daniejd
  1. https://github.com/armbian/build/blob/main/patch/kernel/archive/rockchip64-7.2/board-firefly-rk3399-dts.patch I assume you mean something like this? Thank you both for the explanation. While I understood the concept I really had no idea the layers of patches or the fact that no clean source (patch applied) existed in the repository. I decided to decompile and hack the hex (while the suggestion of using armbian build seems simple, it really isn’t in my situation). It seems promising, not working but the card is now correctly recognized and getting power, so a step closer… Thank you both for you patience, Caio.
  2. Sorry it wasn’t clear to me that the ONLY way to generate a single dtb from source was to go through the entire Armbian custom build process. I was aware that was one possible route, though in my case it seemed overkill. Either way I am grateful you guys got me as far as you did, thank you! -J
  3. I do appreciate the help, but I believe we are just going around in circles. I’ll mark it as the solution to close the thread. Thank You. -J
  4. Im sorry Im not following. https://armbian.com/boards/firefly-rk3399 Is what I have and what is mostly working. All I want to do is correctly reproduce the dtb used in those images from the source. If I use Armbian build won’t it create a kernel etc? And I don’t think my board could handle that. At this point im assuming that Armbian build applies something to the dtb other than whats listed in the dts. No idea. I really don’t want to decompile the working dtb, and try and hack my way through all those hex addresses, but unless I can reproduce the working dtb, that may be the only option.
  5. Those links were a no go. They compiled and behaved exactly like the previous failed dtb. For example the current working dtb from the image is 85k. From the mainline, it compiles to 65k, and silently fails (getting to the uart is a bit of a pia, that’s why I am only trying to reproduce what is already working). From the armbian tree it compiles to 97k and also fails silently, though the power led works. This is compiling on the board itself. No warnings or errors. A basic clone>makeconfig>make. The image dtb works, but I can’t reproduce it. -J
  6. Thank you! At this point I am just trying to reproduce the rk3399-firefly.dtb that is currently available in the weekly images. (I am new to this and it gets confusing with multiple repositories and dts that are different in them, though it is probably me just not knowing where to look.) And to further obscure things firefly chose the single worse naming conventions for their boards! I will give the links you supplied a try.
  7. Let me start by saying thank you all for the great work, it is appreciated! So a bit of info first. board: firefly rk3399-pc pro ( yeah I know it’s old, but so am I!) os: armbian Debian trixie kernel: 6.18.35 Bear with me, last time I touched Linux, lilo and xfree86 were things… I installed the community supported rk3399-firefly as I didn’t find a better match for the pro. Most of the hardware worked with the major exception of the audio. No problem, the rk3399-roc-plus.dts had the correct audio for the board all I needed to do was switch the audio portion into the rk3399-firefly.dts (though other aspects including just booting stopped me from directly switching to the plus dts). I mistakenly cloned and compiled from the mainline (I put the ‘no!’ In noob). It of course didnt work. Next I cloned and compiled (without changing anything) from the armbian repository. Again it would not boot. So here is the embarrassing question. Where is the repository that contains the dts files that are actually used to build the dtb files in the active images? My last try was github.com/armbian/rockchip.git . Im pretty sure I’m cloning, compiling and switching the dtb correctly, just can’t find the right source material! Again, thank you in advance. -J
