Skip to content
View in the app
Armbian Community Forums
Unable to complete bootloader bypass method
Featured Replies
I'm trying to complete the installation of Armbian onto the HC4 (HC4-P if that changes anything).
With a fresh SD card I run
sudo dd if=Armbian_22.11.1_Odroidhc4_bullseye_current_5.19.17.img of=/dev/sdb status=progress
plug in the card to the board, plug in the ethernet cable, hold down the boot switch, and plug it into power. It all seems to run correctly: I can SSH into the board and I complete the initial steps to set-up the installation (root pass, default shell, username, real name, and locale). However it does not seem as I can access the SPI FLASH device. Running the following commands from the HC4 page do not work as there are no mtd devices.
root@odroidhc4:~# ls -ltr /dev/mtd*
ls: cannot access '/dev/mtd*': No such file or directory
Here's a paste of the files available under /dev: https://paste.tildeverse.org/?aa94ecb514ce9e50#E5qD2kbTFiQzaHRrgnBLfMw8PMfspfVsCFrxhPATYDyi
It seems that support for SPI got lost when upgrading kernel. Nothing unusual for software where maintaining is sponsored by its developers in their free time.
Workaround (thank you) - previous 5.10.y kernel images from archive works well ... use it and don't upgrade (apt-mark hold linux-image* and linux-dtb*)
I received my new Odroid HC4 today and ran into the same problem. I used the recent armbian, but I booted into petitboot (with an attached display and keyboard), and erased the flash storage from there. This worked just fine! As far as I can tell, this has no downside when compared disabling petitboot via ssh, other than having to have a display and a keyboard.
@Igor: Thank you for providing armbian!!!
Hi all,
i also encountered a problem getting rid of pertitboot. The button variant also works to boot into the armbian linux, but the mtd-devices are also not visible.
Therefore, I tried the petitboot variant with connected monitor and keyboard, but there is nothing showing up on the screen after applying power.
Fortunately, I had the official USB-serial-cable from ODROID available and could plug in it easily after opening the HC4 case. On the serial console (115200,8N1) I could execute the flash_eraseall commands. This took a few minutes especially for the /dev/mtd3.
After erasing them, the board booted seamlessly into armbian.
Regards,
themole
I just set up my new HC-4 with Armbian 23.02.2 Bullseye following the instructions at https://www.armbian.com/odroid-hc4/
Unfortunately, I have exactly the same problem as themole.
On the installed kernel 6.1.11-meson64, I don't see the mtd-devices.
I downgraded to 5.10.16-meson64. Still no mtd-devices.
I started the HC-4 without pressing the button, in the hope to apply the method "Petitboot Console Method" from the instructions. But then, nothing happens. The screen stays dark.
Unlike themole, I don't have the USB-serial-cable around that I could use. So please, could you give me a hint how I can get rid of petitboot. Is there a specific kernel version I should boot? Or a specific image for the SD-card that I should use?
Here is the output of armbianmonitor -u (on 6.1.11-meson64 kernel):
https://paste.armbian.com/sapizoqiva
Edited by eacton
Account
Navigation
Search
Search
Chrome (Android)
  3. Adjust your preference.
Chrome (Desktop)
  2. Select Site settings.
