April 22, 20233 yr Hello I want to get cpu and ram infos via bash command. So i use this for temperature: For the cpu usage i needed a long time to find a solution. now i found this: echo $[100-$(vmstat 1 2|tail -1|awk '{print $15}')] For the free ram usage, i will use free --mega My question Are this command correct? the cpu command line is really new for me... does it takes a lot of ressources, if i use this commands every 2 seconds to get a real time listening? i need to write it in a database to get a graphical solution. Thank you for your help
