Skip to content
View in the app
Armbian Community Forums
Will the NPi R1S on with the R1 image?
Featured Replies
On 11/11/2019 at 5:14 AM, guidol said:
Because the R1S doenst seem to use the AMPAK WiFi/Bluetooth as the NPi R1, but a Realtek module?
RTL single stream on the WiFi for the R1S - ASIX USB-1Gbe on one of the ports, so for routing it's going to have some challenges... USB 2.0 PHY on one of the ports, and the CPU is going to be busy doing all routing in SW.
(maybe the H3 variant might be a better match compared to H5 because of that USB2.0 PHY, but H5's gigabit is generally good for FriendlyARM boards)
I'm assuming that the H5 variant will be similar to NanoPi NEO2 for thermals and clocks
Good artists copy - great artists steal... Remarkable that the ID is similar to the GL-Inet Mango (and other small GL-Inet devices) - expected more from FriendlyARM there.
I just tried the R1 images on the R1S-H5 and it will not boot. Would it make any sense to try an H2 image like Neo or Core 2?
  • Author
I would try a NPi Neo2 or NPi Core2 (both H5) on your NPi R1S with H5 CPU.
The normal NPi Neo Image I only would try on the NPi R1S with H3 CPU,
because the normal NPi R1 has a H3 CPU
Thanks, I just went with the Nano Pi 2 Black image,  and it just works, dual ethernet and wifi.
Actually overnight it froze up, and it looks like it is overheating. I will put the official image for some time and see if it's a hardware problem.
  • Author
maybe you could set the cpu governor in
armbian-config =>> system =>> cpu to max of 1008000 Hz and conservative governor
and then take a look if it will overheat.
whats acutal the max cpu value?
I tried out the NanoPi Neo 2 image, the cpu still appears hot (59c), although it doesn't look like it's going out of control. The maximum cpu speed option I see there is 816.
Screenshot from 2019-11-29 13:30:30.png
Screenshot from 2019-11-29 12:50:20.png
After reviewing the schematics.... I stand corrected...
eth0 - realtek RTL8211E which is tied to the H3/H5 gigabit designware MAC onboard the SoC
eth1 - realtek RTL8253B USB3.0 to 1Gbe, will be limited by USB2 obviously, but a better choice perhaps than the Asix chip for some packet offloading
Oddly enough, WiFi is hanging off the SDIO bus, schematic calls out the Ampak AP6212 SOM, which is a broadcom/cypress WiFi 802.11n/BT 4.2 (which is connected to UART3) which would have made this board much more interesting for IoT things. Would be interesting to see things there, as @martinayotte points out, it looks like a generic RTL8723 - and there, some have BT, and some do not... what's odd with R1S, there's an IPX-I connection on the module, but I'm not seeing an antenna here - patch antenna inside the housing?
Would be nice with the SPINOR on-board, as 16MB flash there can do both u-Boot and host OpenWRT on that flash part, and then secondary boot to SDIO for Amrbian...
Anyways - the R1 seems to be the better solution, more balanced across interfaces, and includes the option for the eMMC. even though it's only H3 - I might order one, as it does pique my interest to get an ARM variant of the code I'm currently doing on AR9331 (MIPS) - but since I have a Neo and Neo2 already, I can pretty much fake it there, just not as tidy of a box.
For R1S - only reason why one might consider the H5 variant would be OpenVPN, as there, the H5 is going to perform better than H3, but for general routing purposes, H3 might be a better choice as it'll clock higher than H5, and since routing it all about clocks without a dedicated switch on the board... after all, H3/H5 are application driven, compared to chips like Marvell MV3720, or others like this, which are purpose built for communications/networking.
Edited by sfx2000
edit for SPINOR
I tried to boot R1S-H5 with:
Buster minimal kernel 5.4 boots sucessfully
Buster server kernel 5.3 did not boot (I had no time to monitor the UART output yet)
So the output is from "Buster minimal kernel 5.4"
uname -r:
5.4.2-sunxi64
here output of dmesg -t :
Memory: 351456K/524288K available (10878K kernel code, 726K rwdata, 2804K rodata, 768K init, 288K bss, 41760K reserved, 131072K cma-reserved)
SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
rcu: Hierarchical RCU implementation.
rcu:    RCU restricting CPUs from NR_CPUS=8 to nr_cpu_ids=4.
rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
GIC: Using split EOI/Deactivate mode
random: get_random_bytes called from start_kernel+0x2a8/0x430 with crng_init=0
arch_timer: cp15 timer(s) running at 24.00MHz (phys).
clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns
sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
Console: colour dummy device 80x25
Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=96000)
pid_max: default: 32768 minimum: 301
LSM: Security Framework initializing
Mount-cache hash table entries: 1024 (order: 1, 8192 bytes, linear)
Mountpoint-cache hash table entries: 1024 (order: 1, 8192 bytes, linear)
*** VALIDATE tmpfs ***
*** VALIDATE proc ***
*** VALIDATE cgroup1 ***
*** VALIDATE cgroup2 ***
ASID allocator initialised with 32768 entries
rcu: Hierarchical SRCU implementation.
smp: Bringing up secondary CPUs ...
Detected VIPT I-cache on CPU1
CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
Detected VIPT I-cache on CPU2
CPU2: Booted secondary processor 0x0000000002 [0x410fd034]
Detected VIPT I-cache on CPU3
CPU3: Booted secondary processor 0x0000000003 [0x410fd034]
smp: Brought up 1 node, 4 CPUs
SMP: Total of 4 processors activated.
CPU features: detected: 32-bit EL0 Support
CPU features: detected: CRC32 instructions
CPU: All CPU(s) started at EL2
alternatives: patching kernel code
devtmpfs: initialized
Registered cp15_barrier emulation handler
Registered setend emulation handler
clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
xor: measuring software checksum speed
   8regs     :  1615.000 MB/sec
   32regs    :  1853.000 MB/sec
   arm64_neon:  1674.000 MB/sec
xor: using function: 32regs (1853.000 MB/sec)
pinctrl core: initialized pinctrl subsystem
NET: Registered protocol family 16
DMA: preallocated 256 KiB pool for atomic allocations
audit: initializing netlink subsys (disabled)
audit: type=2000 audit(0.136:1): state=initialized audit_enabled=0 res=1
cpuidle: using governor menu
hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
Serial: AMBA PL011 UART driver
HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages
HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages
cryptd: max_cpu_qlen set to 1000
raid6: neonx8   gen()  1062 MB/s
raid6: neonx8   xor()   999 MB/s
raid6: neonx4   gen()  1013 MB/s
raid6: neonx4   xor()   976 MB/s
raid6: neonx2   gen()   773 MB/s
raid6: neonx2   xor()   809 MB/s
raid6: neonx1   gen()   516 MB/s
raid6: neonx1   xor()   611 MB/s
raid6: int64x8  gen()   791 MB/s
raid6: int64x8  xor()   518 MB/s
raid6: int64x4  gen()   668 MB/s
raid6: int64x4  xor()   503 MB/s
raid6: int64x2  gen()   461 MB/s
raid6: int64x2  xor()   410 MB/s
raid6: int64x1  gen()   302 MB/s
raid6: int64x1  xor()   312 MB/s
raid6: using algorithm neonx8 gen() 1062 MB/s
raid6: .... xor() 999 MB/s, rmw enabled
raid6: using neon recovery algorithm
iommu: Default domain type: Translated
SCSI subsystem initialized
usbcore: registered new interface driver usbfs
usbcore: registered new interface driver hub
usbcore: registered new device driver usb
pps_core: LinuxPPS API ver. 1 registered
pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
PTP clock support registered
clocksource: Switched to clocksource arch_sys_counter
VFS: Disk quotas dquot_6.6.0
VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
*** VALIDATE ramfs ***
*** VALIDATE hugetlbfs ***
thermal_sys: Registered thermal governor 'fair_share'
thermal_sys: Registered thermal governor 'bang_bang'
thermal_sys: Registered thermal governor 'step_wise'
thermal_sys: Registered thermal governor 'user_space'
thermal_sys: Registered thermal governor 'power_allocator'
NET: Registered protocol family 2
tcp_listen_portaddr_hash hash table entries: 256 (order: 0, 4096 bytes, linear)
TCP established hash table entries: 4096 (order: 3, 32768 bytes, linear)
TCP bind hash table entries: 4096 (order: 4, 65536 bytes, linear)
TCP: Hash tables configured (established 4096 bind 4096)
UDP hash table entries: 256 (order: 1, 8192 bytes, linear)
UDP-Lite hash table entries: 256 (order: 1, 8192 bytes, linear)
RPC: Registered named UNIX socket transport module.
RPC: Registered udp transport module.
RPC: Registered tcp transport module.
RPC: Registered tcp NFSv4.1 backchannel transport module.
Trying to unpack rootfs image as initramfs...
Freeing initrd memory: 7464K
Initialise system trusted keyrings
workingset: timestamp_bits=44 max_order=17 bucket_order=0
zbud: loaded
squashfs: version 4.0 (2009/01/31) Phillip Lougher
NFS: Registering the id_resolver key type
Key type id_resolver registered
Key type id_legacy registered
nfs4filelayout_init: NFSv4 File Layout Driver Registering...
Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
9p: Installing v9fs 9p2000 file system support
async_tx: api initialized (async)
Key type asymmetric registered
Asymmetric key parser 'x509' registered
Block layer SCSI generic (bsg) driver version 0.4 loaded (major 248)
io scheduler mq-deadline registered
io scheduler kyber registered
io scheduler bfq registered
sun8i-h3-r-pinctrl 1f02c00.pinctrl: initialized sunXi PIO driver
sun50i-h5-pinctrl 1c20800.pinctrl: initialized sunXi PIO driver
Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
sun50i-h5-pinctrl 1c20800.pinctrl: 1c20800.pinctrl supply vcc-pa not found, using dummy regulator
printk: console [ttyS0] disabled
1c28000.serial: ttyS0 at MMIO 0x1c28000 (irq = 29, base_baud = 1500000) is a U6_16550A
printk: console [ttyS0] enabled
cacheinfo: Unable to detect cache hierarchy for CPU 0
loop: module loaded
libphy: Fixed MDIO Bus: probed
ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
ehci-platform: EHCI generic platform driver
ehci-platform 1c1a000.usb: EHCI Host Controller
ehci-platform 1c1a000.usb: new USB bus registered, assigned bus number 1
ehci-platform 1c1a000.usb: irq 12, io mem 0x01c1a000
ehci-platform 1c1a000.usb: USB 2.0 started, EHCI 1.00
usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.04
usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
usb usb1: Product: EHCI Host Controller
usb usb1: Manufacturer: Linux 5.4.2-sunxi64 ehci_hcd
usb usb1: SerialNumber: 1c1a000.usb
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 1 port detected
ehci-platform 1c1b000.usb: EHCI Host Controller
ehci-platform 1c1b000.usb: new USB bus registered, assigned bus number 2
ehci-platform 1c1b000.usb: irq 14, io mem 0x01c1b000
ehci-platform 1c1b000.usb: USB 2.0 started, EHCI 1.00
usb usb2: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.04
usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
usb usb2: Product: EHCI Host Controller
usb usb2: Manufacturer: Linux 5.4.2-sunxi64 ehci_hcd
usb usb2: SerialNumber: 1c1b000.usb
hub 2-0:1.0: USB hub found
hub 2-0:1.0: 1 port detected
ehci-platform 1c1c000.usb: EHCI Host Controller
ehci-platform 1c1c000.usb: new USB bus registered, assigned bus number 3
ehci-platform 1c1c000.usb: irq 16, io mem 0x01c1c000
ehci-platform 1c1c000.usb: USB 2.0 started, EHCI 1.00
usb usb3: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.04
usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
usb usb3: Product: EHCI Host Controller
usb usb3: Manufacturer: Linux 5.4.2-sunxi64 ehci_hcd
usb usb3: SerialNumber: 1c1c000.usb
hub 3-0:1.0: USB hub found
hub 3-0:1.0: 1 port detected
ehci-platform 1c1d000.usb: EHCI Host Controller
ehci-platform 1c1d000.usb: new USB bus registered, assigned bus number 4
ehci-platform 1c1d000.usb: irq 18, io mem 0x01c1d000
ehci-platform 1c1d000.usb: USB 2.0 started, EHCI 1.00
usb usb4: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.04
usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
usb usb4: Product: EHCI Host Controller
usb usb4: Manufacturer: Linux 5.4.2-sunxi64 ehci_hcd
usb usb4: SerialNumber: 1c1d000.usb
hub 4-0:1.0: USB hub found
hub 4-0:1.0: 1 port detected
ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
ohci-platform: OHCI generic platform driver
ohci-platform 1c1a400.usb: Generic Platform OHCI controller
ohci-platform 1c1a400.usb: new USB bus registered, assigned bus number 5
ohci-platform 1c1a400.usb: irq 13, io mem 0x01c1a400
usb usb5: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 5.04
usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
usb usb5: Product: Generic Platform OHCI controller
usb usb5: Manufacturer: Linux 5.4.2-sunxi64 ohci_hcd
usb usb5: SerialNumber: 1c1a400.usb
hub 5-0:1.0: USB hub found
hub 5-0:1.0: 1 port detected
ohci-platform 1c1b400.usb: Generic Platform OHCI controller
ohci-platform 1c1b400.usb: new USB bus registered, assigned bus number 6
ohci-platform 1c1b400.usb: irq 15, io mem 0x01c1b400
usb usb6: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 5.04
usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1
usb usb6: Product: Generic Platform OHCI controller
usb usb6: Manufacturer: Linux 5.4.2-sunxi64 ohci_hcd
usb usb6: SerialNumber: 1c1b400.usb
hub 6-0:1.0: USB hub found
hub 6-0:1.0: 1 port detected
ohci-platform 1c1c400.usb: Generic Platform OHCI controller
ohci-platform 1c1c400.usb: new USB bus registered, assigned bus number 7
ohci-platform 1c1c400.usb: irq 17, io mem 0x01c1c400
usb usb7: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 5.04
usb usb7: New USB device strings: Mfr=3, Product=2, SerialNumber=1
usb usb7: Product: Generic Platform OHCI controller
usb usb7: Manufacturer: Linux 5.4.2-sunxi64 ohci_hcd
usb usb7: SerialNumber: 1c1c400.usb
hub 7-0:1.0: USB hub found
hub 7-0:1.0: 1 port detected
ohci-platform 1c1d400.usb: Generic Platform OHCI controller
ohci-platform 1c1d400.usb: new USB bus registered, assigned bus number 8
ohci-platform 1c1d400.usb: irq 19, io mem 0x01c1d400
usb usb8: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 5.04
usb usb8: New USB device strings: Mfr=3, Product=2, SerialNumber=1
usb usb8: Product: Generic Platform OHCI controller
usb usb8: Manufacturer: Linux 5.4.2-sunxi64 ohci_hcd
usb usb8: SerialNumber: 1c1d400.usb
hub 8-0:1.0: USB hub found
hub 8-0:1.0: 1 port detected
usbcore: registered new interface driver usb-storage
usb_phy_generic usb_phy_generic.0.auto: usb_phy_generic.0.auto supply vcc not found, using dummy regulator
musb-hdrc musb-hdrc.1.auto: MUSB HDRC host driver
musb-hdrc musb-hdrc.1.auto: new USB bus registered, assigned bus number 9
usb usb9: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.04
usb usb9: New USB device strings: Mfr=3, Product=2, SerialNumber=1
usb usb9: Product: MUSB HDRC host driver
usb usb9: Manufacturer: Linux 5.4.2-sunxi64 musb-hcd
usb usb9: SerialNumber: musb-hdrc.1.auto
hub 9-0:1.0: USB hub found
hub 9-0:1.0: 1 port detected
mousedev: PS/2 mouse device common for all mice
sun6i-rtc 1f00000.rtc: registered as rtc0
sun6i-rtc 1f00000.rtc: RTC enabled
i2c /dev entries driver
sunxi-wdt 1c20ca0.watchdog: Watchdog enabled (timeout=16 sec, nowayout=0)
sun8i-h3-r-pinctrl 1f02c00.pinctrl: 1f02c00.pinctrl supply vcc-pl not found, using dummy regulator
sdhci: Secure Digital Host Controller Interface driver
sdhci: Copyright(c) Pierre Ossman
Synopsys Designware Multimedia Card Interface Driver
sun50i-h5-pinctrl 1c20800.pinctrl: 1c20800.pinctrl supply vcc-pf not found, using dummy regulator
sunxi-mmc 1c0f000.mmc: Got CD GPIO
sunxi-mmc 1c0f000.mmc: initialized, max. request size: 16384 KB, uses new timings mode
sun50i-h5-pinctrl 1c20800.pinctrl: 1c20800.pinctrl supply vcc-pg not found, using dummy regulator
sunxi-mmc 1c10000.mmc: allocated mmc-pwrseq
usb 2-1: new high-speed USB device number 2 using ehci-platform
mmc0: host does not support reading read-only switch, assuming write-enable
mmc0: new high speed SDHC card at address b368
mmcblk0: mmc0:b368       14.9 GiB
 mmcblk0: p1
usb 2-1: New USB device found, idVendor=0bda, idProduct=8153, bcdDevice=31.00
usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=6
usb 2-1: Product: USB 10/100/1000 LAN
usb 2-1: Manufacturer: Realtek
usb 2-1: SerialNumber: 000000000000
sunxi-mmc 1c10000.mmc: initialized, max. request size: 16384 KB, uses new timings mode
sun50i-h5-pinctrl 1c20800.pinctrl: 1c20800.pinctrl supply vcc-pc not found, using dummy regulator
sunxi-mmc 1c11000.mmc: initialized, max. request size: 2048 KB
sdhci-pltfm: SDHCI platform and OF driver helper
ledtrig-cpu: registered to indicate activity on CPUs
hidraw: raw HID events driver (C) Jiri Kosina
usbcore: registered new interface driver usbhid
usbhid: USB HID core driver
mmc1: new high speed SDIO card at address 0001
sunxi-mmc 1c11000.mmc: no support for card's volts
mmc2: error -22 whilst initialising SDIO card
NET: Registered protocol family 10
Segment Routing with IPv6
NET: Registered protocol family 17
8021q: 802.1Q VLAN Support v1.8
9pnet: Installing 9P2000 support
Key type dns_resolver registered
registered taskstats version 1
Loading compiled-in X.509 certificates
zswap: loaded using pool lzo/zbud
Key type ._fscrypt registered
Key type .fscrypt registered
Btrfs loaded, crc32c=crc32c-generic
Key type encrypted registered
sun50i-h5-pinctrl 1c20800.pinctrl: 1c20800.pinctrl supply vcc-pd not found, using dummy regulator
sun6i-rtc 1f00000.rtc: setting system clock to 2019-12-22T07:01:38 UTC (1576998098)
of_cfs_init
of_cfs_init: OK
Freeing unused kernel memory: 768K
Run /init as init process
dwmac-sun8i 1c30000.ethernet: IRQ eth_wake_irq not found
dwmac-sun8i 1c30000.ethernet: IRQ eth_lpi not found
dwmac-sun8i 1c30000.ethernet: PTP uses main clock
dwmac-sun8i 1c30000.ethernet: 1c30000.ethernet supply phy-io not found, using dummy regulator
dwmac-sun8i 1c30000.ethernet: No HW DMA feature register supported
dwmac-sun8i 1c30000.ethernet: RX Checksum Offload Engine supported
dwmac-sun8i 1c30000.ethernet: COE Type 2
dwmac-sun8i 1c30000.ethernet: TX Checksum insertion supported
dwmac-sun8i 1c30000.ethernet: Normal descriptors
dwmac-sun8i 1c30000.ethernet: Chain mode enabled
libphy: stmmac: probed
dwmac-sun8i 1c30000.ethernet: Found internal PHY node
libphy: mdio_mux: probed
dwmac-sun8i 1c30000.ethernet: Switch mux to internal PHY
dwmac-sun8i 1c30000.ethernet: Powering internal PHY
dwmac-sun8i 1c30000.ethernet: Switch mux to external PHY
random: fast init done
EXT4-fs (mmcblk0p1): mounted filesystem with writeback data mode. Opts: (null)
systemd[1]: systemd 241 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
systemd[1]: Detected architecture arm64.
systemd[1]: Set hostname to <nanopineo2black>.
systemd[1]: Failed to bump fs.file-max, ignoring: Invalid argument
systemd[1]: File /lib/systemd/system/systemd-journald.service:12 configures an IP firewall (IPAddressDeny=any), but the local system does not support BPF/cgroup based firewalling.
systemd[1]: Proceeding WITHOUT firewalling in effect! (This warning is only shown for the first loaded unit using IP firewalling.)
random: systemd: uninitialized urandom read (16 bytes read)
systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
systemd[1]: Listening on udev Kernel Socket.
systemd[1]: Listening on fsck to fsckd communication Socket.
systemd[1]: Reached target Remote File Systems.
EXT4-fs (mmcblk0p1): re-mounted. Opts: commit=600,errors=remount-ro
systemd-journald[401]: Received request to flush runtime journal from PID 1
zram: Added device: zram0
zram: Added device: zram1
zram: Added device: zram2
zram1: detected capacity change from 0 to 251269120
usbcore: registered new interface driver r8152
lima 1e80000.gpu: IRQ ppmmu4 not found
lima 1e80000.gpu: IRQ ppmmu5 not found
lima 1e80000.gpu: IRQ ppmmu6 not found
lima 1e80000.gpu: IRQ ppmmu7 not found
lima 1e80000.gpu: gp - mali450 version major 0 minor 0
lima 1e80000.gpu: pp0 - mali450 version major 0 minor 0
lima 1e80000.gpu: pp1 - mali450 version major 0 minor 0
lima 1e80000.gpu: pp2 - mali450 version major 0 minor 0
lima 1e80000.gpu: pp3 - mali450 version major 0 minor 0
lima 1e80000.gpu: IRQ pp4 not found
lima 1e80000.gpu: IRQ pp5 not found
lima 1e80000.gpu: IRQ pp6 not found
lima 1e80000.gpu: IRQ pp7 not found
lima 1e80000.gpu: l2 cache 8K, 4-way, 64byte cache line, 128bit external bus
lima 1e80000.gpu: l2 cache 128K, 4-way, 64byte cache line, 128bit external bus
lima 1e80000.gpu: bus rate = 200000000
lima 1e80000.gpu: mod rate = 384000000
[drm] Initialized lima 1.0.0 20190217 for 1e80000.gpu on minor 0
usbcore: registered new interface driver cdc_ether
cfg80211: Loading compiled-in X.509 certificates for regulatory database
cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
usb 2-1: reset high-speed USB device number 2 using ehci-platform
platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
cfg80211: failed to load regulatory.db
sun4i-codec 1c22c00.codec: Failed to register our card
debugfs: Directory '1c22c00.codec' with parent 'H3 Audio Codec' already present!
sun4i-codec 1c22c00.codec: Codec <-> 1c22c00.codec mapping ok
r8152 2-1:1.0 (unnamed net_device) (uninitialized): Invalid ether addr 00:00:00:00:00:00
r8152 2-1:1.0 (unnamed net_device) (uninitialized): Random ether addr 46:57:86:4f:22:0a
r8152 2-1:1.0 eth1: v1.10.10
bFWReady == _FALSE call reset 8051...
Adding 245376k swap on /dev/zram1.  Priority:5 extents:1 across:245376k SSFS
zram0: detected capacity change from 0 to 52428800
EXT4-fs (zram0): mounted filesystem without journal. Opts: discard
ext4 filesystem being mounted at /var/log supports timestamps until 2038 (0x7fffffff)
random: crng init done
random: 7 urandom warning(s) missed due to ratelimiting
dwmac-sun8i 1c30000.ethernet eth0: PHY [0.2:07] driver [RTL8211E Gigabit Ethernet]
dwmac-sun8i 1c30000.ethernet eth0: No Safety Features support found
dwmac-sun8i 1c30000.ethernet eth0: No MAC Management Counters available
dwmac-sun8i 1c30000.ethernet eth0: PTP not supported by HW
dwmac-sun8i 1c30000.ethernet eth0: configuring for phy/rgmii link mode
==> rtl8188e_iol_efuse_patch
dwmac-sun8i 1c30000.ethernet eth0: Link is Up - 1Gbps/Full - flow control rx/tx
IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
lsusb:
Bus 008 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 007 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 002 Device 002: ID 0bda:8153 Realtek Semiconductor Corp. RTL8153 Gigabit Ethernet Adapter
Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 005 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 009 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
lsusb -v -d 0bda:
Device Descriptor:
  bLength                18
  bDescriptorType         1
  bcdUSB               2.10
  bDeviceClass            0
  bDeviceSubClass         0
  bDeviceProtocol         0
  bMaxPacketSize0        64
  idVendor           0x0bda Realtek Semiconductor Corp.
  idProduct          0x8153 RTL8153 Gigabit Ethernet Adapter
  bcdDevice           31.00
  iManufacturer           1 Realtek
  iProduct                2 USB 10/100/1000 LAN
  iSerial                 6 000000000000
  bNumConfigurations      2
  Configuration Descriptor:
    bLength                 9
    bDescriptorType         2
    wTotalLength       0x0027
    bNumInterfaces          1
    bConfigurationValue     1
    iConfiguration          0
    bmAttributes         0xa0
      (Bus Powered)
      Remote Wakeup
    MaxPower              350mA
    Interface Descriptor:
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        0
      bAlternateSetting       0
      bNumEndpoints           3
      bInterfaceClass       255 Vendor Specific Class
      bInterfaceSubClass    255 Vendor Specific Subclass
      bInterfaceProtocol      0
      iInterface              0
      Endpoint Descriptor:
        bLength                 7
        bDescriptorType         5
        bEndpointAddress     0x81  EP 1 IN
        bmAttributes            2
          Transfer Type            Bulk
          Synch Type               None
          Usage Type               Data
        wMaxPacketSize     0x0200  1x 512 bytes
        bInterval               0
        bLength                 7
        bDescriptorType         5
        bEndpointAddress     0x02  EP 2 OUT
        bmAttributes            2
          Transfer Type            Bulk
          Synch Type               None
          Usage Type               Data
        bInterval               0
        bLength                 7
        bDescriptorType         5
        bEndpointAddress     0x83  EP 3 IN
        bmAttributes            3
          Transfer Type            Interrupt
          Synch Type               None
          Usage Type               Data
        wMaxPacketSize     0x0002  1x 2 bytes
        bInterval               8
    bLength                 9
    bDescriptorType         2
    wTotalLength       0x0050
    bNumInterfaces          2
    bConfigurationValue     2
    iConfiguration          0
    bmAttributes         0xa0
      (Bus Powered)
      Remote Wakeup
    MaxPower              350mA
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        0
      bAlternateSetting       0
      bNumEndpoints           1
      bInterfaceClass         2 Communications
      bInterfaceSubClass      6 Ethernet Networking
      iInterface              5 CDC Communications Control
      CDC Header:
        bcdCDC               1.10
      CDC Union:
        bMasterInterface        0
        bSlaveInterface         1
      CDC Ethernet:
        iMacAddress                      3 000000000000
        bmEthernetStatistics    0x00000000
        wMaxSegmentSize               1514
        wNumberMCFilters            0x0000
        bNumberPowerFilters              0
        bLength                 7
        bDescriptorType         5
        bmAttributes            3
          Synch Type               None
          Usage Type               Data
        wMaxPacketSize     0x0010  1x 16 bytes
        bInterval               8
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        1
      bAlternateSetting       0
      bNumEndpoints           0
      bInterfaceClass        10 CDC Data
      bInterfaceSubClass      0
      iInterface              0
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        1
      bAlternateSetting       1
      bNumEndpoints           2
      iInterface              4 Ethernet Data
        bLength                 7
        bDescriptorType         5
        bmAttributes            2
          Transfer Type            Bulk
          Synch Type               None
          Usage Type               Data
        bInterval               0
        bLength                 7
        bDescriptorType         5
        bmAttributes            2
          Transfer Type            Bulk
          Synch Type               None
          Usage Type               Data
        bInterval               0
Binary Object Store Descriptor:
  bLength                 5
  bDescriptorType        15
  wTotalLength       0x0016
  bNumDeviceCaps          2
  USB 2.0 Extension Device Capability:
    bLength                 7
    bDescriptorType        16
    bDevCapabilityType      2
    bmAttributes   0x00000006
      BESL Link Power Management (LPM) Supported
  SuperSpeed USB Device Capability:
    bLength                10
    bDescriptorType        16
    bDevCapabilityType      3
    bmAttributes         0x02
      Latency Tolerance Messages (LTM) Supported
    wSpeedsSupported   0x000e
      Device can operate at Full Speed (12Mbps)
      Device can operate at High Speed (480Mbps)
      Device can operate at SuperSpeed (5Gbps)
    bFunctionalitySupport   2
      Lowest fully-functional device speed is High Speed (480Mbps)
    bU1DevExitLat          10 micro seconds
    bU2DevExitLat        2047 micro seconds
can't get debug descriptor: Resource temporarily unavailable
Device Status:     0x0000
  (Bus Powered)
If anyone needs more information, please let me know
Robert
I loaded the FriendlyWRT image on NanoPI R1S-H5. It works except the radio.0 interface says "Device is not active". Has anybody succeeded in activation the WiFi interface?
Thanks,
Laszlo
2 hours ago, No Name said:
Do you plan to add the nanopi R1S-H5 device in the list in a near future ?
Regards
Definitely not in near future and not sure even after. Allwinner stopped producing the H5 SoC so boards having them will become extinct in a while anyways...
However if a community contribution brings the board up it will be added as community supported (CSC).
Account
Navigation
Search
Search
Chrome (Android)
  3. Adjust your preference.
Chrome (Desktop)
  2. Select Site settings.
