "rmii"; tx-delay = <0x7>; rx-delay = <0x1f>; phy-rst; gmac-power0; gmac-power1; gmac-power2; status = "okay"; linux,phandle = <0x176>; phandle = <0x176>; }; gpio_encrypt { compatible = "allwinner,gpio_encrypt"; gpio_number_sun = <0x5>; gpio1_value = <0x0>; gpio2_value = <0x0>; gpio3_value = <0x0>; gpio4_value = <0x0>; gpio5_value = <0x0>; gpio1_pin = <0x53 0x8 0x1 0x1 0xffffffff 0xffffffff 0x0>; gpio2_pin = <0x53 0x8 0x2 0x1 0xffffffff 0xffffffff 0x0>; gpio3_pin = <0x53 0x8 0x3 0x1 0xffffffff 0xffffffff 0x0>; gpio4_pin = <0x53 0x8 0x4 0x1 0xffffffff 0xffffffff 0x0>; gpio5_pin = <0x53 0x8 0x5 0x1 0xffffffff 0xffffffff 0x0>; status = "disable"; linux,phandle = <0x177>; phandle = <0x177>; }; fd650 { compatible = "oranth,fd650"; status = "okay"; fd650_gpio_clk = <0x53 0x8 0xb 0x1 0xffffffff 0xffffffff 0x0>; fd650_gpio_dat = <0x53 0x8 0xc 0x1 0xffffffff 0xffffffff 0x0>; }; wlan { compatible = "allwinner,sunxi-wlan"; clocks = <0x1b>; pinctrl-0 = <0xd3>; pinctrl-names = "default"; wlan_busnum = <0x1>; wlan_power; wlan_io_regulator; wlan_regon = <0x53 0x6 0x12 0x1 0xffffffff 0xffffffff 0x0>; wlan_hostwake = <0x53 0x6 0xf 0x6 0xffffffff 0xffffffff 0x0>; chip_en; power_en; status = "okay"; linux,phandle = <0x178>; phandle = <0x178>; }; bt { compatible = "allwinner,sunxi-bt"; clocks = <0x1b>; bt_power; bt_io_regulator; bt_rst_n = <0x53 0x6 0x13 0x1 0xffffffff 0xffffffff 0x0>; status = "okay"; linux,phandle = <0x179>; phandle = <0x179>; }; btlpm { compatible = "allwinner,sunxi-btlpm"; uart_index = <0x1>; bt_wake = <0x53 0x6 0x11 0x1 0xffffffff 0xffffffff 0x1>; bt_hostwake = <0x53 0x6 0x10 0x6 0xffffffff 0xffffffff 0x0>; status = "okay"; linux,phandle = <0x17a>; phandle = <0x17a>; }; addr_mgt { compatible = "allwinner,sunxi-addr_mgt"; type_addr_wifi = <0x0>; type_addr_bt = <0x0>; type_addr_eth = <0x0>; status = "okay"; linux,phandle = <0x17b>; phandle = <0x17b>; }; sprd-marlin3 { compatible = "sprd,marlin3"; reset-gpios = <0x53 0x6 0x13 0x1 0xffffffff 0xffffffff 0x0>; enable-gpios = <0x53 0x6 0x12 0x1 0xffffffff 0xffffffff 0x0>; m2-to-ap-irq-gpios = <0x53 0x6 0x10 0x6 0xffffffff 0xffffffff 0x0>; sdhci-name = <0xd4>; sprd,btwf-file-name = "/vendor/etc/firmware/wcnmodem.bin"; sprd,gnss-file-name = "/vendor/etc/firmware/gnssmodem.bin"; adma-tx; adma-rx; data-irq; linux,phandle = <0x17c>; phandle = <0x17c>; }; gpio_para { device_type = "gpio_para"; status = "okay"; compatible = "allwinner,sunxi-init-gpio"; gpio_num = <0x2>; gpio_pin_1 = <0x53 0x7 0x6 0x1 0xffffffff 0xffffffff 0x1>; gpio_pin_2 = <0x53 0x7 0x7 0x1 0xffffffff 0xffffffff 0x0>; normal_led = "gpio_pin_1"; standby_led = "gpio_pin_2"; easy_light_used = <0x1>; normal_led_light = <0x1>; standby_led_light = <0x1>; }; product { device_type = "product"; version = "100"; machine = "evb"; }; platform { device_type = "platform"; eraseflag = <0x1>; debug_mode = <0x3>; }; target { device_type = "target"; boot_clock = <0x3f0>; storage_type = <0xffffffff>; advert_enable = <0x0>; burn_key = <0x1>; dragonboard_test = <0x0>; auto_fel = <0x1>; }; power_sply { device_type = "power_sply"; dcdc2_vol = <0xf4628>; aldo1_vol = <0xf4948>; dldo1_vol = <0xf4f24>; }; axp1530_power_sply { device_type = "axp1530_power_sply"; dcdc2_vol = <0xf4628>; aldo1_vol = <0xf4948>; dldo1_vol = <0xf4f24>; }; axp806_power_sply { device_type = "axp806_power_sply"; dcdce_vol = <0xf4f24>; aldo1_vol = <0xf4f24>; bldo1_vol = <0xf4948>; }; card_boot { device_type = "card_boot"; logical_start = <0xa000>; sprite_gpio0 = <0x53 0x7 0x6 0x1 0xffffffff 0xffffffff 0x1>; }; boot_init_gpio { device_type = "boot_init_gpio"; status = "okay"; gpio0 = <0x53 0x7 0x6 0x1 0xffffffff 0xffffffff 0x1>; gpio1 = <0x53 0x7 0x7 0x1 0xffffffff 0xffffffff 0x0>; }; ir_boot_recovery { device_type = "ir_boot_recovery"; status = "okay"; ir_work_mode = <0x2>; ir_press_times = <0x1>; ir_detect_time = <0x7d0>; ir_key_no_duplicate = <0x0>; ir_recovery_key_code0 = <0x45>; ir_addr_code0 = <0x4040>; ir_recovery_key_code1 = <0x49>; ir_addr_code1 = <0x7f80>; }; key_boot_recovery { device_type = "key_boot_recovery"; recovery_key_used = <0x1>; press_mode_enable = <0x0>; key_work_mode = <0x2>; short_press_mode = <0x0>; long_press_mode = <0x1>; key_press_time = <0x7d0>; recovery_key = <0x53 0x7 0x9 0x0 0xffffffff 0xffffffff 0xffffffff>; }; pm_para { device_type = "pm_para"; standby_mode = <0x1>; }; card0_boot_para { device_type = "card0_boot_para"; card_ctrl = <0x0>; card_high_speed = <0x1>; card_line = <0x4>; pinctrl-0 = <0x184>; }; card2_boot_para { device_type = "card2_boot_para"; card_ctrl = <0x2>; card_high_speed = <0x1>; card_line = <0x8>; pinctrl-0 = <0x185 0x186>; sdc_ex_dly_used = <0x2>; sdc_io_1v8 = <0x1>; sdc_tm4_win_th = <0xa>; }; gpio_bias { device_type = "gpio_bias"; pc_bias = <0x708>; }; twi_para { device_type = "twi_para"; twi_port = <0x0>; pinctrl-0 = <0x187>; }; uart_para { device_type = "uart_para"; uart_debug_port = <0x0>; pinctrl-0 = <0x188>; }; jtag_para { device_type = "jtag_para"; jtag_enable = <0x1>; pinctrl-0 = <0x189>; }; clock { device_type = "clock"; pll4 = <0x12c>; pll6 = <0x258>; pll8 = <0x168>; pll9 = <0x129>; pll10 = <0x108>; }; dram_select_para { device_type = "dram_select_para"; select_mode = <0x0>; select_gpio0 = <0x53 0x8 0xe 0x0 0x1 0xffffffff 0xffffffff>; select_gpio1 = <0x53 0x8 0xf 0x0 0x1 0xffffffff 0xffffffff>; select_gpio2 = <0x53 0x8 0x10 0x0 0x1 0xffffffff 0xffffffff>; select_gpio3; }; dram_para1 { device_type = "dram_para1"; dram_clk = <0x258>; dram_type = <0x3>; dram_dx_odt = <0x3030303>; dram_dx_dri = <0xe0e0e0e>; dram_ca_dri = <0x1c12>; dram_odt_en = <0x1>; dram_para1 = <0x30fb>; dram_para2 = <0x0>; dram_mr0 = <0x840>; dram_mr1 = <0x4>; dram_mr2 = <0x8>; dram_mr3 = <0x0>; dram_mr4 = <0x0>; dram_mr5 = <0x0>; dram_mr6 = <0x0>; dram_mr11 = <0x0>; dram_mr12 = <0x0>; dram_mr13 = <0x0>; dram_mr14 = <0x0>; dram_mr16 = <0x0>; dram_mr17 = <0x0>; dram_mr22 = <0x0>; dram_tpr0 = <0xc0000a05>; dram_tpr1 = <0x0>; dram_tpr2 = <0x0>; dram_tpr3 = <0x0>; dram_tpr6 = <0x33808080>; dram_tpr10 = <0x2f0006>; dram_tpr11 = <0xddddcccc>; dram_tpr12 = <0xeddc7564>; dram_tpr13 = <0x40>; }; dram_para2 { device_type = "dram_para2"; dram_clk = <0x258>; dram_type = <0x3>; dram_dx_odt = <0x3030303>; dram_dx_dri = <0xe0e0e0e>; dram_ca_dri = <0x1c12>; dram_odt_en = <0x1>; dram_para1 = <0x30fb>; dram_para2 = <0x0>; dram_mr0 = <0x840>; dram_mr1 = <0x4>; dram_mr2 = <0x8>; dram_mr3 = <0x0>; dram_mr4 = <0x0>; dram_mr5 = <0x0>; dram_mr6 = <0x0>; dram_mr11 = <0x0>; dram_mr12 = <0x0>; dram_mr13 = <0x0>; dram_mr14 = <0x0>; dram_mr16 = <0x0>; dram_mr17 = <0x0>; dram_mr22 = <0x0>; dram_tpr0 = <0xc0000a05>; dram_tpr1 = <0x0>; dram_tpr2 = <0x0>; dram_tpr3 = <0x0>; dram_tpr6 = <0x33808080>; dram_tpr10 = <0x2f0006>; dram_tpr11 = <0xddddcccc>; dram_tpr12 = <0xeddc7564>; dram_tpr13 = <0x40>; }; dram_para3 { device_type = "dram_para3"; dram_clk = <0x258>; dram_type = <0x3>; dram_dx_odt = <0x3030303>; dram_dx_dri = <0xe0e0e0e>; dram_ca_dri = <0x1c12>; dram_odt_en = <0x1>; dram_para1 = <0x30fb>; dram_para2 = <0x0>; dram_mr0 = <0x840>; dram_mr1 = <0x4>; dram_mr2 = <0x8>; dram_mr3 = <0x0>; dram_mr4 = <0x0>; dram_mr5 = <0x0>; dram_mr6 = <0x0>; dram_mr11 = <0x0>; dram_mr12 = <0x0>; dram_mr13 = <0x0>; dram_mr14 = <0x0>; dram_mr16 = <0x0>; dram_mr17 = <0x0>; dram_mr22 = <0x0>; dram_tpr0 = <0xc0000a05>; dram_tpr1 = <0x0>; dram_tpr2 = <0x0>; dram_tpr3 = <0x0>; dram_tpr6 = <0x33808080>; dram_tpr10 = <0x2f0006>; dram_tpr11 = <0xddddcccc>; dram_tpr12 = <0xeddc7564>; dram_tpr13 = <0x40>; }; dram_para4 { device_type = "dram_para4"; dram_clk = <0x258>; dram_type = <0x3>; dram_dx_odt = <0x3030303>; dram_dx_dri = <0xe0e0e0e>; dram_ca_dri = <0x1c12>; dram_odt_en = <0x1>; dram_para1 = <0x30fb>; dram_para2 = <0x0>; dram_mr0 = <0x840>; dram_mr1 = <0x4>; dram_mr2 = <0x8>; dram_mr3 = <0x0>; dram_mr4 = <0x0>; dram_mr5 = <0x0>; dram_mr6 = <0x0>; dram_mr11 = <0x0>; dram_mr12 = <0x0>; dram_mr13 = <0x0>; dram_mr14 = <0x0>; dram_mr16 = <0x0>; dram_mr17 = <0x0>; dram_mr22 = <0x0>; dram_tpr0 = <0xc0000a05>; dram_tpr1 = <0x0>; dram_tpr2 = <0x0>; dram_tpr3 = <0x0>; dram_tpr6 = <0x33808080>; dram_tpr10 = <0x2f0006>; dram_tpr11 = <0xddddcccc>; dram_tpr12 = <0xeddc7564>; dram_tpr13 = <0x40>; }; dram_para5 { device_type = "dram_para5"; dram_clk = <0x258>; dram_type = <0x3>; dram_dx_odt = <0x3030303>; dram_dx_dri = <0xe0e0e0e>; dram_ca_dri = <0x1c12>; dram_odt_en = <0x1>; dram_para1 = <0x30fb>; dram_para2 = <0x0>; dram_mr0 = <0x840>; dram_mr1 = <0x4>; dram_mr2 = <0x8>; dram_mr3 = <0x0>; dram_mr4 = <0x0>; dram_mr5 = <0x0>; dram_mr6 = <0x0>; dram_mr11 = <0x0>; dram_mr12 = <0x0>; dram_mr13 = <0x0>; dram_mr14 = <0x0>; dram_mr16 = <0x0>; dram_mr17 = <0x0>; dram_mr22 = <0x0>; dram_tpr0 = <0xc0000a05>; dram_tpr1 = <0x0>; dram_tpr2 = <0x0>; dram_tpr3 = <0x0>; dram_tpr6 = <0x33808080>; dram_tpr10 = <0x2f0006>; dram_tpr11 = <0xddddcccc>; dram_tpr12 = <0xeddc7564>; dram_tpr13 = <0x40>; }; dram_para6 { device_type = "dram_para6"; dram_clk = <0x258>; dram_type = <0x3>; dram_dx_odt = <0x3030303>; dram_dx_dri = <0xe0e0e0e>; dram_ca_dri = <0x1c12>; dram_odt_en = <0x1>; dram_para1 = <0x30fb>; dram_para2 = <0x0>; dram_mr0 = <0x840>; dram_mr1 = <0x4>; dram_mr2 = <0x8>; dram_mr3 = <0x0>; dram_mr4 = <0x0>; dram_mr5 = <0x0>; dram_mr6 = <0x0>; dram_mr11 = <0x0>; dram_mr12 = <0x0>; dram_mr13 = <0x0>; dram_mr14 = <0x0>; dram_mr16 = <0x0>; dram_mr17 = <0x0>; dram_mr22 = <0x0>; dram_tpr0 = <0xc0000a05>; dram_tpr1 = <0x0>; dram_tpr2 = <0x0>; dram_tpr3 = <0x0>; dram_tpr6 = <0x33808080>; dram_tpr10 = <0x2f0006>; dram_tpr11 = <0xddddcccc>; dram_tpr12 = <0xeddc7564>; dram_tpr13 = <0x40>; }; dram_para7 { device_type = "dram_para7"; dram_clk = <0x258>; dram_type = <0x3>; dram_dx_odt = <0x3030303>; dram_dx_dri = <0xe0e0e0e>; dram_ca_dri = <0x1f12>; dram_odt_en = <0x1>; dram_para1 = <0x30fb>; dram_para2 = <0x0>; dram_mr0 = <0x840>; dram_mr1 = <0x4>; dram_mr2 = <0x8>; dram_mr3 = <0x0>; dram_mr4 = <0x0>; dram_mr5 = <0x0>; dram_mr6 = <0x0>; dram_mr11 = <0x0>; dram_mr12 = <0x0>; dram_mr13 = <0x0>; dram_mr14 = <0x0>; dram_mr16 = <0x0>; dram_mr17 = <0x0>; dram_mr22 = <0x0>; dram_tpr0 = <0xc0001002>; dram_tpr1 = <0x0>; dram_tpr2 = <0x0>; dram_tpr3 = <0x0>; dram_tpr6 = <0x33808080>; dram_tpr10 = <0x2f1107>; dram_tpr11 = <0xddddcccc>; dram_tpr12 = <0xeddc7665>; dram_tpr13 = <0x40>; }; secure { device_type = "secure"; dram_region_mbytes = <0x50>; drm_region_mbytes = <0x0>; drm_region_start_mbytes = <0x0>; }; }; aliases { serial0 = "/soc@03000000/uart@05000000", "/soc@03000000/uart@05000000"; serial1 = "/soc@03000000/uart@05000400", "/soc@03000000/uart@05000400"; serial2 = "/soc@03000000/uart@05000800", "/soc@03000000/uart@05000800"; serial3 = "/soc@03000000/uart@05000c00", "/soc@03000000/uart@05000c00"; serial4 = "/soc@03000000/uart@05001000", "/soc@03000000/uart@05001000"; serial5 = "/soc@03000000/uart@05001400", "/soc@03000000/uart@05001400"; twi0 = "/soc@03000000/twi@0x05002000", "/soc@03000000/twi@0x05002000"; twi1 = "/soc@03000000/twi@0x05002400", "/soc@03000000/twi@0x05002400"; twi2 = "/soc@03000000/twi@0x05002800", "/soc@03000000/twi@0x05002800"; twi3 = "/soc@03000000/twi@0x05002c00", "/soc@03000000/twi@0x05002c00"; twi4 = "/soc@03000000/twi@0x05003000", "/soc@03000000/twi@0x05003000"; twi5 = "/soc@03000000/twi@0x07081400", "/soc@03000000/twi@0x07081400"; spi0 = "/soc@03000000/spi@05010000", "/soc@03000000/spi@05010000"; spi1 = "/soc@03000000/spi@05011000", "/soc@03000000/spi@05011000"; ir0 = "/soc@03000000/s_cir@07040000", "/soc@03000000/s_cir@07040000"; pcie = "/soc@03000000/pcie@0x05400000", "/soc@03000000/pcie@0x05400000"; scr0 = "/soc@03000000/smartcard@0x05005000", "/soc@03000000/smartcard@0x05005000"; gmac0 = "/soc@03000000/eth@05020000", "/soc@03000000/eth@05020000"; gmac1 = "/soc@03000000/eth@05030000", "/soc@03000000/eth@05030000"; global_timer0 = "/soc@03000000/timer@03009000", "/soc@03000000/timer@03009000"; mmc0 = "/soc@03000000/sdmmc@04020000", "/soc@03000000/sdmmc@04020000"; mmc2 = "/soc@03000000/sdmmc@04022000", "/soc@03000000/sdmmc@04022000"; nand0 = "/soc@03000000/nand0@04011000", "/soc@03000000/nand0@04011000"; disp = "/soc@03000000/disp@01000000", "/soc@03000000/disp@01000000"; lcd0 = "/soc@03000000/lcd0@01c0c000", "/soc@03000000/lcd0@01c0c000"; lcd1 = "/soc@03000000/lcd1@01c0c001", "/soc@03000000/lcd1@01c0c001"; hdmi = "/soc@03000000/hdmi@06000000", "/soc@03000000/hdmi@06000000"; pwm = "/soc@03000000/pwm@0300a000", "/soc@03000000/pwm@0300a000"; tv0 = "/soc@03000000/tv0@01c94000", "/soc@03000000/tv0@01c94000"; ac200 = "/soc@03000000/ac200", "/soc@03000000/ac200"; boot_disp = "/soc@03000000/boot_disp", "/soc@03000000/boot_disp"; pmu0 = "/soc@03000000/twi@0x07081400/pmu", "/soc@03000000/twi@0x07081400/pmu"; standby_param = "/soc@03000000/twi@0x07081400/pmu/standby_param", "/soc@03000000/twi@0x07081400/pmu/standby_param"; linux,phandle = <0x17d>; phandle = <0x17d>; }; chosen { bootargs = "earlyprintk=sunxi-uart,0x05000000 loglevel=8 initcall_debug=1 console=ttyS0 init=/init"; linux,initrd-start = <0x0 0x0>; linux,initrd-end = <0x0 0x0>; }; firmware { android { compatible = "android,firmware"; boot_devices = "soc/sdc0,soc/sdc2,soc"; vbmeta { compatible = "android,vbmeta"; parts = "vbmeta,vbmeta_system,vbmeta_vendor,boot,super,recovery"; }; }; optee { compatible = "linaro,optee-tz"; method = "smc"; }; }; cpus { #address-cells = <0x2>; #size-cells = <0x0>; cpu@0 { device_type = "cpu"; compatible = "arm,cortex-a53", "arm,armv8"; reg = <0x0 0x0>; enable-method = "psci"; clocks = <0xd5>; operating-points-v2 = <0xd6>; cpu-idle-states = <0xd7>; dynamic-power-coefficient = <0x64>; #cooling-cells = <0x2>; cpu-supply = <0xd8>; linux,phandle = <0xc8>; phandle = <0xc8>; }; cpu@1 { device_type = "cpu"; compatible = "arm,cortex-a53", "arm,armv8"; reg = <0x0 0x1>; enable-method = "psci"; clocks = <0xd5>; operating-points-v2 = <0xd6>; cpu-idle-states = <0xd7>; #cooling-cells = <0x2>; }; cpu@2 { device_type = "cpu"; compatible = "arm,cortex-a53", "arm,armv8"; reg = <0x0 0x2>; enable-method = "psci"; clocks = <0xd5>; operating-points-v2 = <0xd6>; cpu-idle-states = <0xd7>; #cooling-cells = <0x2>; }; cpu@3 { device_type = "cpu"; compatible = "arm,cortex-a53", "arm,armv8"; reg = <0x0 0x3>; enable-method = "psci"; clocks = <0xd5>; operating-points-v2 = <0xd6>; cpu-idle-states = <0xd7>; #cooling-cells = <0x2>; }; idle-states { entry-method = "arm,psci"; cpu-sleep-0 { compatible = "arm,idle-state"; arm,psci-suspend-param = <0x10000>; entry-latency-us = <0x2e>; exit-latency-us = <0x3b>; min-residency-us = <0xdf2>; local-timer-stop; linux,phandle = <0xd7>; phandle = <0xd7>; }; }; }; opp_l_table { compatible = "allwinner,sun50i-operating-points"; nvmem-cells = <0xd9>; nvmem-cell-names = "speed"; opp-shared; linux,phandle = <0xd6>; phandle = <0xd6>; opp@480000000-0 { opp-hz = <0x0 0x1c9c3800>; opp-microvolt = <0xdbba0>; clock-latency-ns = <0x3b9b0>; opp-supported-hw = <0x33>; }; opp@480000000-1 { opp-hz = <0x0 0x1c9c3800>; opp-microvolt = <0xdbba0>; clock-latency-ns = <0x3b9b0>; opp-supported-hw = <0xc>; }; opp@600000000-0 { opp-hz = <0x0 0x23c34600>; opp-microvolt = <0xdbba0>; clock-latency-ns = <0x3b9b0>; opp-supported-hw = <0x23>; }; opp@600000000-1 { opp-hz = <0x0 0x23c34600>; opp-microvolt = <0xdbba0>; clock-latency-ns = <0x3b9b0>; opp-supported-hw = <0xc>; }; opp@720000000 { opp-hz = <0x0 0x2aea5400>; opp-microvolt = <0xdbba0>; clock-latency-ns = <0x3b9b0>; opp-supported-hw = <0x30>; }; opp@792000000-0 { opp-hz = <0x0 0x2f34f600>; opp-microvolt = <0xdbba0>; clock-latency-ns = <0x3b9b0>; opp-supported-hw = <0x3>; }; opp@792000000-1 { opp-hz = <0x0 0x2f34f600>; opp-microvolt = <0xe57e0>; clock-latency-ns = <0x3b9b0>; opp-supported-hw = <0xc>; }; opp@936000000 { opp-hz = <0x0 0x37ca3a00>; opp-microvolt = <0xdbba0>; clock-latency-ns = <0x3b9b0>; opp-supported-hw = <0x30>; }; opp@1008000000-0 { opp-hz = <0x0 0x3c14dc00>; opp-microvolt = <0xe09c0>; clock-latency-ns = <0x3b9b0>; opp-supported-hw = <0x1>; }; opp@1008000000-1 { opp-hz = <0x0 0x3c14dc00>; opp-microvolt = <0xdbba0>; clock-latency-ns = <0x3b9b0>; opp-supported-hw = <0x2>; }; opp@1008000000-2 { opp-hz = <0x0 0x3c14dc00>; opp-microvolt = <0xf9060>; clock-latency-ns = <0x3b9b0>; opp-supported-hw = <0xc>; }; opp@1008000000-3 { opp-hz = <0x0 0x3c14dc00>; opp-microvolt = <0xe7ef0>; clock-latency-ns = <0x3b9b0>; opp-supported-hw = <0x30>; }; opp@1104000000 { opp-hz = <0x0 0x41cdb400>; opp-microvolt = <0xf4240>; clock-latency-ns = <0x3b9b0>; opp-supported-hw = <0x30>; }; opp@1200000000-0 { opp-hz = <0x0 0x47868c00>; opp-microvolt = <0xef420>; clock-latency-ns = <0x3b9b0>; opp-supported-hw = <0x1>; }; opp@1200000000-1 { opp-hz = <0x0 0x47868c00>; opp-microvolt = <0xea600>; clock-latency-ns = <0x3b9b0>; opp-supported-hw = <0x2>; }; opp@1200000000-2 { opp-hz = <0x0 0x47868c00>; opp-microvolt = <0x10c8e0>; clock-latency-ns = <0x3b9b0>; opp-supported-hw = <0xc>; }; opp@1200000000-3 { opp-hz = <0x0 0x47868c00>; opp-microvolt = <0x100590>; clock-latency-ns = <0x3b9b0>; opp-supported-hw = <0x30>; }; opp@1296000000-0 { opp-hz = <0x0 0x4d3f6400>; opp-microvolt = <0x10c8e0>; clock-latency-ns = <0x3b9b0>; opp-supported-hw = <0x2>; }; opp@1296000000-1 { opp-hz = <0x0 0x4d3f6400>; opp-microvolt = <0x111700>; clock-latency-ns = <0x3b9b0>; opp-supported-hw = <0x8>; }; opp@1320000000 { opp-hz = <0x0 0x4ead9a00>; opp-microvolt = <0x10c8e0>; clock-latency-ns = <0x3b9b0>; opp-supported-hw = <0x30>; }; opp@1344000000 { opp-hz = <0x0 0x501bd000>; opp-microvolt = <0x111700>; clock-latency-ns = <0x3b9b0>; opp-supported-hw = <0x4>; }; opp@1416000000-0 { opp-hz = <0x0 0x54667200>; opp-microvolt = <0x118c30>; clock-latency-ns = <0x3b9b0>; opp-supported-hw = <0x10>; }; opp@1416000000-1 { opp-hz = <0x0 0x54667200>; opp-microvolt = <0x11b340>; clock-latency-ns = <0x3b9b0>; opp-supported-hw = <0x20>; }; opp@1416000000 { opp-hz = <0x0 0x54667200>; opp-microvolt = <0x118c30>; clock-latency-ns = <0x3b9b0>; opp-supported-hw = <0x10>; }; opp@1512000000 { opp-hz = <0x0 0x5a1f4a00>; opp-microvolt = <0x111700>; clock-latency-ns = <0x3b9b0>; opp-supported-hw = <0x1>; }; opp@480000000-ab { opp-hz = <0x0 0x1c9c3800>; opp-microvolt-a1 = <0xdbba0>; opp-microvolt-b1 = <0xdbba0>; opp-microvolt-b0 = <0xdbba0>; opp-microvolt-c0 = <0xdbba0>; opp-microvolt-c1 = <0xdbba0>; opp-microvolt-c2 = <0xdbba0>; clock-latency-ns = <0x3b9b0>; }; opp@600000000-ab { opp-hz = <0x0 0x23c34600>; opp-microvolt-b0 = <0xdbba0>; opp-microvolt-c0 = <0xdbba0>; opp-microvolt-c2 = <0xdbba0>; clock-latency-ns = <0x3b9b0>; }; opp@720000000-ab { opp-hz = <0x0 0x2aea5400>; opp-microvolt-a1 = <0xdbba0>; opp-microvolt-b1 = <0xdbba0>; opp-microvolt-c1 = <0xe7ef0>; clock-latency-ns = <0x3b9b0>; }; opp@792000000-ab { opp-hz = <0x0 0x2f34f600>; opp-microvolt-b0 = <0xdbba0>; opp-microvolt-c0 = <0xe57e0>; opp-microvolt-c2 = <0xe57e0>; clock-latency-ns = <0x3b9b0>; }; opp@936000000-ab { opp-hz = <0x0 0x37ca3a00>; opp-microvolt-c1 = <0xe7ef0>; clock-latency-ns = <0x3b9b0>; }; opp@1008000000-ab { opp-hz = <0x0 0x3c14dc00>; opp-microvolt-b0 = <0xe09c0>; opp-microvolt-c0 = <0xf9060>; opp-microvolt-c1 = <0xf4240>; opp-microvolt-c2 = <0xf9060>; clock-latency-ns = <0x3b9b0>; }; opp@1032000000-ab { opp-hz = <0x0 0x3d831200>; opp-microvolt-a1 = <0xdbba0>; opp-microvolt-b1 = <0xdbba0>; clock-latency-ns = <0x3b9b0>; }; opp@1104000000-ab { opp-hz = <0x0 0x41cdb400>; opp-microvolt-a1 = <0xe7ef0>; opp-microvolt-b1 = <0xe7ef0>; opp-microvolt-c1 = <0x100590>; clock-latency-ns = <0x3b9b0>; }; opp@1200000000-ab { opp-hz = <0x0 0x47868c00>; opp-microvolt-a1 = <0xf4240>; opp-microvolt-b1 = <0xf4240>; opp-microvolt-b0 = <0xef420>; opp-microvolt-c0 = <0x10c8e0>; opp-microvolt-c1 = <0x10c8e0>; opp-microvolt-c2 = <0x10c8e0>; clock-latency-ns = <0x3b9b0>; }; opp@1296000000-ab { opp-hz = <0x0 0x4d3f6400>; opp-microvolt-a1 = <0x100590>; opp-microvolt-b1 = <0x100590>; clock-latency-ns = <0x3b9b0>; }; opp@1320000000-ab { opp-hz = <0x0 0x4ead9a00>; opp-microvolt-c1 = <0x11b340>; clock-latency-ns = <0x3b9b0>; }; opp@1344000000-ab { opp-hz = <0x0 0x501bd000>; opp-microvolt-c0 = <0x111700>; opp-microvolt-c2 = <0x111700>; clock-latency-ns = <0x3b9b0>; }; opp@1416000000-ab { opp-hz = <0x0 0x54667200>; opp-microvolt-a1 = <0x10c8e0>; opp-microvolt-b1 = <0x10c8e0>; clock-latency-ns = <0x3b9b0>; }; opp@1512000000-ab { opp-hz = <0x0 0x5a1f4a00>; opp-microvolt-a1 = <0x11b340>; opp-microvolt-b1 = <0x11b340>; opp-microvolt-b0 = <0x111700>; clock-latency-ns = <0x3b9b0>; }; }; psci { compatible = "arm,psci-1.0"; method = "smc"; }; n_brom { compatible = "allwinner,n-brom"; reg = <0x0 0x0 0x0 0xa000>; }; s_brom { compatible = "allwinner,s-brom"; reg = <0x0 0x0 0x0 0x10000>; }; sram_ctrl { device_type = "sram_ctrl"; compatible = "allwinner,sram_ctrl"; reg = <0x0 0x3000000 0x0 0x100>; }; sram_a1 { compatible = "allwinner,sram_a1"; reg = <0x0 0x20000 0x0 0x8000>; }; sram_a2 { compatible = "allwinner,sram_a2"; reg = <0x0 0x100000 0x0 0x14000>; }; prcm { compatible = "allwinner,prcm"; reg = <0x0 0x1f01400 0x0 0x400>; }; s_cpuscfg { compatible = "allwinner,s_cpuscfg"; reg = <0x0 0x1f01c00 0x0 0x400>; }; ion { compatible = "allwinner,sunxi-ion"; heap_sys_user@0 { compatible = "allwinner,sys_user"; heap-name = "sys_user"; heap-id = <0x0>; heap-base = <0x0>; heap-size = <0x0>; heap-type = "ion_system"; }; heap_cma@0 { compatible = "allwinner,cma"; heap-name = "cma"; heap-id = <0x4>; heap-base = <0x0>; heap-size = <0x0>; heap-type = "ion_cma"; }; heap_secure@0 { compatible = "allwinner,secure"; heap-name = "secure"; heap-id = <0x6>; heap-base = <0x0>; heap-size = <0x0>; heap-type = "ion_secure"; }; }; dram { compatible = "allwinner,dram"; clocks = <0xda>; clock-names = "pll_ddr"; dram_clk = <0x2d0>; dram_type = <0x7>; dram_zq = <0x3f3fdd>; dram_odt_en = <0x9988eeee>; dram_para1 = <0x30fa>; dram_para2 = <0x1000>; dram_mr0 = <0x0>; dram_mr1 = <0xc3>; dram_mr2 = <0x6>; dram_mr3 = <0x1>; dram_tpr0 = <0x0>; dram_tpr1 = <0x0>; dram_tpr2 = <0x0>; dram_tpr3 = <0x0>; dram_tpr4 = <0x0>; dram_tpr5 = <0x0>; dram_tpr6 = <0x2fb08080>; dram_tpr7 = <0x0>; dram_tpr8 = <0x0>; dram_tpr9 = <0x0>; dram_tpr10 = <0x402f4469>; dram_tpr11 = <0xe0f0d0d>; dram_tpr12 = <0x11131213>; dram_tpr13 = <0x60>; linux,phandle = <0x17e>; phandle = <0x17e>; device_type = "dram"; dram_dx_odt = <0x6060606>; dram_dx_dri = <0xd0d0d0d>; dram_ca_dri = <0x1919>; dram_mr4 = <0x0>; dram_mr5 = <0x0>; dram_mr6 = <0x0>; dram_mr11 = <0x0>; dram_mr12 = <0x0>; dram_mr13 = <0x0>; dram_mr14 = <0x0>; dram_mr16 = <0x0>; dram_mr17 = <0x0>; dram_mr22 = <0x0>; }; memory@40000000 { device_type = "memory"; reg = <0x0 0x40000000 0x0 0x20000000>; }; interrupt-controller@03020000 { compatible = "arm,cortex-a15-gic", "arm,cortex-a9-gic"; #interrupt-cells = <0x3>; #address-cells = <0x0>; device_type = "gic"; interrupt-controller; reg = <0x0 0x3021000 0x0 0x1000 0x0 0x3022000 0x0 0x2000 0x0 0x3024000 0x0 0x2000 0x0 0x3026000 0x0 0x2000>; interrupts = <0x1 0x9 0xf04>; interrupt-parent = <0x85>; linux,phandle = <0x85>; phandle = <0x85>; }; interrupt-controller@0 { compatible = "allwinner,sunxi-wakeupgen"; interrupt-controller; #interrupt-cells = <0x3>; interrupt-parent = <0x85>; linux,phandle = <0x1>; phandle = <0x1>; }; intc-nmi@07010320 { compatible = "allwinner,sun8i-nmi"; interrupt-parent = <0x85>; #interrupt-cells = <0x2>; #address-cells = <0x0>; interrupt-controller; reg = <0x0 0x7010320 0x0 0xc>; pad-control-v1 = <0x7000208>; interrupts = <0x0 0x67 0x4>; linux,phandle = <0x17f>; phandle = <0x17f>; }; sunxi-sid@03006000 { compatible = "allwinner,sunxi-sid"; device_type = "sid"; reg = <0x0 0x3006000 0x0 0x1000>; linux,phandle = <0x180>; phandle = <0x180>; }; sunxi-sid-ng@03006000 { compatible = "allwinner,sun50iw9p1-sid"; reg = <0x0 0x3006000 0x0 0x1000>; #address-cells = <0x1>; #size-cells = <0x1>; linux,phandle = <0xc5>; phandle = <0xc5>; speed@00 { reg = <0x0 0x2>; linux,phandle = <0xd9>; phandle = <0xd9>; }; calib@14 { reg = <0x14 0x8>; linux,phandle = <0xc4>; phandle = <0xc4>; }; }; sunxi-chipid@03006200 { compatible = "allwinner,sunxi-chipid"; device_type = "chipid"; reg = <0x0 0x3006200 0x0 0x200>; linux,phandle = <0x181>; phandle = <0x181>; }; timer_arch { compatible = "arm,armv8-timer"; interrupts = <0x1 0xd 0xf08 0x1 0xe 0xf08 0x1 0xb 0xf08 0x1 0xa 0xf08>; clock-frequency = <0x16e3600>; interrupt-parent = <0x85>; arm,no-tick-in-suspend; }; pmu { compatible = "arm,armv8-pmuv3"; interrupts = <0x0 0x8c 0x4 0x0 0x8d 0x4 0x0 0x8e 0x4 0x0 0x8f 0x4>; }; dramfreq { compatible = "allwinner,sunxi-dramfreq"; reg = <0x0 0x4002000 0x0 0x1000 0x0 0x4003000 0x0 0x3000 0x0 0x3001000 0x0 0x1000>; interrupts = <0x0 0x21 0x4>; clocks = <0xda>; status = "okay"; }; uboot { linux,phandle = <0x182>; phandle = <0x182>; }; iommu@030f0000 { compatible = "allwinner,sunxi-iommu"; reg = <0x0 0x30f0000 0x0 0x1000>; interrupts = <0x0 0x3d 0x4>; interrupt-names = "iommu-irq"; clocks = <0xdb>; clock-names = "iommu"; #iommu-cells = <0x2>; status = "okay"; linux,phandle = <0x28>; phandle = <0x28>; }; gpu@0x01800000 { device_type = "gpu"; compatible = "arm,mali-midgard"; reg = <0x0 0x1800000 0x0 0x10000>; interrupts = <0x0 0x5f 0x4 0x0 0x60 0x4 0x0 0x61 0x4>; interrupt-names = "JOB", "MMU", "GPU"; clocks = <0xdc 0xdd 0xde>; clock-names = "clk_parent", "clk_mali", "clk_bak"; #cooling-cells = <0x2>; gpu_idle = <0x1>; dvfs_status = <0x0>; operating-points = <0x927c0 0xe7ef0 0x8ca00 0xe7ef0 0x83d60 0xe7ef0 0x7b0c0 0xe7ef0>; linux,phandle = <0xc9>; phandle = <0xc9>; ipa_dvfs { compatible = "arm,mali-simple-power-model"; static-coefficient = <0x4268>; dynamic-coefficient = <0x2ee>; ts = <0x3e2da 0x2568 0xffffff98 0x4>; thermal-zone = "gpu_thermal_zone"; ss-coefficient = <0x24>; ff-coefficient = <0x123>; linux,phandle = <0x183>; phandle = <0x183>; }; }; box_start_os0 { compatible = "allwinner,box_start_os"; start_type = <0x1>; irkey_used = <0x0>; pmukey_used = <0x0>; pmukey_num = <0x0>; led_power = <0x0>; led_state = <0x0>; pinctrl-0 = <0xdf>; pinctrl-1 = <0xe0>; }; __symbols__ { clk_losc = "/clocks/losc"; clk_iosc = "/clocks/iosc"; clk_hosc = "/clocks/hosc"; clk_osc48m = "/clocks/osc48m"; clk_hoscdiv32k = "/clocks/hoscdiv32k"; clk_pll_periph0div25m = "/clocks/pll_periph0div25m"; clk_pll_cpu = "/clocks/pll_cpu"; clk_pll_ddr0 = "/clocks/pll_ddr0"; clk_pll_ddr1 = "/clocks/pll_ddr1"; clk_pll_periph0 = "/clocks/pll_periph0"; clk_pll_periph1 = "/clocks/pll_periph1"; clk_pll_gpu = "/clocks/pll_gpu"; clk_pll_video0x4 = "/clocks/pll_video0x4"; clk_pll_video1 = "/clocks/pll_video1"; clk_pll_video2 = "/clocks/pll_video2"; clk_pll_ve = "/clocks/pll_ve"; clk_pll_de = "/clocks/pll_de"; clk_pll_csi = "/clocks/pll_csi"; clk_pll_audiox4 = "/clocks/pll_audiox4"; clk_pll_periph0x2 = "/clocks/pll_periph0x2"; clk_pll_periph0x4 = "/clocks/pll_periph0x4"; clk_periph32k = "/clocks/periph32k"; clk_pll_periph1x2 = "/clocks/pll_periph1x2"; clk_pll_audio = "/clocks/pll_audio"; clk_pll_audiox2 = "/clocks/pll_audiox2"; clk_pll_video0 = "/clocks/pll_video0"; clk_pll_video1x4 = "/clocks/pll_video1x4"; clk_pll_video2x4 = "/clocks/pll_video2x4"; clk_hoscd2 = "/clocks/hoscd2"; clk_osc48md4 = "/clocks/osc48md4"; clk_pll_periph0d6 = "/clocks/pll_periph0d6"; clk_cpu = "/clocks/cpu"; clk_axi = "/clocks/axi"; clk_cpuapb = "/clocks/cpuapb"; clk_psi = "/clocks/psi"; clk_ahb1 = "/clocks/ahb1"; clk_ahb2 = "/clocks/ahb2"; clk_ahb3 = "/clocks/ahb3"; clk_apb1 = "/clocks/apb1"; clk_apb2 = "/clocks/apb2"; clk_mbus = "/clocks/mbus"; clk_de = "/clocks/de"; clk_g2d = "/clocks/g2d"; clk_di = "/clocks/di"; clk_gpu0 = "/clocks/gpu0"; clk_gpu1 = "/clocks/gpu1"; clk_ce = "/clocks/ce"; clk_ve = "/clocks/ve"; clk_dma = "/clocks/dma"; clk_msgbox = "/clocks/msgbox"; clk_hwspinlock_rst = "/clocks/hwspinlock_rst"; clk_hwspinlock_bus = "/clocks/hwspinlock_bus"; clk_hstimer = "/clocks/hstimer"; clk_avs = "/clocks/avs"; clk_dbgsys = "/clocks/dbgsys"; clk_pwm = "/clocks/pwm"; clk_iommu = "/clocks/iommu"; clk_sdram = "/clocks/sdram"; clk_nand0 = "/clocks/nand0"; clk_nand1 = "/clocks/nand1"; clk_sdmmc0_mod = "/clocks/sdmmc0_mod"; clk_sdmmc0_bus = "/clocks/sdmmc0_bus"; clk_sdmmc0_rst = "/clocks/sdmmc0_rst"; clk_sdmmc1_mod = "/clocks/sdmmc1_mod"; clk_sdmmc1_bus = "/clocks/sdmmc1_bus"; clk_sdmmc1_rst = "/clocks/sdmmc1_rst"; clk_sdmmc2_mod = "/clocks/sdmmc2_mod"; clk_sdmmc2_bus = "/clocks/sdmmc2_bus"; clk_sdmmc2_rst = "/clocks/sdmmc2_rst"; clk_uart0 = "/clocks/uart0"; clk_uart1 = "/clocks/uart1"; clk_uart2 = "/clocks/uart2"; clk_uart3 = "/clocks/uart3"; clk_uart4 = "/clocks/uart4"; clk_uart5 = "/clocks/uart5"; clk_twi0 = "/clocks/twi0"; clk_twi1 = "/clocks/twi1"; clk_twi2 = "/clocks/twi2"; clk_twi3 = "/clocks/twi3"; clk_twi4 = "/clocks/twi4"; clk_scr0 = "/clocks/scr0"; clk_spi0 = "/clocks/spi0"; clk_spi1 = "/clocks/spi1"; clk_ephy_25m = "/clocks/ephy_25m"; clk_gmac0 = "/clocks/gmac0"; clk_gmac1 = "/clocks/gmac1"; clk_gpadc = "/clocks/gpadc"; clk_ts = "/clocks/ts"; clk_ths = "/clocks/ths"; clk_spdif = "/clocks/spdif"; clk_dmic = "/clocks/dmic"; clk_codec_1x = "/clocks/codec_1x"; clk_codec_4x = "/clocks/codec_4x"; clk_ahub = "/clocks/ahub"; clk_usbphy0 = "/clocks/usbphy0"; clk_usbphy1 = "/clocks/usbphy1"; clk_usbphy2 = "/clocks/usbphy2"; clk_usbphy3 = "/clocks/usbphy3"; clk_usbohci0 = "/clocks/usbohci0"; clk_usbohci0_12m = "/clocks/usbohci0_12m"; clk_usbohci1 = "/clocks/usbohci1"; clk_usbohci1_12m = "/clocks/usbohci1_12m"; clk_usbohci2 = "/clocks/usbohci2"; clk_usbohci2_12m = "/clocks/usbohci2_12m"; clk_usbohci3 = "/clocks/usbohci3"; clk_usbohci3_12m = "/clocks/usbohci3_12m"; clk_usbehci0 = "/clocks/usbehci0"; clk_usbehci1 = "/clocks/usbehci1"; clk_usbehci2 = "/clocks/usbehci2"; clk_usbehci3 = "/clocks/usbehci3"; clk_usb3_0_host = "/clocks/usb3_0_host"; clk_usbotg = "/clocks/usbotg"; clk_lradc = "/clocks/lradc"; clk_hdmi = "/clocks/hdmi"; clk_hdmi_slow = "/clocks/hdmi_slow"; clk_hdmi_cec = "/clocks/hdmi_cec"; clk_display_top = "/clocks/display_top"; clk_tcon_lcd = "/clocks/tcon_lcd"; clk_tcon_lcd1 = "/clocks/tcon_lcd1"; clk_tcon_tv = "/clocks/tcon_tv"; clk_tcon_tv1 = "/clocks/tcon_tv1"; clk_lvds = "/clocks/lvds"; clk_tve = "/clocks/tve"; clk_tve_top = "/clocks/tve_top"; clk_csi_top = "/clocks/csi_top"; clk_csi_master0 = "/clocks/csi_master0"; clk_csi_master1 = "/clocks/csi_master1"; clk_hdmi_hdcp = "/clocks/hdmi_hdcp"; clk_pio = "/clocks/pio"; clk_cpurcir = "/clocks/cpurcir"; clk_hosc32k = "/clocks/hosc32k"; clk_losc_out = "/clocks/losc_out"; clk_cpurcpus_pll = "/clocks/cpurcpus_pll"; clk_cpurcpus = "/clocks/cpurcpus"; clk_cpurahbs = "/clocks/cpurahbs"; clk_cpurapbs1 = "/clocks/cpurapbs1"; clk_cpurapbs2_pll = "/clocks/cpurapbs2_pll"; clk_cpurapbs2 = "/clocks/cpurapbs2"; clk_cpurpio = "/clocks/cpurpio"; clk_dcxo_out = "/clocks/dcxo_out"; clk_stwi = "/clocks/stwi"; soc = "/soc@03000000"; r_pio = "/soc@03000000/pinctrl@07022000"; s_rsb0_pins_a = "/soc@03000000/pinctrl@07022000/s_rsb0@0"; s_twi0_pins_a = "/soc@03000000/pinctrl@07022000/s_twi0@0"; s_twi0_pins_b = "/soc@03000000/pinctrl@07022000/s_twi0@1"; pio = "/soc@03000000/pinctrl@0300b000"; clk_losc_pins_a = "/soc@03000000/pinctrl@0300b000/clk_losc@0"; s_cir0_pins_a = "/soc@03000000/pinctrl@0300b000/s_cir0@0"; vdevice_pins_a = "/soc@03000000/pinctrl@0300b000/vdevice@0"; uart0_pins_a = "/soc@03000000/pinctrl@0300b000/uart0@0"; uart0_pins_b = "/soc@03000000/pinctrl@0300b000/uart0@1"; uart1_pins_a = "/soc@03000000/pinctrl@0300b000/uart1@0"; uart1_pins_b = "/soc@03000000/pinctrl@0300b000/uart1@1"; uart2_pins_a = "/soc@03000000/pinctrl@0300b000/uart2@0"; uart2_pins_b = "/soc@03000000/pinctrl@0300b000/uart2@1"; uart3_pins_a = "/soc@03000000/pinctrl@0300b000/uart3@0"; uart3_pins_b = "/soc@03000000/pinctrl@0300b000/uart3@1"; uart4_pins_a = "/soc@03000000/pinctrl@0300b000/uart4@0"; uart4_pins_b = "/soc@03000000/pinctrl@0300b000/uart4@1"; uart5_pins_a = "/soc@03000000/pinctrl@0300b000/uart5@0"; uart5_pins_b = "/soc@03000000/pinctrl@0300b000/uart5@1"; twi0_pins_a = "/soc@03000000/pinctrl@0300b000/twi0@0"; twi0_pins_b = "/soc@03000000/pinctrl@0300b000/twi0@1"; twi1_pins_a = "/soc@03000000/pinctrl@0300b000/twi1@0"; twi1_pins_b = "/soc@03000000/pinctrl@0300b000/twi1@1"; twi2_pins_a = "/soc@03000000/pinctrl@0300b000/twi2@0"; twi2_pins_b = "/soc@03000000/pinctrl@0300b000/twi2@1"; twi3_pins_a = "/soc@03000000/pinctrl@0300b000/twi3@0"; twi3_pins_b = "/soc@03000000/pinctrl@0300b000/twi3@1"; twi4_pins_a = "/soc@03000000/pinctrl@0300b000/twi4@0"; twi4_pins_b = "/soc@03000000/pinctrl@0300b000/twi4@1"; ts0_pins_a = "/soc@03000000/pinctrl@0300b000/ts0@0"; ts0_pins_b = "/soc@03000000/pinctrl@0300b000/ts0_sleep@0"; spi0_pins_a = "/soc@03000000/pinctrl@0300b000/spi0@0"; spi0_pins_b = "/soc@03000000/pinctrl@0300b000/spi0@1"; spi0_pins_c = "/soc@03000000/pinctrl@0300b000/spi0@2"; spi1_pins_a = "/soc@03000000/pinctrl@0300b000/spi1@0"; spi1_pins_b = "/soc@03000000/pinctrl@0300b000/spi1@1"; spi1_pins_c = "/soc@03000000/pinctrl@0300b000/spi1@2"; sdc0_pins_a = "/soc@03000000/pinctrl@0300b000/sdc0@0"; sdc0_pins_b = "/soc@03000000/pinctrl@0300b000/sdc0@1"; sdc0_pins_c = "/soc@03000000/pinctrl@0300b000/sdc0@2"; sdc1_pins_a = "/soc@03000000/pinctrl@0300b000/sdc1@0"; sdc1_pins_b = "/soc@03000000/pinctrl@0300b000/sdc1@1"; sdc2_pins_a = "/soc@03000000/pinctrl@0300b000/sdc2@0"; sdc2_pins_b = "/soc@03000000/pinctrl@0300b000/sdc2@1"; sdc2_pins_c = "/soc@03000000/pinctrl@0300b000/sdc2@2"; spdif_pins_a = "/soc@03000000/pinctrl@0300b000/spdif@0"; spdif_pins_b = "/soc@03000000/pinctrl@0300b000/spdif_sleep@0"; dmic_pins_a = "/soc@03000000/pinctrl@0300b000/dmic@0"; dmic_pins_b = "/soc@03000000/pinctrl@0300b000/dmic_sleep@0"; ahub_daudio0_pins_a = "/soc@03000000/pinctrl@0300b000/ahub_daudio0@0"; ahub_daudio0_pins_b = "/soc@03000000/pinctrl@0300b000/ahub_daudio0_sleep@0"; ahub_daudio0_pins_c = "/soc@03000000/pinctrl@0300b000/h_ahub_daudio0@0"; ahub_daudio0_pins_d = "/soc@03000000/pinctrl@0300b000/h_ahub_daudio0_sleep@0"; ahub_daudio2_pins_a = "/soc@03000000/pinctrl@0300b000/ahub_daudio2@0"; ahub_daudio2_pins_b = "/soc@03000000/pinctrl@0300b000/ahub_daudio2_sleep@0"; ahub_daudio3_pins_a = "/soc@03000000/pinctrl@0300b000/ahub_daudio3@0"; ahub_daudio3_pins_b = "/soc@03000000/pinctrl@0300b000/ahub_daudio3_sleep@0"; csi1_pins_a = "/soc@03000000/pinctrl@0300b000/csi1@0"; csi1_pins_b = "/soc@03000000/pinctrl@0300b000/csi1@1"; csi_mclk0_pins_a = "/soc@03000000/pinctrl@0300b000/csi_mclk0@0"; csi_mclk0_pins_b = "/soc@03000000/pinctrl@0300b000/csi_mclk0@1"; csi_cci0_pins_a = "/soc@03000000/pinctrl@0300b000/csi_cci0@0"; csi_cci0_pins_b = "/soc@03000000/pinctrl@0300b000/csi_cci0@1"; csi_mclk1_pins_a = "/soc@03000000/pinctrl@0300b000/csi_mclk1@0"; csi_mclk1_pins_b = "/soc@03000000/pinctrl@0300b000/csi_mclk1@1"; csi_cci1_pins_a = "/soc@03000000/pinctrl@0300b000/csi_cci1@0"; csi_cci1_pins_b = "/soc@03000000/pinctrl@0300b000/csi_cci1@1"; scr0_pins_a = "/soc@03000000/pinctrl@0300b000/scr0@0"; scr0_pins_b = "/soc@03000000/pinctrl@0300b000/scr0@1"; scr0_pins_c = "/soc@03000000/pinctrl@0300b000/scr0@2"; scr1_pins_a = "/soc@03000000/pinctrl@0300b000/scr1@0"; scr1_pins_b = "/soc@03000000/pinctrl@0300b000/scr1@1"; scr1_pins_c = "/soc@03000000/pinctrl@0300b000/scr1@2"; nand0_pins_a = "/soc@03000000/pinctrl@0300b000/nand0@0"; nand0_pins_b = "/soc@03000000/pinctrl@0300b000/nand0@1"; nand0_pins_c = "/soc@03000000/pinctrl@0300b000/nand0@2"; ccir_clk_pin_a = "/soc@03000000/pinctrl@0300b000/ac200@2"; ccir_clk_pin_b = "/soc@03000000/pinctrl@0300b000/ac200@3"; gmac_pins_a = "/soc@03000000/pinctrl@0300b000/gmac@0"; gmac_pins_b = "/soc@03000000/pinctrl@0300b000/gmac@1"; gmac1_pins_a = "/soc@03000000/pinctrl@0300b000/gmac1@0"; gmac1_pins_b = "/soc@03000000/pinctrl@0300b000/gmac1@1"; lvds0_pins_a = "/soc@03000000/pinctrl@0300b000/lvds0@0"; lvds0_pins_b = "/soc@03000000/pinctrl@0300b000/lvds0@1"; lvds1_pins_a = "/soc@03000000/pinctrl@0300b000/lvds1@0"; lvds1_pins_b = "/soc@03000000/pinctrl@0300b000/lvds1@1"; lvds2link_pins_a = "/soc@03000000/pinctrl@0300b000/lvds2link@0"; lvds2link_pins_b = "/soc@03000000/pinctrl@0300b000/lvds2link@1"; rgb24_pins_a = "/soc@03000000/pinctrl@0300b000/rgb24@0"; rgb24_pins_b = "/soc@03000000/pinctrl@0300b000/rgb24@1"; pwm5_pin_a = "/soc@03000000/pinctrl@0300b000/pwm5@0"; pwm5_pin_b = "/soc@03000000/pinctrl@0300b000/pwm5@1"; standby_red = "/soc@03000000/pinctrl@0300b000/standby@0"; standby_blue = "/soc@03000000/pinctrl@0300b000/standby@1"; standby_bt = "/soc@03000000/pinctrl@0300b000/standby@2"; dma0 = "/soc@03000000/dma-controller@03002000"; mbus0 = "/soc@03000000/mbus-controller@047fa000"; msgbox = "/soc@03000000/msgbox@03003000"; hwspinlock = "/soc@03000000/hwspinlock@3004000"; s_cir0 = "/soc@03000000/s_cir@07040000"; soc_timer0 = "/soc@03000000/timer@03009000"; rtc = "/soc@03000000/rtc@07000000"; wdt = "/soc@03000000/watchdog@030090a0"; ve = "/soc@03000000/ve@01c0e000"; vp9 = "/soc@03000000/vp9@01c00000"; uart0 = "/soc@03000000/uart@05000000"; uart1 = "/soc@03000000/uart@05000400"; uart2 = "/soc@03000000/uart@05000800"; uart3 = "/soc@03000000/uart@05000c00"; uart4 = "/soc@03000000/uart@05001000"; uart5 = "/soc@03000000/uart@05001400"; twi0 = "/soc@03000000/twi@0x05002000"; twi1 = "/soc@03000000/twi@0x05002400"; twi2 = "/soc@03000000/twi@0x05002800"; twi3 = "/soc@03000000/twi@0x05002c00"; twi4 = "/soc@03000000/twi@0x05003000"; twi5 = "/soc@03000000/twi@0x07081400"; pmu0 = "/soc@03000000/twi@0x07081400/pmu"; standby_param = "/soc@03000000/twi@0x07081400/pmu/standby_param"; reg_dcdc1 = "/soc@03000000/twi@0x07081400/pmu/regulators/dcdc1"; reg_dcdc2 = "/soc@03000000/twi@0x07081400/pmu/regulators/dcdc2"; reg_dcdc3 = "/soc@03000000/twi@0x07081400/pmu/regulators/dcdc3"; reg_aldo1 = "/soc@03000000/twi@0x07081400/pmu/regulators/ldo1"; reg_dldo1 = "/soc@03000000/twi@0x07081400/pmu/regulators/ldo2"; usbc0 = "/soc@03000000/usbc0@0"; udc = "/soc@03000000/udc-controller@0x05100000"; ehci0 = "/soc@03000000/ehci0-controller@0x05101000"; ohci0 = "/soc@03000000/ohci0-controller@0x05101400"; usbc1 = "/soc@03000000/usbc1@0"; ehci1 = "/soc@03000000/ehci1-controller@0x05200000"; ohci1 = "/soc@03000000/ohci1-controller@0x05200400"; usbc2 = "/soc@03000000/usbc2@0"; ehci2 = "/soc@03000000/ehci2-controller@0x05310000"; ohci2 = "/soc@03000000/ohci2-controller@0x05310400"; usbc3 = "/soc@03000000/usbc3@0"; ehci3 = "/soc@03000000/ehci3-controller@0x05311000"; ohci3 = "/soc@03000000/ohci3-controller@0x05311400"; ac200_codec = "/soc@03000000/ac200_codec"; spdif = "/soc@03000000/spdif-controller@0x05093000"; dmic = "/soc@03000000/dmic-controller@0x05095000"; codec = "/soc@03000000/codec@0x05096000"; cpudai = "/soc@03000000/cpudai-controller@0x05096000"; ahub_cpudai0 = "/soc@03000000/cpudai0-controller@0x05097000"; ahub_cpudai1 = "/soc@03000000/cpudai1-controller@0x05097000"; ahub_cpudai2 = "/soc@03000000/cpudai2-controller@0x05097000"; ahub_cpudai3 = "/soc@03000000/cpudai3-controller@0x05097000"; ahub_codec = "/soc@03000000/ahub_codec@0x05097000"; ahub_daudio0 = "/soc@03000000/ahub_daudio0@0x05097000"; ahub_daudio1 = "/soc@03000000/ahub_daudio1@0x05097000"; ahub_daudio2 = "/soc@03000000/ahub_daudio2@0x05097000"; ahub_daudio3 = "/soc@03000000/ahub_daudio3@0x05097000"; snddaudio0 = "/soc@03000000/sound@0"; sndhdmi = "/soc@03000000/sound@1"; snddaudio2 = "/soc@03000000/sound@2"; snddaudio3 = "/soc@03000000/sound@3"; sndspdif = "/soc@03000000/sound@4"; snddmic = "/soc@03000000/sound@5"; sndcodec = "/soc@03000000/sound@6"; sndahub = "/soc@03000000/sound@7"; spi0 = "/soc@03000000/spi@05010000"; spi1 = "/soc@03000000/spi@05011000"; pcie = "/soc@03000000/pcie@0x05400000"; sdc2 = "/soc@03000000/sdmmc@04022000"; sdc0 = "/soc@03000000/sdmmc@04020000"; sdc1 = "/soc@03000000/sdmmc@04021000"; disp = "/soc@03000000/disp@01000000"; tv0 = "/soc@03000000/tv0@01c94000"; lcd0 = "/soc@03000000/lcd0@01c0c000"; lcd1 = "/soc@03000000/lcd1@01c0c001"; boot_disp = "/soc@03000000/boot_disp"; hdmi = "/soc@03000000/hdmi@06000000"; g2d = "/soc@03000000/g2d@01480000"; soc_tr = "/soc@03000000/tr@01000000"; pwm = "/soc@03000000/pwm@0300a000"; pwm0 = "/soc@03000000/pwm0@0300a000"; pwm1 = "/soc@03000000/pwm1@0300a000"; pwm2 = "/soc@03000000/pwm2@0300a000"; pwm3 = "/soc@03000000/pwm3@0300a000"; pwm4 = "/soc@03000000/pwm4@0300a000"; pwm5 = "/soc@03000000/pwm5@0300a000"; ac200 = "/soc@03000000/ac200"; vind0 = "/soc@03000000/vind@0"; csi_cci0 = "/soc@03000000/vind@0/cci@0"; csi_cci1 = "/soc@03000000/vind@0/cci@1"; csi0 = "/soc@03000000/vind@0/csi@0"; csi1 = "/soc@03000000/vind@0/csi@1"; mipi0 = "/soc@03000000/vind@0/mipi@0"; isp0 = "/soc@03000000/vind@0/isp@0"; isp1 = "/soc@03000000/vind@0/isp@1"; scaler0 = "/soc@03000000/vind@0/scaler@0"; scaler1 = "/soc@03000000/vind@0/scaler@1"; scaler2 = "/soc@03000000/vind@0/scaler@2"; scaler3 = "/soc@03000000/vind@0/scaler@3"; scaler4 = "/soc@03000000/vind@0/scaler@4"; scaler5 = "/soc@03000000/vind@0/scaler@5"; actuator0 = "/soc@03000000/vind@0/actuator@0"; flash0 = "/soc@03000000/vind@0/flash@0"; sensor0 = "/soc@03000000/vind@0/sensor@0"; sensor1 = "/soc@03000000/vind@0/sensor@1"; vinc0 = "/soc@03000000/vind@0/vinc@0"; vinc1 = "/soc@03000000/vind@0/vinc@1"; vinc2 = "/soc@03000000/vind@0/vinc@2"; vinc3 = "/soc@03000000/vind@0/vinc@3"; vinc4 = "/soc@03000000/vind@0/vinc@4"; vinc5 = "/soc@03000000/vind@0/vinc@5"; Vdevice = "/soc@03000000/vdevice@0"; emce = "/soc@03000000/emce@01905000"; cryptoengine = "/soc@03000000/ce@1904000"; di = "/soc@03000000/deinterlace@0x01420000"; scr0 = "/soc@03000000/smartcard@0x05005000"; nand0 = "/soc@03000000/nand0@04011000"; ts0 = "/soc@03000000/ts0@05060000"; ths = "/soc@03000000/thermal_sensor"; cpu_trips = "/soc@03000000/thermal-zones/cpu_thermal_zone/trips"; cpu_threshold = "/soc@03000000/thermal-zones/cpu_thermal_zone/trips/trip-point@0"; cpu_target = "/soc@03000000/thermal-zones/cpu_thermal_zone/trips/trip-point@1"; cpu_crit = "/soc@03000000/thermal-zones/cpu_thermal_zone/trips/cpu_crit@0"; gpadc = "/soc@03000000/gpadc"; keyboard0 = "/soc@03000000/keyboard"; gmac0 = "/soc@03000000/eth@05020000"; gmac1 = "/soc@03000000/eth@05030000"; gpio_encrypt = "/soc@03000000/gpio_encrypt"; wlan = "/soc@03000000/wlan"; bt = "/soc@03000000/bt"; btlpm = "/soc@03000000/btlpm"; addr_mgt = "/soc@03000000/addr_mgt"; sprd_marlin3 = "/soc@03000000/sprd-marlin3"; aliases = "/aliases"; cpu0 = "/cpus/cpu@0"; CPU_SLEEP_0 = "/cpus/idle-states/cpu-sleep-0"; cpu_opp_l_table = "/opp_l_table"; dram = "/dram"; gic = "/interrupt-controller@03020000"; wakeupgen = "/interrupt-controller@0"; nmi_intc = "/intc-nmi@07010320"; sid = "/sunxi-sid@03006000"; sunxi_sid = "/sunxi-sid-ng@03006000"; speedbin_efuse = "/sunxi-sid-ng@03006000/speed@00"; ths_calib = "/sunxi-sid-ng@03006000/calib@14"; chipid = "/sunxi-chipid@03006200"; uboot = "/uboot"; mmu_aw = "/iommu@030f0000"; gpu = "/gpu@0x01800000"; ipa_dvfs = "/gpu@0x01800000/ipa_dvfs"; }; };
