SV6256P WiFi Now Working on Linux 6.x (Armbian Tested)
Hello. Thanks for the reply. Since a new version has been released yesterday, I give it a try and no dice. The module ssv6051 shipped with the kernel does not work in my tv-box, it gives lots of trace in dmesg and the error "RTNETLINK answers: Operation not permitted". For now I switch to stable channel, installed the driver by @eloirotava and hold the kernel, headers and firmware packages. Below the console output: [ OK ] Reached target graphical.target - Graphical Interface. Armbian_community 26.11.0-trunk.33 Trixie tty1 rk322x-box login: root Password: _ _ _ _ _ /_\ _ _ _ __ | |__(_)__ _ _ _ __ ___ _ __ _ __ _ _ _ _ (_) |_ _ _ / _ \| '_| ' \| '_ \ / _` | ' \ / _/ _ \ ' \| ' \ || | ' \| | _| || | /_/ \_\_| |_|_|_|_.__/_\__,_|_||_| \__\___/_|_|_|_|_|_\_,_|_||_|_|\__|\_, | |__/ v26.11 rolling for rk322x-box running Armbian Linux 6.18.48-current-rockchip Packages: Debian stable (trixie) Support: for advanced users (rolling release) IPv4: (LAN) 192.168.1.247 (WAN) Performance: Load: 40% Uptime: 1m Memory usage: 5% of 1.94G CPU temp: 60øC Usage of /: 17% of 7.0G Tips: Becoming a sponsor? https://github.com/sponsors/armbian Commands: Configuration: armbian-config Monitoring : htop root@rk322x-box:~# ip link set wlan0 up RTNETLINK answers: Operation not permitted root@rk322x-box:~# dmesg | grep ssv | tail [ 19.098501] ieee80211 phy0: Selected rate control algorithm 'ssv6xxx_rate_control' [ 134.526425] SSV WLAN driver ssv6200: chip id: RSV6200A0-201311, tag: 2014012420010960 [ 134.689135] SSV WLAN driver ssv6200: Failed to allocate packet buffer of 904 bytes in 0 type. [ 134.689224] SSV WLAN driver ssv6200: opps allocate pbuf error [ 134.689268] WARNING: CPU: 3 PID: 1371 at drivers/net/wireless/ssv6051/smac/init.c:608 ssv6xxx_init_mac+0xc28/0xc30 [ssv6051] [ 134.689407] Modules linked in: snd_soc_hdmi_codec ir_nec_decoder snd_soc_spdif_tx gpio_ir_recv gpio_keys snd_soc_audio_graph_card2 cpufreq_dt ssv6051 snd_soc_simple_card_utils mac80211 dw_hdmi_i2s_audio dw_hdmi_cec hantro_vpu rockchip_rg a rockchip_vdec v4l2_jpeg v4l2_vp9 v4l2_h264 lima videobuf2_dma_contig snd_soc_rk3228 snd_soc_rockchip_spdif snd_soc_rockchip_i2s gpu_sched v4l2_mem2mem snd_soc_core snd_pcm_dmaengine snd_pcm snd_timer rockchip_thermal snd rk_crypto soundco re dw_wdt crypto_engine cfg80211 zram 842_decompress 842_compress lz4hc_compress lz4_compress binfmt_misc sch_fq_codel fuse nfnetlink ip_tables x_tables btrfs blake2b_generic blake2b_neon [ 134.690277] warn_slowpath_fmt from ssv6xxx_init_mac+0xc28/0xc30 [ssv6051] [ 134.690365] ssv6xxx_init_mac [ssv6051] from ssv6200_start+0x34/0x190 [ssv6051] [ 134.690486] ssv6200_start [ssv6051] from drv_start+0x48/0xfc [mac80211] [ 134.694102] SSV WLAN driver ssv6200: Failed to initialize mac, ret=1 root@rk322x-box:~# ip link show wlan0 3: wlan0: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN mode DEFAULT group default qlen 1000 link/ether e0:f5:af:82:83:5b brd ff:ff:ff:ff:ff:ff altname wlxe0f5af82835b root@rk322x-box:~# setterm --dump --file ssv.dump
Hello! First post here. Thank you for the great job bringing to life this older tv-box. Following this thread, what worked here with TV box PROSB-2000/2GB (maybe a clone of MX) was the driver SSV6051P from @eloirotava, the SSV6X5X loads but no device is shown (wlan0). The command linux-headers-$(uname -r) returns an error (Couldn't find any package), instead I need to run: # apt install linux-headers-current-rockchip After compile successful, just replace the ssv6051 respective files and run: # depmod -a # update-initramfs -u Using the Network basic option in armbian-config to connect wireless AP works after reboot. Once again, thank you.
lopanrs
