Skip to content
View in the app
Armbian Community Forums
OdroidC4: How to reduce clock freq below 1GHz to save power
Featured Replies
Hello,
I tried to reduce the clock frequency with nano /etc/default/cpufrequtils.
I also set the governor to userspace in order to enable direct frequency setting.
But there is no effect to be seen with  cpufreq-info -o except the governor is switched to "userspace" now.
I also tried it with echo 500000 > /sys/devices/system/cpu/cpu0/cpufreq/scaling_setspeed , but clock frequency did not change.
According to the S905X3 datasheet the SoC could even run at 100Mhz...
I would appreciate a hint, how to reduce clock speed way below 1GHz, in order to save power consumption
Thanks a lot
Andy
PS: I am running VERSION=23.02.0-trunk
Solved by SteeMan
Account
Navigation
Search
Search
Chrome (Android)
  3. Adjust your preference.
Chrome (Desktop)
  2. Select Site settings.
