Henrik Larsson
  1. I have now built the module with the armbian build framework and then it works.
  2. I am having the same issue on Nanopi Neo Air and uname -r 6.12.51-current-sunxi I can't find a solution. I can also as @mue473 mentioned see that prebuild kernel modules: readelf -r netlink_diag.ko | grep cleanup 00000000 00003402 R_ARM_ABS32 00000001 cleanup_module 000002d4 00003402 R_ARM_ABS32 00000001 cleanup_module while my own has readelf -r testm.ko | grep cleanup 00000000 00004902 R_ARM_ABS32 00000001 cleanup_module 000002c4 00004902 R_ARM_ABS32 00000001 cleanup_module I have no idea though if this matters at all. Does anyone know?
  3. Hi, I see in the /usr/lib/armbian/armbian-firstrun script that it runs the command: update-rc.d ap6212-bluetooth defaults for nanopi neo air (and some other boards) However if I try to run this script sudo /usr/lib/armbian/armbian-firstrun start The result is: update-rc.d: error: unable to read /etc/init.d/ap6212-bluetooth setfont: ERROR kdfontop.c:183 put_font_kdfontop: Unable to load such font with such kernel version setfont: ERROR kdfontop.c:183 put_font_kdfontop: Unable to load such font with such kernel version setfont: ERROR kdfontop.c:183 put_font_kdfontop: Unable to load such font with such kernel version setfont: ERROR kdfontop.c:183 put_font_kdfontop: Unable to load such font with such kernel version setfont: ERROR kdfontop.c:183 put_font_kdfontop: Unable to load such font with such kernel version setfont: ERROR kdfontop.c:183 put_font_kdfontop: Unable to load such font with such kernel version I cannot find ap6212-bluetooth anywhere ... is this something old that was left by mistake in the armbian-firstrun script? Anyone know? (wifi and bluetooth seem to work)
