Skip to content
View in the app
Armbian Community Forums
orange pi pc and 1wire ds18b20 don't find
Featured Replies
Hi all,
I trying many days set up temperature sensor work, but no luck (
Orange PI PC Armbian 20.11.3 Focal with Linux 5.9.14-sunxi
try many pins, 3 and 5 V , but same result, no sensor read. No any resistor, 1 sensor
armbianenv:
overlays=w1-gpio usbhost0
param_w1_pin=PD14
param_w1_pin_int_pullup=1
output:
root@orangepipc:~# gpio readall
 +------+-----+----------+------+---+OrangePiH3+---+------+----------+-----+------+
 | GPIO | wPi |   Name   | Mode | V | Physical | V | Mode | Name     | wPi | GPIO |
 |      |     |     3.3V |      |   |  1 || 2  |   |      | 5V       |     |      |
 |   12 |   0 |    SDA.0 |  OFF | 0 |  3 || 4  |   |      | 5V       |     |      |
 |   11 |   1 |    SCL.0 |  OFF | 0 |  5 || 6  |   |      | GND      |     |      |
 |    6 |   2 |      PA6 |  OFF | 0 |  7 || 8  | 0 | OFF  | TXD.3    | 3   | 13   |
 |      |     |      GND |      |   |  9 || 10 | 0 | OFF  | RXD.3    | 4   | 14   |
 |    1 |   5 |    RXD.2 |  OFF | 0 | 11 || 12 | 1 | IN   | PD14     | 6   | 110  |
 |    0 |   7 |    TXD.2 |  OFF | 0 | 13 || 14 |   |      | GND      |     |      |
 |    3 |   8 |    CTS.2 |  OFF | 0 | 15 || 16 | 0 | OFF  | PC04     | 9   | 68   |
 |      |     |     3.3V |      |   | 17 || 18 | 0 | OFF  | PC07     | 10  | 71   |
 |   64 |  11 |   MOSI.0 |  OFF | 0 | 19 || 20 |   |      | GND      |     |      |
 |   65 |  12 |   MISO.0 |  OFF | 0 | 21 || 22 | 0 | OFF  | RTS.2    | 13  | 2    |
 |   66 |  14 |   SCLK.0 |  OFF | 0 | 23 || 24 | 0 | OFF  | CE.0     | 15  | 67   |
 |      |     |      GND |      |   | 25 || 26 | 0 | OFF  | PA21     | 16  | 21   |
 |   19 |  17 |    SDA.1 |  OFF | 0 | 27 || 28 | 0 | OFF  | SCL.1    | 18  | 18   |
 |    7 |  19 |     PA07 |  OFF | 0 | 29 || 30 |   |      | GND      |     |      |
 |    8 |  20 |     PA08 |  OFF | 0 | 31 || 32 | 0 | OFF  | RTS.1    | 21  | 200  |
 |    9 |  22 |     PA09 |  OFF | 0 | 33 || 34 |   |      | GND      |     |      |
 |   10 |  23 |     PA10 |  OFF | 0 | 35 || 36 | 0 | OFF  | CTS.1    | 24  | 201  |
 |   20 |  25 |     PA20 |  OFF | 0 | 37 || 38 | 0 | OFF  | TXD.1    | 26  | 198  |
 |      |     |      GND |      |   | 39 || 40 | 0 | OFF  | RXD.1    | 27  | 199  |
root@orangepipc:~# cat /sys/kernel/debug/gpio
gpiochip0: GPIOs 0-223, parent: platform/1c20800.pinctrl, 1c20800.pinctrl:
 gpio-15  (                    |orangepi:red:status ) out lo
 gpio-110 (                    |onewire@0           ) out hi
 gpio-166 (                    |cd                  ) in  lo ACTIVE LOW
 gpio-204 (                    |usb0_id_det         ) in  hi IRQ
gpiochip1: GPIOs 352-383, parent: platform/1f02c00.pinctrl, 1f02c00.pinctrl:
 gpio-354 (                    |usb0-vbus           ) out lo
 gpio-355 (                    |sw4                 ) in  hi IRQ ACTIVE LOW
 gpio-362 (                    |orangepi:green:pwr  ) out hi
root@orangepipc:~# dmesg | grep -i wire
[    6.430149] Driver for 1-wire Dallas network protocol.
[    6.459512] gpio-110 (onewire@0): enforced open drain please flag it properly in DT/ACPI DSDT/board file
[   56.017951] w1_master_driver w1_bus_master1: Attaching one wire slave 00.800000000000 crc 8c
[  114.631209] w1_master_driver w1_bus_master1: Attaching one wire slave 00.400000000000 crc 46
[  161.437506] w1_master_driver w1_bus_master1: Attaching one wire slave 00.c00000000000 crc ca
[  232.114781] w1_master_driver w1_bus_master1: Attaching one wire slave 00.200000000000 crc 23
[  290.730986] w1_master_driver w1_bus_master1: Attaching one wire slave 00.a00000000000 crc af
[  325.739928] w1_master_driver w1_bus_master1: Attaching one wire slave 00.600000000000 crc 65
[  362.455883] w1_master_driver w1_bus_master1: Attaching one wire slave 00.e00000000000 crc e9
[  420.673710] w1_master_driver w1_bus_master1: Attaching one wire slave 00.100000000000 crc 9d
Any help?
Thanks!
Solved by sergesa
  • Author
Hi,
mmm
root@orangepipc:~#  armbianmonitor -u
System diagnosis information will now be uploaded to gzip: /var/log/armbian-hardware-monitor.log.1.gz: No such file or directory
http://ix.io/2K2F
Thanks
  • Author
  • Solution
Ok, resolved
after I add outboard pullup , immediately :
[292751.493482] w1_master_driver w1_bus_master1: Attaching one wire slave 28.00000615392c crc ca
[292751.613810] w1_master_driver w1_bus_master1: Attaching one wire slave 28.00000615191f crc 86
It seems no internal pullup work on 5.9.14 ..
Regards.
Account
Navigation
Search
Search
Chrome (Android)
  3. Adjust your preference.
Chrome (Desktop)
  2. Select Site settings.
