1111Windows
  1. 1111Windows replied to sven-ola's topic in RISC-V
    Hello @4A studio ,I'm sorry for the late reply. I accidentally installed the image to a partition on the Micro SD card using the `dd` command (of=/dev/sd*2). I eventually resolved the issue by using the correct `dd` command (of=/dev/sd*).
  2. 1111Windows replied to sven-ola's topic in RISC-V
    Hi @sven-ola , I'm having an issue where my portrait-oriented monitor isn't displaying anything properly. I have a portrait-oriented monitor, and when I try to connect it via HDMI, it doesn't display anything—the screen remains blank. I found this in dmesg: [drm] spacemit_hdmi_connector_detect() hdmi status connected [drm] Initialized spacemit 1.0.0 for c0440000.display-subsystem-hdmi on minor 1 [drm] spacemit_hdmi_connector_detect() hdmi status connected [drm] spacemit_hdmi_get_edid_block() len 128 [drm] spacemit_hdmi_get_edid_block() len 128 spacemit-drm-drv c0440000.display-subsystem-hdmi: [drm] Cannot find any crtc or sizes I added `video=1080x1920@60` to the kernel parameters. Now it outputs: [ 4.162834] spacemit-drm-drv c0440000.display-subsystem-hdmi: [drm] User-defined mode not supported: "1080x1920": 60 137020 1080 1152 1160 1176 1920 1934 1936 1942 0x68 0x5 [ 4.162871] spacemit-drm-drv c0440000.display-subsystem-hdmi: [drm] Cannot find any crtc or sizes I think this is because the driver only supports a resolution of 1920x1080, but not 1080x1920. dmesg.txt
  3. 1111Windows replied to sven-ola's topic in RISC-V
    Hello@sven-ola After flashing the image correctly, I found that running `sudo apt upgrade` to update the system caused the kernel to fail to load; the issue appears to stem from the kernel update. Installing the `linux-image-current-spacemit 26.2.1` update causes the kernel to fail to load. I noticed that the kernel version in the image is 6.18.18-current-spacemit, while the kernel version in the Armbian repository is 6.6.99-current-spacemit. I think this is likely the root of the problem; I should not have used apt to update the kernel. In any case, thank you for porting Armbian to the OrangePi RV2.
  4. 1111Windows replied to sven-ola's topic in RISC-V
    @sven-ola Have you tried booting from a microSD card? I downloaded Armbian-unofficial_26.02.0-trunk_Orangepirv2_trixie_current_6.18.18_gnome_desktop.img and flashed it to my microSD card, but it won't boot. log: sys: 0x200 try sd... bm:3 j... U-Boot SPL 2022.10_armbian-2022.10-Sd61c-P155c-H452d-V4161-B61c5-R448a (Mar 17 2026 - 03:52:17 +0000) [ 0.381] DDR type LPDDR4X [ 0.383] set ddr tx odt to 80ohm! [ 0.393] lpddr silicon init consume 11ms [ 0.394] Change DDR data rate to 2400MT/s [ 0.633] Boot from fit configuration x1_orangepi-rv2 [ 0.635] ## Checking hash(es) for config conf_18 ... OK [ 0.641] ## Checking hash(es) for Image uboot ... crc32+ OK [ 0.652] ## Checking hash(es) for Image fdt_18 ... crc32+ OK [ 0.674] ## Checking hash(es) for config config_1 ... OK [ 0.677] ## Checking hash(es) for Image opensbi ... crc32+ OK [ 0.725] U-Boot 2022.10_armbian-2022.10-Sd61c-P155c-H452d-V4161-B61c5-R448a (Mar 17 2026 - 03:52:17 +0000) [ 0.732] CPU: rv64imafdcv [ 0.734] Model: ky x1 orangepi-rv2 board [ 0.738] DRAM: 2 GiB [ 0.830] Core: 414 devices, 29 uclasses, devicetree: board [ 0.843] WDT: Started PMIC_WDT with servicing (60s timeout) [ 0.848] WDT: Started watchdog@D4080000 with servicing (60s timeout) [ 0.857] MMC: [ 0.956] *** Warning - bad CRC, using default environment [ 0.961] initialize_console_log_buffer [ 0.962] Have allocated memory for console log buffer [ 0.967] In: serial [ 0.969] Out: serial [ 0.971] Err: serial [ 1.116] k1x_qspi spi@d420c000: qspi iobase:0x0x00000000d420c000, ahb_addr:0x0x00000000b8000000, max_hz:26500000Hz [ 1.124] k1x_qspi spi@d420c000: rx buf size:128, tx buf size:256, ahb buf size=512 [ 1.131] k1x_qspi spi@d420c000: AHB read enabled [ 1.136] k1x_qspi spi@d420c000: bus clock: 26500000Hz, PMUap reg[0xd4282860]:0x0000075b [ 1.143] k1x_qspi spi@d420c000: AHB buf size: 512 [ 1.148] SF: Detected XM25QU128C with page size 256 Bytes, erase size 64 KiB, total 16 MiB List of MTD devices: [ 1.159] * nor0 [ 1.160] - device: flash@0 [ 1.163] - parent: spi@d420c000 [ 1.166] - driver: jedec_spi_nor [ 1.170] - path: /soc/spi@d420c000/flash@0 [ 1.173] - type: NOR flash [ 1.176] - block size: 0x10000 bytes [ 1.180] - min I/O: 0x1 bytes [ 1.183] - 0x000000000000-0x000001000000 : "nor0" [ 1.188] - 0x000000000000-0x000000010000 : "bootinfo" [ 1.193] - 0x000000010000-0x000000020000 : "private" [ 1.198] - 0x000000020000-0x000000060000 : "fsbl" [ 1.203] - 0x000000060000-0x000000070000 : "env" [ 1.208] - 0x000000070000-0x0000000a0000 : "opensbi" [ 1.213] - 0x0000000a0000-0x000001000000 : "uboot" [ 1.219] Failed to get fastboot key config: -19 [ 1.222] Failed to probe HUSB239: -19 [ 1.227] RGMII interface [ 1.228] eth0: ethernet@cac80000 [ 1.231] MAC mapping file path not set in environment [ 1.236] K1X: :_load_env_from_blk [ 1.247] Can't set block device [ 1.248] Net: eth0: ethernet@cac80000 [ 1.254] Hit any key to stop autoboot: 0 Loading K1-X Environment ... [ 2.260] [ 2.261] Running NVMe Scan ... [ 2.272] pcie_dw_k1x pcie@ca400000: has no power-on-status flag, use default. [ 2.277] Now init Rterm... [ 2.279] pcie prot id = 1, porta_init_done = 0 [ 2.283] Now waiting portA resister tuning done... [ 2.288] porta redonly_reg2: 00005d37 [ 2.292] pcie_rcal = 0x00005d37 [ 2.295] pcie port id = 1, lane num = 2 [ 2.298] Now int init_puphy... [ 2.301] waiting pll lock... [ 2.304] Now finish init_puphy.... [ 2.307] pcie_dw_k1x pcie@ca400000: Unable to get phy0 [ 2.312] pcie_dw_k1x pcie@ca400000: Unable to get phy1 [ 2.317] pcie_dw_k1x pcie@ca400000: PCIe interface power on, set gpio 116 to 1 [ 3.426] PCIE-0: Link down [ 3.438] pcie_dw_k1x pcie@ca800000: has no power on gpio. [ 3.441] pcie_dw_k1x pcie@ca800000: has no power-on-status flag, use default. [ 3.448] Now init Rterm... [ 3.450] pcie prot id = 2, porta_init_done = 0 [ 3.455] Now waiting portA resister tuning done... [ 3.459] porta redonly_reg2: 00005d37 [ 3.463] pcie_rcal = 0x00005d37 [ 3.466] pcie port id = 2, lane num = 2 [ 3.470] Now int init_puphy... [ 3.472] waiting pll lock... [ 3.475] Now finish init_puphy.... [ 3.479] pcie_dw_k1x pcie@ca800000: Unable to get phy0 [ 3.484] pcie_dw_k1x pcie@ca800000: Unable to get phy1 [ 4.590] PCIE-1: Link down [ 4.642] pcie_dw_k1x pcie@ca400000: has no power-on-status flag, use default. [ 4.646] Now init Rterm... [ 4.648] pcie prot id = 1, porta_init_done = 0 [ 4.653] Now waiting portA resister tuning done... [ 4.657] porta redonly_reg2: 00005d37 [ 4.661] pcie_rcal = 0x00005d37 [ 4.664] pcie port id = 1, lane num = 2 [ 4.668] Now int init_puphy... [ 4.671] waiting pll lock... [ 4.673] Now finish init_puphy.... [ 4.677] pcie_dw_k1x pcie@ca400000: Unable to get phy0 [ 4.682] pcie_dw_k1x pcie@ca400000: Unable to get phy1 [ 4.687] pcie_dw_k1x pcie@ca400000: PCIe interface power on, set gpio 116 to 1 [ 5.795] PCIE-0: Link down [ 5.807] pcie_dw_k1x pcie@ca800000: has no power on gpio. [ 5.810] pcie_dw_k1x pcie@ca800000: has no power-on-status flag, use default. [ 5.817] Now init Rterm... [ 5.819] pcie prot id = 2, porta_init_done = 0 [ 5.824] Now waiting portA resister tuning done... [ 5.828] porta redonly_reg2: 00005d37 [ 5.832] pcie_rcal = 0x00005d37 [ 5.835] pcie port id = 2, lane num = 2 [ 5.839] Now int init_puphy... [ 5.841] waiting pll lock... [ 5.844] Now finish init_puphy.... [ 5.848] pcie_dw_k1x pcie@ca800000: Unable to get phy0 [ 5.853] pcie_dw_k1x pcie@ca800000: Unable to get phy1 [ 6.959] PCIE-1: Link down [ 6.963] no nvme partition table available [ 6.964] Couldn't find partition nvme 0:1 [ 6.968] Couldn't find partition nvme 0:1 [ 6.972] Couldn't find partition nvme 0:1 [ 6.976] Couldn't find partition nvme 0:1 [ 6.980] Couldn't find partition nvme 0:1 =>
