April 11, 20224 yr Hello. I am new to armbian, sbc, linux. I would like to buy OPI 3 LTS to install OMV on it. My little NAS server. I looked a little information on the Internet, please tell me, on your image, can I install OMV through the sudo armbian-config command? It seems that the board does not officially support armbian. Thanks a lot for the replies.
April 11, 20224 yr 4 minutes ago, Mk51 said: Hello. I am new to armbian, sbc, linux. I would like to buy OPI 3 LTS to install OMV on it. My little NAS server. I looked a little information on the Internet, please tell me, on your image, can I install OMV through the sudo armbian-config command? It seems that the board does not officially support armbian. Thanks a lot for the replies. Support is WIP: https://github.com/armbian/build/pull/3628 You do not need armbian-config to do anything. This is just a tool to make things more convenient, especially for beginners. However it lacks maintenance and is in queue for major rework. So if in doubt try installing omv manually. Check their documentation if necessary.
April 11, 20224 yr 54 minutes ago, Werner said: Support is WIP: https://github.com/armbian/build/pull/3628 You do not need armbian-config to do anything. This is just a tool to make things more convenient, especially for beginners. However it lacks maintenance and is in queue for major rework. Can I put myself forward for maintainer? And what sort of rework is required on this? Is there anything I can do to help with this pull request? It's my pull request after all haha! Ukhellfire = afaulkner420 😉
April 11, 20224 yr We can test your pr once boards have arrived in the lab. You're welcome to volunteer as maintainer then
April 11, 20224 yr 35 minutes ago, Werner said: We can test your pr once boards have arrived in the lab. You're welcome to volunteer as maintainer then You have an actual lab? Do you buy them in especially? Well as far as I can see, the only issue remaining, I believe, is the panfrost issue. Which I believe you have a fair bit of experience in 😉 haha! May pick your brains at some point if you don't mind? Oh I will be volunteering! That's why I've been trying to keep everything as tidy etc as possible. Is there a formal way to do this? Or do I just stick my hand up here and wait to get picked? I haven't stopped playing over the last few weeks! I've learnt alot! And it's all thanks to this great community!
April 12, 20224 yr 10 hours ago, Ukhellfire said: You have an actual lab? Do you buy them in especially? Sometimes we get samples from vendors but more often we buy on our own 10 hours ago, Ukhellfire said: panfrost I am not very deep into stuff but didn't Panfrost for the T-720 work already a year ago? At least on my OPi1+ it was in kind of a working state. Do not have an OPi3 or even LTS version. They all come with H6 SoC. 10 hours ago, Ukhellfire said: . Is there a formal way to do this? There is if you like to go through Feel free to do so: https://forum.armbian.com/staffapplications/ Check here for supported criteria: https://docs.armbian.com/User-Guide_Board-Support-Rules/
April 12, 20224 yr On 4/10/2022 at 9:02 PM, Ukhellfire said: @Eemeien I'll just leave this here 😉 Wow great news! Sorry for the delay. I will check your repo again.
April 12, 20224 yr I installed bluetootctl with armbian-config but no devices found. I just install image from your repo. Do I need to do anything else?
April 12, 20224 yr 12 minutes ago, Eemeien said: I installed bluetootctl with armbian-config but no devices found. I just install image from your repo. Do I need to do anything else? If you were to clone my fix-bt repo, once I've pushed a little update. And build from that. Build the edge branch. It will all work "out of the box" Give me an hour or so, and I'll update my repos. I'll let you know once I've done it! 2 hours ago, Werner said: I am not very deep into stuff but didn't Panfrost for the T-720 work already a year ago? At least on my OPi1+ it was in kind of a working state. Do not have an OPi3 or even LTS version. They all come with H6 SoC. As far as I was aware, yes panfrost was working. But I'm getting a very "glitchy" dm. And once logged in, and running a dmesg, we're getting an error constantly looping flooding the dmesg... I'll have a look I to the configs etc for the t-720 to see if there's anything I'm missing.
April 12, 20224 yr Just now, Ukhellfire said: If you were to clone my fix-bt repo, once I've pushed a little update. And build from that. Build the edge branch. It will all work "out of the box" Give me an hour or so, and I'll update my repos. I'll let you know once I've done it! As far as I was aware, yes panfrost was working. But I'm getting a very "glitchy" dm. And once logged in, and running a dmesg, we're getting an error constantly looping flooding the dmesg... I'll have a look I to the configs etc for the t-720 to see if there's anything I'm missing. Okey I understand, in sun50iw6.conf if [[ $BUILD_DESKTOP == yes && $BOARD == orangepi3-lts ]]; I always build server. I will try desktop build. And after you update your repo I will test it again.
April 12, 20224 yr 6 minutes ago, Eemeien said: Okey I understand, in sun50iw6.conf if [[ $BUILD_DESKTOP == yes && $BOARD == orangepi3-lts ]]; I always build server. I will try desktop build. And after you update your repo I will test it again. That won't work the line of code I put was in the wrong line, it doesn't come across. I'll pish my changes.. I was thinking about removing the "BUILD_DESKTOP" for the Bluetooth...
April 12, 20224 yr 5 minutes ago, Eemeien said: OK. Than I'm waiting for your changes. Changes made 😀
April 12, 20224 yr 2 hours ago, Eemeien said: It's working now. Nice job!! Pleased to hear it 😉 enjoy! What are your plans? Will you be using the gpio header at all? This is one thing I haven't tested. But. It should work! **Crosses everything he has**
April 12, 20224 yr 53 minutes ago, shaw fung said: Can you give the download link? https://mega.nz/file/9sFG2LBT#TsNYnUfNcdPkJgCKFUsYWeKA3R2jJXFVOW-9Vh_H1To This build also has panfrost disabled for time being. It causes issues. This bypasses the login screen/dm, but it shouldn't be a problem for you. This is also a desktop build. Server builds coming shortly!
April 13, 20224 yr 11 hours ago, Ukhellfire said: https://mega.nz/file/9sFG2LBT#TsNYnUfNcdPkJgCKFUsYWeKA3R2jJXFVOW-9Vh_H1To This build also has panfrost disabled for time being. It causes issues. This bypasses the login screen/dm, but it shouldn't be a problem for you. This is also a desktop build. Server builds coming shortly! You the man! Thanks for all your hard work!
April 13, 20224 yr 16 hours ago, Ukhellfire said: Pleased to hear it 😉 enjoy! What are your plans? Will you be using the gpio header at all? This is one thing I haven't tested. But. It should work! **Crosses everything he has** I tested hdmi, type c power, ethernet, wifi and BT. All good for now. In 2 or 3 weeks I will test gpios too.
April 13, 20224 yr On 4/12/2022 at 9:18 PM, Ukhellfire said: https://mega.nz/file/9sFG2LBT#TsNYnUfNcdPkJgCKFUsYWeKA3R2jJXFVOW-9Vh_H1To This build also has panfrost disabled for time being. It causes issues. This bypasses the login screen/dm, but it shouldn't be a problem for you. This is also a desktop build. Server builds coming shortly! Thank you.
April 13, 20224 yr Just a weird little quirk with the latest build... my load average never seems to drop below 1. Is anyone else experiencing this? CPU load never seems to increase above 2 - 3% but after letting the OPI idle, it's more or less just sitting at a constant 1.0. top - 11:59:18 up 1:24, 3 users, load average: 1.11, 1.04, 1.04 Tasks: 186 total, 1 running, 185 sleeping, 0 stopped, 0 zombie %Cpu(s): 0.2 us, 0.5 sy, 0.0 ni, 99.3 id, 0.0 wa, 0.0 hi, 0.0 si, 0.0 st @Ukhellfire
April 13, 20224 yr 12.04.2022 в 18:18, Ukhellfire сказал: https://mega.nz/file/9sFG2LBT#TsNYnUfNcdPkJgCKFUsYWeKA3R2jJXFVOW-9Vh_H1To This build also has panfrost disabled for time being. It causes issues. This bypasses the login screen/dm, but it shouldn't be a problem for you. This is also a desktop build. Server builds coming shortly! Doesn't boot after i configured and rebooted, LED doesn't light
April 13, 20224 yr 1 hour ago, orangepifan said: Just a weird little quirk with the latest build... my load average never seems to drop below 1. Is anyone else experiencing this? CPU load never seems to increase above 2 - 3% but after letting the OPI idle, it's more or less just sitting at a constant 1.0. top - 11:59:18 up 1:24, 3 users, load average: 1.11, 1.04, 1.04 Tasks: 186 total, 1 running, 185 sleeping, 0 stopped, 0 zombie %Cpu(s): 0.2 us, 0.5 sy, 0.0 ni, 99.3 id, 0.0 wa, 0.0 hi, 0.0 si, 0.0 st @Ukhellfire Is this on the first armbian build? If so, please try the build i linked above with panfrost disabled. Panfrost is looping at the moment with errors (check dmesg) this could be the cause, or at least probably wont be helping the load average. 30 minutes ago, lakeke5544 said: Doesn't boot after i configured and rebooted, LED doesn't light Ok thank you. i shall have a look into this.
April 18, 20224 yr Thank you for the great work in supporting this board on Armbian. I've been testing the nightly build and found the WiFi can't keep up an access point. Did anyone else get these errors? Is there an alternative WiFi driver to try? When I start the hotspot, it stays on for about a minute. If it doesn't crash, this command does a WiFi scan and instantly crashes it: iw dev wlan0 scan systemctl stop wpa_supplicant ip link set dev wlan0 down ip a add 10.0.1.5/24 brd + dev wlan0 ip link set dev wlan0 up dhcpcd -k wlan0 systemctl start hostapd dmesg | grep 'WCN\|wlan0' [ 4.977803] WCN: marlin_init entry! [ 4.978314] WCN: wcn config bt wake host [ 4.978537] WCN_ERR: dts node for bt_wake not found [ 4.978541] WCN: marlin2 parse_dt some para not config [ 4.983959] WCN: marlin_probe ok! [ 4.999011] WCN: marlin power state:0, subsys: [MARLIN_BLUETOOTH] power 0 [ 5.102498] WCN: start_marlin [MARLIN_WIFI] [ 5.102522] WCN: marlin power state:0, subsys: [MARLIN_WIFI] power 1 [ 5.102529] WCN: the first power on start [ 5.213542] WCN: marlin chip en dummy pull up -- need manually set GPIO [ 5.241793] WCN: marlin_scan_finish! [ 5.241941] WCN: then marlin start to download [ 5.242342] WCN: marlin_get_wcn_chipid: chipid: 0x2355b001 [ 5.242360] WCN: marlin_request_firmware from /lib/firmware/wcnmodem.bin start! [ 5.506517] WCN: start_marlin [MARLIN_BLUETOOTH] [ 6.148961] WCN: combin_img 0 marlin_firmware_write finish and successful [ 6.149338] WCN: marlin_start_run read reset reg val:0x1 [ 6.149356] WCN: after do marlin_start_run reset reg val:0x0 [ 6.149671] WCN: s_marlin_bootup_time=6149669142 [ 6.156900] WCN: clock mode: TSX [ 6.157095] WCN: marlin_write_cali_data sync init_state:0x0 [ 6.183625] WCN: marlin_write_cali_data sync init_state:0x0 [ 6.213403] WCN: marlin_write_cali_data sync init_state:0xf0f0f0f1 [ 6.213432] WCN: sdio_config bt_wake_host trigger:[high] [ 6.213475] WCN: sdio_config irq:[inband] [ 6.213478] WCN: sdio_config wake_host_level_duration_time:[20ms] [ 6.213483] WCN: sdio_config wake_host_data_separation:[bt/wifi reuse] [ 6.213485] WCN: marlin_send_sdio_config_to_cp sdio_config:0x80f01 (enable config) [ 6.213851] WCN: marlin_write_cali_data finish [ 6.214032] WCN: check_cp_ready sync val:0xf0f0f0f2, prj_type val:0x0 [ 6.241770] WCN: check_cp_ready sync val:0xf0f0f0f2, prj_type val:0x0 [ 6.269746] WCN: check_cp_ready sync val:0xf0f0f0f2, prj_type val:0x0 [ 6.298346] WCN: check_cp_ready sync val:0xf0f0f0f2, prj_type val:0x0 [ 6.325733] WCN: check_cp_ready sync val:0xf0f0f0f6, prj_type val:0x0 [ 6.325757] WCN: marlin_bind_verify confuse data: 0xcfe38251b04db73419dc5cae40581e72 [ 6.325773] WCN: marlin_bind_verify verify data: 0x1ed7454972563e2294bc7cf590020acc [ 6.326345] WCN: check_cp_ready sync val:0xf0f0f0f7, prj_type val:0x0 [ 6.353720] WCN: check_cp_ready sync val:0xf0f0f0ff, prj_type val:0x0 [ 6.364493] WCN: get_cp2_version entry! [ 6.403829] WCN: WCND at cmd read:WCN_VER:Platform Version:MARLIN3_19B_W20.37.4~Project Version:sc2355_marlin3_lite_ott~09-11-2020 21:27:32~ [ 6.403867] WCN: switch_cp2_log - close entry! [ 6.405182] WCN: WCND at cmd read:OK [ 6.405241] WCN: then marlin download finished and run ok [ 6.405256] WCN: start_loopcheck [ 6.405520] WCN: marlin power state:4, subsys: [MARLIN_BLUETOOTH] power 1 [ 6.405531] WCN: marlin have open, GNSS is closed [ 6.462911] WCN: get_board_ant_num [one_ant] root@orangepi3-lts:~# dmesg | grep WCN [ 4.977803] WCN: marlin_init entry! [ 4.978314] WCN: wcn config bt wake host [ 4.978537] WCN_ERR: dts node for bt_wake not found [ 4.978541] WCN: marlin2 parse_dt some para not config [ 4.983959] WCN: marlin_probe ok! [ 4.999011] WCN: marlin power state:0, subsys: [MARLIN_BLUETOOTH] power 0 [ 5.102498] WCN: start_marlin [MARLIN_WIFI] [ 5.102522] WCN: marlin power state:0, subsys: [MARLIN_WIFI] power 1 [ 5.102529] WCN: the first power on start [ 5.213542] WCN: marlin chip en dummy pull up -- need manually set GPIO [ 5.241793] WCN: marlin_scan_finish! [ 5.241941] WCN: then marlin start to download [ 5.242342] WCN: marlin_get_wcn_chipid: chipid: 0x2355b001 [ 5.242360] WCN: marlin_request_firmware from /lib/firmware/wcnmodem.bin start! [ 5.506517] WCN: start_marlin [MARLIN_BLUETOOTH] [ 6.148961] WCN: combin_img 0 marlin_firmware_write finish and successful [ 6.149338] WCN: marlin_start_run read reset reg val:0x1 [ 6.149356] WCN: after do marlin_start_run reset reg val:0x0 [ 6.149671] WCN: s_marlin_bootup_time=6149669142 [ 6.156900] WCN: clock mode: TSX [ 6.157095] WCN: marlin_write_cali_data sync init_state:0x0 [ 6.183625] WCN: marlin_write_cali_data sync init_state:0x0 [ 6.213403] WCN: marlin_write_cali_data sync init_state:0xf0f0f0f1 [ 6.213432] WCN: sdio_config bt_wake_host trigger:[high] [ 6.213475] WCN: sdio_config irq:[inband] [ 6.213478] WCN: sdio_config wake_host_level_duration_time:[20ms] [ 6.213483] WCN: sdio_config wake_host_data_separation:[bt/wifi reuse] [ 6.213485] WCN: marlin_send_sdio_config_to_cp sdio_config:0x80f01 (enable config) [ 6.213851] WCN: marlin_write_cali_data finish [ 6.214032] WCN: check_cp_ready sync val:0xf0f0f0f2, prj_type val:0x0 [ 6.241770] WCN: check_cp_ready sync val:0xf0f0f0f2, prj_type val:0x0 [ 6.269746] WCN: check_cp_ready sync val:0xf0f0f0f2, prj_type val:0x0 [ 6.298346] WCN: check_cp_ready sync val:0xf0f0f0f2, prj_type val:0x0 [ 6.325733] WCN: check_cp_ready sync val:0xf0f0f0f6, prj_type val:0x0 [ 6.325757] WCN: marlin_bind_verify confuse data: 0xcfe38251b04db73419dc5cae40581e72 [ 6.325773] WCN: marlin_bind_verify verify data: 0x1ed7454972563e2294bc7cf590020acc [ 6.326345] WCN: check_cp_ready sync val:0xf0f0f0f7, prj_type val:0x0 [ 6.353720] WCN: check_cp_ready sync val:0xf0f0f0ff, prj_type val:0x0 [ 6.364493] WCN: get_cp2_version entry! [ 6.403829] WCN: WCND at cmd read:WCN_VER:Platform Version:MARLIN3_19B_W20.37.4~Project Version:sc2355_marlin3_lite_ott~09-11-2020 21:27:32~ [ 6.403867] WCN: switch_cp2_log - close entry! [ 6.405182] WCN: WCND at cmd read:OK [ 6.405241] WCN: then marlin download finished and run ok [ 6.405256] WCN: start_loopcheck [ 6.405520] WCN: marlin power state:4, subsys: [MARLIN_BLUETOOTH] power 1 [ 6.405531] WCN: marlin have open, GNSS is closed [ 6.462911] WCN: get_board_ant_num [one_ant] root@orangepi3-lts:~# dmesg | grep WCN [ 4.977803] WCN: marlin_init entry! [ 4.978314] WCN: wcn config bt wake host [ 4.978537] WCN_ERR: dts node for bt_wake not found [ 4.978541] WCN: marlin2 parse_dt some para not config [ 4.983959] WCN: marlin_probe ok! [ 4.999011] WCN: marlin power state:0, subsys: [MARLIN_BLUETOOTH] power 0 [ 5.102498] WCN: start_marlin [MARLIN_WIFI] [ 5.102522] WCN: marlin power state:0, subsys: [MARLIN_WIFI] power 1 [ 5.102529] WCN: the first power on start [ 5.213542] WCN: marlin chip en dummy pull up -- need manually set GPIO [ 5.241793] WCN: marlin_scan_finish! [ 5.241941] WCN: then marlin start to download [ 5.242342] WCN: marlin_get_wcn_chipid: chipid: 0x2355b001 [ 5.242360] WCN: marlin_request_firmware from /lib/firmware/wcnmodem.bin start! [ 5.506517] WCN: start_marlin [MARLIN_BLUETOOTH] [ 6.148961] WCN: combin_img 0 marlin_firmware_write finish and successful [ 6.149338] WCN: marlin_start_run read reset reg val:0x1 [ 6.149356] WCN: after do marlin_start_run reset reg val:0x0 [ 6.149671] WCN: s_marlin_bootup_time=6149669142 [ 6.156900] WCN: clock mode: TSX [ 6.157095] WCN: marlin_write_cali_data sync init_state:0x0 [ 6.183625] WCN: marlin_write_cali_data sync init_state:0x0 [ 6.213403] WCN: marlin_write_cali_data sync init_state:0xf0f0f0f1 [ 6.213432] WCN: sdio_config bt_wake_host trigger:[high] [ 6.213475] WCN: sdio_config irq:[inband] [ 6.213478] WCN: sdio_config wake_host_level_duration_time:[20ms] [ 6.213483] WCN: sdio_config wake_host_data_separation:[bt/wifi reuse] [ 6.213485] WCN: marlin_send_sdio_config_to_cp sdio_config:0x80f01 (enable config) [ 6.213851] WCN: marlin_write_cali_data finish [ 6.214032] WCN: check_cp_ready sync val:0xf0f0f0f2, prj_type val:0x0 [ 6.241770] WCN: check_cp_ready sync val:0xf0f0f0f2, prj_type val:0x0 [ 6.269746] WCN: check_cp_ready sync val:0xf0f0f0f2, prj_type val:0x0 [ 6.298346] WCN: check_cp_ready sync val:0xf0f0f0f2, prj_type val:0x0 [ 6.325733] WCN: check_cp_ready sync val:0xf0f0f0f6, prj_type val:0x0 [ 6.325757] WCN: marlin_bind_verify confuse data: 0xcfe38251b04db73419dc5cae40581e72 [ 6.325773] WCN: marlin_bind_verify verify data: 0x1ed7454972563e2294bc7cf590020acc [ 6.326345] WCN: check_cp_ready sync val:0xf0f0f0f7, prj_type val:0x0 [ 6.353720] WCN: check_cp_ready sync val:0xf0f0f0ff, prj_type val:0x0 [ 6.364493] WCN: get_cp2_version entry! [ 6.403829] WCN: WCND at cmd read:WCN_VER:Platform Version:MARLIN3_19B_W20.37.4~Project Version:sc2355_marlin3_lite_ott~09-11-2020 21:27:32~ [ 6.403867] WCN: switch_cp2_log - close entry! [ 6.405182] WCN: WCND at cmd read:OK [ 6.405241] WCN: then marlin download finished and run ok [ 6.405256] WCN: start_loopcheck [ 6.405520] WCN: marlin power state:4, subsys: [MARLIN_BLUETOOTH] power 1 [ 6.405531] WCN: marlin have open, GNSS is closed [ 6.462911] WCN: get_board_ant_num [one_ant] root@orangepi3-lts:~# dmesg | grep WCN [ 4.977803] WCN: marlin_init entry! [ 4.978314] WCN: wcn config bt wake host [ 4.978537] WCN_ERR: dts node for bt_wake not found [ 4.978541] WCN: marlin2 parse_dt some para not config [ 4.983959] WCN: marlin_probe ok! [ 4.999011] WCN: marlin power state:0, subsys: [MARLIN_BLUETOOTH] power 0 [ 5.102498] WCN: start_marlin [MARLIN_WIFI] [ 5.102522] WCN: marlin power state:0, subsys: [MARLIN_WIFI] power 1 [ 5.102529] WCN: the first power on start [ 5.213542] WCN: marlin chip en dummy pull up -- need manually set GPIO [ 5.241793] WCN: marlin_scan_finish! [ 5.241941] WCN: then marlin start to download [ 5.242342] WCN: marlin_get_wcn_chipid: chipid: 0x2355b001 [ 5.242360] WCN: marlin_request_firmware from /lib/firmware/wcnmodem.bin start! [ 5.506517] WCN: start_marlin [MARLIN_BLUETOOTH] [ 6.148961] WCN: combin_img 0 marlin_firmware_write finish and successful [ 6.149338] WCN: marlin_start_run read reset reg val:0x1 [ 6.149356] WCN: after do marlin_start_run reset reg val:0x0 [ 6.149671] WCN: s_marlin_bootup_time=6149669142 [ 6.156900] WCN: clock mode: TSX [ 6.157095] WCN: marlin_write_cali_data sync init_state:0x0 [ 6.183625] WCN: marlin_write_cali_data sync init_state:0x0 [ 6.213403] WCN: marlin_write_cali_data sync init_state:0xf0f0f0f1 [ 6.213432] WCN: sdio_config bt_wake_host trigger:[high] [ 6.213475] WCN: sdio_config irq:[inband] [ 6.213478] WCN: sdio_config wake_host_level_duration_time:[20ms] [ 6.213483] WCN: sdio_config wake_host_data_separation:[bt/wifi reuse] [ 6.213485] WCN: marlin_send_sdio_config_to_cp sdio_config:0x80f01 (enable config) [ 6.213851] WCN: marlin_write_cali_data finish [ 6.214032] WCN: check_cp_ready sync val:0xf0f0f0f2, prj_type val:0x0 [ 6.241770] WCN: check_cp_ready sync val:0xf0f0f0f2, prj_type val:0x0 [ 6.269746] WCN: check_cp_ready sync val:0xf0f0f0f2, prj_type val:0x0 [ 6.298346] WCN: check_cp_ready sync val:0xf0f0f0f2, prj_type val:0x0 [ 6.325733] WCN: check_cp_ready sync val:0xf0f0f0f6, prj_type val:0x0 [ 6.325757] WCN: marlin_bind_verify confuse data: 0xcfe38251b04db73419dc5cae40581e72 [ 6.325773] WCN: marlin_bind_verify verify data: 0x1ed7454972563e2294bc7cf590020acc [ 6.326345] WCN: check_cp_ready sync val:0xf0f0f0f7, prj_type val:0x0 [ 6.353720] WCN: check_cp_ready sync val:0xf0f0f0ff, prj_type val:0x0 [ 6.364493] WCN: get_cp2_version entry! [ 6.403829] WCN: WCND at cmd read:WCN_VER:Platform Version:MARLIN3_19B_W20.37.4~Project Version:sc2355_marlin3_lite_ott~09-11-2020 21:27:32~ [ 6.403867] WCN: switch_cp2_log - close entry! [ 6.405182] WCN: WCND at cmd read:OK [ 6.405241] WCN: then marlin download finished and run ok [ 6.405256] WCN: start_loopcheck [ 6.405520] WCN: marlin power state:4, subsys: [MARLIN_BLUETOOTH] power 1 [ 6.405531] WCN: marlin have open, GNSS is closed [ 6.462911] WCN: get_board_ant_num [one_ant] root@orangepi3-lts:~# dmesg | grep 'WCN\|wlan0' [ 4.977803] WCN: marlin_init entry! [ 4.978314] WCN: wcn config bt wake host [ 4.978537] WCN_ERR: dts node for bt_wake not found [ 4.978541] WCN: marlin2 parse_dt some para not config [ 4.983959] WCN: marlin_probe ok! [ 4.999011] WCN: marlin power state:0, subsys: [MARLIN_BLUETOOTH] power 0 [ 5.102498] WCN: start_marlin [MARLIN_WIFI] [ 5.102522] WCN: marlin power state:0, subsys: [MARLIN_WIFI] power 1 [ 5.102529] WCN: the first power on start [ 5.213542] WCN: marlin chip en dummy pull up -- need manually set GPIO [ 5.241793] WCN: marlin_scan_finish! [ 5.241941] WCN: then marlin start to download [ 5.242342] WCN: marlin_get_wcn_chipid: chipid: 0x2355b001 [ 5.242360] WCN: marlin_request_firmware from /lib/firmware/wcnmodem.bin start! [ 5.506517] WCN: start_marlin [MARLIN_BLUETOOTH] [ 6.148961] WCN: combin_img 0 marlin_firmware_write finish and successful [ 6.149338] WCN: marlin_start_run read reset reg val:0x1 [ 6.149356] WCN: after do marlin_start_run reset reg val:0x0 [ 6.149671] WCN: s_marlin_bootup_time=6149669142 [ 6.156900] WCN: clock mode: TSX [ 6.157095] WCN: marlin_write_cali_data sync init_state:0x0 [ 6.183625] WCN: marlin_write_cali_data sync init_state:0x0 [ 6.213403] WCN: marlin_write_cali_data sync init_state:0xf0f0f0f1 [ 6.213432] WCN: sdio_config bt_wake_host trigger:[high] [ 6.213475] WCN: sdio_config irq:[inband] [ 6.213478] WCN: sdio_config wake_host_level_duration_time:[20ms] [ 6.213483] WCN: sdio_config wake_host_data_separation:[bt/wifi reuse] [ 6.213485] WCN: marlin_send_sdio_config_to_cp sdio_config:0x80f01 (enable config) [ 6.213851] WCN: marlin_write_cali_data finish [ 6.214032] WCN: check_cp_ready sync val:0xf0f0f0f2, prj_type val:0x0 [ 6.241770] WCN: check_cp_ready sync val:0xf0f0f0f2, prj_type val:0x0 [ 6.269746] WCN: check_cp_ready sync val:0xf0f0f0f2, prj_type val:0x0 [ 6.298346] WCN: check_cp_ready sync val:0xf0f0f0f2, prj_type val:0x0 [ 6.325733] WCN: check_cp_ready sync val:0xf0f0f0f6, prj_type val:0x0 [ 6.325757] WCN: marlin_bind_verify confuse data: 0xcfe38251b04db73419dc5cae40581e72 [ 6.325773] WCN: marlin_bind_verify verify data: 0x1ed7454972563e2294bc7cf590020acc [ 6.326345] WCN: check_cp_ready sync val:0xf0f0f0f7, prj_type val:0x0 [ 6.353720] WCN: check_cp_ready sync val:0xf0f0f0ff, prj_type val:0x0 [ 6.364493] WCN: get_cp2_version entry! [ 6.403829] WCN: WCND at cmd read:WCN_VER:Platform Version:MARLIN3_19B_W20.37.4~Project Version:sc2355_marlin3_lite_ott~09-11-2020 21:27:32~ [ 6.403867] WCN: switch_cp2_log - close entry! [ 6.405182] WCN: WCND at cmd read:OK [ 6.405241] WCN: then marlin download finished and run ok [ 6.405256] WCN: start_loopcheck [ 6.405520] WCN: marlin power state:4, subsys: [MARLIN_BLUETOOTH] power 1 [ 6.405531] WCN: marlin have open, GNSS is closed [ 6.462911] WCN: get_board_ant_num [one_ant] [ 6.593857] unisoc_wifi unisoc_wifi wlan0: mixed HW and IP checksum settings. [ 71.410334] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready [ 114.433395] WCN: mdbg_assert_read:WCN Assert in rf_marlin.c line 993, pri20_offset == NO_OFFSET,data length 128 [ 114.433436] WCN: stop_loopcheck [ 114.433453] WCN_ERR: chip reset & notify every subsystem... [ 114.433684] WCN: [marlin_cp2_reset], DO BSP RESET [ 114.433700] WCN: marlin power state:5, subsys: [MARLIN_WIFI] power 0 [ 114.433713] WCN: can not power off, other module is on [ 114.433722] WCN: start_loopcheck [ 114.433735] WCN: marlin power state:1, subsys: [MARLIN_BLUETOOTH] power 0 [ 114.433747] WCN: stop_loopcheck [ 114.433757] WCN: wcn chip start power off! [ 114.433881] WCN: chip_power_off [ 114.433889] WCN: marlin chip en dummy pull down -- need manually set GPIO [ 114.433898] WCN: marlin power off! Configuration for reference. Connecting to the AP won't give you an IP via DHCP, I've left that part out to make the example simpler: # File: /etc/default/hostapd DAEMON_CONF="/etc/hostapd/hostapd.conf" # File: /etc/hostapd/hostapd.conf interface=wlan0 #driver=nl80211 ssid=MyHotspot hw_mode=g channel=4 #wmm_enabled=0 #macaddr_acl=0 auth_algs=1 ignore_broadcast_ssid=0 wpa=2 wpa_passphrase=1234 wpa_key_mgmt=WPA-PSK wpa_pairwise=CCMP TKIP rsn_pairwise=CCMP country_code=ZA ieee80211n=0 ieee80211d=1 # Append to file: /etc/dhcpcd.conf nohook wpa_supplicant static domain_name_servers=8.8.4.4 8.8.8.8
April 18, 20224 yr On 4/13/2022 at 1:22 PM, Ukhellfire said: Is this on the first armbian build? If so, please try the build i linked above with panfrost disabled. Panfrost is looping at the moment with errors (check dmesg) this could be the cause, or at least probably wont be helping the load average. Ok thank you. i shall have a look into this. I believe it was on your linked build -- I will be reflashing my second unit with the linked build to confirm. The really odd thing is there appears to be a disconnect between load average and CPU usage -- CPU reads pretty low and the unit is overall responsive. If it WAS panfrost, would any clues in ps and/or top indicate it as the cause? I'll let you know what things look like on the latest flash.
April 19, 20224 yr Hi all! Thank you for the great work I have a small problem: When i flash the image to the EMMC and reboot the second time the Pi does not boot up Flashed the second build, the first one works good. Any solutions? Ps: I am a noob at this time.
April 19, 20224 yr Hi all! Thank you for the great work I have a small problem: When i flash the image to the EMMC and reboot the second time the Pi does not boot up Flashed the second build, the first one works good. Any solutions? Ps: I am a noob at this time. Currently i am using the Armbian_22.05.0_trunk 5.15.31 version. Sorry for being not specific.
