Skip to content
View in the app
Armbian Community Forums
Is is possible to disable the first run wizard via armbain build framework?
Featured Replies
Hi,
i'd like to know if it's possible to disable the first run wizard (set up of root password, timezone locale etc) via armbian build framework? I have build my own image, and set the parameter DEST_LANG="de_DE.UTF-8" , but still the wizard shows up after flashing and asks me for the locale.
Can i do this type of customization in the customize-image.sh? (sorry if that's a too stupid or obvious question). This is my customize-image.sh script (i have truncated it).
#!/bin/bash
# arguments: $RELEASE $LINUXFAMILY $BOARD $BUILD_DESKTOP
# This is the image customization script
# NOTE: It is copied to /tmp directory inside the image
# and executed there inside chroot environment
# so don't reference any files that are not already installed
# NOTE: If you want to transfer files between chroot and host
# userpatches/overlay directory on host is bind-mounted to /tmp/overlay in chroot
# The sd card's root path is accessible via $SDCARD variable.
echo "add user rock"
useradd -s /bin/bash -m -c "rock" rock -p rock
echo "set hostname"
hostname -b "myrockpi"
echo "update armbianEnv"
ARMBIANENV="/boot/armbianEnv.txt"
if grep -q "console=" "$ARMBIANENV"; then
    sed -i 's/console=.*/console=display/g' $ARMBIANENV
else
    echo "console=display" >> $ARMBIANENV
fi
Michael
Solved by Igor
Account
Navigation
Search
Search
Chrome (Android)
  3. Adjust your preference.
Chrome (Desktop)
  2. Select Site settings.
