Skip to content
View in the app
Armbian Community Forums
Tinker board S / Enabling Serial Port hardware (USV Hat from StromPi)
Featured Replies
Hi
I need to do the following things on my Tinker Board S what i normally do on Raspberry Pi 3:
raspi-config; system; Hardware;  5 interfacing options, 6 Serial
Would you like a login shell to be accessible over serial? = No
Would you like the serial port hardware to be enabled? = Yes
then I need to add the following line in the /boot/config.txt
dtoverlay=rpi3-minuart-bt
This activates the Serial Console on /dev/serial0
Where do I config Serial and how?
what is the correct dtoverlay for the miniuar-bt in tinkerboard?
does anyone have a hint for me?
  • Author
23 hours ago, martinayotte said:
Your question is not really clear ...
What are you trying to achieve ?
Hi
I would need the GPIO 15 & 16 Serial Port at Physical Pin 8 and 10 referenced as /dev/serial0 or /dev/ttyAMA0
And here dmesg output
dmesg | grep tty
[    0.000000] Kernel command line: earlyprintk root=UUID=bae26a9d-0ce2-427d-b5ad-fc7e7f9144e6 rootwait rootfstype=ext4 console=ttyS2,115200n8 console=tty1 panic=10 consoleblank=0 loglevel=1 ubootpart=6dc22fe6-01 usb-storage.quirks=   cgroup_enable=cpuset cgroup_memory=1 cgroup_enable=memory swapaccount=1
[    0.001831] console [tty1] enabled
[    2.395963] ff180000.serial: ttyS0 at MMIO 0xff180000 (irq = 39, base_baud = 1500000) is a 16550A
[    2.396976] ff190000.serial: ttyS1 at MMIO 0xff190000 (irq = 40, base_baud = 1500000) is a 16550A
[    2.398003] ff690000.serial: ttyS2 at MMIO 0xff690000 (irq = 41, base_baud = 1500000) is a 16550A
[    2.398219] console [ttyS2] enabled
[    5.187164] usb 1-1.4: GSM modem (1-port) converter now attached to ttyUSB0
[    5.188446] usb 1-1.4: GSM modem (1-port) converter now attached to ttyUSB1
[    5.190296] usb 1-1.4: GSM modem (1-port) converter now attached to ttyUSB2
[    5.192186] usb 1-1.4: GSM modem (1-port) converter now attached to ttyUSB3
[    8.533335] ttyS2 - failed to request DMA
[   10.494551] usb 1-1.1: cp210x converter now attached to ttyUSB4
[   10.542230] usb 1-1.3: FTDI USB Serial Device converter now attached to ttyUSB5
[   17.112699] ttyS0 - failed to request DMA
Thanks
4 hours ago, SecureXperts said:
would need the GPIO 14 & 15 Serial Port at Physical Pin 8 and 10 referenced as /dev/serial0 or /dev/ttyAMA0
I don't own a TinkerBoard, but looking at kernel sources, the DT seems to have all UARTs already enabled.
But I presume that GPIO14/15 are not at /dev/serial0 or /dev/ttyAMA0, but maybe some thing like /dev/ttyS1 .
Account
Navigation
Search
Search
Chrome (Android)
  3. Adjust your preference.
Chrome (Desktop)
  2. Select Site settings.
