cal5582
  1. cal5582 replied to sven-ola's topic in RISC-V
    not sure how i missed that. thanks1
  2. cal5582 replied to sven-ola's topic in RISC-V
    so im not exactly sure why, but now i am getting an error building the most recent images in debian 13 under virtualbox. [🔨] INSTALL /home/vm/armbian/build/.tmp/work-7197f8ae-9b85-4959-9885-0c198551c928/kernel_dest_install_dir-wUSTJ/libc_headers/include [🔨] /bin/sh: 1: rsync: not found [🔨] make[2]: *** [Makefile:1416: headers_install] Error 127 [🔨] make[1]: *** [/home/vm/armbian/build/cache/sources/linux-kernel-worktree/6.18__spacemit__riscv64/Makefile:380: __build_one_by_one] Error 2 [🔨] make: *** [Makefile:248: __sub-make] Error 2 [🌱] Ccache result [ hit=0 miss=0 (0%) ] [💥] Error 2 occurred in main shell [ at /home/vm/armbian/build/lib/functions/compilation/kernel.sh:264 kernel_build() --> lib/functions/compilation/kernel.sh:264 do_with_hooks() --> lib/functions/general/extensions.sh:618 do_with_logging() --> lib/functions/logging/section-logging.sh:81 kernel_prepare_build_and_package() --> lib/functions/compilation/kernel.sh:166 compile_kernel() --> lib/functions/compilation/kernel.sh:99 artifact_kernel_build_from_sources() --> lib/functions/artifacts/artifact-kernel.sh:310 artifact_build_from_sources() --> lib/functions/artifacts/artifacts-obtain.sh:34 obtain_complete_artifact() --> lib/functions/artifacts/artifacts-obtain.sh:280 build_artifact_for_image() --> lib/functions/artifacts/artifacts-obtain.sh:394 main_default_build_packages() --> lib/functions/main/build-packages.sh:97 full_build_packages_rootfs_and_image() --> lib/functions/main/default-build.sh:31 do_with_default_build() --> lib/functions/main/default-build.sh:42 cli_standard_build_run() --> lib/functions/cli/cli-build.sh:25 armbian_cli_run_command() --> lib/functions/cli/utils-cli.sh:136 cli_entrypoint() --> lib/functions/cli/entrypoint.sh:216 main() --> compile.sh:50 ] [💥] Cleaning up [ please wait for cleanups to finish ] [✨] Repeat Build Options [ ./compile.sh build BOARD=orangepirv2 BRANCH=current BUILD_DESKTOP=no BUILD_MINIMAL=no INSTALL_HEADERS=yes KERNEL_CONFIGURE=yes KERNEL_GIT=Full RELEASE=trixie ]
  3. cal5582 replied to sven-ola's topic in RISC-V
    took me a long time to figure out why, my nvme drive would show under lspci, and it would see the controller but id never get anything under lsblk. still not sure what changed but if anyone else runs into similar problem thats how i fixed it.
  4. cal5582 replied to sven-ola's topic in RISC-V
    Not sure why, but i had to add the pcie_aspm=off to my /boot/extlinux.conf to get the newest build to see my nvme drive, this has never happened on previous builds, and the only options i turn on from the default config being fetched is enabling graphics drivers. very strange.
  5. cal5582 replied to sven-ola's topic in RISC-V
    just curious is there any way to rebuild the kernel inside the board itself and update it manually, since the armbian build tools only generate an image to flash to sd card? like its it possible to rebuild the custom kernel files, copy them over, and then relink them somehow in the bootloader or no? im new to this whole, embedded systems non-x86 approach.
  6. cal5582 replied to sven-ola's topic in RISC-V
    just need to enable device drivers >graphics support> direct rendering manager> AMD GPU device drivers >graphics support> direct rendering manager> Noveau (nvidia) cards device drivers >graphics support> direct rendering manager> Intel Xe2 Graphics in the config
  7. cal5582 replied to sven-ola's topic in RISC-V
    how do i do that? i just apt-hold marked the packages for the time being.
  8. cal5582 replied to sven-ola's topic in RISC-V
    just wanted to ask, is there any way to recompile the included drivers in the kernel after a kernel update? for instance i built the intel xe and radeon drivers into my kernel when building this image, but the kernel updates from mainline apt seem to overwrite it and the drivers go away. even when dkms installed.
  9. cal5582 replied to sven-ola's topic in RISC-V
    nvme drive is in the bottom slot, oculink adapter going to a powered external pci-e adapter in the top nvme slot. i was able to plug a non-gpu in it and get a device to detect. just both my intel arc gpus failed to detect. edit, new discovery, when the fpga device is active on the 2nd nvme slot i can no longer see my original nvme drive if booting off the sd card. very strange. almost like its a lane bifrucation issue. ignore that, misconfig on my end.
  10. cal5582 replied to sven-ola's topic in RISC-V
    not sure if this is the right place to ask, but i was able to get it to recompile the kernel with the xe driver flag turned on, and got a working booting 6.18.9 image, which is amazing, i have never been able to get anything newer than the 6.6 kernel the manufacturer provided working. so thank you so much for all your hard work. theres only one problem, when i do the lspci command, i dont see anything attached to that slot. i tried two different intel arc gpus, an arc 350 and an arc 310 neither detects. so i pulled out an ibm fpga card and plugged it into the same powered oculink adapter, and lo and behold the fpga card detected, so my pcie adapter setup is good. is there any advice you could offer besides enabling the xe2 driver in kernel that i may have to persue? i know this is kind of off topic, id just like to get hardware accelerated graphics working on this device.
  11. cal5582 replied to sven-ola's topic in RISC-V
    so i am testing your edge build of 6.18 kernel and it works great. but one of the things i would like to do is to enable the intel and amd graphics drivers for testing(ive got an external intel gpu on the nvme slot). on normal debian i just download the kernel do a make menuconfig and specify, im new to armbian and see it uses a compile.sh script. i didnt see a branch on your github for the edge kernel, just saw rv2 and rv2-ky. so im kind of curious as to where i clone from to get your edge kernel branch.
