Skip to content
View in the app
Armbian Community Forums
Button connection via GPIO Header on Orange Pi 3
Featured Replies
I can’t get the result of a button click. The button is connected to the PD15  contact.
echo 9 > /sys/class/gpio/export   (gpio9?)
cat /sys/class/gpio/gpio9/value
every result: 0
Tell me what the problem is.
I also have https://github.com/orangepi-xunlong/WiringOP installed, which shows:
gpio -v
gpio version: 2.46
Copyright (c) 2012-2018 Gordon Henderson
This is free software with ABSOLUTELY NO WARRANTY.
For details type: gpio -warranty
   * Device tree is enabled.
   * -> OrangePi 3
gpio readall  (what Orange Pi RK3399?)
 +------+-----+----------+------+---+OrangePi RK3399---+---+------+---------+-----+--+
 | GPIO | wPi |   Name   | Mode | V | Physical | V | Mode | Name     | wPi | GPIO |
 |      |     |     3.3v |      |   |  1 || 2  |   |      | 5v       |     |      |
 |   43 |   0 |    SDA.0 | ALT4 | 0 |  3 || 4  |   |      | 5V       |     |      |
 |   44 |   1 |    SCL.0 |   IN | 0 |  5 || 6  |   |      | 0v       |     |      |
 |   64 |   2 |    GPIO4 |   IN | 1 |  7 || 8  | 0 | IN   | Tx       | 3   | 148  |
 |      |     |       0v |      |   |  9 || 10 | 0 | IN   | Rx       | 4   | 147  |
 |   80 |   5 |   GPIO17 |   IN | 1 | 11 || 12 | 1 | IN   | GPIO18   | 6   | 65   |
 |   81 |   7 |   GPIO27 |   IN | 0 | 13 || 14 |   |      | 0v       |     |      |
 |   82 |   8 |   GPIO22 | ALT2 | 1 | 15 || 16 | 0 | IN   | GPIO23   | 9   | 66   |
 |      |     |     3.3v |      |   | 17 || 18 | 1 | ALT2 | GPIO24   | 10  | 67   |
 |   39 |  11 |     MOSI | ALT3 | 0 | 19 || 20 |   |      | 0v       |     |      |
 |   40 |  12 |     MISO | ALT4 | 1 | 21 || 22 | 0 | IN   | GPIO25   | 13  | 83   |
 |   41 |  14 |     SCLK |   IN | 0 | 23 || 24 | 1 | OUT  | CS0      | 15  | 42   |
 |      |     |       0v |      |   | 25 || 26 | 0 | ALT4 | CS1      | 16  | 133  |
 |  154 |  17 |     DNP1 |   IN | 1 | 27 || 28 | 1 | OUT  | DNP2     | 18  | 50   |
 |   68 |  19 |    GPIO5 |   IN | 0 | 29 || 30 |   |      | 0v       |     |      |
 |   69 |  20 |    GPIO6 | ALT2 | 0 | 31 || 32 | 0 | IN   | GPIO12   | 21  | 76   |
 |   70 |  22 |   GPIO13 |  OUT | 1 | 33 || 34 |   |      | 0v       |     |      |
 |   71 |  23 |   GPIO19 | ALT2 | 0 | 35 || 36 | 0 | IN   | GPIO16   | 24  | 73   |
 |   72 |  25 |   GPIO26 |   IN | 1 | 37 || 38 | 1 | OUT  | GPIO20   | 26  | 74   |
 |      |     |       0v |      |   | 39 || 40 | 0 | ALT2 | GPIO21   | 27  | 75   |
 |      |     | (null) |      |   | 41 || 42 |   |      | (null) |     |      |
For any AllWinner SoC, gpio numbers are calculated as follow :
gpio_number = ('bank_letter' - 'A') * 32 + number
This means that PD15 is GPIO-111, so you should do :
echo 111 > /sys/class/gpio/export
echo in > /sys/class/gpio/gpio111/direction
cat /sys/class/gpio/gpio111/value
  • Author
Can you explain the variables from the formula? it’s not clear how to count.
I have done a wiringPi type set of utilities for various Orange Pi boards including the Orange Pi 3 (H6)..
I have a zip of the binaries on my website..
I got tired of trying to modify the various wiringOPs out there and the armbianIO package uses the sysfs interface which can cause many problems.  My package is all register based...   Just need to add the PWM.. and then a programmer's interface for the interrupts...  All done in C++ whhch is another reason I went away from the wiringOPs...
I could use some help with the Port numbers for the LEDs on the Pi 3 and the PC2.. I include them in my version of "readall"...
Can I post a link here to my binaries....  Once I have the sources cleaned up I will put them up on github..
Thanks all
Account
Navigation
Search
Search
Chrome (Android)
  3. Adjust your preference.
Chrome (Desktop)
  2. Select Site settings.
