February 1, 20233 yr Hello, I'm using a orangepi pc with armbian and I want to boot (automatically if possible) from the usb flash drive where I flashed batoceda. Is it possible? And if so, would you have step by step? Thanks a lot.
February 1, 20233 yr Since as you say you are not using armbian but Bateceda, the Armbian forums are not the proper place for your question. You should ask your question in the Bateceda forums.
February 1, 20233 yr Author So strange, my firts words were "Hello, I'm using a orangepi pc with armbian..." I thought it was pretty obvious that i'm actually using Armbian. I'm a beginner, that's true, english is not my mother language, also true, but i'm looking for help to understand and learn. I thought that with a name like this (forum.armbian.com) in a section for beginners i could find some. The thing is that i'm trying to build a bootable usb for my device (whatever the os i'm looking to boot on). I would appreciate if someone had a solution for that. Thanks a lot.
February 1, 20233 yr I still don't understand what you are asking. Why do you mention Batoceda if you are trying to use Armbian. Both are linux distributions, it is one or the other. As for Armbian on an OrangePi PC have you tried the builds and instructions for your device located here: https://www.armbian.com/orange-pi-pc
