rix81
  1. flashed to m2 mvme, board attempts to boot , then after armbian logo it falls into busybox command prompt (
  2. Hello, i'm using Armbian 23.11 Jammy-amazingfated Gnome. Kernel 5.10 If to seek a couple of times in h264 1080p BD remux'es it will cause system restart. Any video players are affected. Tried mpv, vlc, kodi and others. Problem affect just h264 1080p remuxes, that typically are 30..40 Gb, smaller h264 or even larger h265 files seem to work fine. I tried fresh install of armbian, where no rkmpp is installed, then h264 files plays/seeks fine, in software mode of course. Once I did sudo update/upgrade, that also installs rkmpp and other rockchip stuff, then videos start to play with rkmpp and problem is back. I've tried disabling hw decoding as workaround , weird, but it seems it's not possible to do in any player. In mpv : hwdec=no , or pressing ctrl+h has no affect, can't get rid of rkmpp decoder. Ive tried all possible commands related to this, from official mpv documentation, but nothing helps to disable rkmpp . This is probably another issue. Disabling buggy h264_rkmpp_decoder could be good workaround, as cpu is easily capable do play 1080p in sw, but can't find a way to do this, no matter i try, pls help. Especially looking for solution for mpv
