Skip to content
View in the app
Armbian Community Forums
Connecting banana pi m2 zero with ili9341 display over spi on latest armbian image
Featured Replies
I tried all weekend to add the touch function of the LCD's XPT2046
With this DTS:
Spoiler
/dts-v1/;
/plugin/;
compatible = "allwinner,sun8i-h3";
fragment@0 {
	target = <&pio>;
	__overlay__ {
		display_pins: display_pins {
			pins = "PC4", "PA2"; /*reset,dc*/
			function = "gpio_out", "gpio_out";
		ads7846_pins: ads7846_pins {
			pins = "PA19"; /*irq*/
			function = "irq";
		spi0_cs0: spi0_cs0 {
			pins = "PC3";
			function = "gpio_out";
			output-high;
		spi0_cs1: spi0_cs1 {
			pins = "PC7";
			output-high;
}; /*closing of fragment@0*/
fragment@1 {
	target = <&spi0>;
	__overlay__ {
		pinctrl-names = "default", "default";
		pinctrl-1 = <&spi0_cs1>;
		cs-gpios = <0>, <&pio 2 7 0>; /* PC7 */
};  /*closing of fragment@1*/
fragment@2 {
	target = <&spi0>;
	__overlay__ {
		/* needed to avoid dtc warning */
		#address-cells = <1>;
		#size-cells = <0>;
		status="okay";
		pinctrl-names = "default", "default"; /*added by ryjelsum*/
		cs-gpios = <&pio 2 3 0>, <&pio 2 7 0>; /* cs0=C3,cs1=C7 */
		#num-chipselects = <2>; /*deleted by ryjelsum*/
		display: display@0 {
			/*compatible = "ilitek,ili9341";*/
			compatible = "adafruit,yx240qv29", "ilitek,ili9341";
			reg = <0>;
			pinctrl-names = "default";
			pinctrl-0 = <&display_pins>;
			pinctrl-1 = <&spi1_cs0>; /*added by ryjelsum*/
			spi-max-frequency = <24000000>;
			status="okay"; /*added by ryjelsum*/
			rotation= <90>;
			bgr = <0>;
			fps = <15>;
			buswidth = <8>;
			height = <320>;
			width = <240>;
			reset-gpios = <&pio 2 4 0>; /* C4,GPIO 24 polarity 0 for adafruit */
			dc-gpios    = <&pio 0 2 0>; /* A2,GPIO 25 */
			debug = <3>;
		ads7846: ads7846@1 { /*this whole block added by ryjelsum*/
			reg = <1>; /* Chip Select 1 */
			compatible = "ti,ads7846";
			spi-max-frequency = <1000000>;
			status = "okay";
			pinctrl-2=<&spi0_cs1 &spi0_cs1>;
			pinctrl-3 = <&ads7846_pins>;
			interrupt-parent = <&pio>;
			interrupts = <0 19 2>; /* PA19 IRQ_TYPE_EDGE_FALLING */
			pendown-gpio = <&pio 0 19 0>; /* PA19 */
			/* driver defaults, optional */
			ti,x-min = /bits/ 16 <0>;
			ti,y-min = /bits/ 16 <0>;
			ti,x-max = /bits/ 16 <0x0FFF>;
			ti,y-max = /bits/ 16 <0x0FFF>;
			ti,pressure-min = /bits/ 16 <0>;
			ti,pressure-max = /bits/ 16 <0xFFFF>;
			ti,x-plate-ohms = /bits/ 16 <400>;
}; /*closing of fragment@2*/
__overrides__ {
	rotation = <&display>, "rotation:0";
	fps = <&display>, "fps:0";
	debug = <&display>, "debug:0";
}; /* closing of overrides */
It gets compiled, but the bootloader rejects it:
Applying user provided DT overlay ili9341-touch-sp0.dtbo
failed on fdt_overlay_apply(): FDT_ERR_NOT_FOUND
Error applying DT overlays, restoring original DT
(i included the spi-add-cs1.dtbo as suggested in https://ryjelsum.me/homelab/xpt2046-ili9341-opi-zero/ )
Hi robertoj,
I can see some lines that look problematic. Firstly you are defining cs-gpio twice.
Once here:
5 hours ago, robertoj said:
fragment@1 {
	target = <&spi0>;
	__overlay__ {
 Note - Remember that 0 refers to the native cs line (PC3)
fragment@2 {
	target = <&spi0>;
	__overlay__ {
		#size-cells = <0>;
		status="okay";
Here the pinctrl references are wrong. I am not sure how strictly the ordering matters but for clarity 'pinctrl-names' should be before the actual pin control nodes.
Adding spi-add-cs1.dtbo is not needed as all it does it defined the pins to use as cs lines which you have already done above anyway. My other suggestion would be to look into what the latest bindings should for the ads7846 touch controller. Let me know how you get on with following overlay:
Spoiler
/dts-v1/;
/plugin/;
fragment@0 {
    target = <&pio>;
    __overlay__ {
            function = "irq";
            pins = "PC3";
            output-high;
            pins = "PC7";
            output-high;
fragment@1 {
    target = <&spi0>;
    __overlay__ {
        #size-cells = <0>;
        status="okay";
        pinctrl-1 = <&spi0_cs1>; /* pinctrl-0 is already declared in the primary dts */
        cs-gpios = <0>, <&pio 2 7 0>; /* cs0=C3,cs1=C7 */
            reg = <0>;
            pinctrl-names ="default";
            status="okay";
            rotation= <90>;
            bgr = <0>;
            fps = <15>;
            buswidth = <8>;
            height = <320>;
            width = <240>;
            debug = <3>;
            status = "okay";
            pinctrl-0 = <&ads7846_pins>;
__overrides__ {
best of luck
Ryzer
I went with your corrected DTS ... so far it looks great
Spoiler
roberto@bananapim2zero:~$ lsmod |grep ads
ads7846                20480  0
roberto@bananapim2zero:~$ lsmod |grep spi
roberto@bananapim2zero:~$ sudo cat /proc/interrupts | grep ads
[sudo] password for roberto:
 59:        574          0          0          0  sunxi_pio_edge  19 Edge      ads7846
roberto@bananapim2zero:~$ dmesg | grep spi
[    7.139676] ads7846 spi0.1: supply vcc not found, using dummy regulator
[    7.140801] ads7846 spi0.1: touchscreen, irq 59
[    7.153779] input: ADS7846 Touchscreen as /devices/platform/soc/1c68000.spi/spi_master/spi0/spi0.1/input/input1
[    7.195022] panel-ilitek-ili9341 spi0.0: get optional vcc failed
[    7.196412] [drm] Initialized ili9341 1.0.0 20210716 for spi0.0 on minor 1
[    7.702554] panel-ilitek-ili9341 spi0.0: [drm] Initialized display serial interface
[    7.762184] panel-ilitek-ili9341 spi0.0: [drm] fb0: ili9341drmfb frame buffer device
(Did NOT use the spi-add-cs1.dtbo, as advised)
I went out running to work, and I will continue tests when I go back home
Day 2 of testing:
Spoiler
roberto@bananapim2zero:~$ dmesg | grep ads
[    1.702669] ads7846@1 enforce active low on GPIO handle
roberto@bananapim2zero:~$ sudo cat /sys/kernel/debug/gpio
gpiochip0: GPIOs 0-223, parent: platform/1c20800.pinctrl, 1c20800.pinctrl:
 gpio-0   (CON2-P13            )
 gpio-1   (CON2-P11            )
 gpio-2   (CON2-P22            |dc                  ) out hi
 gpio-3   (CON2-P15            )
 gpio-4   (CON3-P03            )
 gpio-5   (CON3-P02            )
 gpio-6   (CON2-P07            )
 gpio-7   (CON2-P29            )
 gpio-8   (CON2-P31            )
 gpio-9   (CON2-P33            )
 gpio-10  (CON2-P35            )
 gpio-11  (CON2-P05            )
 gpio-12  (CON2-P03            )
 gpio-13  (CON2-P08            )
 gpio-14  (CON2-P10            )
 gpio-15  (CON2-P16            )
 gpio-16  (CON2-P12            )
 gpio-17  (CON2-P37            )
 gpio-18  (CON2-P28            )
 gpio-19  (CON2-P27            |pendown             ) in  hi IRQ
 gpio-20  (CON2-P40            )
 gpio-21  (CON2-P38            )
 gpio-64  (CON2-P19            )
 gpio-65  (CON2-P21            )
 gpio-66  (CON2-P23            )
 gpio-67  (CON2-P24            )
 gpio-68  (CON2-P18            |reset               ) out hi
 gpio-71  (CON2-P26            |spi0 CS1            ) out hi ACTIVE LOW
 gpio-110 (CSI-PWR-EN          )
 gpio-128 (CN3-P17             )
 gpio-129 (CN3-P13             )
 gpio-130 (CN3-P09             )
 gpio-131 (CN3-P07             )
 gpio-132 (CN3-P19             )
 gpio-133 (CN3-P21             )
 gpio-134 (CN3-P22             )
 gpio-135 (CN3-P20             )
 gpio-136 (CN3-P18             )
 gpio-137 (CN3-P16             )
 gpio-138 (CN3-P14             )
 gpio-139 (CN3-P12             )
 gpio-140 (CN3-P05             )
 gpio-141 (CN3-P03             )
 gpio-142 (CN3-P06             )
 gpio-143 (CN3-P08             )
 gpio-160 (SDC0-D1             )
 gpio-161 (SDC0-D0             )
 gpio-162 (SDC0-CLK            )
 gpio-163 (SDC0-CMD            )
 gpio-164 (SDC0-D3             )
 gpio-165 (SDC0-D2             )
 gpio-166 (SDC0-DET            |cd                  ) in  hi
 gpio-192 (WL-SDIO-CLK         )
 gpio-193 (WL-SDIO-CMD         )
 gpio-194 (WL-SDIO-D0          )
 gpio-195 (WL-SDIO-D1          )
 gpio-196 (WL-SDIO-D2          )
 gpio-197 (WL-SDIO-D3          )
 gpio-198 (BT-UART-TX          )
 gpio-199 (BT-UART-RX          )
 gpio-200 (BT-UART-RTS         )
 gpio-201 (BT-UART-CTS         )
 gpio-202 (WL-WAKE-AP          )
 gpio-203 (BT-WAKE-AP          |host-wakeup         ) in  lo
 gpio-204 (BT-RST-N            |shutdown            ) out hi
 gpio-205 (AP-WAKE-BT          |device-wakeup       ) out hi
gpiochip1: GPIOs 352-383, parent: platform/1f02c00.pinctrl, 1f02c00.pinctrl:
 gpio-353 (CPUX-SET            |vdd-cpux            ) out hi
 gpio-354 (CON2-P32            )
 gpio-355 (POWER-KEY           |power               ) in  hi IRQ ACTIVE LOW
 gpio-356 (CON2-P36            )
 gpio-357 (VCC-IO-EN           )
 gpio-358 (USB0-ID             |usb0_id_det         ) in  hi IRQ
 gpio-359 (WL-PWR-EN           |reset               ) out hi ACTIVE LOW
 gpio-360 (PWR-STB             |vcc1v2              ) out hi
 gpio-361 (PWR-DRAM            |vcc-dram            ) out hi
 gpio-362 (PWR-LED             |bananapi-m2-zero:red) out lo ACTIVE LOW
 gpio-363 (IR-RX               )
roberto@bananapim2zero:~$ sudo apt install evtest
...done
roberto@bananapim2zero:~$ sudo evtest
No device specified, trying to scan all of /dev/input/event*
Available devices:
/dev/input/event0:	gpio-keys
/dev/input/event1:	ADS7846 Touchscreen
Select the device event number [0-1]: 1
Input driver version is 1.0.1
Input device ID: bus 0x1c vendor 0x0 product 0x1ea6 version 0x0
Input device name: "ADS7846 Touchscreen"
Supported events:
  Event type 0 (EV_SYN)
  Event type 1 (EV_KEY)
    Event code 330 (BTN_TOUCH)
  Event type 3 (EV_ABS)
    Event code 0 (ABS_X)
      Value   3303
      Min        0
      Max     4095
    Event code 1 (ABS_Y)
      Value   2584
      Min        0
      Max     4095
    Event code 24 (ABS_PRESSURE)
      Value  62397
      Min        0
      Max    65535
Properties:
Testing ... (interrupt to exit)
Event: time 1726556440.417809, type 3 (EV_ABS), code 0 (ABS_X), value 3294
Event: time 1726556440.417809, type 3 (EV_ABS), code 1 (ABS_Y), value 2585
Event: time 1726556440.417809, type 3 (EV_ABS), code 24 (ABS_PRESSURE), value 64811
Event: time 1726556440.417809, -------------- SYN_REPORT ------------
Event: time 1726556440.477739, type 3 (EV_ABS), code 0 (ABS_X), value 3303
Event: time 1726556440.477739, type 3 (EV_ABS), code 1 (ABS_Y), value 2584
Event: time 1726556440.477739, type 3 (EV_ABS), code 24 (ABS_PRESSURE), value 63498
evtest shows a random stream of events, then stops... then lcd touches dont get reactions.
I will check my wiring and order a new LCD, because mine has a cracked glass
Is there any way to tell that the SPI, IRQ, CS inputs/outputs to the XPT2046 (ADS 7846) is working correctly, and blame everything on a bad resistive panel?
I had some success by changing the touch chip pins from:
CS1=PC7 PA18 (I avoided the "native Spi0 CS1 PC7" and used PA18)
IRQ=PA19 PA7 (maybe this was unnecessary)
New DTS:
Spoiler
roberto@bananapim2zero:~/ili9341$ cat ili9341-touch-sp0-ryzer-other-cs1-irq.dts
/dts-v1/;
/plugin/;
fragment@0 {
    target = <&pio>;
    __overlay__ {
            pins = "PA7"; /*irq*/
            function = "irq";
            pins = "PC3";
            output-high;
            pins = "PA18";
            output-high;
fragment@1 {
    target = <&spi0>;
    __overlay__ {
        #size-cells = <0>;
        status="okay";
        cs-gpios = <0>, <&pio 0 18 0>; /* cs0=PC3,cs1=PA18 */
            reg = <0>;
            status="okay";
            rotation= <90>;
            bgr = <0>;
            fps = <15>;
            buswidth = <8>;
            height = <320>;
            width = <240>;
            debug = <3>;
            status = "okay";
            interrupts = <0 7 2>; /* PA7 IRQ_TYPE_EDGE_FALLING */
            pendown-gpio = <&pio 0 7 0>; /* PA7 */
            ti,x-min = /bits/ 16 <200>;
            ti,y-min = /bits/ 16 <200>;
            ti,x-max = /bits/ 16 <3900>;
            ti,y-max = /bits/ 16 <3900>;
            /*ti,pressure-min = /bits/ 16 <0>;*/
            ti,pressure-max = /bits/ 16 <255>;
            ti,x-plate-ohms = /bits/ 16 <60>;
__overrides__ {
With inspiration from https://github.com/jonathan-gatard/ili9486-xpt2046/tree/main for the IOs and the analog parameters
Now sudo evtest prints an event each time I press on the LCD screen
Spoiler
Available devices:
Supported events:
      Value   3312
      Min      200
      Max     3900
      Value   2579
      Min      200
      Max     3900
      Value    238
      Min        0
      Max      255
Properties:
Event: time 1726725202.045512, type 3 (EV_ABS), code 0 (ABS_X), value 3319
Event: time 1726725202.045512, type 3 (EV_ABS), code 1 (ABS_Y), value 2588
Event: time 1726725202.045512, type 3 (EV_ABS), code 24 (ABS_PRESSURE), value 4
Event: time 1726725202.045512, -------------- SYN_REPORT ------------
Event: time 1726725202.885527, type 3 (EV_ABS), code 0 (ABS_X), value 3311
Event: time 1726725202.885527, type 3 (EV_ABS), code 1 (ABS_Y), value 2596
Event: time 1726725202.885527, type 3 (EV_ABS), code 24 (ABS_PRESSURE), value 30
Event: time 1726725202.885527, -------------- SYN_REPORT ------------
Event: time 1726725205.495577, type 3 (EV_ABS), code 0 (ABS_X), value 3280
Event: time 1726725205.495577, type 3 (EV_ABS), code 1 (ABS_Y), value 2560
Event: time 1726725205.495577, type 3 (EV_ABS), code 24 (ABS_PRESSURE), value 43
Event: time 1726725205.495577, -------------- SYN_REPORT ------------
Event: time 1726725206.767507, type 3 (EV_ABS), code 0 (ABS_X), value 3304
Event: time 1726725206.767507, type 3 (EV_ABS), code 1 (ABS_Y), value 2579
Event: time 1726725206.767507, type 3 (EV_ABS), code 24 (ABS_PRESSURE), value 87
If an LCD suffers a disconnection and reconnection, is it possible to reset, re-initialize and continue working the LCD?
Or would it always need a Linux reboot?
problem solved: IRQ i/o needed the reverse polarity in pendown-gpio. armbianEnv.txt and DTS here:
(it is working with sudo evtest, so I dont know if it needs calibration... and I wonder if I need to reverse the polarity in the interrupts line too)
Spoiler
roberto@bananapim2zero:~/ili9341$ cat ili9341-touch-sp0.dts
/dts-v1/;
/plugin/;
fragment@0 {
    target = <&pio>;
    __overlay__ {
            function = "irq";
            pins = "PC3";
            output-high;
            pins = "PA18";
            output-high;
fragment@1 {
    target = <&spi0>;
    __overlay__ {
        #size-cells = <0>;
        status="okay";
            reg = <0>;
            status="okay";
            rotation= <90>;
            bgr = <0>;
            fps = <15>;
            buswidth = <8>;
            height = <320>;
            width = <240>;
            debug = <3>;
            status = "okay";
            pendown-gpio = <&pio 0 7 1>; /* PA7 */
            /* driver defaults, optional*/
            ti,x-max = /bits/ 16 <0xFFF>;
            ti,y-max = /bits/ 16 <0xFFF>;
__overrides__ {
roberto@bananapim2zero:~/ili9341$ cat /boot/armbianEnv.txt
verbosity=1
bootlogo=false
console=both
disp_mode=1920x1080p60
overlay_prefix=sun8i-h3
rootdev=UUID=c809ccbe-42ae-40e8-b871-04e14b950d7a
rootfstype=ext4
user_overlays=ili9341-touch-sp0
usbstoragequirks=0x2537:0x1066:u,0x2537:0x1068:u
I could run lightdm with
apt install xinit xterm xauth x11-apps xserver-xorg lightdm xserver-xorg-input-evdev xserver-xorg-video-fbdev
/usr/share/X11/xorg.conf.d/99-fbdev.conf:
Section "Device"
   Identifier "myfb"
    Driver "fbdev"
    Option "fbdev" "/dev/fb0"
EndSection
However, the cursor is moving at 90-degrees from my finger movement. Also, it is very unstable... it crashes, leaving a white screen. The white screen remains after reboot, and I can only make it work again by removing and connecting the 5V power.
Can someone share how they installed a window manager with ili9341?
is 24MHz too fast? Would native cs1 help anything?
https://github.com/raspberrypi/linux/issues/6067
https://github.com/raspberrypi/linux/pull/6029
https://forums.raspberrypi.com/viewtopic.php?p=2206990&hilit=ads7846#p2206990
https://github.com/raspberrypi/bookworm-feedback/issues/88
There seems to be some instability in the ads7846 driver in the latest linux. If anyone is having a good experience with ads7846, please indicate how you did it.
Hi robertoj,
There are addtional touchscreen parameters that you could try to address the cursor movement being wrong. based on what you have said I would suggest adding the line 'ti,swap-xy = <1>;' to:
            status = "okay";
In regards to the crashing that, will be a bit harder to pin down. Thinking about I would suggest double checking 'interrupts = <0 7 2>;' as I would have expected it to be something like 'interrupts = <0 7 IRQ_TYPE_EDGE_FALLING>. That said, it does appear to be registering correctly when looking here:
Does /proc/interrupts list the gpio as being set to trigger on falling edge as expected?
24MHz is the maximum speed that the ili9341 will work at in spi mode. It may be possible that there indeed problems with the driver but without investigating deeper its hard to say. Raspberry Pi have there own distinct linux kernel fork so the problems mentioned may not be common to the mainline kernel used by Armbian. I wonder if the crashes are possibly caused by the cs lines of both devices being pulled low at the same time under certain conditions.
best of luck
Ryzer
Edited by Ryzer
Thank you. I will try that, and I learned about the xinput_calibrator, which I will apply next time.
(and https://github.com/reinderien/xcalibrate/blob/main/xcalibrate is a new interesting project)
Now I am focusing on moving the touchscreen pins to an independent gpio-based SPI set of pins... we will know whether the LCD crash is from interfering SPI commands.
I did an experiment with the "backlight = <&backlight_gpio>" parameter as shown in https://github.com/beagleboard/bb.org-overlays/blob/master/src/arm/BB-LCD-ADAFRUIT-24-SPI0-00A0.dts
and https://forums.raspberrypi.com/viewtopic.php?t=358240  but so far it ended up in a kernel not loading. I will leave this task for last.
If the DTS configuration does not specify CPHA and CPOL, what is the default setting of the SPI protocol?
I decided to use the gpio-spi driver, to emulate software spi just for the touch chip ADS7846/XPT2048, and use a different DTS file
Here is what I think would work: ads7846-spi-gpio.dts
Spoiler
/* Configure the GPIO to handle ADS7846 touch surface chip
with the gpio-spi driver:
https://www.kernel.org/doc/Documentation/devicetree/bindings/spi/spi-gpio.txt
https://stackoverflow.com/questions/78905378/how-do-i-use-spi-gpio-driver-in-linux
https://gist.github.com/BjoernSch/39d3bca950a3b025b806decc2b686bbc
/dts-v1/;
/plugin/;
compatible = "allwinner,sun4i-a10", "allwinner,sun7i-a20", "allwinner,sun8i-h3", "allwinner,sun50i-a64", "allwinner,sun50i-h5";
fragment@0 {
	target = <&pio>;
	__overlay__ {
			pins = "PA1"; /*irq*/
			function = "irq";
fragment@1 {
	/*target = <&spi-gpio>; /* what goes here ???? */
	target-path = "/"; /* what goes here ???? */
	__overlay__ {
		my_new_spi {
		compatible = "spi-gpio";
		ranges;
		status="okay";
		mosi-gpios = <&pio 0 12 0>; /*t_din= PA12*/
		sck-gpios = <&pio 0 11 0>;  /*t_clk= PA11*/
		miso-gpios = <&pio 0 6 0>;  /*t_dout=PA6*/
		cs-gpios = <&pio 0 0 0>;    /*t_cs=  PA0*/
		num-chipselects = <1>;
			reg = <0>; /* Chip Select 0 on this separate SPI bus */
			status = "okay";
			interrupts = <0 1 2>; /* PA1 IRQ_TYPE_EDGE_FALLING */
			pendown-gpio = <&pio 0 1 1>; /* PA1 */
			ti,swap-xy = <1>;
		}; //end of my_new_spi
I used these references:
and need to check this too:
http://terminal28.blogspot.com/2015/12/bitbanging-spi-on-raspberry-pi-via-spi.html
http://terminal28.blogspot.com/2016/05/enabling-spi1-on-raspberry-pi-bzero23.html
My DTS compiles well :) but the linux in my armbian image did not include spi-gpio.ko, in /lib/modules/6.6.44-current-sunxi/kernel/drivers/spi/
Therefore, I am building a new OS image.
Does anyone see a problem with my DTS?
Update:) it works :) good stability
now the only problem is that both x-axis and y-axis are reversed (not swapped). More updates on the way
Hi robertoj,
This would most like be set somewhere within the SPI controller driver.
I tried that in my other post with not much success but I will try to give it another shot.
maybe you could try reversing the min and max values
best of luck
Ryzer
I simply rotated the image with the "rotation" parameter in the LCD DTS, and turned the screen 180 degrees physically. :D
I will try the min, max swap later, but right now I am on a roll, making my tkinter apps work :)
Another thing I will try is not using a chip select pin at all, since LCD and touch-chip are on different buses now.
Hi all, I tried to compile codes from this topic on my banana pi m2 berry but it still don't work, I tried with chat gpt implement my pins but in my analyzer I cannot see anything on ouptut, on dmesg of spi I have information about timeout of connecting to ili9341. Below I put my dts configuration:
Spoiler
/dts-v1/;
/plugin/;
fragmen@0 {
target = <&pio>;
__overlay__ {
pins = "PH27", "PH26";
fragment@1 {
target = <&spi0>;
__overlay__ {
#size-cells = <0>;
status="okay";
cs-gpios = <&pio 2 23 0>;
reg = <0>;
spi-max-frequency = <8000000>;
rotation= <270>;
bgr = <0>;
fps = <10>;
buswidth = <8>;
height = <240>;
width = <320>;
reset-gpios = <&pio 7 27 1>; /* GPIO 24 */
dc-gpios = <&pio 7 26 0>; /* GPIO 25 */
debug = <3>;
__overrides__ {
Below I put information from dmesg :
Spoiler
[    2.019202] sun6i-spi 1c05000.spi: Failed to request TX DMA channel
[    2.019219] sun6i-spi 1c05000.spi: Failed to request RX DMA channel
[    2.019374] sun6i-spi 1c05000.spi: cannot register SPI master
[    2.046614] sun6i-spi 1c05000.spi: Failed to request TX DMA channel
[    2.046639] sun6i-spi 1c05000.spi: Failed to request RX DMA channel
[    3.203221] panel-ilitek-ili9341 spi0.0: get optional vcc failed
[    3.213019] [drm] Initialized ili9341 1.0.0 20210716 for spi0.0 on minor 1
[    4.010262] panel-ilitek-ili9341 spi0.0: [drm] Initialized display serial interface
[    4.219308] panel-ilitek-ili9341 spi0.0: [drm] fb0: ili9341drmfb frame buffer device
[   11.960172] spi_master spi0: spi0.0: timeout transferring 153600 bytes@8000000Hz for 524(500)ms
[   11.961183] panel-ilitek-ili9341 spi0.0: SPI transfer failed: -110
[   11.961764] spi_master spi0: failed to transfer one message from queue
[   11.962131] spi_master spi0: noqueue transfer failed
[   11.963464] panel-ilitek-ili9341 spi0.0: [drm] *ERROR* Failed to update display -110
[   12.502597] spi_master spi0: spi0.0: timeout transferring 1 bytes@8000000Hz for 524(500)ms
[   12.502642] panel-ilitek-ili9341 spi0.0: SPI transfer failed: -110
[   12.502661] spi_master spi0: failed to transfer one message from queue
[   12.502670] spi_master spi0: noqueue transfer failed
[   12.502694] panel-ilitek-ili9341 spi0.0: error -110 when sending command 0x2a
[   13.014611] spi_master spi0: spi0.0: timeout transferring 1 bytes@8000000Hz for 512(500)ms
[   13.014660] panel-ilitek-ili9341 spi0.0: SPI transfer failed: -110
[   13.014683] spi_master spi0: failed to transfer one message from queue
[   13.014693] spi_master spi0: noqueue transfer failed
[   13.014715] panel-ilitek-ili9341 spi0.0: error -110 when sending command 0x2b
[   13.528719] spi_master spi0: spi0.0: timeout transferring 1 bytes@8000000Hz for 512(500)ms
[   13.529786] panel-ilitek-ili9341 spi0.0: SPI transfer failed: -110
[   13.530429] spi_master spi0: failed to transfer one message from queue
[   13.531366] spi_master spi0: noqueue transfer failed
[   14.070607] spi_master spi0: spi0.0: timeout transferring 1 bytes@8000000Hz for 512(500)ms
[   14.070653] panel-ilitek-ili9341 spi0.0: SPI transfer failed: -110
[   14.070673] spi_master spi0: failed to transfer one message from queue
[   14.070683] spi_master spi0: noqueue transfer failed
[   14.070700] panel-ilitek-ili9341 spi0.0: error -110 when sending command 0x2a
[   14.582602] spi_master spi0: spi0.0: timeout transferring 1 bytes@8000000Hz for 512(500)ms
[   14.582656] panel-ilitek-ili9341 spi0.0: SPI transfer failed: -110
[   14.582677] spi_master spi0: failed to transfer one message from queue
[   14.582686] spi_master spi0: noqueue transfer failed
[   14.582708] panel-ilitek-ili9341 spi0.0: error -110 when sending command 0x2b
[   15.094565] spi_master spi0: spi0.0: timeout transferring 1 bytes@8000000Hz for 512(500)ms
[   15.094599] panel-ilitek-ili9341 spi0.0: SPI transfer failed: -110
[   15.094617] spi_master spi0: failed to transfer one message from queue
[   15.094626] spi_master spi0: noqueue transfer failed
[   15.606606] spi_master spi0: spi0.0: timeout transferring 1 bytes@8000000Hz for 504(500)ms
[   15.606652] panel-ilitek-ili9341 spi0.0: SPI transfer failed: -110
[   15.606673] spi_master spi0: failed to transfer one message from queue
[   15.606682] spi_master spi0: noqueue transfer failed
[   15.606701] panel-ilitek-ili9341 spi0.0: error -110 when sending command 0x2a
[   16.119297] spi_master spi0: spi0.0: timeout transferring 1 bytes@8000000Hz for 512(500)ms
[   16.119343] panel-ilitek-ili9341 spi0.0: SPI transfer failed: -110
[   16.119362] spi_master spi0: failed to transfer one message from queue
[   16.119371] spi_master spi0: noqueue transfer failed
[   16.119392] panel-ilitek-ili9341 spi0.0: error -110 when sending command 0x2b
[   16.634576] spi_master spi0: spi0.0: timeout transferring 1 bytes@8000000Hz for 516(500)ms
[   16.634617] panel-ilitek-ili9341 spi0.0: SPI transfer failed: -110
[   16.634636] spi_master spi0: failed to transfer one message from queue
[   16.634644] spi_master spi0: noqueue transfer failed
[   17.174760] spi_master spi0: spi0.0: timeout transferring 1 bytes@8000000Hz for 532(500)ms
[   17.174818] panel-ilitek-ili9341 spi0.0: SPI transfer failed: -110
[   17.174841] spi_master spi0: failed to transfer one message from queue
[   17.174850] spi_master spi0: noqueue transfer failed
[   17.174872] panel-ilitek-ili9341 spi0.0: error -110 when sending command 0x2a
[   17.686826] spi_master spi0: spi0.0: timeout transferring 1 bytes@8000000Hz for 512(500)ms
[   17.686873] panel-ilitek-ili9341 spi0.0: SPI transfer failed: -110
[   17.686892] spi_master spi0: failed to transfer one message from queue
[   17.686901] spi_master spi0: noqueue transfer failed
[   17.686925] panel-ilitek-ili9341 spi0.0: error -110 when sending command 0x2b
[   18.198675] spi_master spi0: spi0.0: timeout transferring 1 bytes@8000000Hz for 512(500)ms
[   18.198719] panel-ilitek-ili9341 spi0.0: SPI transfer failed: -110
[   18.198738] spi_master spi0: failed to transfer one message from queue
[   18.198747] spi_master spi0: noqueue transfer failed
[   18.710586] spi_master spi0: spi0.0: timeout transferring 1 bytes@8000000Hz for 504(500)ms
[   18.710632] panel-ilitek-ili9341 spi0.0: SPI transfer failed: -110
[   18.710652] spi_master spi0: failed to transfer one message from queue
[   18.710661] spi_master spi0: noqueue transfer failed
[   18.710681] panel-ilitek-ili9341 spi0.0: error -110 when sending command 0x2a
[   19.222600] spi_master spi0: spi0.0: timeout transferring 1 bytes@8000000Hz for 512(500)ms
[   19.222648] panel-ilitek-ili9341 spi0.0: SPI transfer failed: -110
[   19.222669] spi_master spi0: failed to transfer one message from queue
[   19.222678] spi_master spi0: noqueue transfer failed
[   19.222702] panel-ilitek-ili9341 spi0.0: error -110 when sending command 0x2b
[   19.734562] spi_master spi0: spi0.0: timeout transferring 1 bytes@8000000Hz for 512(500)ms
[   19.734604] panel-ilitek-ili9341 spi0.0: SPI transfer failed: -110
[   19.734623] spi_master spi0: failed to transfer one message from queue
[   19.734631] spi_master spi0: noqueue transfer failed
[   20.246615] spi_master spi0: spi0.0: timeout transferring 1 bytes@8000000Hz for 504(500)ms
[   20.246666] panel-ilitek-ili9341 spi0.0: SPI transfer failed: -110
[   20.246687] spi_master spi0: failed to transfer one message from queue
[   20.246695] spi_master spi0: noqueue transfer failed
[   20.246721] panel-ilitek-ili9341 spi0.0: error -110 when sending command 0x2a
[   20.758633] spi_master spi0: spi0.0: timeout transferring 1 bytes@8000000Hz for 512(500)ms
[   20.758728] panel-ilitek-ili9341 spi0.0: SPI transfer failed: -110
[   20.758749] spi_master spi0: failed to transfer one message from queue
[   20.758758] spi_master spi0: noqueue transfer failed
[   20.758778] panel-ilitek-ili9341 spi0.0: error -110 when sending command 0x2b
[   21.270606] spi_master spi0: spi0.0: timeout transferring 1 bytes@8000000Hz for 512(500)ms
[   21.270649] panel-ilitek-ili9341 spi0.0: SPI transfer failed: -110
[   21.270669] spi_master spi0: failed to transfer one message from queue
[   21.270677] spi_master spi0: noqueue transfer failed
[   21.782700] spi_master spi0: spi0.0: timeout transferring 1 bytes@8000000Hz for 508(500)ms
[   21.782733] panel-ilitek-ili9341 spi0.0: SPI transfer failed: -110
[   21.782749] spi_master spi0: failed to transfer one message from queue
[   21.782756] spi_master spi0: noqueue transfer failed
[   21.782772] panel-ilitek-ili9341 spi0.0: error -110 when sending command 0x2a
[   22.294588] spi_master spi0: spi0.0: timeout transferring 1 bytes@8000000Hz for 512(500)ms
[   22.294621] panel-ilitek-ili9341 spi0.0: SPI transfer failed: -110
[   22.294637] spi_master spi0: failed to transfer one message from queue
[   22.294643] spi_master spi0: noqueue transfer failed
[   22.294663] panel-ilitek-ili9341 spi0.0: error -110 when sending command 0x2b
[   22.806580] spi_master spi0: spi0.0: timeout transferring 1 bytes@8000000Hz for 512(500)ms
[   22.806615] panel-ilitek-ili9341 spi0.0: SPI transfer failed: -110
[   22.806633] spi_master spi0: failed to transfer one message from queue
[   22.806639] spi_master spi0: noqueue transfer failed
[   23.318613] spi_master spi0: spi0.0: timeout transferring 1 bytes@8000000Hz for 508(500)ms
[   23.318658] panel-ilitek-ili9341 spi0.0: SPI transfer failed: -110
[   23.318677] spi_master spi0: failed to transfer one message from queue
[   23.318686] spi_master spi0: noqueue transfer failed
[   23.318707] panel-ilitek-ili9341 spi0.0: error -110 when sending command 0x2a
[   23.830593] spi_master spi0: spi0.0: timeout transferring 1 bytes@8000000Hz for 512(500)ms
[   23.830643] panel-ilitek-ili9341 spi0.0: SPI transfer failed: -110
[   23.830662] spi_master spi0: failed to transfer one message from queue
[   23.830671] spi_master spi0: noqueue transfer failed
[   23.830693] panel-ilitek-ili9341 spi0.0: error -110 when sending command 0x2b
[   24.342601] spi_master spi0: spi0.0: timeout transferring 1 bytes@8000000Hz for 512(500)ms
[   24.342644] panel-ilitek-ili9341 spi0.0: SPI transfer failed: -110
[   24.342746] spi_master spi0: failed to transfer one message from queue
[   24.342756] spi_master spi0: noqueue transfer failed
[   24.854609] spi_master spi0: spi0.0: timeout transferring 1 bytes@8000000Hz for 512(500)ms
[   24.854652] panel-ilitek-ili9341 spi0.0: SPI transfer failed: -110
[   24.854672] spi_master spi0: failed to transfer one message from queue
[   24.854680] spi_master spi0: noqueue transfer failed
[   24.854699] panel-ilitek-ili9341 spi0.0: error -110 when sending command 0x2a
[   25.367019] spi_master spi0: spi0.0: timeout transferring 1 bytes@8000000Hz for 512(500)ms
[   25.367062] panel-ilitek-ili9341 spi0.0: SPI transfer failed: -110
[   25.367081] spi_master spi0: failed to transfer one message from queue
[   25.367089] spi_master spi0: noqueue transfer failed
[   25.367111] panel-ilitek-ili9341 spi0.0: error -110 when sending command 0x2b
[   25.878574] spi_master spi0: spi0.0: timeout transferring 1 bytes@8000000Hz for 512(500)ms
[   25.878618] panel-ilitek-ili9341 spi0.0: SPI transfer failed: -110
[   25.878634] spi_master spi0: failed to transfer one message from queue
[   25.878643] spi_master spi0: noqueue transfer failed
[   27.702605] spi_master spi0: spi0.0: timeout transferring 1 bytes@8000000Hz for 508(500)ms
[   27.702650] panel-ilitek-ili9341 spi0.0: SPI transfer failed: -110
[   27.702669] spi_master spi0: failed to transfer one message from queue
[   27.702677] spi_master spi0: noqueue transfer failed
[   27.702697] panel-ilitek-ili9341 spi0.0: error -110 when sending command 0x2a
[   28.214628] spi_master spi0: spi0.0: timeout transferring 1 bytes@8000000Hz for 512(500)ms
[   28.214672] panel-ilitek-ili9341 spi0.0: SPI transfer failed: -110
[   28.214692] spi_master spi0: failed to transfer one message from queue
[   28.214700] spi_master spi0: noqueue transfer failed
[   28.214723] panel-ilitek-ili9341 spi0.0: error -110 when sending command 0x2b
[   28.726613] spi_master spi0: spi0.0: timeout transferring 1 bytes@8000000Hz for 512(500)ms
[   28.726658] panel-ilitek-ili9341 spi0.0: SPI transfer failed: -110
[   28.726678] spi_master spi0: failed to transfer one message from queue
[   28.726697] spi_master spi0: noqueue transfer failed
[   29.654665] spi_master spi0: spi0.0: timeout transferring 1 bytes@8000000Hz for 512(500)ms
[   29.654708] panel-ilitek-ili9341 spi0.0: SPI transfer failed: -110
[   29.654726] spi_master spi0: failed to transfer one message from queue
[   29.654734] spi_master spi0: noqueue transfer failed
[   29.654753] panel-ilitek-ili9341 spi0.0: error -110 when sending command 0x2a
[   30.166602] spi_master spi0: spi0.0: timeout transferring 1 bytes@8000000Hz for 512(500)ms
[   30.166644] panel-ilitek-ili9341 spi0.0: SPI transfer failed: -110
[   30.166662] spi_master spi0: failed to transfer one message from queue
[   30.166671] spi_master spi0: noqueue transfer failed
[   30.166690] panel-ilitek-ili9341 spi0.0: error -110 when sending command 0x2b
[   30.678636] spi_master spi0: spi0.0: timeout transferring 1 bytes@8000000Hz for 512(500)ms
[   30.678681] panel-ilitek-ili9341 spi0.0: SPI transfer failed: -110
[   30.678699] spi_master spi0: failed to transfer one message from queue
[   30.678708] spi_master spi0: noqueue transfer failed
Have you any idea to prepare good configuration ?
Edited by Koliber93
Change:
to:
reset-gpios = <&pio 7 27 0>; /* GPIO 24 */
Change the SPI speed to 24MHz
Format your DTS so we can read it easily.
Correct the comments with GPIO nnn because they are confusing.
Show a wiring schematic between the BPI M2 Berry and your LCD
Use the "Spoiler" (eye) button, so that your long texts don't take so much space.
Thank you for quick reply, my current configuration is :
MOSI - GPIO10 (PIN19)
MISO - GPIO9 (PIN21)
SCLK - GPIO 11 (PIN23)
CS - GPIO8 (PIN24)
DC - GPIO24 (PIN18)
RESET - GPIO25 (PIN22)
Below I put the picture with 40-pin header description.
Spoiler
I also found the issue with spi0 on Banana PI M2 Berry and I also try this configuration - for this issue I found another configuration and I tried mixed it together :
Spoiler
/dts-v1/;
/plugin/;
        compatible = "allwinner,sun6i-a31";
        fragment@0 {
                target = <&pio>;
                __overlay__ {
                                pins = "PC0", "PC1", "PC2", "PC23", "PH26", "PH27";
                                function = "spi0", "spi0", "spi0", "gpio_out", "gpio_out", "gpio_out";
        fragment@1 {
                target = <&spi0>;
                __overlay__ {
                        #size-cells = <0>;
                        status = "okay";
                        cs-gpios = <&pio 2 23 0>; /* PC23 for CS */
                                reg = <0>;
                                rotation = <270>;
                                bgr = <0>;
                                fps = <10>;
                                buswidth = <8>;
                                height = <240>;
                                width = <320>;
                                reset-gpios = <&pio 7 26 0>; /* PH26 for Reset */
                                dc-gpios = <&pio 7 27 0>;    /* PH27 for Data/Command */
                                debug = <3>;
        __overrides__ {
The only difference what I noticed is that I had some signals on the output as you can see below from my pulseview:
Spoiler
image.thumb.png.445e0661a05567a2326da76cd37ac666.pngD0 - MISO
D1 - SCK
D2 - MOSI
D3 - DC
D4 -  RESET
D5 - CS
Another issue what I concern is problem with DMA from dmesg
Try all combinations of (I have no idea why these things sometimes work):
* Only define the PH26,PH27 in pins = "PC0", "PC1", "PC2", "PC23", "PH26", "PH27";
* only cs-gpios = <0>; //use default CS instead of cs-gpios = <&pio 2 23 0>; /* PC23 for CS */
Make sure that there are no erorrs in:
dmesg|grep spi
dmesg|grep mipi
Usually these are good signs:
lsmod|grep ili shows a loaded kernel module
ls /dev/fb* shows a created video device
Hi Koliber93,
Before trying to the ili9341 display working can you confirm that spi0 works with a simple spidev setup then move onto to trying to configure the display. Do not mix up pin functions, you should have a seperate node for the spi pins and additional gpio used for the display. Normaly the spi pins should already defined under the pinctrl node in which case we can simply refer to associated label. for reference please see: https://git.kernel.org/pub/scm/linux/kernel/git/stable/linux.git/tree/arch/arm/boot/dts/allwinner/sun8i-r40.dtsi?h=v6.6.66 As suggested by robertoj, I would stick with the hardware cs pin as I have had nothing but problems with gpio defind cs lines in recent kernels. If a simple SPI set works then please feel free to try the following overlay:
/dts-v1/;
/plugin/;
        compatible = "allwinner,sun8i-h3", "allwinner,sun8i-r40";
        fragment@0 {
                target = <&pio>;
                __overlay__ {
                                pins ="PH26", "PH27";
                                function ="gpio_out", "gpio_out";
        fragment@1 {
                target = <&spi0>;
                __overlay__ {
                        #size-cells = <0>;
                        status = "okay";
                        pinctrl-0 = <&spi0_pc_pins>;
			pinctrl-1 = <&spi0_cs0_pc_pin>;
                        cs-gpios = <0>; /* PC23 for CS */
                                reg = <0>;
                                rotation = <270>;
                                bgr = <0>;
                                fps = <10>;
                                buswidth = <8>;
                                height = <240>;
                                width = <320>;
                                debug = <3>;
        __overrides__ {
I do find it strange however that you are not getting any activity on the DC line, are you sure you have probes labelled correctly?
Best of luck
Ryzer
Account
Navigation
Search
Search
Chrome (Android)
  3. Adjust your preference.
Chrome (Desktop)
  2. Select Site settings.
