Skip to content
View in the app
Armbian Community Forums
GEMBIRD Webcam Orange Pi One
Featured Replies
Hi guys. I've just spent yet another two hours trying to find an answer to my webcam problem and there does not seem to be an answer from what I can discern.
Still working to try to get a camera to work with Octopi from what I have around.  Strange thing I discovered that the USB OTG port on the Opi One does not seem to work, but when plugged into my single regular USB, I get this for the camera:
pi@citrico-opione:~/ffmpeg_cedrus264_H3$ lsusb
Bus 004 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 003 Device 002: ID 1908:2310 GEMBIRD
Bus 002 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 005 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
It is one of the known working with mjpeg-streamer
https://community.octoprint.org/t/usb-webcams-known-to-work-with-mjpg-streamer/21149
but the notes don't seem to be current.
pi@citrico-opione:~/ffmpeg_cedrus264_H3$ ls /dev/video*
/dev/video0  /dev/video1  /dev/video2
I have tried some of the old gits out there. My only ray of hope was when I did
modprobe hid-gembird
it did not error, just seemed to say ok.
But still no webcam, just a different message, of/dev/video0: Device or resource busy
instead of it not being a video capture device.
So I"m out of ideas. Any help would be appreciated. Trying to find an inexpensive webcam solution for octopi using my Opi Ones.
  • Author
A few more details:
pi@citrico-opione:~/ffmpeg_cedrus264_H3$ v4l2-ctl --list-devices
cedrus (platform:cedrus):
    /dev/video2
USB2.0 PC CAMERA: USB2.0 PC CAM (usb-1c1b000.usb-1):
    /dev/video0
    /dev/video1
pi@citrico-opione:~/ffmpeg_cedrus264_H3$ cd
pi@citrico-opione:~$ v4l2-ctl --list-devices
    /dev/
pi@citrico-opione:~$ v4l2-ctl -d /dev/video2 --list-formats --list-ctrls
Codec Controls
        mpeg_2_slice_parameters 0x009909fa (unknown): type=103 flags=has-payload
   mpeg_2_quantization_matrices 0x009909fb (unknown): type=104 flags=has-payload
    h264_sequence_parameter_set 0x00990ce8 (unknown): type=110 flags=has-payload
     h264_picture_parameter_set 0x00990ce9 (unknown): type=111 flags=has-payload
            h264_scaling_matrix 0x00990cea (unknown): type=112 flags=has-payload
          h264_slice_parameters 0x00990ceb (unknown): type=113 flags=has-payload
         h264_decode_parameters 0x00990cec (unknown): type=114 flags=has-payload
               h264_decode_mode 0x00990ced (menu)   : min=0 max=0 default=0 value=0
                h264_start_code 0x00990cee (menu)   : min=0 max=0 default=0 value=0
    hevc_sequence_parameter_set 0x00990cf0 (unknown): type=120 flags=has-payload
     hevc_picture_parameter_set 0x00990cf1 (unknown): type=121 flags=has-payload
          hevc_slice_parameters 0x00990cf2 (unknown): type=122 flags=has-payload
            hevc_scaling_matrix 0x00990cf3 (unknown): type=123 flags=has-payload
               hevc_decode_mode 0x00990cf7 (menu)   : min=0 max=0 default=0 value=0
                hevc_start_code 0x00990cf8 (menu)   : min=0 max=0 default=0 value=0
ioctl: VIDIOC_ENUM_FMT
    Type: Video Capture
    [0]: 'ST12' (Sunxi Tiled NV12 Format, compressed)
    [1]: 'NV12' (Y/CbCr 4:2:0)
    /dev/video0
    /dev/video1
I'm still working on it.  These commands I got from @ldiaz working on my rpi cameras that didn't work. It seems like the gembird is a common camera though, and it seems like it should be working, but so far it isn't.
  • Author
And get this. The snapshot works in octoprint, which is listed as this:
http://127.0.0.1:8080/?action=snapshot
That was after I switched the ffmpeg path to:
/home/pi/ffmpeg_cedrus264_H3/ffmpeg
  • Author
For those who may be finding this thread later, I made some interesting progress today. The Orange Pi One has only one regular USB port, which, using OctoPi, you need for the printer.  But it does have also a USB OTG, which you may call Micro USB, and I have never used it for anything.  Initially I plugged in the camera to that with an adapter, and got nothing on lsusb at all.
After some digging, I found the way to cure this.  You have to edit the dtb file in the /boot/ dtb/ directory for your board. All the supported boards are in there.
Then you have to convert that binary dtb file into text, with a program called dtc.
pi@citrico-opione:/boot/dtb$ sudo dtc -I dtb /boot/dtb/sun8i-h3-orangepi-one.dtb -O dts -o /boot/dtb/sun8i-h3-orangepi-one.dts
that gives you the dts file, which you can open in nano.
pi@citrico-opione:/boot/dtb$ sudo nano sun8i-h3-orangepi-one.dts
Find the code block that has dr_mode in it. On this board it is usb@1c19000.  Change the value to host instead of otb.
Then control x, y, enter to save the file.
Then you have to convert it back to binary.  You can make a backup of your original binary file first if you want, then do this:
pi@citrico-opione:/boot/dtb$ sudo dtc -I dts /boot/dtb/sun8i-h3-orangepi-one.dts -O dtb -o /boot/dtb/sun8i-h3-orangepi-one.dtb
then reboot.  The micro usb is now a regular usb, and my gembird camera came up under lsusb.   I also had enabled usb0 in the hardware options in armbian-config, but I don't know if I had to do that. I actually just enabled them all before finding this solution.
Still stuck on the video though. Snapshots are working.
  • Author
I have made the change on several of these Orange Pi Ones now, and you don't have to do anything in armbian-config. Just that one field in the dtb file is it.
Overlays are pieces of device tree configurations that can be activated and deactivated dynamically. Using overlays you do not need to recomplile the dts for your board every time.  In armbian is quite simple to activate them simply add /boot/armbianEnv.txt
overlay = usbhost0 ...<other overlays>
and reboot.
Account
Navigation
Search
Search
Chrome (Android)
  3. Adjust your preference.
Chrome (Desktop)
  2. Select Site settings.
