February 7, 20233 yr I noticed my Armbian has some mitigation activated, however I want to squeeze up the maximum performance from my board, how can I disable Spectre V1 & V2... On X86/AMD you may pass this command to GRUB: `mitigations=off` ; can you do the same with Armbian? And how? Thanks, F.
February 7, 20233 yr Author Nope... I saw this file mentioned in the Armbian-config tool though, I'll give it a try hoping to be able to boot the board again... 🤞
