- Rock 5B+ fails to boot from SPI+NVMe when second NVMe is present (solid blue LED)
Hi @Werner, I bought an UART USB device and followed your video here https://www.youtube.com/watch?v=UpVMO7gbnYM to read boot logs. I'm not a huge expert but looks like there is a problem finding /boot when two nvme are connected. Please find attached the following logs: uart-bootcorrectnvme.log -> one nvme plugged (the one with os installed in slot 1) - works! uart-bootdualnvme.log -> two nvme plugged (the one with os installed in slot 1) - fails! uart-bootmicrosd.log -> two nvme plugged + microsd plugged - works! Tests have been executed with official 30W Radxa Power adapter ( same result with POE+ 25W hat) Please, let me know if there is anything else I can provide. Thanks uart-bootcorrectnvme.log uart-bootdualnvme.log uart-bootmicrosd.log
Hi everyone, I'm facing an issue with Armbian installation on Rock 5B Plus. Hardware Board: Radxa ROCK 5B+ (RK3588) Storage: NVMe #1 (system): 256 GB, in M.2 slot 1 NVMe #2 (backup): 128 GB, in M.2 slot 2 Boot: MTD flash + NVMe Power supply: both POE+ HAT 25W and official power supply 30W Software Armbian: 25.11.2 Desktop ubuntu Kernel: 6.1.115-vendor-rk35xx Boot configured via armbian-install → “Boot from MTD Flash, system on NVMe” Initial install steps Wrote Armbian image to microSD and booted from SD. Used armbian-install to install: Boot from MTD Flash, system on NVMe #1 Powered off, removed SD, left only NVMe #1 installed. Board boots fine from SPI+NVMe #1: blue LED, OS comes up, Green LED, everything OK. Power off the board and plug NVME #2 (preformatted ext4 with gparted and empty, the disk works because I tried the procedure the other way around, using the second disk as the main one) Power on. Solid blue light, no OS, no HDMI output (I don't have UART) lsblk -f with microSD plugged: mtdblock0 mmcblk1 └─mmcblk1p1 ext4 1.0 armbi_root 2e67f233-22a9-46c9-90a7-8f0e0f2d3154 21.7G 22% /var/log.hdd / zram0 [SWAP] zram1 36M 16% /var/log zram2 nvme1n1 ├─nvme1n1p1 ext4 1.0 cacf66ca-ea9b-4dc4-b7b3-185f18e7c64f 100G 6% /mnt/main └─nvme1n1p2 ext4 1.0 data a7d6675c-3ca6-4a87-85cf-7d91856fd79c nvme0n1 └─nvme0n1p1 ext4 1.0 armbi_backup 5aadc790-715a-4f48-bbbc-ce4bfd2717bd 110.8G 0% /mnt/backup /boot/armbianEnv.txt looks correct verbosity=1 bootlogo=true console=both extraargs=cma=256M overlay_prefix=rockchip-rk3588 overlays=panthor-gpu fdtfile=rockchip/rk3588-rock-5b-plus.dtb rootdev=UUID=cacf66ca-ea9b-4dc4-b7b3-185f18e7c64f rootfstype=ext4 usbstoragequirks=0x2537:0x1066:u,0x2537:0x1068:u /etc/fstab looks correct # <file system> <mount point> <type> <options> <dump> <pass> tmpfs /tmp tmpfs defaults,nosuid 0 0 UUID=cacf66ca-ea9b-4dc4-b7b3-185f18e7c64f / ext4 defaults,noatime,commit=120,errors=remount-ro,x-gvfs-hide 0 1 UUID=5aadc790-715a-4f48-bbbc-ce4bfd2717bd /mnt/backup ext4 defaults,nofail 0 2 <--- also tried without this line I've also tried by "forcing" the mount of NMVE #2 by adding it to /etc/fstab of NVME #1 but nothing changes. Could you please help me understand if this is an issue related to my configuration or could be a bug? Thanks
Emanuele T.
