diaamant
  1. How to change dts file to make Allwinner H618 Banana Pi M4 zero USB connector become host instead of OTG ??? usb@5100000 { compatible = "allwinner,sun50i-h616-musb\0allwinner,sun8i-h3-musb"; reg = <0x5100000 0x400>; clocks = <0x02 0x70>; resets = <0x02 0x32>; interrupts = <0x00 0x19 0x04>; interrupt-names = "mc"; phys = <0x23 0x00>; phy-names = "usb"; extcon = <0x23 0x00>; status = "okay"; # dr_mode = "peripheral"; # ????? dr_mode = "host"; phandle = <0x5f>;
  2. Success Bookworm!!! Done building [ Armbian-unofficial_24.5.1_Bananapim4zero_bookworm_current_6.6.30_minimal.img ] [|] SHA256 calculating [ Armbian-unofficial_24.5.1_Bananapim4zero_bookworm_current_6.6.30_minimal.img ] [|] Moving artefacts using rsync to final destination [ Armbian-unofficial_24.5.1_Bananapim4zero_bookworm_current_6.6.30_minimal ] [|] sending incremental file list [|] Armbian-unofficial_24.5.1_Bananapim4zero_bookworm_current_6.6.30_minimal.img [|] Armbian-unofficial_24.5.1_Bananapim4zero_bookworm_current_6.6.30_minimal.img.sha [|] Armbian-unofficial_24.5.1_Bananapim4zero_bookworm_current_6.6.30_minimal.img.txt
  3. Success!!! [ Armbian-unofficial_24.5.1_Bananapim4zero_jammy_current_6.6.30_minimal.img ] [|] Moving artefacts using rsync to final destination [ Armbian-unofficial_24.5.1_Bananapim4zero_jammy_current_6.6.30_minimal ] [|] sending incremental file list [|] Armbian-unofficial_24.5.1_Bananapim4zero_jammy_current_6.6.30_minimal.img [|] Armbian-unofficial_24.5.1_Bananapim4zero_jammy_current_6.6.30_minimal.img.sha [|] Armbian-unofficial_24.5.1_Bananapim4zero_jammy_current_6.6.30_minimal.img.txt
  4. Perhaps this will be useful: Downloaded and ran the Docker binaries. Compilation current Bookworm for Bananapi M4 Zero fails with error: ``` CC [M] drivers/iio/light/zopt2201.o LD [M] drivers/net/usb/asix.o [|] AR drivers/built-in.a [|] make[2]: *** [Makefile:1915: .] Error 2 [|] make[1]: *** [/armbian/cache/sources/linux-kernel-worktree/6.6__sunxi64__arm64/Makefile:359: __build_one_by_one] Error 2 [|] make: *** [Makefile:234: __sub-make] Error 2 [|] Error 2 occurred in main shell [ at /armbian/lib/functions/logging/runners.sh:211 run_host_command_logged_raw() --> lib/functions/logging/runners.sh:211 run_host_command_logged() --> lib/functions/logging/runners.sh:193 run_kernel_make_internal() --> lib/functions/compilation/kernel-make.sh:61 run_kernel_make_long_running() --> lib/functions/compilation/kernel-make.sh:74 do_with_ccache_statistics() --> lib/functions/compilation/ccache.sh:39 kernel_build() --> lib/functions/compilation/kernel.sh:224 do_with_hooks() --> lib/functions/general/extensions.sh:557 do_with_logging() --> lib/functions/logging/section-logging.sh:81 kernel_prepare_build_and_package() --> lib/functions/compilation/kernel.sh:158 compile_kernel() --> lib/functions/compilation/kernel.sh:91 artifact_kernel_build_from_sources() --> lib/functions/artifacts/artifact-kernel.sh:240 artifact_build_from_sources() --> lib/functions/artifacts/artifacts-obtain.sh:34 obtain_complete_artifact() --> lib/functions/artifacts/artifacts-obtain.sh:280 build_artifact_for_image() --> lib/functions/artifacts/artifacts-obtain.sh:392 main_default_build_packages() --> lib/functions/main/build-packages.sh:108 full_build_packages_rootfs_and_image() --> lib/functions/main/default-build.sh:31 do_with_default_build() --> lib/functions/main/default-build.sh:42 cli_standard_build_run() --> lib/functions/cli/cli-build.sh:25 armbian_cli_run_command() --> lib/functions/cli/utils-cli.sh:136 cli_entrypoint() --> lib/functions/cli/entrypoint.sh:176 main() --> compile.sh:50 ```
  5. Good afternoon. I have great respect for your work (I signed up for an Individual subscription and made a small contribution to Funding equipment in April 2023) Question about Bananapi M4 Zero board The board is assigned the status "Standard Support", but there are no links to a stable image (for example Armbian 24.2.1 Bookworm CLI). There are only links to daily/rolling releases. I understand how much time and effort goes into maintaining a large number of boards. Tell me, can we hope for the appearance of stable firmware versions for Bananapi M4 Zero?
