Armbian for Pendoo X6 PRO?
The info report also says: CPU Hardware : sun50iw6p1 which is Allwinner and I think more accurate.
Installing Armbian on the A95X F3 Air
You need to actually provide some details on what you have done. What image are you trying to install? What were the edits to the extlinux.conf file you tried? Are you following the install instructions found on this site (https://forum.armbian.com/topic/33676-installation-instructions-for-tv-boxes-with-amlogic-cpus) You mention REGlinux, per the instructions have you reinstalled android firmware to restore the system to clean before trying to run Armbian?
Moved to correct forum
Installation Instructions for TV Boxes with Amlogic CPUs
Upgrades are just standard debian/ubuntu upgrades. apt update apt upgrade for deb package updates.
- RGMII Settings in DTB files for Odroid-M1
@Blucasd73 That information is in the installation instructions already
Searching Armbian files for Debian 11 and 12 on TV Box X96 Air P3 (Amlogic S905X3)
Not uEnv.txt anymore as the current images use extlinux. Info is in the link I posted above.
Moved
Does anyone have the firmware for this MXQ 5G PLUS 4K TV box?
Done
Armbian on CM3588, fan does not work
You are on a vendor kernel. That is not mainline linux, you need to be on current or edge to run mainline. Having said that, the general rule of thumb is that vendor is old (unpatched with all that implies security wise) but generally feature complete, while mainline is newer but waiting for features to be accepted in mainline (some of which might never get ported to mainline). Each user generally cares about different features, so try different kernels to find the kernel that works best for your use cases.
Tanix TX6 is not booting the latest community release
moved post to the proper forum
HK1 RBOX K8, Need Help Restoring a Device Stuck on Red and Blue LEDs
moved post to correct sub-forum as this is a Rockchip CPU based box
Armbian 26.08.0 on Turing-rk1 based on resolute_edge 7.1.9 - can't control the fans?
The first question I have for you is why are you trying an edge kernal? "edge" means for testing purposes and things may not work. I'd recommend you first try the current stable kernel.
Moved post to correct forum
SteeMan
Moderators
