Skip to content
View in the app
Armbian Community Forums
OPI ONE CPU temperature
Featured Replies
I use OPI - ONE.
I upgraded a package.
The CPU temperature become so hot.
Welcome to ARMBIAN Debian GNU/Linux 8 (jessie) 3.4.112-sun8i
System load:   0.29             Up time:       7 min
Memory usage:  11 % of 494Mb    IP:            192.168.10.112 192.168.10.116
CPU temp:      60°C
Usage of /:    18% of 7.2G
Last login: Tue Aug  2 16:42:15 2016 from 192.168.10.101
orangepi@orangepione:~$ cat /etc/armbian-release
# PLEASE DO NOT EDIT THIS FILE
BOARD=orangepione
BOARD_NAME="Orange Pi One"
VERSION=5.16
LINUXFAMILY=sun8i
BRANCH=default
ARCH=arm
orangepi@orangepione:~$ cat /sys/devices/virtual/thermal/thermal_zone0/temp
59
orangepi@orangepione:~$ cat /sys/devices/virtual/thermal/thermal_zone1/temp
59
@Thomas
Please provide the output from 'sudo armbianmonitor -u'
you may put this sentence as a signature, please :) it might sound useful
  • Author
orangepi@orangepione:~$ sudo armbianmonitor -u
/var/log/armhwinfo.log has been uploaded to http://sprunge.us/BMGK
Please post the URL in the Armbian forum where you've been asked for.
I use OPI - ONE.
CPU temp:      60°C
BOARD=orangepione
VERSION=5.16
LINUXFAMILY=sun8i
BRANCH=default
ARCH=arm
59
59
I think 60°C is completely normal for OPI ONE if there is no heatsink at SoC. Mine, with heatsink was around 45/50°C idle in Armbian and this was in more coldly weather, couple of mounts ago. While in OpenElec i use the most in this board it easily reach near 90°C idle. So this temperature is ok for me, if there is no tweaks about this in recent Armbian.
  • Author
Hmm... there are no anomalies (except of SD card errors) in the logs. How do a few lines output of 'sudo armbianmonitor -m' look like?
Thank you for checking it.
orangepi@orangepione:~$ sudo armbianmonitor -m
Stop monitoring using [ctrl]-[c]
Time        CPU    load %cpu %sys %usr %nice %io %irq   CPU
15:31:24: 1008MHz  0.16   0%   0%   0%   0%   0%   0%   55°C
15:31:29:  480MHz  0.23   0%   0%   0%   0%   0%   0%   55°C
15:31:34:  480MHz  0.21   0%   0%   0%   0%   0%   0%   55°C
15:31:39:  480MHz  0.19   1%   0%   0%   0%   0%   0%   55°C
15:31:45: 1008MHz  0.26   3%   1%   1%   0%   0%   0%   57°C
15:31:50:  480MHz  0.24   3%   1%   1%   0%   0%   0%   55°C
15:31:55:  480MHz  0.22   3%   1%   2%   0%   0%   0%   55°C
15:32:00:  480MHz  0.20   3%   1%   2%   0%   0%   0%   55°C
15:32:05:  480MHz  0.18   3%   1%   2%   0%   0%   0%   55°C
15:32:10:  480MHz  0.17   1%   1%   0%   0%   0%   0%   55°C
15:32:15:  480MHz  0.16   1%   0%   0%   0%   0%   0%   55°C
15:32:20:  480MHz  0.14   1%   0%   0%   0%   0%   0%   55°C
The record when using Armbian_5.14 was left.
45
46
I'll install this release again and check it.
EDIT
I tried.
I think there is cause in USB-Wifi module.
Disable Wifi:
BOARD=orangepione
ID="Orange Pi One"
VERSION=5.14
LINUXFAMILY=sun8i
BRANCH=default
16:01:34: 1008MHz  0.06   3%   1%   0%   0%   1%   0%   49°C
16:01:39:  480MHz  0.06   3%   1%   0%   0%   1%   0%   49°C
16:01:44:  480MHz  0.05   3%   1%   0%   0%   1%   0%   49°C
16:01:49:  480MHz  0.05   3%   1%   0%   0%   1%   0%   49°C
16:01:54:  480MHz  0.05   2%   1%   0%   0%   1%   0%   49°C
16:02:00:  480MHz  0.04   2%   1%   0%   0%   1%   0%   49°C
16:02:05:  480MHz  0.04   2%   1%   0%   0%   1%   0%   49°C
16:02:10:  480MHz  0.04   2%   1%   0%   0%   1%   0%   49°C
16:02:15:  480MHz  0.03   2%   0%   0%   0%   1%   0%   49°C
16:02:20:  480MHz  0.03   2%   0%   0%   0%   1%   0%   49°C
16:02:25:  480MHz  0.03   2%   0%   0%   0%   0%   0%   50°C
16:02:30:  480MHz  0.03   2%   0%   0%   0%   0%   0%   49°C
16:02:35:  480MHz  0.02   2%   0%   0%   0%   0%   0%   49°C
16:02:41:  480MHz  0.02   2%   0%   0%   0%   0%   0%   50°C
Enable Wifi:
BOARD=orangepione
ID="Orange Pi One"
VERSION=5.14
LINUXFAMILY=sun8i
BRANCH=default
16:28:44: 1008MHz  0.10   1%   0%   0%   0%   0%   0%   58°C
16:28:50:  480MHz  0.09   1%   0%   0%   0%   0%   0%   58°C
16:28:55:  480MHz  0.08   1%   0%   0%   0%   0%   0%   58°C
16:29:00:  480MHz  0.08   1%   0%   0%   0%   0%   0%   58°C
16:29:05:  480MHz  0.07   1%   0%   0%   0%   0%   0%   58°C
16:29:10:  480MHz  0.06   1%   0%   0%   0%   0%   0%   58°C
16:29:15:  480MHz  0.06   1%   0%   0%   0%   0%   0%   59°C
16:29:20:  480MHz  0.05   1%   0%   0%   0%   0%   0%   59°C
16:29:25:  480MHz  0.05   1%   0%   0%   0%   0%   0%   59°C
16:29:30:  480MHz  0.05   1%   0%   0%   0%   0%   0%   59°C
16:29:36:  480MHz  0.04   1%   0%   0%   0%   0%   0%   59°C
16:29:41:  480MHz  0.04   1%   0%   0%   0%   0%   0%   59°C
orangepi@orangepione:~$ lsusb
Bus 008 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 007 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 005 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 002 Device 002: ID 0bda:0179 Realtek Semiconductor Corp.
Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
I'll change USB-Wifi dongle.
EDIT2
I changed the USB dongle to RTL8188CUS.
The situation was improved.
BOARD=orangepione
ID="Orange Pi One"
VERSION=5.14
LINUXFAMILY=sun8i
BRANCH=default
00:07:07: 1008MHz  0.01   0%   0%   0%   0%   0%   0%   53°C
00:07:12:  480MHz  0.01   0%   0%   0%   0%   0%   0%   54°C
00:07:17:  480MHz  0.01   0%   0%   0%   0%   0%   0%   53°C
00:07:22:  480MHz  0.01   0%   0%   0%   0%   0%   0%   53°C
00:07:27:  480MHz  0.01   0%   0%   0%   0%   0%   0%   53°C
00:07:32:  480MHz  0.01   0%   0%   0%   0%   0%   0%   53°C
00:07:37:  480MHz  0.00   0%   0%   0%   0%   0%   0%   53°C
00:07:43:  480MHz  0.00   0%   0%   0%   0%   0%   0%   52°C
00:07:48:  480MHz  0.00   0%   0%   0%   0%   0%   0%   53°C
00:07:53:  480MHz  0.00   0%   0%   0%   0%   0%   0%   52°C
00:07:58:  480MHz  0.00   0%   0%   0%   0%   0%   0%   52°C
00:08:03:  480MHz  0.00   0%   0%   0%   0%   0%   0%   52°C
EDIT3
The CPU temperature becomes high as expected.
BOARD=orangepione
VERSION=5.16
LINUXFAMILY=sun8i
BRANCH=default
ARCH=arm
10:45:53: 1008MHz  0.11   0%   0%   0%   0%   0%   0%   64°C
10:45:58:  480MHz  0.10   0%   0%   0%   0%   0%   0%   64°C
10:46:03:  480MHz  0.09   0%   0%   0%   0%   0%   0%   64°C
10:46:08:  480MHz  0.09   0%   0%   0%   0%   0%   0%   64°C
10:46:13:  480MHz  0.08   0%   0%   0%   0%   0%   0%   64°C
10:46:19:  480MHz  0.07   0%   0%   0%   0%   0%   0%   64°C
10:46:24:  480MHz  0.07   0%   0%   0%   0%   0%   0%   64°C
10:46:29:  480MHz  0.06   0%   0%   0%   0%   0%   0%   64°C
10:46:34:  480MHz  0.06   0%   0%   0%   0%   0%   0%   64°C
  • Author
I updated Armbian from 5.16 to 5.17.
I think this problem was resolved.
BOARD=orangepione
VERSION=5.16
LINUXFAMILY=sun8i
BRANCH=default
ARCH=arm
BOARD=orangepione
VERSION=5.17
LINUXFAMILY=sun8i
BRANCH=default
ARCH=arm
[sudo] password for orangepi:
11:24:04: 1152MHz  0.01   0%   0%   0%   0%   0%   0%   51°C
11:24:09:  480MHz  0.01   0%   0%   0%   0%   0%   0%   51°C
11:24:14:  480MHz  0.01   0%   0%   0%   0%   0%   0%   51°C
11:24:19:  480MHz  0.01   0%   0%   0%   0%   0%   0%   50°C
11:24:25:  480MHz  0.01   0%   0%   0%   0%   0%   0%   51°C
11:24:30:  480MHz  0.01   0%   0%   0%   0%   0%   0%   51°C
11:24:35:  480MHz  0.01   0%   0%   0%   0%   0%   0%   51°C
11:24:40:  480MHz  0.09   0%   0%   0%   0%   0%   0%   51°C
11:24:45:  480MHz  0.07   0%   0%   0%   0%   0%   0%   51°C
Account
Navigation
Search
Search
Chrome (Android)
  3. Adjust your preference.
Chrome (Desktop)
  2. Select Site settings.
